A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Your dealer probably charges you $55 for OEM pads + 1/2 hr labor.
It's about right for Honda service.
That's strange. I didn't use a micrometer to check, but a brand new set of original equipment Honda Accord pads look and feel exactly the same thickness - front and rear. How did you determine that the rears are thinner?
Does the emergency brake work off the rear pads, or do they use a seperate drum on the rotors?
mrbill
I had to replace the rear pads on my 99 V-6 Coupe at 45,000 miles. The original fronts still had almost 5MM left.
But, then, I'm not a hard driver...anymore!
Anything you can share with me abuot your experiences would be greatly appreciated.
I will test the coupe and reply back. I am concerned about rear view visibility. any thoughts???
Horsepower has been growing over the years, and the more people have the more they want. You really need to try it yourself and see if you like it. The 4 cyl currently has 160 hp. When I campare that to my second car, a1975 Mustang with a rare 302 V8 and a whopping 122 hp, it really goes.
Mrbill
I drove an '85 Pontiac Sunbird for a few years and it really was a slug--especially with the A/C on. But there was never a problem getting up hills here because gearing was low enough with it's decent A/T.
I have the '04 Accord EX-L sedan with 4 cyl. and A/T and see no reason to have the V6 because the 4 is plenty quick both on hills and everywhere else I've been driving.
Maybe if I were carrying heavy loads I'd consider the V6, but with one or 2 passengers the 4 is more than adequate IMO...........Richard
thank you all for great input--it is sooooo helpful.
We finally narrowed it down to the seat cushion is what is sliding or moving against the seat frame. Our dealer had a new cushion ordered and had his detail shop reapply the cushion to the seat frame.
We have had the car back now for 5 days and have not felt the seat move at all. Hope this may help others out there with the same problem?
Well, I do.
You didn't say what year your Accord is or how many miles are on it.
Accords are great cars but things can and do happen to all makes and models.
Just unfortunate in your case. You might want to get another opinion and quote on this repair.
It was only that a tech from the dealership saw the cushion or bottom seat slide and not the whole seat move when my wife took him for the road test. And that was after two days of other techs driving the car and saying they couldn't feel anything wrong with it?
Also, does anyone have recommendations on a good floor jack? I'm thinking of a Craftsman 3000 lb. aluminum/steel low profile jack that lifts up to 18.5 inches, but I'm open to suggestions.
I am looking for the actual MPG anyone is getting on their V6 Accord.
I know what the window sticker says....but actual MPG is usually different.
I would appreciate any help on this.
Thanks so much in advance!!!!!
I work and live closest to Trickett, but take my S2000 to Waltrip in Franklin. The service manager there (Archie) was tons of help to me in the past and I started taking my car there for service sort of as a pay back for all the help. Service appointments including Saturday service were a big plus. With my wife's new Accord we got a coupon book for discount oil changes, etc so I will probably takes her car there as well.
I ride my Honda motorcycles to Sloan's in Murfreesboro for service as well. Didn't get them there, and there are a lot close dealers but they have always treated me well so I keep coming back.
I have not heard anything bad about Trickett and when I had a Civic Si way back when used to take it their for service. They DID have a "runner" joy ride in my car (I caught him) and he was fired - but this was years and year back.
As tntitan also mentioned, you can get an oil and filter change about any place - you don't have to go the dealer for this. I like to use OEM filters, so I have been known to order OEM filters and washers and take the car to Valvoline for the oil change. If I don't do it myself, I like to watch to make sure it gets done. Old oil and filter off, new oil and filter in. Even at the dealership you don't KNOW they did anything
If you buy from Trickett you get a discount on oil changes every time. They used to call it the "apple gang" and give you a cheap change and free apple. With Waltrip it is a coupon book. The other area dealers may offer similar deals to customers that buy from them.
Dennis
The four jacking points are the same, no matter what kind of jack you use to raise your car.
Your 4-cylinder 2004 Accord weighs less than 3,200 lbs. If we presume that 60% of the weight is on the front wheels (since that's where the engine and transmission are), the greatest weight that your jack will need to lift is no more than 960 lbs. at any one corner of your car. Therefore you can be confident purchasing any floor or bottle jack with a 1,500 lb. (¾ ton), or more, capacity. Jacks are not complicated, so you should shop by price.
Honda refuses to acknowledge this as a defect because the seat was deliberately designed in this fashion. It has been suggested, by some here, that the seats will change or soften over time. This is very unlikely. It is analogous to buying a pair of shoes. If they were uncomfortable when they were new, they will probably still be uncomfortable when they are worn out.
the above link takes you to another independent quality rating. Lacrosse is under large cars and Camcord under mid but:
886 500 (large segment average 868)
886 Maxima (large segment average 868)
883 300 (large segment average 868)
875 G6 (midsize segment average 852)
874 LaCrosse (large segment average 868)
853 Camry (midsize segment average 852)
852 Accord (midsize segment average 852)
Now all the above cars were above or at average in their segment so they are not dogs but it does show how the domestics have this quality issue behind them on the new models. These are October/November bought vehicles so they are brand new models on the domestics and older models on the transplants. The domestics scores will only go up as they fix the early quality bugs.
My two main cars have staggered tire sizes, so no rotating - but most shops will do this "Free" for you if as part of an inspection.
I have never jacked up a car to clean wheels, either.
When I autocrossed, I used a floor jack to save some of the work. I guess I don't use the jack enough now to want to fool something other than OEM.
Dennis
You may try a Costco/ Sams Club, they used to sell a jack for around $60. As with all jacks, never work under the car while it's on the jack, always use stands.
I made up a flat metal plate with a hard rubber covering. It sits just inside the circular "dish" of the jack, which allows jacking of the car (at the jack points) without worry of marring anything.
Mrbill
Thanks for the detailed explanation with regard to the seat design and the reason for it's discomfort. As I mentioned before, I'm getting use to a slightly different sitting postion, but I still notice it at times. It's too bad because I love the car - it's my 4th (87, 93, 98, 05) consecutive Accord and to be honest with you - I really didn't test drive this car before I bought it - I just sat in it for 5 minutes. I figured the others were comfortable so this one will be too. And you're right, only some people feel this support - my wife drove the car the other day (for the first time) and remarked how comfortable the seat was....So I guess this is another example of where technology sometimes gets in the way. I'll learn to live with it knowing it's a safety thing that I'm feeling....haha.
Thanks, again for the explanation.
Since you cross-posted your message here's my corresponding cross-posted reply:
Since I (and presumably millions of others) have never read of "Strategic Vision" as a recognized authority on automotive quality, I read a bit about them and their philosophy on the website that you linked in post #3312. They appear to be a marketing-oriented organization interested in "social issues and trends". They compile data (in their own words) using "an individual's personal feelings and values--safety, security, trust, freedom, control, pride, self-esteem--are at the core of the buying decision and how people evaluate products and service after they have made those decisions".
They state "More than 40,793 buyers who bought 2005 models in October and November of 2004 supplied data. “We gather comprehensive data that reflects the breadth and depth of the ownership experience, including emotions. The information is used to calculate ‘Total Quality’ indices. These integrated relationships between attributes and emotions mirror how people respond to their new vehicle. Those product and performance characteristics that deliver more desired emotions more strongly impact the perception of Total Quality.”
This does not impress me personally as being the most reliable gauge of automotive quality beyond the initial six or fewer months used as the basis of their published numbers. I'd rather see owner reports about the quality of their vehicles after they've driven them for one or more years. That is the only way to determine longer term reliability, when the excitement and emotion about a new purchase has worn off somewhat.
Here is the mileage chart for my 03 V6 LX in Seattle, Wa.
Here is the chart from data that i_h8_riceboys posted at the TOV website. He says he has an 04 V6 EX M6 in Michigan.
Charts are calculated on 5 tank running average mpg.
In Fla, expect to see a different seasonal pattern.
That's what REALLY matters!
When was the last time that you had a shop high-speed balance your wheels? You might also want to check that all of your wheel lug nuts are tighened to specification.
I hope by now you've had someone take a look at it! This isn't something to guess about or ask about on a forum. This is serious!
A tire shop should be able to inspect and tell you which is wrong. If you are "lucky" and have steel wheels, you can probably find one in a junk yard for $25 or so. If you have alloys, it may cost you $50-75 for one. If your tire is bad, the look at the tread depth of the other tires and see if you need to go ahead and buy a new pair or 4 new ones. If you only get a single tire or a pair, put the new tires on the back of the car to start.
Dennis
