Visitor Agreement.
I have a 95 Mazda Protege (Automatic),which has driven 103K miles. I bought this car around 10 days ago. Recently, a yellow LED in the car has started glowing, on checking it in the "Mazda Manual", they say that " Electrical Circuitry problem". I was wondering if any of you guys have faced such a problem before.
Any help/suggestion in this matter is highly appreciated.
I'm not too car savvy, but I did install new speakers about a year ago so I know how to get inside the inner door panel. I took a look and reseated the wires into the bottom of the switch panel, but unfortunately it wasn't that simple of a fix. All the other windows work
So possible causes? Bad switch, bad relay, or busted motor? The MOST IMPORTANT thing in the short term: is there an easy way to manually "roll it up"? If the motor has failed, can a motor from a rear window be swapped in for the driver side window?
Modern Automotive Technology / James E. Duffy. Tinley Park, IL : Goodheart-Willcox, c1998. p.679
p.s. this is a wonderful book for getting to know your vehicle; the current edition is available from your local bookseller or check your local public library
pete
1. Open driver's door
2. Turn the key to on position (not ACC, but ON)
3. Turn the key off and REMOVE it.
4. Repeat the last 2 steps two times removing the key each time. Keep the key out.
5. Press the light switch in the door (that turns the light off when the door closes) three times.
6. There should be a chime similar to when your seatbelt is not fastened. (Mine did not chime but the door locks went down)
7. Press the lock button on your remote two times
did you get a response for your 95 mazda protege vibration post. I too have a 95 mazda protege and it goes the same thing. At idle it runs fine but when in park and stopped (waiting on a light to turn green) it vibrates quite a lot. Temporaroy fix is to put it in neutral but I want a permanent fix. Please let me know if you have found a fix for the problem as I am barely starting to look into it. Bought this car used a month ago.
O Alanis
Hope this has been helpful to someone.
Good Forum,
RDL
Considering there is about a million parts he said it would just be easier to take everything off and put in a whole new system. Problem is I really dont know what everything grouped together is called, or what I am even searching for..:sick: I am completly utterly lost. Any help is appreciated, thanks in advance.
Very much the same thing.. Change the belt, squeal, tighten, squeal, bust, replace, tighten, squeal.. replace alternator... repeat. I paid to have the waterpump and timing belt replaced... it was a nightmare, but I am beginning to wonder about the waterpump. and the shimming..
Please advise if your waterpump shimming method works
Taking it to the dealer next week. But would like to have an idea what to expect.
Thanks for any ideas.
Last year when I had my winter tires installed I heard exactly this type of cracking and creaking. It was coming from my plastic wheel covers which were being pinched by the tires during turns especially. A little grease on the wheel cover contact points and presto no creaking noises!
Suggestion: try to isolate the problem, is it all the wheels or just on one side or just one wheel? Check if there is anything visible obstructing the free movement of the wheels. You can then describe specific symptoms to the service advisor
I'd like to clean mine. I get the P0402 message about every 3K miles (it takes quite a while for it to turn back on after getting work done or disconn battery, but it eventually does). I just want to get the whole engine cleaned up as well (it's my wife's and its filthy)!
Sounds like a wheel alignment may be needed. Also, check the state of the tires and look to see if they all match (same size).
When you bought the car did you get it inspected at an independent garage? If not, it may still be a good idea for your peace of mind.
Rich
Hope this helps.
The muffler flange was too rusted out for repairs. A bad design, in my opinion. The new Bosal muffler I installed was easy to do and works well and should last longer due to a better flange.
Joe
Recently I checked pulley alignment with a steel ruler-there is enough space on the outer edge of the inner crankshaft pulley to position the ruler on two points at its edge. It indicated the the waterpump pulley was about1/16 inch off-center (towards the engine block). Similarly, the alternator-crankshaft pulley alignment checked out OK. I used steel 1/4 inch (ID) washers on the inside surface- it is easiest to "glue" them in place with a little silicone RTV. I also changed the bolts to slightly longer ones (6 mm stainless steel from Lowes- I just love stainless) but be careful that they don't foul on the water pump housing. I also added spring lock washers on the outside surface.
Did it work? It seems to. The alternator pulley doesn't get hot after only a few minutes-there isn't a recollection of the fine rubber powder-and the has been no squeal. Only time will tell for sure.
Only additional suggestion would be to make a real shim. As it stands the waterpump pulley is not mating with the water pump shaft mating surface. Rather, it is elevated the thickness of the washers. I think it would be better to make l large shim with a center hole and three mounting holes- you could use the pulley itself as a template. I was thinking of using either copper or aluminum sheet but the Lowes didn't have any. I'm sure I've seen such material in an ACE hardware but there aren't any near where I live.
Hope that this has been helpful.
RDL
RDL
I have a 1999 Mazda Protege LX I recently purchased. I have since noticed that the two rear door panels have become seperated from the door itself at the top right where the window glass comes up. It looks like the panels have warped somewhat over time and popped up. When I took it in to the dealer recently for service, I showed them the problem. They said that they have seen it before. The cost to replace both door panels is about $600 canadian! It looks to me like a factory defect. Has anyone else out there noticed this in their cars? Thanks.
Does it affect the movement of the window glass or the opening and closing of the doors? Are the door seals still in good shape? Have you had the car out during a rainy day to see if there is any leakage?
Since you bought it second hand, it sounds likely that you would be paying for the repair/adjustment unless you have some kind of warranty from the dealership from whom you bought the car.
I hope to get many good years out to this car. It has 64k miles on it and runs ok.
Wow, that's an average of about 10k miles per year!
My door panels are the same. Thought it was in a wreck
I would love to see a digital picture of this.
My brother has a 1998 Mazda Protege, and he also has the same problem.
Anyone else?
Meade
i am really in a fix here. I have 96' protegeLX, automatic, bought 3 months back, has 108K miles on it.
It was running fine, now the tacho keeps dipping and going back up again whenever the car is braked in gear (say on a stop light) The engine tends to stall but has not done as of yet. This does not happen when stick is in neutral or in parking position. Also, running the A/C worsens the situation.
otherwise the car is absolutely doing fine.
My mechanic has no clue & keeps suggesting everything under the sun, so i am totally confused. The timing belt has not been ever changed on the car; could that be the reason??
please help!
