Stories like this one below remind me that the NHTSA throws a party every time it happens. They celebrate another pad to their padding of the propaganda propagating "speed kills" mythology. Because a dummy that doesn't know how to drive and running from the police to evade capture is EXACTLY the same as someone that does know how to drive and just goes 15 to 20 over an under posted speed limit where it is safe to do so. Makes total sense to lump them together statistically.
https://www.msn.com/en-us/news/crime/one-passenger-dead-after-houston-police-chase-raises-familiar-questions/ar-AA1SJ9yZ?ocid=entnewsntp&pc=U531&cvid=694968c1c00641518602d46bbe8804eb&ei=79#comments
Sounds like it may be closing with too much force stressing the attachment point.
I think it is pulling up that weakens it. The wood is starting to weaken. I haven't looked at it, and it is too hard to get MrsD100 to try and explain it on the phone. All I know is she couldn't go to her TRX class at the Y.
If only there were a way to video it and send it to you.
You took the words right out of my mouth.
Back to appliances! Dryer started acting funny. Sucked the lint trap out and some socks & underwear started going outward. Then it wouldn’t turn on. Called the place I bought it from to check if it still under the extended warranty. Nope. 5 years from April 2019. I’m sure it might be the belt…
That’s a first for me. I never heard of a dryer acting like a vacuum. I’m pretty sure you’ve said your house is all electric, so check the breaker to see if it’s tripped (it’s should be a 30 amp breaker), I’ll assume your drier has digital controls so that is one way to see if you have power, if you don’t have any kind of a display, the breaker is probably tripped. As for the drum not turning that could be a belt, so try to turn the drum by hand if you don’t feel much resistance the belt could be broken. If the belt is broken, if you listen carefully, you should be able to hear the drum motor running,
I still can’t figure out how it’s sucking out clothing. It’s probably throwing the clothes out not sucking them out but that’s just a technicality because that’s still not normal.
Let us know what it turns out to be.
There is definitely power going to the dryer. The display lights up. I can hear the motor. It is difficult to spin by hand.
If the drum is very difficult to turn by hand (it would be nice if you knew how it turned when it was working), it could be the belt has twisted. I’ve heard of that but I’ve never seen that myself. The only way to be sure is to take off what ever panel/s are necessary so you can see if that is the problem.
If the belt is where it should be but there is something keeping the drum from turning, if you run the motor long enough you’ll smell the rubber which is bad and will eventually ruin the belt.
Still can’t explain why the clothes are being ejected. Maybe Google the problem and/or search that problem via your model number.
Again, let us know what you find.
My daughters best friend just got a new Leaf as her primary daily, and she charges up from what I assume is a 110 outlet at her house (11 hours to get a full charge, give or take).
She's helping out at the studio yesterday and today (camp while the kids are out of school), so she's been driving up from Co Springs, a distance of 60+ miles, one way.
No problems yesterday, but for some reason the charge last night didn't fully take, so now she doesn't have enough range to get home. Wife is looking for a charging station close by, but can't find anything as the Leaf uses the older charging technology.
Not exactly sure how this will all play out; if I learn more, I'll pass it along.
Check to be sure the car charging settings have not been changed inadvertently if there is such a thing on the Leaf, then try to charge it again.
Good call - on my Mercedes it is very easy to hit the slider for max charge and lower it. It happened one night when I plugged it in. I noticed it because the completion time was much too soon for as low as it was. Now I always check the app when I plug it in.
Other than the little electronic module that modern appliances are so fond of having, a dryer is an extremely simple machine.
So, the continuation of the Leaf charging story…
She pulled the car around to the back of the studio and plugged into one of the outlets there.
If she needs more charge, there is a charging station about halfway she can stop and use
I know she qualified for credits, but don’t know if it’s brand new or new to her.
I would have done that, but I can't do much about it while she is at home and I am in Florida. She messed up the remote for the TV and I had her point her cell phone camera at the remote because I can't remember how it looks when I am in Florida, and I was able to tell her what to do from here....but the garage door has to wait until I get back. But I hear 20 years is longer than most last.
I admit I don't know anything about garage doors, but I think the stress is caused when it goes up....there is a lot of force pulling the door up....down seems easier.
I know, it is P.I. to question driving EVs, it seems very easy for it to happen, with no easy solution.
All told it was almost $3,000
But the earth resources used comparing the battery materials and motors to regular vehicles' use is too high in my opinion. A hybrid is more justifiable. I originally had thought I'd want a plug-in hybrid, but that's even more consumptive of resources for battery and motors. For many an EV will work easily in the use cycle.
there are actually some advantages, on the gas side. ICE engines are very simple really in a hybrid. Essentially antique tech. No DI, no turbos, or all the other modern stuff that can eat you alive when it starts to fail (and is a lot more complicated to build). I looked at the motor in my Maverick yesterday (filled up the washer fluid) and it reminded me of my 1980s vintage Honda. Everything very accessible, and nothing I didn't know what it was hanging off. The Acura, that is a lot harder to tell what is going on!
Oh, the transmission is way simpler too. Just a planetary gearset.
And at least batteries (unlike engines?) can be fully recycled.
but once you are into the 12-15 range, ICE cars can get very expensive. Engines crapping out, or transmissions (go price a 10 speed modern AT replacement).
IMO the future is EVs that have a small ICE to charge the battery. Similar to how locomotives and cruise ships run.
Ram is supposed to release a truck like that as well as Ford.
Merry Christmas
Merry Christmas to you and yours
https://youtube.com/shorts/zjKIBO_pc9M?si=s2PFL3SUrfYRZ7qp
BMW i3 Also.
I'm not sure which approach is better - big engine, little battery, or vice versa.
Merry Christmas to all...........
We’ve had our ‘25 Camry since June and our very happy with it. It continually returns 38-44 mpg on regular gas. Most fill ups it takes less than 10 gallons of gas. Drop the hammer and the acceleration doesn’t disappoint.
Yours is the AWD version?
Merry Christmas, everyone!
