Zaino Car Care Experiences
16970727475137
  • joebob6joebob6 Member Posts: 239
    Call or e-mail Sal. I think he would say it is fine to use Zaino. Wax smothers the paint while Zaino polish does not and will allow the solvents to outgas and let the paint cure. I would wait 5-7 days after the paint repair work.
  • pblevinepblevine Member Posts: 858
    I have to agree with joebob. But I'd call Sal just because the paint manufacturer is saying one month. From what I remember, auto manufacturers are now using a process which is mostly cured in 48 hours. But that involves baking it dry.
  • bh0001bh0001 Member Posts: 340
    This will be the first winter for my "new" car and its pristene Zaino-treated finish. I'm looking forward to seeing how Zaino will hold up in the annual Ontario salt assault on the roads. However, I'm not looking forward to dragging a swirl-inducing snow brush across the pristene finish on my Impala. Has anyone found a better or less swirl-inducing snow brush than the standard type?
    Brad
    Nope! bh001: I've had the same problem. The only real solution is to wash the car. That's sometimes hard with low temperatures, etc. What I've done is to carry a bottle of water with a bit of Z7 car wash added. I'll spray those super dirty spots and towel off the dirt. Sort of an instant micro-wash job. But it has, in some cases, left swirl marks behind. Aside from the swirl marks problem, two coats of Z2 lasted me all through last winter. I'm in the New York, New England area which does see a lot of road salts and sand too. I'm sure that your winters are colder than ours and that you probably have more ice removal problems than we do.
  • kenyeekenyee Member Posts: 738
    Get a board's hair brush. It's fairly expensive at $40 though.
    Search for "Ultimate Snowbrush" on the net. The handle feels much better than standard brushes.
    I'd post a link, but our Edmund's hosts have been deleting/censoring any msgs I put up w/ URLs in the C-class, M-class forums.
  • homer2000sseihomer2000ssei Member Posts: 159
    Oh man I hate that - runed the finish on my black car the first winter - have to live with the results.
    Now, i just dont brush the snow off close enough to the paint to worry about it.
    And as far as zaino lasting through our winters - 2 properly applied coats (which inclues one of Z1, plus two top coats) will do just fine. You will be impressed. Oh, and do avoid the temptation to go to one of those do it ureslef washes and use the brush there to get all the salt and crap off the car.... soo many bad memories before i discoverd online car care forums . . .
    I have found the Sunoco drive thru touchless to be the ultimate. They have excellent multi purpose (and colour) foams - and the car comes out very clean (for touchless) . They are pricey - but worth it. $9 without gas for the ultimate , but I will drive 30 minutes to get to one in Markham Ont when the need and weather dictates.
  • luck11luck11 Member Posts: 425
    Just as i read the last post, someone walked by and said it was snowing. Guess what...its coming down!!! Good thing I put a coat of Z2 last weekend!!!
    I have been using Z products for almost 1.5 years on my 00 Outback and love it. I've always had problems with water spots though, so for the past while, I always put a coat of Z1 before my Z2. I find this gets rid of any waterspots etc. before my z2 goes on, leaving a clean finish. So the process (every 5 or 6 months) Wash, Z1, Z2or z5, wait, z6, then z2 or z5. Clay each spring. Will using z1 before each z2 or z5 application create a problem?
    Using Z1 for each Z2 or Z5 application 'should' be OK, but you might wish to check with Sal. I do, however, think that is a bit far to go to eliminate water spots. I too am prone to water spots due to hard water. But after a Z7 wash, I rinse the car with a very low pressure hose rinse, use a chamious to elimate most remaining water, and then dry with a clean cotton towel. That seems to remove the spots. Then I use Z6 prior to applying my Z2.
  • jnj91jnj91 Member Posts: 55
    I received notice that my Zaino order should arrive tomorrow! I can't wait to try it.
    Would it be ok to do the Dawn wash today, or should I wait and do it immediatly prior to the Zaino treatment? I am going to use the clay bar if that makes any difference.
    BTW, I just read a new Zaino comparison. Here is the link. http://pages.sbcglobal.net/gheumann/zaino_test/
    Based on all the Zanio information I've read, shouldn't he have kept using the Z5 until he was satified the swirl marks were gone?
    After reading that test I still believe that everyone is going to have a different opinion and even though we may or may not try something different based on what others write, we are still going to like what WE like. If a person tries a product and doesn't like it, no amount of arguement is going to change his/her opinion.
    Now, if I don't like the Zaino, I'll let you know! ;)
       Julie
    Yep. I've complained via email but it seems to go into the "circular file". Complaints that are posted get deleted .
    It's too bad there's no other Zaino forum out there. Sal should put one up on his site.
  • fastdriverfastdriver Member Posts: 2,273
    automophile-
    Mmmmm...........SO, you like Zaino? LOL....... You're welcome, you're welcome, you're welcome! ;-)
    pblevine-
    I'm no "expert" when it comes to Zaino. All I did was read the directions BEFORE I applied Zaino. My car is a daily commuter too. I already have 10,000+ miles since 3/28/01! I NEVER drive this much so soon, but I love this car and I love this shine. MAYBE it doesn't turn as many heads as Christine did, but it does turn heads!
    fastdriver
    I use a broom with a large 100% Cotton Towel wrapped around the bristle area. I try to gently push off the snow and may have to re-wrap the towel a few times, but it seems to work pretty good.
  • graphicguygraphicguy Member Posts: 14,222
    Julie:
    You can wash your car (Dawn) today if you plan on keeping it in a clean area (garage) and not driving it after the wash.
    Then, you can clay the car using Z7/water (1:5 ratio) mixed in a plant sprayer bottle as the lube. After you clay, wash again with Z7, dry (100% cotton towels), apply 1 (very thin) coat of Z1. Do not remove the Z1 (no need to let it dry either)...on top of the Z1 coat, apply either Z2 or Z5 (again, thinly) as is your preference. Let both coats dry (couple of hours). Remove both coats with a clean cotton towel. Enjoy the shine.
    Couple of hints:
    --moisten the included wax applicator with Zaino Shine Enhancer before applying any polish lok or wax.
    --Only put a small amount of Z1 or Z2 or Z5 on the applicator...a very thin "X" should do the trick for each body panel (maybe a couple of "X"s for the larger panels like the top, hood or trunk).
    --if after you wait for the Zaino to dry, and it starts to smear, it is either not dry or you applied too much.
    Good Luck...let us know how it turns out.
    jnj91-
    Oh wait until you see that shine and experience those Zaino smells and get those jealous looks from the regular wax people!! ;-))
    To all-
    Click here to see squidd99's Zainoed Lexus
    More Lexus pics to come soon.
    fastdriver
  • scottc8scottc8 Member Posts: 617
    Thanks, guys. e-mailed my question to Sal this morning and had a reply waiting for me this afternoon. He says a week is plenty, more than long enough. So I can continue to build up my "winter coat" this weekend.
    This good a product with that kind of support can't be beat.
    Thanks for the suggestions everyone. I'll probably try the cotton towel over the bristles on my furry-tipped snow brush. As far as winter washing, I always go to a touchfree wash (they use the pretty coloured soap too). I might try to get my dealer to let me wash my car in their bays a couple of times through the winter (helps to have a brother-in-law as parts manager!).
    Brad
  • joe166joe166 Member Posts: 401
    Didn't you find Sal's email response to be kind of surly? I thought he answered the phone in a gruff voice when I called him. It put me off and I didn't notice if he gave me good advice or not. LOL
    I love those pictures, and can't wait for the jealous looks! thanks fastdriver! (If I drove your car or squid's car I'd get jealous looks with out Zaino! LOL)
    graphicguy; Thanks for the tips. I wrote them down so I'll remember! I'll have to wash it later because I will have to use it.
    I found a couple of paint chips on the hood (really small). I want to Zaino the car, repair the chips, then touch up the spots with Zaino after they have dried for a week or so. Will that work?
    Julie
    jnj91-
    LOL....it's the ZAINO shine that attracts the looks first- not the kind of car! If you have a darker color car, you'll see what we mean after you apply several coats of Z5/Z2/Z6.
    Good luck. REMEMBER- VERY LIGHT COATS. This is not like wax products you may have used in the past. Looking forward to seeing your pics too!
    fastdriver
    PS squidd99 said he'll take more pics next week. Stay tuned!
    Julie:
    If the paint chips are pretty small, you may not want to do anything to them. Anytime you get into touch-up paint, you always run the risk of having the touch-up look worse than the "chips" themselves.
  • squidd99squidd99 Member Posts: 288
    Thanks for the kind comments about my swell new car.
    It is certainly taking the crisis out of my mid-life.
    Nice pics of squidd's car (and nice car too).
    What do ya mean yer not da expert. I'm the guy who read the directions before using. You did the same? What a concept!
    I'm going to be working on my car for awhile! :P
    Thanks for all the advice!
    Julie
  • pjyoungpjyoung Member Posts: 885
    And don't overuse the Z2 because it smells so good!
  • cdnpinheadcdnpinhead Member Posts: 5,632
    "jealous looks" don't comprise the entire board. . .though you'd be hard pressed to prove it with the posts.
    Some of us use the stuff because it's easy and protects the car.
    I guess the point is that this is a product that works for those who preen as well as for those who don't.
  • armtdmarmtdm Member Posts: 2,057
    My Toy with multiple coats of Z2
    http://www.monumental.com/armtdm/images/3000gt.jpg
    Not at all, or else I don't get the joke.:) Sal gave me a detailed answer to my question. He stated that Zaino is "breathable. . . and will allow solvent evaporation or any gases to release. ." This would contradict an opinion that I read, and posted about some weeks back, that Zaino and polymers in general would "over-seal" paint and cause damage over the long term.
    << I guess the point is that this is a product that works for those who preen as well as for those who don't. >>
    That's the point I'd been trying to make for folks who think that Zaino is just too much work. It can be as much, i.e. claying and multiple coats, or as little work as you want. I think it can't be beat for ease of application, shine and endurance.
    I was spoofing a wax review site that gave Zaino a low grade for customer service because Sal was supposedly "gruff" to them which was cited on one of these boards a few days ago. No big deal and certainly not worth revisiting again.
    pblevine-
    "I'm the guy who read the directions before using.
    You did the same? What a concept!"
    LOL... You'd be SURPRISED how many people THINK they know how to apply it and skip ALL the directions. Then, when they don't get the results that we do, they say it's crappy stuff! Knowledge is power! ;-)
    cdnpinhead-
    "Some of us use the stuff because it's easy and protects the car."
    That's what I use it for also, as well as the "wet look shine"!! People at work who could care less about cars and waxes and shine, comment about the looks of my car.
    armtdm-
    Oh yea! Looking good. Thanks for posting the pic.
    fastdriver
    PS- 17 more days before the ZFX comes out??
    Ok, I finally finished with my Dawn/clay/Z7/Z1/Z5! Well, if finished last night but It was late so I watched the game instead of posting here. :)
    So! Do you want my honest opinion, or the 'party line'?
    julie
    Honest opnions are always welcome!
    armtdm: Nice pic! Thanks for posting it.
    Julie: 'Just the facts, mam.
    fastdriver: Thought you'd like that.
    'Just 17 days? Think I can pre-order some ZFX?
    jnj91-
    Just the facts-M'am. It's okay if you don't like it No one will fault you. However, wait until you use the Z2/Z6 and have a few coats of that combo on. When I did the first applications, it looked as good as when I used Meguiars. After I had several coats on, I started to see that wet-look shine. Not everyone likes that look. I do. First impressions in this case may not be the same when several more coats are put on. The "hard" part is over. Now the fun begins! ;-)))
    GO YANKS!!!!
    fastdriver
    I'll second fastdriver - it's okay if you're first impressions aren't the "party line". Contrary to popular belief, we won't report you to the Taliban as a potential target. Since I drive a white car, I haven't ever had the really "wet look", but man the thing still looked good, even under streetlights. FWIW, I also used Z2 first rather than the Z5. The "hard" part is really over. Wait til it rains and you watch it bead water, or wait until you hit some bugs and see how easy they are to remove. And wait a couple of months and notice that the water is still beading. I didn't notice what color your car was, but judging from fastdrivers pics, additional coats on a dark (or bright) color really do start to make it wet looking. Also, you don't have to do multiple coats the same day/weekend.
    jnj91-
    Yea, what pjyoung said! DON'T praise it too much, if that's the case, or you might be labeled a "shill" or "stockholder"!! LOL......
    fastdriver
  • hud116222hud116222 Member Posts: 46
    Having just retired and been gone for quite awhile (enjoying the good life :), I have just now caught up on a couple hundred messages. Quite interesting for sure. I might have shared this a ways back, but while I would not consider myself a "zealot", I am totally impressed with what that, shhhhhhhh, "Z stuff" has done to my car. At the first oil change of my 01 red Solara, I was talking with the service manager when we walked to the back. The ENTIRE service crew was gathered around my car. I thought something was wrong, but then heard the magical word. They wanted to know how I made the car look so "wet." The general manager then told me he didn't want my car sitting next to any others on the lot because it made them look bad. Maybe there are lots of products that will do that, and that is fine with me. I just know how my car looks and EVERYBODY says the same thing; "I have never seen a shine like that." That works for me!!
    I just opened the box and the stuff applied itself to the car. Wow!! Looks great! ;)
    Ok, for real!
    Here is the good :), and bad :(
    Bad- I'm really awful at the claying. Has anyone ever used up BOTH packages of clay bar on the first vehicle? And I still see places I missed!
    Good- I was amazed at how good it looked after I finished claying! (using the z7 as a lube was great)
    Bad- A Suburban is a BUS! Are you sure I gotta wash and dry this again before I can put the Z1/Z5 on? (Ok, I did it.)
    Good- Man that Z stuff smells great!
    Bad- Did you guys say THIN? Exactly how thin is thin? Ok, a few spots were a little thicker than thin.
    Good- It was REALLY, REALLY easy to put on and buff off!
    Bad- I have a load of towels to wash and it was too dark to really see the effect of all my hard work. (And I'm sore.) Did I say I own a bus?
    Good- Ok, there was a little light in the garage. Man! It looks better than good and I've just put one coat on.
    The Worst- It was RAINING when I left this morning and I had to drive around all day in the drizzily, yucky, sloppy weather!
    If there is a good to that it's that the rain DID bead up really well!
    I am truly impressed. I know that I haven't had a chance to see the overall effect, but as far as the EASE of applying, and the initial shine and beading, I think it is great. I was really concerned about the claying, I thought it would be hard to do, but with the tip about lots of lubrication, it was great. Even though my car is only 8 months old- once I started, I could tell it really did need the clay bar step. (Now I just need to learn how to hold on to the clay!)
    Can't wait for the rain to stop! Do I have to wash again, then put another coat of Z5 or Z2 on? Can I put the Z6 on after I wash or after the Z2?
    I didn't expect the curve ball with the nasty rain!
    Julie
    Zaino Fan
    Sounds like you had fun! I'm soooo glad I don't own a Suburban (aka "the bus"). I was sore enough after doing the initial stuff on my Impala. I had the dropsies with the clay too - it gets very slippery. And TOWELS!! Don't get me started - they had to institute a water ban after I washed all my towels ;-)
    There have been several days where I thought I was going to have to call in sick because it was raining and I had just detailed my car. It really sucks to take a pristene vehicle into the sloppy stuff. I get supremely po'd when it drizzles just enough to completely mess up my car and then the sun comes out again.
    As far as what to do next, yes you have to wash again first (I think you know that part). The verdict is out on whether or not to Z6 before you do another Z2/Z5. Personally, I do (somewhere on Sal's web site he suggests that you do so). It takes such a TINY amount of Z6 I figure it's worth doing. Then you can choose whether to use Z5 or Z2. You'll know while you're washing which one you need based on any swirls that you can see. Once you buff off the Z2/Z5, then use Z6 again. All these steps go MUCH faster than your first full treatment. It just keeps getting easier from here (and the benefits keep increasing for the next couple of coats).
    Then stand back and enjoy your handywork.
    jnj91-
    LOL...........SUBURBAN!!! I didn't know! Just WASHING it would make you sore from all the bending and stooping. If I had a "bus", I don't think I would be as enthusiastic about polishing it either. That must be an all day project.
    "Bad- I'm really awful at the claying. Has anyone ever used up BOTH packages of clay bar on the first vehicle? And I still see places I missed!"
    I never used both packages of clay, BUT then again, I didn't clay a "bus" that was 8 months old, but a car that was a week old. Maybe, with all that territory to cover it's not unusual to use all the clay. The clay does get slippery. I put an old army blanket on the ground where I'm working because it is easy to drop.
    "Bad- I have a load of towels to wash and it was too dark to really see the effect of all my hard work. (And I'm sore.) Did I say I own a bus?"
    LOL.....Yep, bus you did say! Hear you about the towels. I think I have more white towels for the car than I have IN the house!
    "Can I put the Z6 on after I wash or after the Z2?"
    Some people do both. I only put it on AFTER I use the Z5 or the Z2. I also use it from time to time when I just don't feel like using Z5/Z2. What color is the "bus"? The darker, the better the results.
    Glad your initial results were good. Just wait and see how much better it looks after a few coats of Z2/Z6.
    hud116222-
    Shhhhhhhhhh........LOL.............Another happy "shill/stockholder"!! Don't you love all the money we're making off this Z stuff? :-)))))))))))))
    fastdriver
    I really like doing this because Z6 is the ultimate dust & lint remover. And in a dry climate on a sunny day, it's impossible to wash & dry a car without leaving a few tiny waterspots. Z6 wipes them right off. Then you're applying Z2 to a surface that is immaculate.
  • mikeb31mikeb31 Member Posts: 25
    Now I just need a day or two off to apply it. Have a 3 week old Silverado Pickup with a week old shell, but haven't had a day off for three weeks, hopefully I'll get one in a couple of weeks, but then it will be time for thanksgiving. I've only washed the truck two times so far with the cotton USA towels so I don't have any swirl marks, light pewter color. I did buy the clay anyway and the swirl remover, don't know the Z #, because my wife has a dark green '94 Accord and I know I'll catch a lot of grief if I spend all the time on my truck and don't do her car also. Washed both of them last week before I got the shell ( so the bed would be nice and clean ) the truck takes twice as long or more than her car. I'll let you know how both vehicles turn out.
    Mike
    We just bought a new Silverado that my husband drives. It's a great truck. It will have to wait to get it's coat of Z too.
    The weather is still too bad to get my second coat on...uuugh!
    Why does this stuff completely change your mind set and make you think of nothing else but getting another coat on? I was completely normal until the UPS driver came to my door Thursday! LOL
    (I don't think it's a condition limited to Zaino users-all polish users have the problem, I hope!)
    I watched two amazing games last night Game 6 of the WS (poor Yanks, ouch!) and the Arkansas at Mississippi game that went through 7 overtime periods! At the end of regulation it was tied @ 17. Arkansas finally won 58 to 56. Go Hogs! :)
    Julie
  • rowlandjrowlandj Member Posts: 254
    Hello, I have been uzing Z on three of my cars since last spring. While I love the shine and the deep wet look on the darker cars my favorite part of the Z line is the ease of use and the longevity. Add to that the fact that nothing seems to "stick" to car like bugs etc... and you I belive this product is a real winner.
    I can Z the cars easily now that the "base coats" are established and I find I do it more ofent than I ever did using traditional waxes.
    Thanks to everyone here as I relied on this board before I took that first plunge in.
    JR
    jnj91-
    "Why does this stuff completely change your mind set and make you think of nothing else but getting another coat on? I was completely normal until the UPS driver came to my door Thursday!"
    OH NO!!! ANOTHER Zainoholic!!! Time for a ZA (Zaino Anonymous) meeting before you get too hooked! LOL............
    I knew this would happen! ;-))
    fastdriver
    If you answer "yes" to more than X of these questions, you are in danger.
    1)Do you find yourself thinking of Z-ing your car at inappropriate times, such as while at work?
    2)Do you Z your car when you should really be doing something else, like cutting the grass?
    3)Do you smugly compare the shine on every other car you see to your own?
    4)At a red light, in the rain, do you glance over at the guy next to you to see if he's noticing the cool way the water is boiling off your Z-ed hood?
    5) Have you ever Z-ed your car after dark?
    6) Do you smirk as you walk past the displays of lesser polishes and mere mortal waxes in the auto parts store?
    OK, I'm fairly new here. Bet lots of people can do better than this.
    << Why does this stuff completely change your mind set and make you think of nothing else but getting another coat on? I was completely normal until the UPS driver came to my door Thursday. >>
    That's it! There is something IN the formula that is BRAINWASHING us into this irrational behavior. Oooooh. I don't think anyone else should try it...
    I answered too many of scottc8's questions yes, and I just started! LOL
    Julie
    You really know you're a Z-Freak when you start looking at ads for 100% cotton towels. I've now got three sets and the wife is looking at me in a funny way. She thinks she can now teach me to run the washing machine, and get me to do the laundry.
    jnj91-
    I answered yes to many of scottc8's questions too! Do you think we could drop some on bin Laden's cave and distract him long enough to GET him?
    pblevine-
    You only have THREE sets of white towels? Oh boy, I REALLY need help! ;-))
    fastdriver
