.00296 MF and 78% residual
Can you please provide the residual and mf for a 2026 AT4 Extended Range for 36/10 and 36/12 for 78521
.00283 and 68%
.00323 and 75%
.00298 MF and 78% RV
No info on what courtesy status does to the numbers
Denali trim for 78645 please?
Can I please get the MF/ Residual/ Incentives for Elevation Extended Range, AT4 Extended Range, AT4 Max Range, Denali Max Range for 24/12 and 36/12 for zip code 94116 . Thank you.
Please cut your request in half.
.00323 MF and 75% residual
75% or 73% RV for 36 or 39 months, 12K
Mf, rv please 26, elevation std range
Incentives? Cab you see what the gms discount is?
12/24
12/36
44870
.00298 and 77%
No info on GMS
Elevation Standard Range
.00298 MF and 75% residual
What do the numbers look like for an AT4 trim, same 36/15 term and 29577 zip?
MAX - .00285 MF and 66% RV
https://www.rivardroyallgmc.com/new/GMC/2026-GMC-Sierra-EV-14fdb72eac182783f5c09a0801578f63.htm
Can I please get the MF/ Residual/ Incentives for AT4 Max Range for 24/12 and 36/12 for zip code 94116 . Thank you.
.00285 MF and 68% residual
ELEV: .00298 MF and 75% residual
DEN: .00183 MF and 62% residual
elevation std range and long range
20148
24/10 or 36/10
thank you!
.00337 and 84%
.00298 and 78%
EXT
.00374 and 82%
.00328 and 76%
Good morning,
Can I please get the MF/ Residual/ Incentives for Denali Extended Range. 24/12 and 36/12 for zip code 60090.
Any loyalty info?
.00183 MF and 64% residual
No info on loyalty
Could I ask for MF/residual info on the Sierra EV AT4 Max and Denali Max at 36/10 for 94588 please?
Thank you very much
DEN: .00183 MF and 65% residual
Can you please give me the Residual, MF and incentives for a Sierra Elevation 26' extended rangw with a 36 and 39 month lease and 15,000 miles for 78575?
63% and 57% residual
No lesae incentives
.00255 and 58%
.00312 MF and 66% residual
Could I please get rv and mf for 2025 sierra max range denali and at4 for 36/12k for zip 20152?
