Chronic Car Buyers Anonymous
1170171172173174176»
  • au1994au1994 Member Posts: 3,780
    edited December 1
    The X1 threw the "Engine temperature high. Drive moderately to cool engine" error message Saturday night. Apparently he has not had heat for some period of time either. Nursed it to the shop yesterday so I sit in wait and see mode. Hoping for a thermostat and not a water pump.
  • tjc78tjc78 Member Posts: 17,390
    And yes... my truck is dirty. I'm ashamed of how it looks right now.
    edited December 1
    Did some reading and it may be that its best just to replace both water pump and thermostat regardless of what the culprit is. One of those 'while you are in there' jobs. It has 84k on it and if it wasn't a BMW I'd say that's premature for a water pump to fail.
  • jmonroe1jmonroe1 Member Posts: 9,695
    @nyccarguy said:
    OK, cool. I've been looking at used (non-CPO) BMWs as well, just for kicks.
    Found a nice 2015 M235i with RWD and a stick shift - 51,000 miles for about $24K. Would work for all but about a month or so of the year, and I'd have the Outback to use on those days. Still can't convince myself that a 3rd car is necessary in our household.
    I like that body style M235i/M240i. You know it’s got performance chops because @roadburner had one. How’s the CarFax look? Like it enough to have a PPI done on it? A RWD BMW with a stick coming up on 11 years old might be something to get a good deal done before 12/31!
    Three owners, one bit of minor damage to the rear of the car.
    320 HP. White over black.
    With minor damage to the rear of the car, one of the previous owners must not have been going too fast in reverse.
  • nyccarguynyccarguy Member Posts: 17,753
    We may do a bit of shuffling in our driveway.
    Present day, we have the 25 Equinox EV. It’s a lease, it’s going back, buying it won’t happen. We have about a year left. Then there’s the 25 Si. We don’t drive it a ton. It has 8,000 miles and we’ve had it a year. There’s the 2014 Odyssey. 150k. No issues. It’s safe.
    Option 1: Sell the Civic, pay about $10k to change to a 25 RAV4 Hybrid before the change to the new 2026 design.
    Option 2: Keep everything we have and lease a cheap Prius, Camry Hybrid, etc.
    Option 3: Keep everything we have and find a used 2015-ish Prius or RAV4.
    We have kid # 2 that will have his permit early next year. Goal is to get a car he can learn in that we can use too. I’m driving more for work and the Civic isn’t ideal, which means we are using the van more than we’d like.
    We are in very similar situations. My son is scheduled to take his road test tomorrow morning at 7:15. Over the summer, I was looking at a Camry AWD and a Prius AWD. I sat in the Prius and noticed the terrible blind spots. Made a right turn out of the exit to the dealership, then made the next right turn to turn back in. We ended up leasing a 2025 Camry SE AWD. We are very happy with the car. My wife, my 19 year old son, & my 16 year old son all seem to like it. It is a very comfortable car to drive. Acceleration isn't mind blowing, but it has zero trouble merging or passing. We have been averaging 38-42 mpg. Most fill ups take less than 10 gallons of gas and net us over 400 miles to a tank. An LE FWD (you are in SoCal, if I remember correctly) will net you better fuel economy due to the smaller wheel & tire combo as well as FWD. The cloth seats in the LE seem on the cheap side. I'd buy or lease another one in a heartbeat.
  • suydamsuydam Member Posts: 5,174
    The Prius seems like a penalty box to me.
    RAV4. Is nice but pricey compared to the Hyundai or Kia equivalents, and cheaper interior to boot. But they sell a ton of them!
  • stickguystickguy Member Posts: 54,134
    If I wanted the economy but not something as large as a Camry, I would go for a Corolla before a Prius.
  • corvettecorvette Member Posts: 11,651
    The current Prius has really improved in terms of performance, the second gen up until the current used to be ten second 0-60 cars (but they'd get 40+ MPG even with regular full throttle starts). I've only sat in the current one and didn't notice the visibility issues, but the instrument cluster and tilt steering wheel positioning did not agree with my preferred seating position. I had the same issue in the bZ4X/Solterra, which appeared to use similar hardware.
  • MichaellMichaell Moderator Posts: 267,734
    Corolla Cross would be a nice compromise, size wise.
    Grandson #1 (23 years old), just bought a new 2026 Corolla FX Edition in bluish/purple over black suede with white rims. He’s going to have a good time keeping those rims clean. That would not have been my choice but he thinks they’re “cool”.
    Not unless you have driven one. Had a rental and was awful.
  • oldfarmer50oldfarmer50 Member Posts: 24,548
    “ The winter use issue came to mind since snow season started, and already hit salted roads. Worrying about that drives me nuts, and right now, I don't want to take either car out when the roads are brined. A lease truck instead of a winter beater car that my wife would hate covers multiple needs.”
    Welcome to my world (or did I infect you with my paranoia?). I think leasing might be the perfect solution for you although more expensive in the long run. Vehicles last about 8 years up here before noticeable rust starts popping through. Eric O. has a great video on problems experienced on a “Chevy Silverusto” he had to work on.
  • ab348ab348 Member Posts: 20,630
    Only if you can tolerate the typical Toyota plastic fantastic interior. Their interiors on lower-end cars make no attempt at style.
    What was the coolant level? None of the scenarios I can come up with are good.😫
    How fast pickups rust is incredible. Would likely not be as bad here since I don’t drive in dirt and try to avoid heavy salt times. And if it does get coated I go to the car wash to at least make an attempt at keeping it clean underneath.
    Would likely also get some kind of fluid film put on as a precaution.
    Or lease and not care!
    A winter beater car also makes sense but then I have to hassle with parking it someplace. And driving it too much in the winter.
    Son #2 passed his road test this morning! I now have 4 cars and 4 drivers in the house.
    Congrats .... and, ouch.
    I remember those times.
    edited December 2
    One of the things that’s off about my Integra is the backup camera. It absolutely has the worst resolution of any backup camera in any car I’ve ever owned dating back to 2010.
    This is on a clear night. Zero precipitation.
    Yeah! Your insurance agent must love you.
  • sdasda Member Posts: 7,712
    Congratulations
    My Kia was the first car I owned with a backup camera and I was disappointed that the picture was so fuzzy. I wiped it off, I cleaned it with windex and nothing helped. Then I examined it closely and discovered the little piece of plastic protector hadn’t been removed by the dealer. Peeled that off and now it’s crystal clear.
    Boy are you going to get a nice holiday card from your insurance broker!
    Nah, the broker is too busy shopping for a new boat.
    Huh. Like it wasn't removed while being prepped? I'll check it out later. Thanks for the suggestion.
    Wow! Not a bad tip coming from a fellow dinosaur. :D
    Strangely, it was normal. No white smoke, no warnings on the 2 mile drive to the small shop we use. I have not heard anything yet. They looked to be backed up when I left it on Sunday.
    The hell with a card, he should get a juicy Christmas ham. Oops, make that a kosher turkey and latkes for Hanukkah. B)
    If it doesn’t have the plastic it has to be defective. That’s unacceptable.
    @nyccarguy - is it that bad during daylight hours? I've had a few that weren't great at night.
  • xwesxxwesx Member Posts: 17,945
    Even if it is only at night... totally unacceptable for a new car!
  • benjaminhbenjaminh Member Posts: 6,770
    edited December 2
    You've mentioned several times getting a beater. But you've also said you don't have the patience at this point to deal with a car that has problems. My guess is that it would be better for your situation to just get something new. Since don't drive all that much, or keep your vehicles that long, a lease seems like a good option. That also has the benefit that when you trade-in one of your well-maintained and near-perfect cars you can put something away to cover those pesky payments. But given the time a car purchase takes it might be wise, as you suggested, to put it off till after you retire.
    edited December 2
    Not many get sedans these days, but this seems like an ok lease offer on a Camry: $269 a month for 39 months with $3700 due at signing. So the real monthly payment would be around $400.
    https://www.toyota.com/deals-incentives/lease/
    The current Accord hybrid lease offer is $349 a month for 36 months with $4100 due at signing. So really about $500 a month.
    That's why I was talking about the maintenance threshold currently being $4,500... because even the cheapest cars are going to cost you that much even to just have them sitting in the garage. And, it is a pretty high threshold. I don't think I have ever had to spend that much on M&R for a single car in a single year (to this point in time).
    Okay, I take that back. I did put a new transmission in the Powerstroke this past summer. But, that's a first!
    Well this is getting fun…Shop #1 punted on the X1 because 1) the leak appears to be behind the oil filter gasket and they don’t have the tool to remove it and 2) even if they did the tech said he wasn’t comfortable making the potential repair. It’s just a regular mom and pop shop that doesn’t specialize in any make. They did recommend a European indy shop so I had them top the coolant and got it over there. No warnings thrown but by the time I drove the 8 miles to the other shop, I could smell coolant on the outside.
    1st shop did say they thought it was going to be an 8 hour job so this isn’t going to be cheap.
    Did they pressure test it at least to confirm the leak?
    yes, there is one and traced it visually to that area where apparently there is a hose hidden/blocked by this oil filter gasket. German engineering at its finest.
  • explorerx4explorerx4 Member Posts: 21,044
    Here's a discussion of what sounds to be the problem with the X1.
    https://f48.bimmerpost.com/forums/showthread.php?t=2058387
    edited December 3
    Is the current X1 still a mini based platform with their engine transverse mounted?
    Yikes, that sounds like what it could be and it sounds labor intensive.
    edited December 3
    When it comes to extended warranties the max that BMW offers is 7 years/100k. Honda tops out at 8/120. Subaru 10/100. Honda's plans are still pretty low cost if you shop around. Our Subaru plan was $2500 for 10/100. I'm guessing that a BMW plan for 7/100 is maybe double that?
    Sounds like a fun project. You got this, @au1994! :#
  • tifightertifighter Member Posts: 3,850
    Hey, is @stickguy still looking for an X1?
    it has been redesigned since the version being discussed. That is why I asked is the new one still a mini transverse motor?
    My wife would be perfectly fine with a "real" BMW (an X3). Even though they cost a bit more money. We will go look at them both anyway. But I am not afraid of a new or CPO X1 since it would have at least 6 years of powertrain warranty (and we would never run out of miles before months!) Will just depend on what we like the best.
    not really sure what else is out there that might be exciting enough to make a move. One of the smaller Lexus models? possibly a Mercedes. The Acura ADX was not special enough to move the needle.
