2026 GMC Sierra EV Lease Deals, Incentives, Rebates, and Prices
2
  • kyfdxkyfdx Moderator Posts: 270,702
    mcleo19 said:
    Hello, can you please provide the RV, MF and any incentives for ‘26 Sierra EV Elevation standard range, based on 24/10 and 36/10, zip code 97266.
    .00335 MF and 84% residual
    .00296 MF and 78% residual
  • raptormnraptormn Member Posts: 2
    MF/RV for a 2026 Sierra EV AT4 Max Range, 36/15, ZIP 28075
  • MichaellMichaell Moderator Posts: 267,363
    .00283 MF and 66% RV
  • STXJIMSTXJIM Member Posts: 36
    Can you please provide the residual and mf for a 2026 AT4 Extended Range for 36/10 and 36/12 for 78521
    .00283 and 68%
  • shikataganaishikataganai Member Posts: 75
    edited September 2
    When you get a moment could you post the September 3-onward incentives (none I'm sure but I'd like to confirm), MF, and RV for a 2026 Sierra EV AT4 Extended Range, 24/12 and 36/12, ZIP 80238? Thanks
    .00368 and 81%
    .00323 and 75%
  • ltak91ltak91 Member Posts: 3
    edited September 4
    When you get a moment could you post the September 3-onward incentives (including courtesy vehicle if available), MF, and RV for a 2026 Sierra elevation Standard Range, 24/10 and 36/10, ZIP 90008?
    .00337 MF and 84% RV
    .00298 MF and 78% RV
    No info on what courtesy status does to the numbers
  • MischaBMischaB Member Posts: 30
    Could I see #'s for 36mo/12K year, 26 Sierra EV Extended Range for 78645 please?
    Could I see #'s for 36mo/12K year, 26 Sierra EV STD
    Denali trim for 78645 please?
    .00183 MF and 64% residual
  • Lance_ISFLance_ISF Member Posts: 74
    Can I please get the MF/ Residual/ Incentives for Elevation Extended Range, AT4 Extended Range, AT4 Max Range, Denali Max Range for 24/12 and 36/12 for zip code 94116 . Thank you.
    Nope, too many permutations.
    Please cut your request in half.
    Sorry. Can I please get the MF/ Residual/ Incentives for AT4 Extended Range for 24/12 and 36/12 for zip code 94116 . Thank you.
    .00368 MF and 81% residual
    .00323 MF and 75% residual
  • SaladBar751SaladBar751 Member Posts: 12
    Does anyone have mf/residual/incentives for 2026 Sierra EV AT4 Extended? 36/12k or 36/10k (or if there is a 39 or 42 options that's more aggressive)
    75032
    75032
    .00323 MF
    75% or 73% RV for 36 or 39 months, 12K
  • bryanwilson1bryanwilson1 Member Posts: 42
    Mf, rv please 26, elevation std range
    Incentives? Cab you see what the gms discount is?
    12/24
    12/36
    44870
    12/24
    12/36
    44870
    .00337 and 83%
    .00298 and 77%
    No info on GMS
  • Jacks1821Jacks1821 Member Posts: 9
    Can I please get the MF and RV for AT4 extended range 48/10 02723 Thanks
    .00347 MF and 68% residual
  • ElonSigElonSig Member Posts: 39
    edited September 17
    Hi, folks. Looking for numbers on the following for a 36/15 in zip code 29577:
    Elevation Standard Range
    One follow-up...any idea if the MF from GM varies depending on whether it is a personal or business purchase?
    .00328 MF and 73% residual
    .00298 MF and 75% residual
    These numbers are for consumer leases. No info on business leases
    Appreciate it, @kyfdx.
    What do the numbers look like for an AT4 trim, same 36/15 term and 29577 zip?
    EXT - .00323 MF and 73% RV
    MAX - .00285 MF and 66% RV
    If anyone's eyeing a Summit White AT4 Extended Range potentially, this is the biggest dealer discount I've seen thus far, at $8,025.
    https://www.rivardroyallgmc.com/new/GMC/2026-GMC-Sierra-EV-14fdb72eac182783f5c09a0801578f63.htm
    Can I please get the MF/ Residual/ Incentives for AT4 Max Range for 24/12 and 36/12 for zip code 94116 . Thank you.
    .00362 MF and 78% residual
    .00285 MF and 68% residual
  • smithc1080smithc1080 Member Posts: 2
    edited September 22
    Can I get the MF / Residual for the Denali Standard Range and Elevation Standard Range for 36/15 and 36/12, for zip 27106. Thank you.
    Can I get the MF / Residual for the Denali Standard Range and Elevation Standard Range for zip 27106. Thank you.
    Apologies! 36/12 and 36/15!
    ELEV: .00298 MF and 75% residual
    DEN: .00183 MF and 62% residual
    Can I please get the RV and MF for 2026 Elevation Extended Range for 36/10. Zip is 02723 Thanks
    .00328 MF and 76% residual
  • bobmcnuggetbobmcnugget Member Posts: 48
    looking for info on
    elevation std range and long range
    20148
    24/10 or 36/10
    thank you!
    looking for info on
    20148
    24/10 or 36/10
    thank you!
    STD
    .00337 and 84%
    .00298 and 78%
    EXT
    .00374 and 82%
    .00328 and 76%
  • tphiliptphilip Member Posts: 108
    Good morning,
    Can I please get the MF/ Residual/ Incentives for Denali Extended Range. 24/12 and 36/12 for zip code 60090.
    Any loyalty info?
    tphilip said:
    Good morning,
    Any loyalty info?
    .00150 MF and 68% residual
    No info on loyalty
  • iuhdiuhd Member Posts: 1
    Good Afternoon,
    Could I ask for MF/residual info on the Sierra EV AT4 Max and Denali Max at 36/10 for 94588 please?
    Thank you very much
    iuhd said:
    Good Afternoon,
    Thank you very much
    AT4: .00285 MF and 69% residual
    DEN: .00183 MF and 65% residual
  • jahc90jahc90 Member Posts: 6
    Can you please give me the Residual, MF and incentives for a Sierra Elevation 26' extended rangw with a 36 and 39 month lease and 15,000 miles for 78575?
    .00312 MF
    63% and 57% residual
    No lesae incentives
    .00300 and 70%
    .00255 and 58%
    When you have a minute I would appreciate lease terms on a 2026 GMC Sierra EV AT4 Extended Range, zip 80238, 24/12 and 36/10. Thanks.
    .00255 MF and 70% residual
    .00312 MF and 66% residual
  • rainy1990rainy1990 Member Posts: 47
    Could I please get rv and mf for 2025 sierra max range denali and at4 for 36/12k for zip 20152?
