Visitor Agreement.
Having your Accord checked for recalls will do nothing for your stability problem.
Soemthing sounds very wrong here and, since you seem to like driving at very high speeds I would suggest you immediatly take this car into a alignment shop or to the dealer! You could have a dangerous situation here. do NOT take it to one of the chains who only like to sell things like struts. Struts rarely go bad on Hondas.
Don't mess around with this....get the car inspected ASAP!
Is there any way to easily convert it to kilometres. I have a 2000 chev venture van and can do this with a touch of a button (back and forth between them). I realize the speedometer face will still be in both miles (large type) and kms (small type).
Again, thanks!
Mike
The previous owner is a friend, and he says the car has always done the floating thing. He doesn't drive fast, but said that if he did, he thought buying a spoiler would fix the problem. Thoughts on aftermarket spoilers, anyone?
And yes, I will be taking it into an alignment shop, to check struts and alignment. BTW, car is an EX, and says VTECH in large letters on the engine. LX in original post was an error on my part.
Mike
When you said it was an LX with a VTEC engine I was thinking that maybe the car was a cobbled up reconstructed wreck. I understand now that it's an EX.
Something just sounds VERY wrong. If they can't find a solution I would stick with the speed limit!
I would say get the shocks and sway bars checked; my car settles right away in the "bumper bounce" test.
I had a set of Bridgestone Potenza RE900 from Costco, which were pretty good and lasted 60K mile. Now I have a set of RE910, happy with them too, though I would have bought Turaza LS-T if Costco had the right size.
Want to replace plugs and wires myself (NOT a DIY person!)
Is there anything I need to look for, like Honda parts or a certain kinda of plug??
It made the job very easy to have a set of long, pointy nose pliers, for like $10.
The plug hole is narrow and deep.
GET IT FIXED NOW!..........Richard
This description I found somewhere helped me to pinpoint what was causing the car to stay out of lock-up, maybe it will help you as well:
I had the same problem with my 91, changing the thermostat fixed it. (No lockup in 4th)
Besides the speed sensing indicator, a converter may not lockup for any of the following reasons:
1. Engine temperature too cold - most converters will not lockup until the coolant reaches about 120°F.
2. Overdrive unit locked out - when an automatic overdrive is "locked-out" the torque converter lockup feature will also be locked out. Overdrive lockout would normally only be used when pulling heavy loads, thus the converter is logically "locked out."
3. Under low engine vacuum, heavy part-throttle acceleration is an additional power demand which could result in the engine lugging. To prevent engine lugging, which could result in serious engine damage, a sensor determines if low manifold vacuum exists.
Typical lockup converters connect these sensors in a series creating a "string" arrangement. That is, if one sensor gives a "no" signal then the converter will not lockup.
As I said before, mine would never engage lock-up in fourth which made it a bit more likely for me that a new thermostat would fix the problem. Sounds like your problem is more intermittent and quite possibly due to an erratic speed sensor, or something other than a tstat. But, it's a cheap item and they do crap out after a while so it's not a bad idea to change that thermostat anyway.
I'll have to look at my service manual to see how to troubleshoot the speed sensor....I'll post some info after I come back home for you. I can say that I got it pretty cheaply and the replacement was quite simple, so if you for some reason cannot test it...swapping it out is very feasible to do with minimal cost/effort.
Good luck, it's nice being about to get 30mpg again.
Since your tach is not working, there may be a wire loose somewhere. It will probably take a skilled mechanic to figure out which wire it is.
terfoster: not sure about your particular model, but the 90-93s (and presumably later models) were prone to speed sensors failing, which would give you a dropping tach usually accompanied by a falling MPH/KPH indicator. Just a thought, they may have changed things in your car's year anyway. Good luck to you as well.
I just want to know if having the tach drop to zero will give me other problems, or can I keep driving my accord without any side effects? Will the car stall out? If I don't have to spend any more $$$ that would be great - but, it's kinda disconcerting having the tach drop when you're cruising at around 85 mph.
Anyway, from what I remember reading nothing bad is going to happen to your car just because your tach is kaput. It seems to be pretty much just a convenience in the cockpit. Even with both the speedometer and tach malfunctioning my car drove perfectly fine. However, I guess if the cause of your tach problem is something very different than mine, then THAT could possibly cause you other difficulties. (ex. a totally shot speed sensor may cause lock-up problems and/or other shifting inconsistencies) So basically, YMMV i guess.
My links won't help much with your '97 I don't think, but you should attempt to retrieve any error codes stored in the computer. Often there are error codes but you will never see an idiot light of any kind. This could also help to narrow down your search if there is/are a code/codes.
i was getting was high gear , it would go in low range manualy an i was able to get going then manualy shift it to high , my research tells me this problem is a
transmission computer, what throughs me is that the same day the S light went out an its shifting perfect thats been about 2 weeks ago an about 150 miles , question? does this sound like trans computer ? going on vacation in about 2
weeks I hate to spend $260.00 for rebuilt computer an misdiagnosis the problem
an still have a problem.
I would not shell out $260 for a rebuilt computer. You can easily get a TCU at a reputable salvage yard for much less than that....and any decent yard will have at least a 30 day return policy. I got mine for about $40 and it has served me well for the last 2 years. Either that or you can send your TCU away in the mail for less than $260, but of course you will be a week or more without any TCU in the meanwhile.
thanks!
Your timing belt is overdue, but even then all the things you listed as needing to be done are just wear items. For all intents and purposes your car is in perfect condition. Why not keep it and drive happy knowing that the bank will not be grabbing car payments from you anytime soon? Considering all the Accords on the road with 200K+ miles on them that are still going strong I don't think you have a timebomb on your hands at all. Plus you have the peace of mind of already knowing all the idiosyncracies of your particular vehicle. A new car may mean trouble free maintenance, but then again there are many people on here with nagging rattles, squeaks, and other small complaints that can make a new car purchase a sordid affiar simply because they ended up with a vehicle "with character".
(Having said that, I'm sure a new Accord would doubtlessly prove just as reliable and trouble-free as yours has been over the years. But I am a big believer in sticking it out with what you have, especially if you know the history of the car to be relatively positive.)
Either way, Happy motoring.
I would test the check valve first before replacing the MC or the booster.
Disconnect the check valve hose at the booster end and the hose at the manifold end. Blow on one end of the hose, then the other. If you can blow through the booster end, but not the manifold end, the check valve is OK. Then I think it's the MC.
No, I haven't tested/replaced my check valve yet. The pedal hasn't gone to the floor lately.
Next time if the pedal sinks to the floor at the stop light, pull up the hand brake and pump the pedal. And if you have to do this for every trip, it's time to replace the MC.
At 128K I think you're better off with new drive shafts. If you don't mind using non-OEM parts, NTB can replace the drive shafts for much less and the part is lifetime warranty. I have them on my 89LXi.
Don't forget to flush the radiator & tranny fluid. It will keep your car running cool and smooth.
Anyway, turning to page 23-110 of the service manual we have "Speed Sensor Input test". This allows for determining if the VSS (vehicle speed sensor) needs to be replaced by testing the input side terminals coming from the engine.
I have no idea how to describe where the VSS is if you already don't know. I can say that you should be leaning over the passenger side of the engine compartment and looking down towards the center of the engine bay. The VSS is held in with 2 mounting bolts and the easiest way to find it is to follow the transmission up to the engine bay, since the sensor is mounted there. I wish I had a scanner handy.
Here's the sequence of events in the service manual:
Note: Check the #1 (10A) fuse in the dash fuse box for proper operation.
1) Disconnect the 3P connector from the VSS. (It's the main plastic connector responsible for linking the VSS to the input side. All testing will be done with the connector that is NOT tethered to the VSS, so you can leave the VSS side of the connector on the side somewhere out of the way).
(taking the connector in your hand, if you orient it so that you have the snap-clip on top and are looking at the terminals inside the connector then from right to left the terminals are ORANGE-YELLOW-BLACK)
2) Check for continuity between BLACK and body ground.
There should be continuity, if NOT then check for either an open in the BLACK wire OR poor ground.
If there IS continuity then go to step 3
3) Check for voltage between YELLOW and body ground with the ignition switch on.
There should be voltage, if NOT then check for an open in the YELLOW wire.
If there IS battery voltage then go to step 4
4) Check for voltage between ORANGE and body ground with the ignition switch on.
There should be approx. 5V, if there is none check for: defective gauge assembly OR an open in the ORANGE wire.
If there IS approx 5V go to step 5
5) If all continuity and voltage tests are normal, but the speedometer and the odo/trip meter do not operate, replace the speed sensor.
If you do end up changing the VSS, make sure you do not lose the little pin (the joint shaft) that is inside when you disconnect the old one/reconnect the new one. They are easy to lose since they are small.
Also, from the troubleshooter in the service manual the possibilities are:
Blown #1 (10A) Fuse
NS speedometer circuit (built into the main print panel)
Main print panel (attached behind the gauge cluster)
Bad speedometer/tach/odo/tripmeter (replace main print panel + speedo + tach +trip/odometer as a set)
Faulty or incorrectly installed speed sensor
Bad ground
Open circuit in wires or loose or disconnected terminals.
Hope all that helps somewhat.
If you have been good about changing oil etc, it's well worth fixing.
Your CV joints are bad if they are clicking. These didn't have to go bad. If someone had spotted the torn boots early they could have just replaced those alone and not the entire joint.
Sounds like just a lot of deferred maintenance has caught up with you.
If you sell it or trade it, the cost of repairs will be deducted from it's value so you might as well get it fixed and drive it.
And a garage pointed out it the boots were starting to crack... but I didn't look untill a couple weeks later and saw that they had seperated completely. But when you add that to the timing belt, etc (and what else at 125K miles would you be doing - routinely replace all the belts and hoses? brake lines fail over time, right? statistically, an older car is more likely to have a sudden, stuck on the side of the road failure than a newer car? I just don't like the potential for that. or am I just paranoid?
I would definitely consider trading it in for a new car.
With the problems it has, I would feel bad selling it to an individual. But I would not feel bad about trading it in.
So I got another EX, a 2005...the sticker was $23,655 and I got it for $15,500 with my trade...
If you can do it financially, a new Accord is the way to go. It's so much better than the '98 and I now have the peace of mind of having a car that will go another 160k miles with mimium upkeep.
Hope this helps,
PS - and. yes, any clinking means to you need to replace the CV's.
I saw another option that seems much more practical.
I am wondering if these things actually work.
http://members.cox.net/ylosk/private/Antistatic/anti_static_strap_earth_ground.htm
If any of you have tried this type of solution please let me know it works. Thanks
I was thinking the problem was caused by the particular OEM Michelin tires that comes on these cars. You are not still running the original tires, are you? I would have thought a replacement with a different brand or model of tire would also have "fixed" this.
Dennis
If touching the metal frame before leaving the car works, then the frame of the car would have to be grounded, thus eliminating the need for the grounding strap.
The static charge built up from sliding over seats wont be corrected with the strap, you need to find means of the keeping the static from being generated in the first place, hence the fabric softener.
I work in an electronics lab, and we have used conductive heel straps that you connect your body by placing part of the strap into your shoe, and the rest wrapping around your shoe's heel, making contact to conductive floor wax.
Obviously this isn't something you would be willing to wear, but that would solve the problem.
Last time I saw one of those used, my dad was mounting one to his new 1969 Delta 88
mrbill
My observations are that the static varied with what pants or jacket I was wearing (nylon jacket or polyester content pants as I scooted on the seat getting out. Nonconduction material + friction + nonconductive material = static electricity. I don't get it as much on the leather seats in our newer car.
But the shoe I was wearing seemed to make a difference. The shoe insulates or bleeds off charge to the ground. A variation in socks could also be a factor. I generally am wearing Reebok or Rockport comfortable shoes.
The method is always to touch the metal on the car. I touch the roof trim and the door handle after I'm out. I'm not sure a grounding strap would help because if you're still charged and the car has lost its charge there's still the potential for a spark as you touch the metal of the gas nozzle if you haven't touched the car metal after getting out.
One of these would last longer that your car, most likely:
http://www.staples.com/Catalog/Browse/Sku.asp?PageType=1&Sku=432935
Dennis
The other aspect of static is that the flowing gasoline may be generating a charge as well. The metal nozzle against the metal tank/car grounded filler dissipates that charge. If someone holds the nozzle in midair, that also could cause a spark.
If they say that your REAR pads need replacement, I'd be cautious. The rear pads can outlast the front pads almost two to one. That's because when you brake, the vehicle's weight shifts forward, making the front pads wear more quickly. Get another opinion.
wear out first.
