Mazda Protege Maintenance and Repair
1303133353674
  • irishalchemistirishalchemist Member Posts: 152
    As Chikoo said, very normal. The groan is very typical of automatics - Although they 'slip', they never 'disengage' as with a manual tranny, so the car is always 'trying to go forward'. This makes the brakes do a 'groaning clunk' (clonk-clonk-clonk...) when you apply light pedal pressure, because the discs want to keep turning. I'm surprised you never noticed with other cars - Every american car I've rented (all automatics) do this. My wife's 626 also does it, although it quieted down some with premium pads...
    G.
  • chikoochikoo Member Posts: 3,008
    when the engine is cold to warming up I find that the revs keep dropping when the car comes to a stop. The revs at a standstill should be around ~700 but when I stop they can drop to 500/550. Noticed again this morning by the first red light. Revs drop to 500-600 car trembles and after few seconds it is gone. Once the engine reaches proper temperature, everything is back to normal.
    What is wrong here?
  • mazdafunmazdafun Member Posts: 2,329
    Any number of items:
    PCV dirty (clean or replace)
    Throttle body dirty (clean)
    MAS failing (replace)
    Plug wires failing (replace)
    Spark plugs worn (replace)
    And probably a few others I can't think of now. The MAS on my 1.6L ('99) was failing and caused low, unsteady idle (as if it was going to stall) whenever I came to a stop or a crawl, even with the engine warmed-up. It also cause my fuel economy to drop from a typical 28-29mpg to 22-24mpg. Mine was covered under an extended warranty Mazda gave to owners of some 1.6L Proteges. You could bring it in to Mazda and ask them to diagnose the problem. I think it costs $36 or something like that.
    My Protege experienced similar symptoms to yours early in the MAS failure. It happened sporadically, mostly when the engine was "cold" but then it happened all the time and got me really worried about stalling (to the point where I'd feather the throttle to keep the engine running at stops).
    You can check the PCV and throttle body yourself by opening them up and seeing if they're really filthy (wipe them out). You can inspect your plugs yourself too for excessive wear (you'll need a very long 16mm spark plug tool, and maybe an extension...I had to use a 3in extension bar with my socket to extract my Protege's plugs). For the wires, you'll need to check their resistance (I don't know the tolerance range). If you have a multimeter, you can check the MAS too, though I can't inform you on what the normal readings should be (all it said on my report was it was "reading low").
  • ashutoshsmashutoshsm Member Posts: 1,007
    Right on the money, Chow-Chi!
    I had similar symptoms at the beginning of winter, and they vanished after doing 3 of those things - I bought NGK spark plugs and wires from the dealership (around $50 total - yeah I could have bought OEM ones for less) and had the PCV replaced at the next oil change - they used a no-name brand. The trembling vanished, and mileage came back up to more familiar levels.
    but I think the problem stemmed from me adjusting the Air adjusting screw too give too little air.
    I have raised it back and looks better now.
    BTW, do you think you could post a pic of the deposits/corrosion in your engine bay you were talking about? I might get a better idea. I should've asked to look at it when I could've.
  • maltbmaltb Member Posts: 3,572
    ...from me adjusting the Air adjusting screw...
    You are begging for trouble messing with that screw and not following the proper procedure.
    what kind of trouble?
    the TAS is the one which one should not be touched at all. There is nothing to my knowledge about the AAS.
    I thought you were playing with the TAS.
    Hi All,
    It's warmer now, so time to roll the window down, enjoy ... and start listening to all those noises coming from the engine bay that went unheard all winter!
    I am starting to notice a 'metallic' noise coming from the engine under certain conditions. It is whistle-like, and although it's very high-pitched, changes pitch. It's not loud, just like metallic 'chirping' - Hard to describe. Anyway, it seems to happen more with the engine cold, and it is noticeable when stepping on the gas under load. I think it may be as simple as a leaf or twig in the air intake, but haven't checked. Car is a 96 DX. Any ideas?
    G.
    Funny, I experience the exact opposite.
    I can hear all sort of engine noises in winter when the windows are all up & there is no AC fan running and the only source of sound is the thin firewalll which lets in all engine noises.
    In spring, with the windows down, I can hear nothing except the wind whistling by and other cars on the road.
    Ok. I get it. you must be driving close to a wall, where the sound of the engine bay gets reflected and you can hear it from your open windows.
    Regarding your sound, could it be the belt stretching itself when cold? or maybe some pulley bearings need to be lubed?
    Chikoo,
    Exactly! When I get on a 'walled' access ramp or drive by parked cars is when I notice the noise...
    I like your suggestion of pulley bearing needing lube - I think that that will also explain why the car makes other variety of noises when accelerating which are somewhat affected by the AC being on or off. I'll check them this weekend.
    Would you use lithium grease on these or are they sealed bearing?
    G.
    Use sealed bearings that can sometimes be replaced. The bearings usually run about $5 from a local parts store.
  • mdaffronmdaffron Member Posts: 4,421
    They say it's the sound of the air going through the valve in the throttle body and not to worry about it.
    I'm not worrying about it because it's been doing it for tens of thousands of miles and I now have 55,500 miles on my '00 ES. And I have the warranty extended to 100K miles. :D
    BTW, mine is a five-speed and I hear it most when taking off in first -- during the first touch of the accelerator pedal -- the loudest. Is this the same for you guys?
    Meade
    Yes, I hear it more in 1st or 2nd with the first touch of the accelerator. Once you get the rpms high it goes away, so I think it makes sense that a valve could be the reason. I won't worry...
    Funny thing is that the noise from the air intake in my wife's 626 is more like a vaccum cleaner: A continuous 'sucking' noise...
    G.
    One more. I built myself a scantool for the Protege, which is an ISO OBD-II compliant car. The contraption I made works fine on a Subaru Legacy 2000 and on a friend's 97 Honda Civic (both ISO OBD-II cars), but it does not work on the Protege! Argh! I know the car is ISO OBD-II (pins on the connector and extensive web searching). Does anyone of you knows if the ECU in early OBD-II compliant Proteges was funky in any way? I know there is a problem because I posted somewhere else an another fellow told me he also had troubles with his 97 1.5L Pro.
    Any hints welcomed...
  • doublesixdoublesix Member Posts: 29
    How often should I have the transmission oil changed for my Protege 99? I could not find any information regarding this in the manual book. Thanks!
  • jrdwyerjrdwyer Member Posts: 168
    The rear struts on my 1995 Protege LX (157K miles)were getting weak, so I decided to replace all four. I tow a utility trailer with an ATV quite often, and I think this contributed to the rear struts wearing out. Anyway, here are a few tips if you decide to do this job yourself.
    As I had never done this before, I consulted a Haynes manual and the instructions were pretty clear. I ordered 4 Monroe Sensi-trac srtuts from Autopartsgiant.com for about $53 apiece. Autozone has spring compressors that they loan out for free with a deposit. I don't own any air tools or impact wrenches and used just standard ratchets, sockets, box wrenches, a torque wrench, and a steel beater bar for leaverage on the ratchet. I also used two jack stands and the jack-up tools that came with the Mazda.
    I did this project over two days interspersed with other household chores, but it could be done in 4-8 hours using primitive tools like mine.
    Don't try to loosen the suspension support-to-piston rod nut on a workbench, it won't work. Break the high torque on this nut while it is secured in the car with a turn or two, then it can easily be removed after you have compressed the springs on the workbench. As the front springs are not that tall, you will have to compress them down almost as far as you can before safely removing the piston rod nut. The rear springs are taller, and you won't have to compress them as far to loosen the spring pressure on the top.
    I didn't replace the rubber bushings or suspension supports as they were in o.k. condition. I just cleaned them up and put them on the new struts. I believe the only place you can get these rubber parts is from Mazda.
    You will need to be careful when lowering the front struts to not damaging the front CV joints . Also, use some care when disconnecting the rear brake line from the rear strut as it is metal line from the strut to the brake housing.
    One problem I did encounter was the anti-sway bar connected to the rear struts. The nuts on the control links were completely frozen and rust spray did not help. So I used a hacksaw to cut the two control links and took off the rear stabilizer bar. I'm sure someone in this forum could explain how to remove these nuts. Anyway, if I can find two new or used control links for a decent price, then I will put the rear stab. bar back on the car.
    Overall, this was not too difficult a project, just time consuming. If you have average mechanical skills, a few tools, and a work bench, then you can do this project. Just be careful when compressing the springs and setting the compressed springs down (compressed springs that come undone are very dangerous). And be sure to put the parts back on in the same order or location as you took them off.
    Finally, you will need a 4 wheel alignment after replacing the struts. Happy Motoring.
  • protegextwoprotegextwo Member Posts: 1,265
    Have a trained tech drain fluid, remove oil pan, clean and inspect, refill with OEM or Mazda compatible tranny fluid every 30,000 miles.
  • tomcivilettitomciviletti Member Posts: 207
    Did you try a propane torch on the nuts?
    Hey,
    My 1.5L Protege, nearing its 60K miles, has developed valve noise (tapping...). I thought that I'd wait until the timing belt change comes up, and have it done then. However, I remember the timing belt in my 626 was pristine when I had it changed. So my plan was to try to do a valve adjustment myself and at the same time check the condition of the timing belt.
    Now, I will have help from a mechanic friend of mine, and he has access to special tools, so I'm not worried about the valve adjustment. The real problem is getting the shims that will be needed to correctly adjust the valves. Any clues as to who may supply these? Trussville Mazda, maybe?
    G.
  • boggseboggse Member Posts: 1,048
    Any Mazda dealer should be able to get you the shims you need. If you are looking to save a little money, there are a number of on-line dealerships like Trussville. Another that I routinely use is Mazdastuff.com. Also, I can often talk my local dealer into matching on-line prices. They don't make the same profit off me as others, but at least I am still making them a little money, and I don't have to pay shipping and wait the extra couple of days for the parts. The down side is I do have to pay sales tax, but at least that money is going into state and local government coffers instead of the pockets of UPS. It may be worth asking your local dealer(s) to price match for convenience sake.
    Excellent advice Ted!
    No I didn't try a torch to remove the nuts on the control links, does this work?
    The control link connects to the stabilizer bar with a joint similar to a tie-rod end. I was able to break and turn one nut but then it just spun inside the tie-rod end and thus wouldn't come off the end of the bolt. There wasn't any flat edge on the inside of the tie-rod to grab with a wrench without destroying the rubber boot. So I just cut the control link.
    Ideas?
    are particularly useful when taking the calipers off the wheel assembly (when replacing rotors). The caliper bolts are usually glued with locktite, and although you can take an impact wrench to them, you'll probably break them. The heat melts the glue, or for rusted things, the two parts expand/anneal differently. I worked on one of the bolts of my wife's 626 for 2 hours, until my neighbor took pitty on me and showed me this trick with the torch...
    G.
  • frank138frank138 Member Posts: 4
    I have mazda protege LX 92 auto with 90k on it. It runs strong. Now it has a problem starting up. Sometimes in the morning, she cranks, but can not start. She ka, ka..., struggles, but fails to start. But after a while, or after a day or so, she is back to normal. I have heard some guys suggested pushing the gas when starting. Any clues, is it indicating I need to do starter or even distributor problem.
    Thanks in advance.
    Frank
    As long as the heat will not destroy rubber ore plastic parts nearby, it is a useful way to loosen seized parts. I don't need it as much now that I live in Oregon, but my vehicles in salt using Pennsylvania needed heat to remove almost all nuts exposed to road spray.
    It is possible that getting red hot could weaken the metal, but it usually doesn't take that much. as irishalchemist notes, it's differential expantion that breaks threads loose.
  • altair4altair4 Member Posts: 1,469
    One thing to check is the condition of your ignition wires. I had a 92 LX (got rid of it at 160K, but it's still on the road at 167K today) and I had to replace the wires and other ignition parts around your mileage. The insulation starts to deteriorate and the car won't start (or starts poorly) especially in the morning (when it's more damp). Pay attention to when the problem occurs - if it's there or worse on damp mornings or rainy days, I'd pop for new wires, distributor cap, rotor and plugs. Just my $0.02. YMMV.
    I discussed with a few people before regarding engine braking by turning off the overdrive button before a stop or slowing down, but the answers were a mix.
    Is it really a bad idea in doing so?
    Ask yourself, what's more expensive in the long run?
    New brake pads every so often, or a new transmission less frequently?
    I'd opt for the pads once in a while in favor of the wear placed on the tranny by lurching it into third all the time.
    Meade
    I'd switch overdrive off while on a long downhill, and if I were already in 3rd gear or lower (if in O/D, brake until you shift into 3rd). I might even shift down to 2nd if the slope is steep and long enough. Brakes don't work as well if they get too hot, especially the organic ones (I think stock are part organic and part metallic). The fumes given off get between the pads and rotors, reducing friction between them and also possibly causing bubbles to form in your brake fluid (they'd have to get really hot for that).
    But I would use the brakes for everyday stops.
    ...by downshifting or using the O/D lockout is mentioned as perfectly acceptable in the owner's manual (look at the section covering the transmission). Living in a hilly part of the country, I frequently engine brake on long, steep descents (there's one hill here that just scares the bejeebers out of people from the midwest - I use first gear on that one).
    Ancedotally, I have maintained this driving style on a Mazda Protege and it has gone 167,000 miles without any transmission problems. None.
    I've done the same on a Ford F-250 (currently showing 140k) and I had to have the pan gasket replaced (it's a '89 and it frequently sits a long time). The mechanic told me the inside of the transmission was very clean and required no other service than the pan gasket.
    Used the same technique on an 1983 Plymouth Horizon and it went 150,000 miles (before the body just got too bad for state inspection), with no transmission issues.
    While your experience may be different, the manual clearly states that engine braking is acceptable. My experience has been good and I'll continue to do so. YMMV.
    The way the guy worded the question, it appeared he was asking about doing this every time he slowed down. I also use my engine for braking on steep grades (I have a five-speed), but I don't routinely downshift every time I approach a stop sign. I'll typically let the engine brake the car until the car's going the minimum speed for the gear it's in (i.e., say, 45 for 5th, 30 for 4th, etc.), and then use only the brakes once I take it out of that gear.
    And even doing that, I've now got 58,000 miles on the original brakes on my 2000 ES.
    Meade
  • feather01feather01 Member Posts: 3
    Hi everyone -
    We have a 2002 Protege ES which we bought new - has 14K miles on it now.
    For the past couple of months it has been "bucking" when you attempt to start driving from a complete stop. This only happens in 1st gear. I've been driving standards all my life and haven't had this happen since my first time learning at 16! To get it going when this happens, you almost have to floor it.
    Also, when you initially start the car after it's been sitting for a little bit (hour or more), it is VERY loud, seems to rev for a while. It's also much louder in general than when I got it.
    Of course it's still under warranty so I brought it to the dealer I got it from, and they have told me there is "absolutely nothing wrong with the car". Has anyone else had this happen? I'm very close to losing money and trading it in for something better.
    Kerry
    Is it a manual or an automatic?
    Meade
    I misread doublesix's message...I don't downshift for every stop sign or light either.
    it's a manual. . . thanks.
  • kaiserheadkaiserhead Member Posts: 166
    I have a 2000 1.6L manual transmission, and every so often its a little temperamental starting from 1st. I've just assumed it was the hot, humid Florida air, I just rev it a little more to compensate. It could just be a strange characteristic of the Protege.
    Well, I can't speak to the "loud" issue, but as as far as the bucking goes, this is something that both my '92 and '00 manuals have done all the time, and I've been told is normal -- until now. Mazda seems to have developed some kind of revised pressure plate and bearing to combat this, and there's a TSB (Technical Service Bulletin) that has recently been written about it. I'd say take it back to your dealer and press the issue since the car's so new.
    FYI, My 2000 ES has 57,000 miles on it and I've already talked to my dealer -- they're not as likely to do anything about it since the car's no longer under the factory warranty. You might have a case. But just to let you know, the '92 Protege I bought new back then did it for all 83,000 miles I owned the car -- just an "idiosyncracy" I got used to. The slipping would occur only on wet mornings and only when I first started out, then everything would be fine. My 2000 has been doing it also since day one. So I don't think the clutch is being hurt by this little quirk. And after a while you learn how to treat the clutch to minimize the effect when you first take off. My mechanically inclined friend who also just happens to be a mechanic at my Mazda dealership (nice, huh?) still says it's not much more than a quirk and not to worry about it --
    Meade
    They bought out most of the Firestone/Bridgestone stores in VA back in 1997 and wouldn't honor road hazard warranties for tire purchased in the same store before it was bought out. People are so stupid. I can think of no way better to assure I won't be back to buy my next set of tires there. I like to stick to independent, local shops. At least that way I know where I stand. I suppose it would be different if I purchased Goodyears, or other mainstream brands.
  • latinladylatinlady Member Posts: 1
    I bought a new 2002 LS Aut. Does anyone wishes to tell me what good things to expect, or troublesome areas to be attentive of? I've had such bad luck with all my cars ...
    Thanks a lot.
    I think you should expect a relatively toruble free experience with your Protege. The key is to follow the maintenance schedule. Other than that, be sure to have fun driving it!
  • toddsailscatstoddsailscats Member Posts: 1
    I noticed two electeic fans on the radiator, but only one was on! Are these set to progressively some on as the temp increases? The engine was running so hot, hot day, A/C on, etc. It never seemed to get this hot before. NO blown fuses, the fan turns freely by hand, but both don't come on together. Anyone know about this, TIA for any help.
    Also, what type on coolant should go in a coolant change, being an all aluminum block?
    First, the coolant: 50/50 Prestone (the green stuff) and water. Use distilled water: Tap water will make calcium carbonate deposits in your block - bad . Make sure that you fill the radiator (with the car COLD!!!) through the radiator cap slowly to avoid trapping air bubbles, and then make sure that the reservoir is in the FULL mark (again, when the engine is COLD).
    As for the fans, they should both run. One is for the A/C, one for cooling the engine. If the engine is overheating (the temperature needle past the middle of the range - it usually sits just below half in mine), then the fan should definitely be on. The A/C fan will go on and off, depending on the temperature inside the cabin (I may be wrong about this, the fan may stay on and the compressor disengage...). In any case, if cold air is coming out of the vents and the engine is on the hot side, both fans should be one.
    It is relatively easy to check if the fans are kaput or the relays that turn them on are kaput. Simply unplug the fan from the harness and connect a battery to it (note the polarity when you do this, and ask for help if you are not comfortable doing it...). If the fan works fine, it should turn. If they do, and you still don't see them both coming on, your relays may be bad (many other things may be bad, but that is the first thing after the fan...).
    One more thing: Check the blades on the fan (do not even put the key in the ignition to do this if you'd like to have all your 10 fingers afterwards!). I had a cracked blade in the fan of my old GLC and would not cool worth crap.
    Hope this helps,
    G.
    Both keyless entry remotes for my 2003 Protege5 have stopped working. Since both have ceased to function, it leads me to believe that the problem is on the receiver side, not the remote transmitter side. I have no doubt this is somehow related to the dealer's less than stellar installation skill when putting in the auto-dimming mirror with compass. They reinstalled that recently. The problem is we are almost 4000 miles from the next oil change, so I guess we will have to make a another special trip to get it fixed.
    It took the service advisor all of 5 seconds to fix the keyless entry problems I was having. Essentially, the remotes got out of sync with the receiver. He claimed it was pretty rare. I'm just happy I didn't have to leave the car.
    After 4 years of living with this problem on my 99 ES, it is finally fixed.
    The problem: Engine jolts/jerks when A/C compressor is engaged.
    The cause: Leaky intake manifold gasket
    Solution: Replaced Gasket.
    It took 4 years for Mazda to figure out this!!!!!
    Jerry Standefer, u listening? Get your car checked.
    That guy is loooong gone. Sold his soul and the rights to his car to Racing Beat or some like outfit over a year ago. Last I heard his 99 Protege was converted into a turbo-charged monster truck. :-)))
    -old head
