2025 Ford Mustang Mach-E Lease Deals, Incentives, Rebates, and Prices
179111213
  • vtingosvtingos Member Posts: 15
    Do you have MF / RV and incentives for Premium AWD Extended Battery 36/10 Zip Code 07726 for the month of September?
  • Tunatango1Tunatango1 Member Posts: 51
    edited September 3
    Hello! Can I please get the September MF, RV and lease incentives for 2025 Ford Mach-e Premium AWD Extended for 12k/24 and 12/36 in zip code 07753. Thank you!
  • kyfdxkyfdx Moderator Posts: 271,510
    edited September 3
    0.05% APR
    54% residual
    $7250 lease cash
    0.05% APR
    60%/53% residual
    $7250 lease cash
  • ehatchehatch Member Posts: 5
    Can I please get the September MF, RV and lease incentives for 2025 Ford Mach-e Premium AWD Extended for 10.5k/24 and 10.5k/36 for zip code 48105?
  • MichaellMichaell Moderator Posts: 267,938
    .05% APR
    61% and 54% RV
    $7250 lease credit
  • TheLackthereOfTheLackthereOf Member Posts: 3
    What are the current MF, RV, and lease incentives for a Premium AWD EXT Range battery in for 10.5k miles/36 months and 12k miles/36 months for the zip code 83716?
    0.05% APR
    53% residual
    $7250 lease cash
  • JimmycarsJimmycars Member Posts: 6
    Hi. May I please have the MF, RV and incentives for a 2025 Mach-E Select, RWD, Standard range, 24/10 36/10 in 92707?
    .05% APR
    59% and 52% RV
    $7250 lease cash
  • peter36peter36 Member Posts: 12
    Can I please get the MF, RV and incentives for the Mach-E Premium, RWD, Standard Range for 36/7,500 miles and the same for the Select, Standard Range , RWD. 90025 zip code. Thanks.
    0.05% APR
    53% residual
    Prem: $8250 lease cash
    Select: $7250 lease cash
  • ldmillioldmillio Member Posts: 3
    Hi. May I please have the MF, RV and incentives for a 2025 Mach-E Select, RWD, Standard range, 36/12 48/12 in 31406?
    .05% APR
    51% and 41% RV
    $6750 lease incentive
    .05% APR
    51% and 41% RV
    Thanks! I have never leased before. What would be a good monthly payment with $0 down?
    ldmillio said:
    .05% APR
    51% and 41% RV
    That depends on the discount you negotiate from sticker. We aren't any help with that; use the Price Checker link below for Edmunds research.
    .05% APR
    51% and 41% RV
    How does a 0.05% APR translate to a Money Factor?
    ldmillio said:
    .05% APR
    51% and 41% RV
    Divide by 2400 for an approximation.
    ldmillio said:
    .05% APR
    51% and 41% RV
    .00001
  • y8g8ne09dy8g8ne09d Member Posts: 4
    - Mach E Select or Premium
    - Standard Range
    - 36 months
    - 10k or 12k miles
    - Zip code 94303?
    Thank you for your time!
    - Standard Range
    - 36 months
    - 10k or 12k miles
    - Zip code 94303?
    RWD or AWD?
    RWD or AWD?
    RWD
    Please and thank you!
    - Standard Range
    - 36 months
    - 10k or 12k miles
    - Zip code 94303?
    y8g8ne09d said:
    RWD or AWD?
    RWD
    .05% APR and 58% RV
    Prem - $8250 incentives
    SEL - $7250 incentives
  • LingranLingran Member Posts: 6
    edited September 7
    • Mach E Premium RWD
    • Extended Range and Standard Range
    • 36 months
    • 10k
    • Zip code 94022?
    • 36 months
    • 10k
    • Zip code 94022?
    0.05% APR
    EXT: 54% residual. $7750 lease cash
    STD: 53% residual. $8000 lease cash
    May I also have the MF, RV and incentives for a
    Mach E Premium RWD
    24 months
    10k
    Zip code 94022?
    Thank you for your time again!
    Mach E Premium RWD
    24 months
    10k
    Zip code 94022?
    The only difference is in the residual
    EXT - 60%
    STD - 59%
  • 06trackevo06trackevo Member Posts: 33
    edited September 8
    Hello! Could I please get the 25 Select and Premium (standard and extended range) RV, MF and incentives? 24/12, 77493. RWD if it makes a difference.
  • chad75chad75 Member Posts: 150
    May I request the MF and residual for a GT, ZIP 33912, for 36 months, both 7.5k & 10.5k... along with any incentives. Thank you!
    .05% APR
    Prem EXT - 59% RV and $7250 incentive
    Prem STD - 58% RV and $7750 incentive
    SEL STD - 58% RV and $6750 incentive
    No SEL EXT range
    36/10.5
    .05% APR and 53% RV
    $6750 incentive
    .05% APR and 53% RV
    $6750 incentive
  • patoandpandapatoandpanda Member Posts: 1
    Hi! New to leasing and trying to understand how to negotiate the best deal I can.
    Went to a dealer and was quoted a 2.05% APR on a 2025 Mach E Premium RWD EXT (36 months/12k miles) in zip code 92630.
    Is the dealer trying to make a profit with the high APR?
    How close to the 0.05% APR being referenced in this thread should I try to get?
    Is it realistic to ask the dealer for a 0.05% APR and how likely is a dealer to accept that rate?
    Thank you for the knowledge share!
    If you have top tier credit, the dealer is marking up the APR for extra profit.
    You want the base rate, or find another dealer. Be polite, but firm.
  • B5BrandoB5Brando Member Posts: 14
    Good afternoon.
    I am looking to find out the MF, Residual and incentives for a 2025 Mach E GT.
    zip code 85142
    24months/10k
    36months/10k.
    B5Brando said:
    Good afternoon.
    zip code 85142
    24months/10k
    36months/10k.
    0.05% APR
    60%/53% residual
    $6750 lease cash
  • ayjay123ayjay123 Member Posts: 7
    Hello! Can I please get the September MF, RV and lease incentives for 2025 Ford Mach-e Premium and Select AWD Standard and Extended for 10.5k/24 and 10.5/36 in zip code 11230. Thank you!
    0.05% APR
    61%/54% residual for EXT range
    60%/53% residual for STD range
    Prem EXT: $7750 lease cash
    Prem STD: $7500 lease cash
    Select EXT: $6500
    Select STD: $7250
  • ChikiDiazChikiDiaz Member Posts: 12
    Hi there, can I please get the lease numbers and incentives for:
    2025 Mustang Mach E premium, extended battery, RWD, in 33185? 36m/10k
    Standard battery too please (same everything else).
    0.05% APR
    EXT: 53% residual. $7250 lease cash
    STD: 52% residual. $7750 lease cash
  • JoacoJoaco Member Posts: 26
    Hello! can I please get the Incentives, MF and RV on the Ford Mustang Mach-E Select and Premium.
    Terms 36/10 and 24/10
    RWD or AWD?
    Standard or Extended Battery?
    What is your location?
    RWD or AWD?
    RWD, Standar, 33317
    Thank you and sorry
  • mikemike123mikemike123 Member Posts: 13
    Hello!
    I am looking to find out the MF, Residual and incentives for a 2025 Mach E Premium AWD.
    Zip: 02346
    36mo
    15k
    Thank you very much!
    RWD or AWD?
    RWD, Standar, 33317
    Thank you and sorry
    0.05% APR
    59%/52% residual for 24/36 mo
    Prem: $7750 lease cash
    Select: $6750 lease cash
    Hello!
    Zip: 02346
    36mo
    15k
    STD or EXT battery?
    Hello!
    Zip: 02346
    36mo
    15k
    STD or EXT battery?
    Whoops sorry about that... EXT please
    Hello!
    Zip: 02346
    36mo
    15k
    STD or EXT battery?
    0.05% APR
    51% residual
    $7750 lease cash
  • Ace_beeAce_bee Member Posts: 10
    Hello, Can you please provide me the RV, MF, and incentives for 2025 mustang mach E Premium AWD for 24m/36m/10,000/12,000 in zip 20772?
    STD or EXT range?
