2026 GMC Sierra EV Lease Deals, Incentives, Rebates, and Prices
shikataganaishikataganai Member Posts: 77
edited July 2025 in GMC
I'm starting to see some hit the lots (and a bunch in transit), so kicking it off.
When you get a moment could you post the incentives (none I'm sure but I'd like to confirm), MF, and RV for a 2026 Sierra EV AT4 Extended Range, 24/12 and 36/12, ZIP 80238?
«13
  • kyfdxkyfdx Moderator Posts: 275,128
    .00353 MF and 81% residual
    .00307 MF and 75% residual
  • BigemoneyBigemoney Member Posts: 16
    Could you please give me the mf and residual on extended range elevation and Denali and a max Denali for 24/15k and 36/15k for 94790?
    ZIP?
  • _valuebet__valuebet_ Member Posts: 23
    edited July 2025
    When you get a chance, could you please provide the MF and RV for:
    2026 Sierra EV Elevation
    Extended Range and Standard Range - is there a difference?
    24 months / 15k miles
    Zip is 34715
    FWIW - FL dealers are stating $7500 EV tax credit is applied to residual and not a point of sale price reduction. Most are offering a $1250 Costco Executive member incentive.
    Zip is 34715
    Std: .00317 MF and 82% residual
    Ext: .00357 MF and 80% residual
    I don't have any insight into the $7500. But, if it's applied to the residual, that would help a lot, though you'll definitely have to turn it in, at the end of lease.
  • jahc90jahc90 Member Posts: 6
    edited July 2025
    When you get the chance could share with me the MF and Residual Value for a 36 months 15k lease for the following trucks on 78575:
    Sierra EV Elevation 26' Extended Range
    Sierra EV Denali 26' Extended Range
    Sierra EV Denali 26' Max Range
    Sorry 84790
    ZIP?
  • MichaellMichaell Moderator Posts: 270,416
    .00311 MF and 73% RV
    .00169 MF and 62% RV
    Bigemoney said:
    Sorry 84790
    ZIP?
    .00136 MF and 67% residual
    .00169 MF and 62% residual
    Either range
  • shikataganaishikataganai Member Posts: 77
    When you get a moment could you post the August incentives (none I'm sure but I'd like to confirm), MF, and RV for a 2026 Sierra EV AT4 Extended Range, 24/12 and 36/12, ZIP 80238?
    Thanks as always.
    Thanks as always.
    .00366 MF and 81% residual
    .00321 MF and 75% residual
  • frank211frank211 Member Posts: 2
    Can you please post Money factor and residual for GMC Sierra Denali Extended Range 32940 zip code 24 months 10k miles and 36 months 10k miles
    .00148 MF and 69% residual
    .00181 MF and 65% residual
  • supaflashsupaflash Member Posts: 39
    Can I get MF, Residual, incentives etc for:
    2026 Elevation Extended Range
    2026 AT4 Extended Range
    80516
    80516
    24/10
    ELEV
    .00372 MF and 82% residual
    .00326 MF and 76% residual
    AT4
    .00366 MF and 82% residual
    .00321 MF and 76% residual
  • jn18Tjn18T Member Posts: 1
    Could you please post Residual/MF for:
    2026 GMC Sierra EV Denali Extended
    36/12k
    36/15k
    36/12k
    36/15k
    .00181 MF and 62% residual
  • STXJIMSTXJIM Member Posts: 37
    Can you please give me the residual and mf for a 2026 Denali ER for 36/10 and 36/12 for 78521
    .00181 MF and 64% residual
  • GevinsGevins Member Posts: 7
    Can I get the MF and RV for a 2026 GMC Sierra EV Extended Range, 36/15, zip 38101?
    And same for a 2025 Sierra Max Range
    And same for a 2025 Sierra Denali Max Range
    Which trim Sierra EV?
    Ask 2025 model questions in the 2025 Sierra EV discussion
    Sorry newbie here.
    Question 1: AT4
    Questions 2 & 3: Will repost
    Gevins said:
    Sorry newbie here.
    Question 1: AT4
    .00321 MF and 73% residual
    edited August 2025
    Thanks. That RV is without the EV credit, correct? Just confirming. My dealer is adding it there instead of reducing the cap cost.
    Gevins said:
    Sorry newbie here.
    Question 1: AT4
    Gevins said:
    Sorry newbie here.
    Question 1: AT4
    We don't know how they account for it.. But, either way, it pretty much works out, as long as you aren't planning on buying the truck at lease end.
    Can I please get the MF and RV for a 2026 GMC Sierra Max Range, 39/15, zip 45251. This vehicle is the magnus matte color if it matters.
    Which trim?
    Which trim?
    AT4
    Gevins said:
    Which trim?
    AT4
    .00283 MF and 64% RV
  • jg8991jg8991 Member Posts: 2
    Can I please get the MF and RV for a 2026 Sierra AT4 Max for 36/12, zip 33309?
  • Lance_ISFLance_ISF Member Posts: 75
    Can I please get the MF/ Residual/ Incentives for 2026 Sierra EV AT4 Max Range for 24/12 and 36/12 for zip code 94116. The color is Magnus Matte Color. If that matters. Thank you.
    .00283 MF and 68% RV
    .00340 MF and 74% residual
    .00283 MF and 68% residual
    So I was told by a dealer that these high residuals are a result of how GM does the 7500 EV rebate, they apply it to the residual. Can anyone confirm if that is true.
    Also could I get the MF/Res on 2026 Denali Extended range 24/10 36/10
    We cannot confirm, but other members have reported the same thing.
    What is your location?
    80516
    80516
    .00148 MF and 69% RV
    .00181 MF and 65% RV
  • SimanderSimander Member Posts: 38
    Hi can you provide for 2026 Sierra ev crew cab short box elevation extended range 24/10 and 36/10 for 14221? Thanks!
    .00372 and 82%
    .00326 and 76%
    80516
    Any idea why the Denali RV is so much lower? Much better MF but does that mean they are not applying the 7500 to the RV on just the Denali or do they somehow apply it to the MF?
  • koljan26koljan26 Member Posts: 99
    Hello, can you please provide the RV, MF and any incentives for ‘26 Sierra EV Elevation standard range, based on 24/12 and 36/12, zip code 98034.
  • raptormnraptormn Member Posts: 2
    MF/RV for a 2026 Sierra EV AT4 Extended Range, 36/15, ZIP 28075
    80516
    Sorry, no idea.
    We just report the news...
    .00335 MF and 83% RV
    .00296 MF and 77% RV
    .00321 MF and 73% RV
    Can I please get the MF/ Residual/ Incentives for 2026 Sierra EV AT4 Extended Range for 24/12 and 36/12 for zip code 94116. Thank you.
    Can you please also provide the same info for 2026 GMC Sierra EV
    Denali Standard Range?
    .00148 MF and 68% RV
    .00181 MF and 64% RV
  • mcleo19mcleo19 Member Posts: 7
    Hello, can you please provide the RV, MF and any incentives for ‘26 Sierra EV Elevation standard range, based on 24/10 and 36/10, zip code 97266.
