2025 GMC Sierra Lease Deals, Incentives, Rebates, and Prices
1234568»
  • ajv5042ajv5042 Member Posts: 12
    Looking at sierra elevation 4wd crew cab standard bed 3.0 diesel. Zip 18612. MF/res? Best term for 15k per year
  • MichaellMichaell Moderator Posts: 269,006
    .00259 MF and 59% RV
    $500 incentive
    Still shopping this one. I am sure I want the diesel engine. What trim and term give the best MF/res for crew cab 4wd. Zip 18612
    Nothings changed from our answer, 3 days ago.
    So you’re confirming elevation trim is the best residual?
    You can't look at the residual in a vacuum. High residuals are often accompanied by higher MFs.
    Get the trim you'll be happy driving for the next 3 years.
  • PackOnePackOne Member Posts: 3
    Hi, may I get the RV & MF for zip 91504:
    Sierra 1500 SLT Diesel crew cab short bed 2wd & 4wd
  • kyfdxkyfdx Moderator Posts: 272,632
    2WD: .00289 MF and 61% residual
    4WD: .00255 MF and 60% residual
    $500 incentive
  • SweetpytSweetpyt Member Posts: 12
    Can I please have MF, RV and incentives for 2025 SIERRA 1500
    Crew Cab, Short Bed, Elevation, 4WD and SIERRA 1500
    Double Cab, Standard Bed, Elevation, 4WD for 36/10 or 24/10 for zip code 08822
    Double
    .00190 MF and 68% residual
    .00185 MF and 60% residual
    $1000 lease cash
    $1000 incentive
    Crew
    .00241 MF and 70%
    .00221 MF and 62%
    $1000 incentive
  • jblackbeltjblackbelt Member Posts: 74
    Hi! Can you provide me with the residual, mf, for a 2026 GMC Sierra 1500 Denali, 36 or 39 15k / 20k please? Any rebates or incentives? Zip is 07928
    Please repost into our 2026 Sierra discussion
  • Jraya1986Jraya1986 Member Posts: 7
    edited September 2025
    Hello Can you please share MF/Residual
    2025 Gmc Sierra 2500 diesel crew 4x4. Denali and AT4 trim. 36/10 36/12 zip code 95901
    Thank You
    Thank You
    AT4 - .00321 MF and 62% RV
    DEN - .00336 MF and 65% RV
  • Jwheeks98765Jwheeks98765 Member Posts: 24
    Hi
    I am looking for the MF/RV/Incentives for a
    2025 GMC Sierra 1500 Elevation 3VL Short Box Crew Cab TurboMax
    Zip 02919
    Thanks !
    Hi
    Zip 02919
    Thanks !
    .00254 MF
    64% and 62% RV
    $2500 incentives
  • Jdaw09Jdaw09 Member Posts: 4
    Can I get the RV and MF for a sierra 2500hd at4 in 44718
  • tseck73tseck73 Member Posts: 28
    Hi - looking for the Oct number (MF/RV) on a 2026 Sierra 1500 AT4X in 27608 - term are 36/12
    edited October 2025
    .00325 MF and 60% residual
    Please re-post in the 2026 model discussion
  • rainy1990rainy1990 Member Posts: 47
    Can I please have rv and mf for 2025 GMC Sierra 1500 Elevation crew cab short bed 4x4
    for 36/12k? for zip 20152
    .00221 MF and 61% RV
    $2500 incentive
    $2500 incentive
    Would also like to check for a 48 month 10k lease on the same trim. thank you
    $2500 incentive
    .00294 MF and 56% residual
    Same incentive
  • thall13thall13 Member Posts: 4
    Hi! Can you provide me with the residual, mf, for a 2025 GMC Sierra 1500 Denali, 36 or 39 15k please? Any rebates or incentives? Zip is 75204
    .00155 MF
    59%/56% residual
    $500 incentive
  • Swiftfold2025Swiftfold2025 Member Posts: 5
    Can I get the RV & MF, and incentives for 2025 Sierra Crew Elevation 2WD short bed and 36/12k zip code 85755 thank you!
    .00254 MF and 63% residual
    $1000 incentive
  • CrushinRushinCrushinRushin Member Posts: 14
    Can I get the RV & MF, and incentives for 2025 Sierra Crew Elevation 4x4 short bed, best terms available. Zip code 01749
    39/10
    .00221 MF and 60% residual
    $1000 incentive
    Could I get updated numbers for November for 2025 Sierra Crew Elevation 4x4 short bed and Seirra 1500 Denali 4WD crew cab, best terms available. Zip code 01749. Thank you!
    Pick a term and mileage, please.
    36/10 or 39/10
    36/10 or 39/10
    ELEV
    .00221 MF and 62% residual
    $1000 incentive
    Denali
    .00165 MF and 62% residual
    $500 incentive
  • adam2475adam2475 Member Posts: 29
    Looking for MF, Residual, and incentives
    2025 Sierra Denali Ultimate 36/15k 48356
    .00165 and 59%
    $500 incentive
  • gitchegumeegitchegumee Member Posts: 7
    Hello, can I please get current incentives, MF and residual % on 2025 24/15,000 and 36/15,000 GMC 1500 Sierra SLT crew cab 4 x 4 3.0 duramax? Zip code is 48324. Thank you
    .00239 MF and 69% residual
    .00216 MF and 60% residual
    $750 incentive
    Thank you for your response to my earlier question. Having looked at 2025 inventory I think I might be better off looking at 2026 models in a couple of different trims.
    Would you have incentives, MF and residual % on 2026 24/15,000 and 36/15,000 GMC 1500 Sierra SLT and AT4 crew cab 4 x 4 3.0 duramax? Zip code is 48324. Thank you again for your assistance.
    .00212 MF and 69% RV
    .00187 MF and 60% RV
    $750 incentive
    Either trim
  • Dmelia1Dmelia1 Member Posts: 15
    Hello. May I please get current MF, Residual and incentives and a 2025 Sierra 1500 Elevation, 4WD- 5.3L- Crew Cab 18411 Zip Code- 36mth/15K per year?
    .00221 MF and 59% residual
    $2750 incentive
    Hello, Could I get updated numbers for January for 2025 Seirra 1500 Denali 4WD crew cab, 36/10 or 39/10. Zip code 01749. Thank you!
    .00119 MF
    62% or 59% residual
    Either $2000 or $500 incentive, depending upon engine
    .00119 MF
    62% or 59% residual
    Thank you! Which one would it be for the EcoTec3 6.2L V-8
