Do you mean the motor is running but the car does not move? If it does move, I suggest you head to your local mechanic. On the other hand, it's almost 17 years old so it may be time ...
The first thing I'd do is run a compression test. Blown head gasket and/or warped head is a good possibility. You can also look for sign of coolant from the tailpipe, oil in the coolant, or bubbles/churning in the radiator when the engine is cranked.
If the engine got really hot it could have damaged sensors and/or sensor cables. I've seen the crank position sensor cable melted by an overheated engine.
I recently replaced a blown head gasket on a mazda that overheated. Don't be fooled by thinking a head gasket is only $60. The repair cost me about $600, and I did all the labor myself. Overheating can do a lot of damage. I had to replace the radiator, the crank position sensor, top end gasket set, and head bolts. With the engine apart it made sense to replace the timing belt, water pump, both serpentine belts, and radiator hoses.
The guys at clubprotege.com and themazdaforum.com can be helpful. You'll need to provide good information, not just say "please help". Like, how do you know the head isn't cracked? What exactly happened? Have you done any tests? Do you have the mechanical skills to troubleshoot and repair? Don't be offended, but folks will respond better to good solid information than desperate pleas.
any thoughts ? thanks
I have a 97 mazda protege and recently i started having issues where the idle is very high. started with 1500 rpms and now its at 3000. Just wondering if anyone else had the same issue with this car and how did it get resolved.
- The ECU is receiving a bad input, or
- The ECU is unable to control something it needs to control
Common problems with inputs
- The Mass Air Flow sensor carefully measures the amount of air flowing into your engine and provides that information to the ECU. The ECU then meters the appropriate amount of fuel to the engine. Two issues can occur leading to incorrect MAF signal to the ECU
-- Dirty MAF. A thin wire inside the sensor sometimes gets dirty. It can be cleaned by spraying brake cleaner or electrical cleaner on the wire. Don't touch the wire with anything (not even a q-tip) or you'll break it.
-- Vacuum leak. A vacuum leak lets excess air into the intake that the ECU doesn't know about. Any vacuum leak will do it, but particularly inspect the large accordion-like pipe between the air cleaner and the engine intake. Cracks sometimes develop in the grooves, and cause air leaks.
- Bad coolant temperature signal. If the coolant temperature signal is wrong, the ECU will incorrectly adjust for temperature. I don't have any diagnostics for this.
On the output side
- Sticky Idle Air Control Valve. Can be removed and cleaned.
- Sticky EGR Valve. Can be removed and cleaned.
There are other possible causes, but these are common.
Checking for leaks can be done easily; the others (MAF, Idle Air Control valve, EGR valve) might involve some skill.
How's the level in the overflow tank?
I'd wait for the car to be dead cold, like overnight, then check the level in the radiator. A pinhole leak will eventually lower coolant level - and usually will grow.
If the coolant isn't going down, you could either wait to see if the leak grows, or take it to a shop to have them try to find it.
2001 Mazda Protege
Interesting. I guess Mazda changed this in 2002 because my Protege has separate bulbs for high & low beam.
I would like to replace the belt as a starting place. If anyone could give me detailed instructions as to how to replace this belt, I would greatly appreciate it.
James
Anyone have any experience w/ P5 clutch replacement:
OEM vs. aftermarket?
prices?
helpful hints?
O15
As for procedure, I'd recommend that you get a Chilton's Import Repair Manual or a subscription to www.alldatadiy.com, so that you'll know how to do the job step by step.
It's important to be thorough, for a successful clutch job. So you want to do pressure plate, clutch disk, throwout bearing and pilot bearing, and a close inspection of the flywheel face for cracking, burning, grooves, etc. If the flywheel doesn't look so good, mark its position and remove it for machining or replacment. Also consider flushing your clutch hydraulic system.
Be sure to work safely.
Thanks for the info. I'll probably go w/ Mazda, but it looks like I should do the entire kit. Not sure yet if I'll have Dealer or Trans shop do it.
As per flushing, Is the clutch hydraulic system part of the brake system, a seperate bleed line, or entire seperate system?
Thanks. O15
I believe the alternator is another item that you may want to have checked while "they" are there. If it's in good shape, then no worry. If not, it may be worth considering for replacement before it fails (and knocks out a battery or two).
whoever "fixed" your car, guessed wrong.
I had a transmission flush and fluid change at the dealer, but it didn't help with this problem. Any suggestions are appreciated.
Thanks, Abner33
Do you think the weather may have anything to do with the hesitation? Some garages can get quite cold overnight and cars react to cold weather. You may want to give it a few more seconds to warm up to see if this helps.
I have been experiencing this problem for about a month now. During that time we have had very warm summer type weather and even though we are having lower than normal temps now, it hasn't been below 50 degrees F.
Abner33
Sounds like your car needs a diagnostic rather than parts replacement.
Yech, this is starting to sound like the head and maybe even the transmission may be involved. You have mentioned visiting a dealer to discuss the problem. Did they mention anything other than the O2 sensor as the possible cause?
I was wondering if this is a common issue to have a switch fail, or possibly something like a relay in the system that is gone. Looking for somewhere to start to fix the issue as winter is fast approaching.
Thanks in advance.
I have a 2002 Protege5 Hatch, with 5spd tranny.
I am having intermittent grinding issues when going into 2nd, 3rd and reverse. I might suspect that is COULD be something as simple as a clutch adjustent, but then again I don't know if they're self adjusting or not.
Seeing as it's intermittent, I wouldn't suspect that the tranny (synchro's) would be bad...???
So looking for feedback. Clutch adjustment of synchro's??
The car has 90K miles (140K KM roughly).
Thanks in advance.
1999 Mazda Protege 4 cyl Front Wheel Drive Automatic 13,333 miles
2009 i bought a car that was sitting for 3 years (DX 1.6 liter). The tires had flat spots: replaced/resolved.
I added a couple ounces of Redline Water Dispersant to the Fuel Tank; replaced Timing Belt and Seal; aligned wheels. Added half a tank of High Test when tank was half full and running rough.
Now I've got a Check Engine Light and an Intermittent Rattle like radio static (The 'stripper' base DX came without a radio or clock) at Idle in Center of Dash! Your thoughts?
Would Disconnecting the Battery Clear the Code and maybe let it learn to like real gasoline; establish new Parameters? What should a poor man do about these problems? Should I buy a Diagnostic Device? Which one?
The Dash problem noise? it stopped for a minute after i slapped the Dash ...
Thank you, Scott.
Did you get a diagnostic done? The codes may help narrow down the problem.
