Visitor Agreement.
Just wondering, those of you who use a chamois to dry your car after washing, how do you clean the chamois? I imagine you shouldn't be machine washing, but any insights would be helpful. Thanks.
Outside watering is still banned here, so guess the Zaino will have to wait a while longer. Everybody pray for rain for central Alabama!!!
You can get a good description of what the clay does for you at www.erazer.com.
It is of benefit on even a brand new car - I can vouch for that. My brnd new car got even smoother and slicker. A side benfit is that the polish goes on and off even easier and faster on a super-smooth car.
Cole 01 - You will not believe how your black will look after 2-3 coats of Zaino. You can see some pics on the Zaino site, but seeing it on your own car will knock you out. It is worth it.
http://www.geocities.com/MotorCity/Flats/7501/febbmw.html or for AOL users-
Click Here
fastdriver
I believe in a clear windshield without water spots, I have a cleaner that I found in a flea market that really cleans water spots, but I want to try Z12, it says it will remove the film that builds inside the car, I am having that problem, my wife says I used a rag contaminated with wax, my theory is, oily air from the engine compartment, Zaino claims is more pronounced in new cars, must be, the mercedes, porsche and bmw have this hazy film that becomes noticeable at nigth with oncoming traffic.
I am ordering Z14, specially for the porsche convertible, the clear back plastic window is loading up with water spots, one has to be carefull because it will swirl easy, if anyone knows something better, please, I am all ears.
Thanks again,
A good test is to wash it (or at least a section) and then catch a reflection of the sun in it. If there's any haziness to that, kind of spider-webby scratches, then the car will look much better after using Z5 and a coat or two of Z2.
Remember to wait 24 hours between coats unless the temps are above 70F.
If you use a Z7 mixture as your lube while claying you just need to rinse that off before using Z1 followed by Z2 or Z5. No need to wash with Dawn again.
Dawn won't hurt the car, it just will take off every bit of wax on it. But not the Zaino; I think that requires alcohol.
You only have to use the DAWN once! You can use the Zaino car wash when you are done claying.
ONE thing Zaino does NOT do is protect against chips! Where did you get the idea that wax/polish protects against chips? If Zaino did that it would be written up in scientific journals AND my 300M would not have a hoodful of chips from everyday driving. ;-)) Sorry, if you thought that was one of Zaino's attributes.
fastdriver
order for Z2,12,14 and 18."
You need Z1 to chemically set up your car's paint for the Z2. Since you're claying (Z18), you will need a lubricant. Z7 and distilled water in a spray bottle makes a good lubricant. Regardless, I advise not to use your Dawn wash water. I found that it reacts negatively with the clay causing it to become lumpy and to separate.
On Zaino Glass Polish: Its really great for removing that plastic residue film on inside windows. And also for really cleaning the outside windshield. But please note two things. First, its a very slight abrasive and will require some heavy duty rubbing. And second, the residue from the glass polish itself is a bit hard to get rid of. My method is to rub it off and then use Windex on the window to remove any remaining residue. In fact, after one application of Zaino Glass Polish, I just keep using good olde Windex. Maybe I use the Glass Polish one every 5 or 6 months.
I hope Zaino products come with some literature and instructions.
Then again I wonder, if there are any long term after effects from using Zaino, how long have they been in business, I have been reading nothing but good stuff around here, and the pics of the shine I have to admit are impresive, but, I have to say I have a cautious nature, specially if something is too good, and new to me. Wife says try in the old pickup before a new 70,000 car.
And again, many thanks to all,
As to the safety of polymer finishes, polymers have been around for years and I have not heard of any cases where use as directed has resulted in any problems. I can't even imagine what problems they COULD cause. I suppose if you applied them over a dirty surface they could scratch, but that is hardly the fault of the product. No, I am pretty sure that it is safe, but even if it weren't, I am sure that Zaino, even though it is not General Motors could afford the price of a repaint. You would have a hell of a time proving it was their fault, but that is another story. Remember, although you get instructions here on how EXACTLY to apply the products, in excruciating detail, I am living proof that you can do it wrong and still recover from your mistakes with no damage done. I will attest that if you do it as instructed you will get the best results, but doing it wrong will still give you really good results and you can fix almost anything you do wrong with some common sense. Then you will want to do it "right" to see if it works as advertised so do it right the first time. Example--you must NEVER let the super gloss spray dry on the car. you must wipe it before it dries. But if you do let it dry, then you just have to (as shown on the bottle), spray it again and wipe while wet. No big deal. You must not try to wipe the z1 and z3 off before it is good and dry. But if you do, you can then wait until it is dry and wipe it off, maybe using some z6 (is that the right number for the super gloss spray?), wiping it off and starting over again. No big deal. If you screw up in some unfathomable way that no one else has thought of, well just call or email Sal Zaino and he will help you out. This is one benefit of this product that the owner is available to advise and direct easily. It is a very user friendly product, don't be scared by the precise methods posted here, they are just because so many want you to share in their discovery of how good your car can really look. It is not brain surgery, it is just "waxing" your car, and with little work at that. Have fun, don't be afraid to just do it.
FWIW, I'm 10 months into Zaino on my White car. There is absolutely no trace of any yellowing or dulling anywhere on the finish. And I''m still amazed at how clean my hood looks, even during a week of rain and road slop.
I regularly reapply and each fall I start over with clay and Z-1. I use the Zaino car wash, tire product and Zaino leather products. I have not tried the glass product.
I have used all Zaino products on two cars for the entire period - not once using any other product.
There have been no problems, concerns or issues of any kind. I have extremely happy with the performance of these products. They are easy to use, last a long time and look great. I especially like how the car does not really get dirty and when I wash it the dirt, grime, etc just doesn't really stick to the car.
I have a bright red car and live in Houston so, long hot bright summers is what I face. Anyone concerned about the product yellowing over time should have **no** concerns based on my experience.
After washing the car and completing the "final" spray rinse, remove the nozzle from the hose and then allow the water to flow gently onto the surfaces. You'll be amazed at how little water is left -- the slick Zaino finish lets the water slide off, and drying then becomes a simple matter that doesn't consume two or three towels or require multiple wring-outs of your Absorber.
Let us know if it works for you!
Like I've said before, I'd rather wash and Zaino the car than clean the windows. I use the Zaino window cleaner too, but I use it on a dampened cloth. The problem is that on the 300M, you have to be a contortionist to clean the front and rear windows. I only clean them about once a month or when I can't see anything! LOL...
fastdriver
I'll try it, but it seems like more of a chore than just driving around the block. I have a wet-dry vac. The motor comes off the can to turn it into a blower. The lawn guy worries about the leaves! LOL...
fastdriver
I reallly don't know how to rectify your situation. I would call Sal and tell him that you are in AZ and ask him what he would suggest for getting the water spots off before "Z"ing.
It doesn't sound like you used too much Z1 since both of your vehicles are quite large. Besides, using too much Zaino will not cause water spots. That can only be done by...well...water.
Let us know what you find out.
I have a 2K Nissan Maxima SE...since day one I have had this mark on my windshield that for the life of me I cannot remove. The mark is actually the length of my passenger wiper and is located at the furthest travel point of that wiper so it is pretty good size 10-12 inches..
The weird thing is that this mark is only visible when the windshield is wet, damp or fogged up with morning dew....the mark stands out perfect on the dewy windshield in the morning but disappears once the windshield drys up...you can just barely and I mean barely feel this mark(about 1/4 inch in wdth) if you drag your fingernail over it. Looks hazy like maybe some sort of nuclear wax
When the windshield is dry you cant see it at all....but once it starts raining that annoying mark is right in my face!
Well I've tried all the household products, Windex, Glass Plus, Windex with Vinegar and also the Armor All Glass Cleaner both with paper towels and newspaper...all have failed misreably...I've even tried some 3M Bug, Wax and tar remover(said safe for glass) and that did not dent it.
I have had minimal success using a razor blade but I really dont like the idea of using it on my glass....
I also did a pretty horsecrap job of putting on some really old Rainx that I'd love to get off my windshield...
So.....should Z12 do the trick and will good ole elbow grease with it do the trick? What should I use to apply it with?
Z-12 is 100% safe on all factory glass. It contains a micro-abrasive specifically designed for glass. It will designed to deep clean and make the glass crystal clear and sparkle...
Z-12 will also remove the plasticizers that attach to the interior glass. That nasty film you see. It will completely remove that in one
application.
Apply Z-12 with a damp cotton cloth. Do small sections at a time. Let Z-12 completely dry and then buff with a clean dry cotton towel. If
there is any smearing or residue left. Just use Windex to clean off the excess polish residue on the windows. You can continue using Windex for maintenence, until the windows become dirty or hazy again. Then use Z-12 again.
No need to use it all the time. I use Z-12 every 30 to 90 days to get the windows crystal clear. Then I maintain the glass with windex.
Z-12 is not for use on aftermarket window tint. The aftermarket window tint are plastic and the Z-12 can scratch it......
Hope this helps.
Michael
Larry
Even more impressed! There is HOPE for Chrysler! ;-))
fastdriver
Never had the need to try it myself, but you might want to give it a shot. The price is right.
