Honda Accord Problems 2000-2005
1206207209211212256
  • atlantabennyatlantabenny Member Posts: 735
    Someone a while back on this or another forum fixed this problem himself after unsuccessful trips to the dealer like you and me. He found the rattle source to be a wiring harness rubbing against the riser mechanism (inside the door cavity). He taped up and secured the harness, eliminating the rattle.
    Turns out the window was just a transmitter, not the cause, of the rattle.
  • blaneblane Member Posts: 2,017
    slawenda:
    No, my 2004 Accord Coupe is totally noise-free. So, I've not had to try the silicone solution. But, it would probably work well on any vehicle that exhibits the problem at the seal-to-glass, seal-to-seal or seal-to-metal interfaces. It's an inexpensive way to isolate or eliminate seals as the culprit.
    atlantabenny makes a good point, that the source of some sounds could be transmitted from other components that are not readily visible.
  • donteydontey Member Posts: 7
    purchasing this vehicle and gave a $250.00 down payment but now I read that there is recall on some Hondas that the fuel pump loses power and entire fuse box should be replaced and read here that some are having moonroof problems (rattles), and some have tranny problems. Being Sunday, Honda recall office is closed and I have 3 business days to cancel my purchase. Does anyone know what models and trim are being recalled and should I cancel my purchase? I know I should have looked here first but went by Consumer Reports only. Thanks in advance.
  • kippikippi Member Posts: 16
    I certainly wouldn't cancel the purchase based on the fuse box recall, which effects very few cars--it is unlikely your new one would be among those recalled--and sounds like a simple fix in any case. Bear in mind that people with complaints tend to come to message boards like this one; as there are millions of Accords on the road, of course there are some problems. Same is true for every car; it's less true for Hondas and Toyotas than most other brands. On balance, the Accord remains extremely popular with its owners and retains an unusually high resale value. There are good reasons for this; Consumer Reports has the right idea. It's a very good car: I suspect your are, quite understandably, experiencing some nervousness at the prospect of committing to an expensive and important purchase. There's always a risk when buying a car, but the Accord is a very good bet.
  • guest123guest123 Member Posts: 27
    Every time I need to get something fixed is it necessary that I take the car
    to the dealership where I got it from? Or can I go to any of the Honda dealerships
    for repairs? I have better prices from dealerships that are 30 mi from my place
    vs the dealers who are within 10miles.
    I couldn't have said that better myself and coming from a non Honda salesperson you are more likely to be believed.
    Funny...if a person reads these boards enough they would probably buy a bicycle or rely on public transportation. I've never even heard of a fuse box recall. No doubt another tempest in a teapot like most recalls.
    For some reason the word "recall" strikes fear in people. The majority of recalls are trivial.
    Still, if a person is THAT scared, they probably whould buy something else.
    The sky is not falling! :)
  • dwynnedwynne Member Posts: 4,018
    I have done this my whole live, with every kind of car and never had a problem.
    True, some dealers do give their customers preferential treatment for service - normally discounts on oil changes, etc. Someone posted a while back that their local dealer said they would put them at the end of the line if they did not get the car from them. I think that is BS - I get a survey from Honda for every trip I make to the service department for any reason. I think a lot of awards and rewards depend on how folks answer that survey. As a result, they treat me like I got the car there each time I am in.
    Dennis
    # 05V132000- consequences: If fuel pump loses power while driving the engine could stall which could result in a crash; and #04V551000- a torn airbag may not offer the same level of protection, in the event thereby increasing the risk of injury to driver. Not a laughing matter, the salesman should have addressed this to me yesterday before I signed the papers for the deposit. Notices can be found on internetAutoGuide. I am now angry, these can cause injury or death, but I still know Honda and Toyota build the best cars, so I don't know what to do.
    Just about every car has recalls and service bulletins on it, just a fact of life. Heck one of my Honda motorcyles had one for a washer on the kickstand "may cause the stand to drop down causing an accident".
    Most of the serious recalls are done on the lot as soon as they come out - and the dealers know not to sell cars that have not been done. The airbag one started November of last year, the fuse box one is a little newer and started in April. My bet would be now, near the end of May - all the ones on the lots have been done.
    You can call Honda (800-999-1009) and give them the VIN of the car you put a deposit on and see if a) it is even in the recal campaign and b) if so, has it already been fixed. So you can do the same thing with the VIN and the service department.
    Why be angry? You can be "chicken little" and run around worrying what might go wrong with ANY car you choose - or just insure before you take delivery that YOUR car has gotten all the recalls done before you drive it off.
    If you can find a perfect car with no recalls that never has a problem, please share it with the rest of us - even Honda and Toyota have problems. Toyota put a new short block in my old T-100 (haul stuff to the dump) truck long after the warranty was over. Seems they had messed up in the design of the engine had a "secret" warranty on the motors. When the coolant dumped into the engine and hydro-locked it it could have "caused a crash" - but if you go look no recall was ever issued.
    Dennis
  • richards38richards38 Member Posts: 606
    You don't know what to do but you've done the right thing by checking out this forum.
    Add me to those you say that if you like the car, buy it. If there has been a recall for cars that include your new car's VIN, the dealer should take care of this before delivery.
    The airbag recall was for ALL 2004, 4 cyl. Accords and a few '05s that were probably sold and fixed months ago. That repair was simple and involved attaching a piece of material over the airbag module to insulate a deploying airbag from possible sharp edges in the steering wheel cover. During tests there were some driver's airbags that tore as they deployed--why this only affected 4 cylinder models, I don't know--probably a different supplier of steering wheel covers. My '04 Accord EX-L was fixed quickly and conveniently.
    The airbag recall involved over 257,000 cars and the fuse box recall involves only 1,923 cars. You can easily check the VIN to see if you car is one of them and, if so, whether it was fixed.
    Enjoy your new car--you have no problem.......Richard
    Thank-you for your advice. I checked the NHTSA website and learned that the vin# of the Accord I'm buying is not involved in the recalls. "I'm no longer angry", I just got excited about "what could have been" before I checked the facts. I'm glad I joined this site and got the answers to my question. Will be picking up my new Accord in a couple days. Thanks again.
  • bobstbobst Member Posts: 1,776
    It sounds like your tranny is screwed up. Our 2005 EX 5-sp shifts like a dream.
    I'm glad you are now happy.
    Most recalls address things that "could" happen, addressing the worst possible senario. If a recall is announced, no matter how trival, a "STOP SALE" bulletin is sent out and sales are frozen on the affected models until the fix is applied.
    It's amazing how we survived back in the "old days". There were no recalls to worry about!
    Enjoy your new car!
  • nasdaqnasdaq Member Posts: 29
    Hi, I have the same problem: Honda Accord 2000 LX SRS light on.
    The car only has 33,000 miles and never has any accidents.
    Dealer will charge $90 for computer diagnose.
    It is free if it is because of saft belt problem which has lift time warrantee.
    Dealer also said low battery might cause RSR light on.
    It seems this problem is common for Honda Accord 2000.
    If anyone had got this problem fixed through dealer, please share your experience.
    Nasdaq
    Hi JP007,
    Did you work it out?
    I have exactly same problem.
    -Nasdaq
  • lexielexie Member Posts: 45
    Thanks. The recirculation mode does help cool it faster. I have to have the dial 'cool' turned all the way to the end for it to be it to be cool. It seems to be working fine.
  • hermannhermann Member Posts: 38
    I am wondering if anyone has had or still has a problem with their 03-05 Accord wanting to climb the crown to the center of the road. Also the steering never seems to be "on-center". This is not severe, but is annoying to maintain a constant light steering pressure to the right. The car has been aligned and is going back for another try Thursday. Just looking for suggestions and wondering if anyone has had this problem and what the solution was. My car has about 2000 miles on the odometer. Any thoughts appreciated.
    Hermann
    hermann:
    It reads like your tires may be overinflated. Are your tires correctly inflated to the pressures specified on the decal on the driver-side door jamb? I.e. probably 32 p.s.i. front and 30 p.s.i. rear? Do you have an accurate tire pressure gauge?
  • bishopk99bishopk99 Member Posts: 11
    Nasdaq -- has anyone replied to this?
    All -- I have the same problem with my '00 EX V-6 that only has 26K miles. Additionally, the light came on about two days after I replaced my battery. At someones suggestion, I then disconnected the battery and still the light showed up. Honda dealerships service departments are great but it always is a 300 dollar visit!
    Kevin
  • nychrisnychris Member Posts: 5
    Any assistance would be appreciated. The Single-CD head unit in my '98 Accord Ex V6 has recently decided to stop playing all burned CD's (CD-R's, CD-RW's). It will only play the music CD's you buy in stores. I've cleaned the CD player itself almost 20 times with two different kinds of CD player cleaners; no help. Any suggestions?
  • whitecloud1whitecloud1 Member Posts: 268
    I had that happen to my '98 4cyl. a few years ago. I think there is something inside
    that is burning out from all the work. Seems like 6 disk changers are better. That's
    what's in my '03. That being said, I do still get enjoyment from my '98 sometimes when I catch it on a good day. I think that having the A/C on seems to help. It keeps the unit cooler. You are right about the factory cd working better, but I can still play some of the created ones too. Not much to do about it except replacement.
  • lumber2lumber2 Member Posts: 184
    Friend been told by Dealer transmission gone bad under 80k......will Honda do anything for us? Looking at a $4k replacement bill The car is barely worth more....dealer serviced all its life.
    All help appreciated
  • biker4biker4 Member Posts: 746
    It seems like some things are caused by cycling of the power on the car. After I replaced my battery the car (99) has a "hunting" idle - goes between 300-800 rpm - doesn't want to settled down. A lot of these things are controlled by the ECU and if it doesn't power up properly it might just get stuck in some weird mode. The only suggestion I can make is that when you take the positive lead off the battery make sure you ground it well for a few seconds to ensure that you are getting a fresh start to the ECU - residual voltage might keep things from resetting properly..
  • joe122joe122 Member Posts: 68
    CD players use a laser to read 0's and 1's (represented by pits) on the spinning disk. However, before the laser and its circuitry can read the information, it needs to look at the CD table of contents. As CD recording technology has progressed, the information about the disk, i.e. how information is written to the spiral has changed. Firmware, on a PROM (programmable read only memory) chip in the player, contains microcode about how to read the spiral. Periodically, it becomes necessary to reprogram or "flash" the chip with updated information for CD-R. Incidentally, the instructions for the player in my 2005 LX state that it will not work with CD-RW. This means, of course, that the laser circuitry and microcode will not understand that spiral.
    The fact that your player can read commercially pressed disks indicates that the lens on the laser is not dirty. BTW, despite claims to the contrary, CD player cleaning kits do not work and can actually damage your player. Certainly, over time, dust can get on the lens. The only way to clean that properly would be to disassemble the unit. Unfortunately, that could lead to damage unless you have technical experience. Another problem occurs when dust or corrosion prevents the laser from moving smoothly back on forth on two stainless steel rods that support it. Replacement, in that case, is the best option.
    I would contact Honda, or the supplier of the CD player, and find out if a flash is possible. This is done with a flash utility in DOS or Windows for a CD player attached to a PC. I don't know if this is possible for a user to do with your type of unit.
    Hope this helps.
    Thanks a bunch you guys. I called three different Honda dealerships in the New York area, and all three had no clue on how to fix it. You could actually hear the rusted gears in their head start to clank to life. Guess I'll have to upgrade to an aftermarket head unit. Hey, it'll give me an excuse to change out those lousy speakers too. Time to give Crutchfield a call.
    Can anyone recommend a good audio website similar to Crutchfield? Their prices can get pretty high.
    Thanks again
    Crutchfield car stereo prices may APPEAR high - but then they include the trim kit and wiring harness free with the head unit purchase - plus the detailed instructions for taking everything apart. On a new 2005 Accord (and some prior models) the trim plate is pretty expensive to purchase on its own. If you save a few bucks on the stereo but then have to buy the kit and the wiring kit - then figure out how to get everything apart on your own.
    If you don't like what you got, send it back and exchange it for something else.
    I got an XM Direct-Connect for my wife's new Accord ($24) and when I asked they e-mailed me the Accord instruction PDF for free.
    Also if you have a Master Card or Amex you can get discounts or free shipping or both with promo deals. Plus a $20 or $25 "refer a friend" discount if you have not ordered from them before.
    I would not buy a TV or home stereo or RADAR detector from them since the price is too high - but for car stereo stuff the freebies make it well worth it.
    Dennis
  • rhsrhs Member Posts: 10
    I have a '96 Accord 4 cyl. V-TEC. I recently got a CEL that has identified the EGR as the cause. Where is the EGR on this engine in case I wanted to change it? Would it be covered under the extended emissions warranty?
    Thanks....
  • accord6mtaccord6mt Member Posts: 53
    Hi folks - I'm new to this forum and I thought I'd post this message in the hope of receiving some feedback...
    I bought a new '05 v-6 6mt coupe in January, have less than 3K miles on it and I love everything about it except: the engine "pings" or sounds almost like valve tap when accelerating in 1st and 2nd gears and the sound only happens BELOW 2,100 RPM.
    Has anyone else experienced this problem? I use regular grade gasoline, and I'm thinking about trying out mid-grade to see if that would fix the problem.
    Any comments would be very much appreciated!
  • vietviet Member Posts: 847
    Some new Accord owners said the new Accord model self-checks the ABS when it departs. A Honda dealer salesman said it is "a characteristic" of the new Accord. My brand new 2005 Accord hybrid appears having same "problem" when departing at low RPM every morning. I guess that is not the problem. You can check with Honda dealer to make sure your car is OK.
    accord6mt:
    You are correct. You probably shouldn't be hearing that sound once your engine is warm. Yes, try a tank of mid-grade fuel to see if the sound goes away. That's a fine test to see if octane is a factor. You might also want to try a few tanks of a different brand of 87 octane fuel before reaching conclusions.
    If the testing confirms your theory, you should head back to your Honda service department with all facts and notes in hand. Your vehicle IS designed to work fine on 87 octane fuel. There may be a wayward valve lifter or tappet making the sound.
    I don't believe that the sound that you described is in any way related to ABS self-check.
    I agree with what blane said, but I would add to try getting your gas from someplace else - preferably a "name brand" station like Chevron or such that does a high volume. You might try to run the current tank to near empty before you fill up.
    My wife tends to stop and any no-name place that has a cheap price while I am loyal to my local Chevron. I pay a little more, but don't buy Techron by the bottle now and never (knock on wood) get a bad tank of gas :-)
    Dennis
    I have 975 miles on my 05 AT 4 cylinder Accord. I am on my third tank of gas and I thought my fuel economy is low -comparable to that of a V6. On my first tank, it average around 19mpg, 25mpg on 2nd tank and 22 mpg on 3rd tank (used AC). I drive 14 miles (RT) averaging 45 mph. I use the AC in the afternoon on the way home (15 minutes). I am wondering if living in high attitude (5200-5400' ) is the reason. There are a few steep hills to climb. I filled up my tank last night. I drove 240 miles and to fill it back up it took 10.721 gals. I got 22.38 miles.
    Put a few more miles on it and see how it does. My wife is reporting around 22mpg commuting to work and back - AC on some mornings and every evening. She is still under 2,000 miles on hers. We are hoping it will improve as the motor breaks in :-)
    We KNOW the EPA numbers are usually wrong, but you are getting a little better than if you had gotten the V-6....
    Dennis
  • chucko3chucko3 Member Posts: 793
    If it happens all the time, I'd bring the car back to the dealer.
    The valves need to be readjusted.
  • midnightcowboymidnightcowboy Member Posts: 1,978
    Chucko3,
    Is absolutely right, you (Accord6MT)should not be hearing valve tappet noise or pinging. Take your car back to the dealer immediately.
    Funny thing when I first read your response i thought you said "It happens all the time", I missed the leading "If" Talk about changing the meaning of the sentence.
    I have a 6-speed and have no noise in 1rst or 2nd and it runs very very well on regular. I do use Chevron though. You (Accord6mt) need to be able to enjoy your car
    Good Luck,
    MidCow
    Thanks to everyone for their input - I was thinking the tap noise was something that just "came" with the car (which would be strange)... I just got off the phone with the dealer and they said several 6MT coupes had the same problem and all of those coupes had an adjustment done to fix the problem.
    I'm taking the car to the dealer on Tuesday, so I'll update everyone on what they find & actions they took to fix the problem.
    Thanks again!
    Cheers!
    My father has an 05 Accord EX 4-cyl 5AT, drives with the Air Conditioner on NONSTOP, i mean his car stays cold in the Alabama heat! He drives briskly, if not floored all the time, and drives in downtown rush hour traffic every day. He averages 26 or 27 mpg, and has since the car was new. (It now has 15,000 miles on it, and he has no complaints about it :shades: )
  • lorryfanlorryfan Member Posts: 76
    Lexie -
    Same MPG as you with same car....before the last fill up, drove 274 miles, and it took 12.92 gallons to fill it back-up = Got 21.21 MPG
    Dennis is right, my Accord has less than 2K miles on it....so am patiently waiting to see if the MPG will improve after 5K miles and after the first oil change. Also you may want to check to make sure your tires are inflated properly to the Honda specs.....if they are under inflated, the coefficient of drag will almost always get you as the car uses more torque [to turn the wheels].
    Good Luck....
  • joonjoon Member Posts: 121
    Just went through my first tank of gas that came with the car when I picked it up last week. I bought an EX-4 cyl AT. This evening my odometer was showing 367 miles and I put 12.82 gallons averaging 29 miles a gallon. I drive about 70/30 highway/local and in the highway I tried to go easy 60-70 mph. I'm happy with the gas mileage so far. I'll be even happier if I can average more than 30 mpg.
    My new HAH does not have a ping or a valse noise. It just generates one very small "characteristic noise" when it first departs. Some other owners/ Honda salemen confirmed that.
    Dennis,
    I did some research. It indicated that fuel in California is same everywhere regardless of fuel stations. I am not sure about other states.
  • platinumplatinum Member Posts: 9
    I purchased a 2001 Honda 3 weeks ago. When I bought it it drove perfect now 600 miles later I have alot of noises I BELIEVE are all brake related ( I HOPE! ) I was wondering if most of you would spend the extra money and go to the dealership for a brake inspection and work or would you go somewhere else (Private mechanic/ Midas/ etc..) I've always had really old cars and just went to my mechanic but a few friends have recommended now that I have a newer vechicle to only go to the dealership?
    the qoute from the dealership to change the front brake pads was $240 I think this is ALOT! if thats even whats going on...
  • pflawedpflawed Member Posts: 1
    I own a 2000 Accord V6 EX and the transmission was recalled and I had the transmission replaced out of warranty and without expense when it started to leak. That was several years ago and I haven't had any more problems. On the down side, the replaced transmission doesn't always go to park well and I have to jiggle the shifter to remove the key sometimes.
    Check to see if the transmission was recalled.
    platinum:
    Congratulations on the purchase of your 6th Generation Accord they are fine cars. FYI, the 7th Generation started with the 2003's.
    What you believe to be brake noises could also be suspension or wheel bearing related. Any good (recommended by friends & neighbors) mechanic should be able to diagnose and repair such parts of your new baby. Of course, their hourly labor rate may only be about $10 or $12 lower than a Honda dealership's rate.
    For peace of mind you might want to consider the Honda shop for your initial checkup. They'll know what to look for if you ask them to determine if all recommended factory Technical Service Bulletins (TSBs) have been applied to your particular car.
  • chestnutchestnut Member Posts: 19
    Same thing happened to my 2000 Accord. It was a problem some electrical component in the drivers seat belt. Honda fixed it free (no charge for the diagnostic).
  • hondalovahondalova Member Posts: 189
    Don't be stymied by recalls - a lot of people react that way and it always surprises me - recalls mean that the manufacturer has found a potential problem BEFORE you did and is notifying you that it can be fixed if you bring the car in so it DOESN'T happen to you. How is that a bad thing?
    My wife's Chevy Van has NEVER been recalled for anything, but it burns a quart of oil every 2500 miles with only 45k on the odometer and the manufacturer says that's "normal operation." To me that's far more annoying and unprofessional.
    I have owned two Hondas - a '91 Accord EX and a 2004 Accord EX-V6 Coupe. My '91 was flawless - sold it with well over a 100k on it and the original back brakes, starter, clutch, alternator, battery, and other parts in it. It never once left me stranded and the only unanticipated repair was a distributor at 105k that still held on long enough for me to get to the garage before it failed.
    While my new Accord has suffered from some of the rattles noted on this board and is currently awaiting the installation of a new Oxygen sensor (which the computer picked up and warned me via the Check Engine light - not because I had any trouble driving the car), I still believe it to be a far better automobile than anything else I might have bought.
    Every car has problems - Hondas generally have less. So, check your car out, but enjoy your purchase - in the long run, you won't be sorry.
    That's not too shabby for 14 mile roundtrips at 45 mph. I have the V-6 - and a week of vacation from my normal commute, at local mileage ran 190 miles at around 19-20 mpg. Ordinarily, I commute 100 miles roundtrip - about 85% hwy/15% local - generally at 70-80 mph on the hwy. I've been averaging 25-26 mpg with the V-6. On a long trip though, I averaged 29-30 mpg.
  • 88buck88buck Member Posts: 3
    I'm new to this accord but have owned a couple in the past. This one is an 88 LX with 175,000 mi.
    I was driving across several states when the car decided to slow down to a crawl. I made it to a service station and replaced my fuel pump and filter ($$$$) then it seemed fine for about an hour and started to bog intermittently and felt like it was running out of gas or had dropped a cylinder. By the end of that trip I had replaced the distributor, rotor, all plugs and the whole harness.
    Before the trip I had the timing belt replaced, the water pump replaced and the idle set, new air filter, the a/c serviced, a new parking break assembly installed and the clutch adjusted. And I do get a pressure release when I open the gas cap.
    The car starts up like a champ, drives just fine for about a half hour (unless its stop and go then maybe 5 minutes) and as soon as I need to slow and change highways or begin stop and go it starts acting up. I'll down shift (doesn't have to be to a stop) and once I accelerate and begin my gear climb again it bogs down, jerks forward and sometimes stalls. It re starts with no problem but I have the hardest time getting it to rev up to move forward it'll just stall again. So far it does eventually get going but I have to coax it to a high rpm to do it.
    If I hold in the clutch and get it to rev up to a high rpm (at a stop or while moving) the problem may clear for a short while but doesn't go away. I equate it to coughing up some phlegm. Not real pleasant but neither is this hassle.
    I have also had mechanics play with the carbs and vacuums but either that isn't the problem or they aren't catching the problem. They did find out why my cruise wasnt working, bonus.
    It feels like it sometimes gets fuel and sometimes doesn't, like it has a hair ball in the way and sometimes purrs so beautifully. But Im no mechanic Im just basing my feelings on past experiences. Im not sure if the outside air temp is a factor but it is getting warmer out and it is happenig sooner than before during each drive but I've had it in the southern states the whole time and from 7000 feet to sea level. But nothing seems to be consistant there.
    Thanks tons for all your help!!!!!!
    88Buck
  • imidazol97imidazol97 Member Posts: 27,703
    That is normal. Cars do use a slight amount of oil. If they don't appear to use oil over a thousand miles, e.g., then usually the volume is being kept up by contaminants are are collecting in the oil. Drive the car on a long drive at highway speeds and much of the extra volume will be burned out and people will say their car uses oil at highway speed. In reality it was just the contaminants being burned away.
    It could be the igniter.
  • dcab1dcab1 Member Posts: 15
    Has anyone used synthetic motor oil or ant other ideals to improve the ride and gas mileage? Has anyone had their sound proved? If so did you get any real improvements?
