Chronic Car Buyers Anonymous
1170171172173174176»
  • au1994au1994 Member Posts: 3,777
    edited December 1
    The X1 threw the "Engine temperature high. Drive moderately to cool engine" error message Saturday night. Apparently he has not had heat for some period of time either. Nursed it to the shop yesterday so I sit in wait and see mode. Hoping for a thermostat and not a water pump.
  • tjc78tjc78 Member Posts: 17,383
    And yes... my truck is dirty. I'm ashamed of how it looks right now.
    edited December 1
    Did some reading and it may be that its best just to replace both water pump and thermostat regardless of what the culprit is. One of those 'while you are in there' jobs. It has 84k on it and if it wasn't a BMW I'd say that's premature for a water pump to fail.
  • jmonroe1jmonroe1 Member Posts: 9,694
    @nyccarguy said:
    OK, cool. I've been looking at used (non-CPO) BMWs as well, just for kicks.
    Found a nice 2015 M235i with RWD and a stick shift - 51,000 miles for about $24K. Would work for all but about a month or so of the year, and I'd have the Outback to use on those days. Still can't convince myself that a 3rd car is necessary in our household.
    I like that body style M235i/M240i. You know it’s got performance chops because @roadburner had one. How’s the CarFax look? Like it enough to have a PPI done on it? A RWD BMW with a stick coming up on 11 years old might be something to get a good deal done before 12/31!
    Three owners, one bit of minor damage to the rear of the car.
    320 HP. White over black.
    With minor damage to the rear of the car, one of the previous owners must not have been going too fast in reverse.
  • nyccarguynyccarguy Member Posts: 17,746
    We may do a bit of shuffling in our driveway.
    Present day, we have the 25 Equinox EV. It’s a lease, it’s going back, buying it won’t happen. We have about a year left. Then there’s the 25 Si. We don’t drive it a ton. It has 8,000 miles and we’ve had it a year. There’s the 2014 Odyssey. 150k. No issues. It’s safe.
    Option 1: Sell the Civic, pay about $10k to change to a 25 RAV4 Hybrid before the change to the new 2026 design.
    Option 2: Keep everything we have and lease a cheap Prius, Camry Hybrid, etc.
    Option 3: Keep everything we have and find a used 2015-ish Prius or RAV4.
    We have kid # 2 that will have his permit early next year. Goal is to get a car he can learn in that we can use too. I’m driving more for work and the Civic isn’t ideal, which means we are using the van more than we’d like.
    We are in very similar situations. My son is scheduled to take his road test tomorrow morning at 7:15. Over the summer, I was looking at a Camry AWD and a Prius AWD. I sat in the Prius and noticed the terrible blind spots. Made a right turn out of the exit to the dealership, then made the next right turn to turn back in. We ended up leasing a 2025 Camry SE AWD. We are very happy with the car. My wife, my 19 year old son, & my 16 year old son all seem to like it. It is a very comfortable car to drive. Acceleration isn't mind blowing, but it has zero trouble merging or passing. We have been averaging 38-42 mpg. Most fill ups take less than 10 gallons of gas and net us over 400 miles to a tank. An LE FWD (you are in SoCal, if I remember correctly) will net you better fuel economy due to the smaller wheel & tire combo as well as FWD. The cloth seats in the LE seem on the cheap side. I'd buy or lease another one in a heartbeat.
  • suydamsuydam Member Posts: 5,173
    The Prius seems like a penalty box to me.
    RAV4. Is nice but pricey compared to the Hyundai or Kia equivalents, and cheaper interior to boot. But they sell a ton of them!
    If I wanted the economy but not something as large as a Camry, I would go for a Corolla before a Prius.
  • corvettecorvette Member Posts: 11,649
    The current Prius has really improved in terms of performance, the second gen up until the current used to be ten second 0-60 cars (but they'd get 40+ MPG even with regular full throttle starts). I've only sat in the current one and didn't notice the visibility issues, but the instrument cluster and tilt steering wheel positioning did not agree with my preferred seating position. I had the same issue in the bZ4X/Solterra, which appeared to use similar hardware.
  • MichaellMichaell Moderator Posts: 267,665
    Corolla Cross would be a nice compromise, size wise.
    Grandson #1 (23 years old), just bought a new 2026 Corolla FX Edition in bluish/purple over black suede with white rims. He’s going to have a good time keeping those rims clean. That would not have been my choice but he thinks they’re “cool”.
    Not unless you have driven one. Had a rental and was awful.
  • oldfarmer50oldfarmer50 Member Posts: 24,545
    “ The winter use issue came to mind since snow season started, and already hit salted roads. Worrying about that drives me nuts, and right now, I don't want to take either car out when the roads are brined. A lease truck instead of a winter beater car that my wife would hate covers multiple needs.”
    Welcome to my world (or did I infect you with my paranoia?). I think leasing might be the perfect solution for you although more expensive in the long run. Vehicles last about 8 years up here before noticeable rust starts popping through. Eric O. has a great video on problems experienced on a “Chevy Silverusto” he had to work on.
    Only if you can tolerate the typical Toyota plastic fantastic interior. Their interiors on lower-end cars make no attempt at style.
    What was the coolant level? None of the scenarios I can come up with are good.😫
    How fast pickups rust is incredible. Would likely not be as bad here since I don’t drive in dirt and try to avoid heavy salt times. And if it does get coated I go to the car wash to at least make an attempt at keeping it clean underneath.
    Would likely also get some kind of fluid film put on as a precaution.
    Or lease and not care!
    A winter beater car also makes sense but then I have to hassle with parking it someplace. And driving it too much in the winter.
    Son #2 passed his road test this morning! I now have 4 cars and 4 drivers in the house.
    Congrats .... and, ouch.
    I remember those times.
    edited 8:40AM
    One of the things that’s off about my Integra is the backup camera. It absolutely has the worst resolution of any backup camera in any car I’ve ever owned dating back to 2010.
    This is on a clear night. Zero precipitation.
    Yeah! Your insurance agent must love you.
  • sdasda Member Posts: 7,712
    Congratulations
    My Kia was the first car I owned with a backup camera and I was disappointed that the picture was so fuzzy. I wiped it off, I cleaned it with windex and nothing helped. Then I examined it closely and discovered the little piece of plastic protector hadn’t been removed by the dealer. Peeled that off and now it’s crystal clear.
    Boy are you going to get a nice holiday card from your insurance broker!
    Nah, the broker is too busy shopping for a new boat.
    Huh. Like it wasn't removed while being prepped? I'll check it out later. Thanks for the suggestion.
    Wow! Not a bad tip coming from a fellow dinosaur. :D
    Strangely, it was normal. No white smoke, no warnings on the 2 mile drive to the small shop we use. I have not heard anything yet. They looked to be backed up when I left it on Sunday.
    The hell with a card, he should get a juicy Christmas ham. Oops, make that a kosher turkey and latkes for Hanukkah. B)
    If it doesn’t have the plastic it has to be defective. That’s unacceptable.
    @nyccarguy - is it that bad during daylight hours? I've had a few that weren't great at night.
  • xwesxxwesx Member Posts: 17,940
    Even if it is only at night... totally unacceptable for a new car!
  • benjaminhbenjaminh Member Posts: 6,769
    edited 3:30PM
    You've mentioned several times getting a beater. But you've also said you don't have the patience at this point to deal with a car that has problems. My guess is that it would be better for your situation to just get something new. Since don't drive all that much, or keep your vehicles that long, a lease seems like a good option. That also has the benefit that when you trade-in one of your well-maintained and near-perfect cars you can put something away to cover those pesky payments. But given the time a car purchase takes it might be wise, as you suggested, to put it off till after you retire.
    edited 3:20PM
    Not many get sedans these days, but this seems like an ok lease offer on a Camry: $269 a month for 39 months with $3700 due at signing. So the real monthly payment would be around $400.
    https://www.toyota.com/deals-incentives/lease/
    The current Accord hybrid lease offer is $349 a month for 36 months with $4100 due at signing. So really about $500 a month.
    I miss the days when you could get a pretty nice car for $250/month with $500 DAS. I think my loaded Sonata limited was only about $300.
