Visitor Agreement.
but for $2000 more also, I could have gotten a better car than the GTI with more space.. but to each their own...
Quiz:
VW Claim: Jetta is an entry level mid-size car.
How does VW prove it?
Ans: By putting 3 headrests in the back seat!!!!
From my copy of the Consumer Reports: "2001 Annual Auto Issue"
Volkswagen Jetta- "Front seats are comfortable and supportive, but the rear seat is cramped. Reliability has deteriorated from average last year to below average now, so we no longer recommend the Jetta." CR April 2001
Mazda Protege- "The Protege is one of our top-rated small sedans. Interior room is spacious for a small sedan and includes a fairly comfortable rear seat. Overall, the Protege is a solid, refined car, with excellent reliability."
Mdriver,your statements reflecting your point of view are open to discussion, as you have done nothing to support your position. Sam, your observations might hold water in the Honda Civic topic, however we know better here.
Respectfully,
Larry
I am new here to post, although I have been reading the forum for quite some time.
I have a 96 Pro LX 5 speed with 100K miles. Got it used at 72K miles. It has been a good car. However, recently, I have been getting an annoying whistling sound coming somewhere from the front right wheel (at least I think so). The sound can be heard only when it is above 75 degrees around and only after the car has been driven for at least 5 miles.The whistle seems to be most audible at low speeds, although after a while, it shows up at hihgway speeds as well. Since it takes some time for it to develop, it is not very easy to demonstrate it to mechanics. I have done it twice, though. The first one said that it was a noise from the transmission (although it does not seem to depend in which gear the car is (ant it certainly comes from the passenger side), and another one said that the first one was #$#$#$. But still, he did not find anything wrong. Personally, I suspect a wheel bearing as the right one gets warmer than the left one, indeed. I had the wheel bearing checked by the "second" mechanic and he, again, did not find anything wrong. There are no clicks or anything while turning, though.
A Mazda dealer told me, however, that the previous owner of the car had one of the front wheel bearings repacked under warranty (they do not know which one, though).
The brakes are fine, by the way. I had front brakes done recently as a part of maintenance - it did not change anything in terms of the noise.
My question is should I suspect the wheel bearing as the potential culprit or there could be other components as well.
And also, can a wheel bearing be failing without showing up the "classic" sympthoms like clicking etc?
BTW, I have driven the car for around 15K miles with the whistle, including a 400 mile trip to Canada non-stop, so I guess, it is not going to fail tomorrow because the noise is not getting any worse. It is just there. Another option I have is to crank up the radio and wait for the winter...
I did some quick soul-searching and decided I was letting my emotions get me all interested in this pickup that I didn't need. I wound up with a 2000 Protege ES for $15K and $284/mo.
So what would I buy with $21K? NOTHING! I've had such good fun in 23,000 miles, I'd buy the $15K Protege again and POCKET SIX GRAND!!!
Meade
Steve
I have read through the previous 475 postings but can't find a similar problem.
Any ideas guys?
Thanks in advance for any input,
-Terry
-Terry
can someone tell me what type of pads these are. thanks.
road surface at a slow speed from 5 mph to 10 mph - No noise at all at higher speed. My ears hear the noise coming from the front
driver side strut but I may be wrong. I am going to take it to the dealer this Monday.
However I would appreciate if any one else had similar situation and would like to tell me what was the problem and how it could have happened and how much it cost to get it fixed.
Will wait for response.
I bought a set of new tires for my 1999 Mazda Protege ES quite a few months ago. They are Nokian Brand (an off-brand), low profile DIRECTIONAL tires.
At first, the tires were great in all aspects. However, over the past few months, the tires have become VERY noisy. The noise now sounds like our Mazda is wearing off-road tires (loud grinding sound). I checked to be sure the tires were installed in the proper direction (since they are directional tires), but that was OK. I had the tires rotated front to rear and balanced, but there was no reduction in noise level.
Also, I did notice some strange looking swirl marks on the sidewalls of a couple of the tires, near the tread, but don't know if this means anything.
Does anyone have any idea why this has happened? Is there a chance one or more belts inside the tire structure have failed?
Please help. The noise level is becoming atrocious.
It looks like we may have to deal with the sound until we can replace them again. I'm leaning toward the Yokohama Avid T-4, as my wife mainly drives the Protege now and I can't see her getting too concerned with tires with a lower speed rating. Plus they are pretty inexpensive.
I know the pains of shopping for tires for the Protege ES. The 195/55R15 size limits you to performance tires of the high-price nature. That's why I switched to 205/50R15. The diameter of this size is nearly identical and doesn't require a speedometer calibration. You get a slightly lower profile and wider tread width for better response and traction. Plus, this tire size is much more common and cheaper.
I've looked around at a few websites for some tires that look good. Where are you located? If it snows in your area, do you have seperate snow tires? If you don't get snow in your area, or if you have dedicated snow tires, I would recommend the Continental Sport Contact CV90. It's a performance tire that has good wet and dry traction, quiet ride, comfortable ride, and a long tread life. From the Tire Rack, they cost $62 each.
We get little snow here (Nashville, TN area), so I never need snow tires. Thanks for the tip on the Continental (although I owned one set of Continentals that developed sidewall bubbles, so I am a bit leery of using them again).
Thanks again!
http://pw1.netcom.com/~sgalaba/tiresize.htm#ustires for speedometer change
or here for graphical overlay of the tire.
http://www.miata.net/garage/tirecalc.html
and for chikoo... you can go to http://www.discounttire.com/ and they will tell you what the various sizes (including Plus+ sizing) will fit. then you can input them into the previous speedometer links about to get new speeds and sizes in relation to OE.
195/55R15
65mph indicated = 65mph actual (0.0%)
205/50R15
65mph indicated = 63.96mph actual (-1.6%)
205/55R15
65mph indicated = 66.2mph actual (+1.85%)
215/50R15
65mph indicated = 65.52 mph actual (+0.8%)
Respectfully,
Larry
Thanks again!
great info.
I read somewhere that upto 1.5% error on speedo is allowable.
So I guess +0.3% on allowable should be fine?
BTW would 215 width wheels fit in the wheel well?
If YES, I am game!!
Do you have any info on pricing, performance in dry/wet and light snow on TOYO PROXES T-1S?
There is a size which we can use:
205/55VR15 with UTQG 280AA A.
On changing tire sizes: remenber to consider tire-well interference. I'd worry about putting a 215/ on the pro, even if the height is the same as stock. the added width could cause a problem.
Has anyone tried the Kuomo's?
Sure, turn the radio way up. :-)
I have 205/50's on my '99 ES right now and there is still plenty of clearance with the tire-well. I don't think 215's would be a problem, but I will let you all know when I change them in the next month.
Respectfully,
Larry
