A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Honda Accord Problems 2000-2005
1207208210212213256
  • vietviet Member Posts: 847
    Hi Hondalova:
    Something wrong with your Honda when it burns 1 quart of oil at 45K miles. I have been driving Honda motorcyles and autos for 40 years and no leaking or burning oil problems at all. My old Accord 95 started burning oil at almost 200K miles. I changed the engine/ transmission and it runs beautifully. My other Accord LX 92 that I gave to my relative still runs now at over 260K miles. Honda at 45K miles is still considered new if I do not want to say brand-new..
  • todd7todd7 Member Posts: 16
    I use amsoil 5w20 in my 05 EX 4 cyl. Refer to gas mileage thread to see my MPG's.
    I wasn't sure if I understood your other questions, but I thought you were asking about audio upgrades and suspension upgrades. I will have my digital camera back soon and will post these upgrades.
    For suspension, I'm using Eiback springs with Koni adjustables. I also added adjustable control arms and a camber kit. The Koni's are set to medium, but are still somewhat firm. This upgrade is definately not for everyone.
    For sound, I'm using a Nakamichi 700 head unit and the factory unit. Power is run by two Extant amps(606 and 1001) I 've replaced the interior speackers with two sets of MB Quart QSD 216 and 2 JL 12w6s. This system is built for clarity and does an excellent job.
    For anyone who has complaints about road noise or anything similar, check out Dynamat. I've installed three bulk kits covering the floor, roof, inner and outer door skins and firewall. This car is just about as quiet as an Lexus LS.
    Hope this helps you
    Todd
    I don't understand why you would think a Chevy that uses a quart of oil every 2500 miles is "annoying and unprofessional"?
    Unprofessional?
    That is totally normal and nothing to worry about at all.
    Dump that Chevy and buy a Honda to solve the issue of "1 quart of oil burned at every 2,500 miles". You may make Honda Inc. and Mr. IsellHonda happy.
    isellhondas,
    hondalova writes:
    My wife's Chevy Van has NEVER been recalled for anything, but it burns a quart of oil every 2500 miles with only 45k on the odometer and the manufacturer says that's "normal operation." To me that's far more annoying and unprofessional.
    presumably its the manufacturer's statement that is annoying and unprofessional, not the car's oil consumption...
    presuming a well maintained vehicle, is that an appropriate oil consumption on a car with under 50K miles?
  • laboilerlaboiler Member Posts: 1
    I just moved from Tennessee to California and went to put my new CA plates on my 96 Accord. I assumed the front would be no problem even though I've never needed to put a plate there because Tennessee just uses rear plates. Well, I can't find a set of holes for the front plate! I've found a few plastic brackets with holes in the grill, but they are spaced too far apart to fit the plate and the face of the bracket is angled slightly downward. My guess is that these are not intended for a license plate (though what they are for I don't know). Are there supposed to be two holes drilled in the bumper? Mine has none. I can't think of a more embarassing problem than not being able to put the license plate on!
  • blaneblane Member Posts: 2,017
    laboiler:
    Does your front bumper have two small "dimples" in the middle of the front bumper? If so, those are the points at which to drill two tiny holes to accept a couple of non-corrosive screws.
  • gee35coupegee35coupe Member Posts: 3,387
    That installs under the front bumper. They don't screw the holes right into the bumper cover. Your dealer should have it in stock.
    Thanks for clearing that up for me. I went back and re-read the post and you are correct.
    Using a quart of oil in 2500 miles is nothing. ALL cars use SOME oil. They have to! Back in the "old days" it was pretty normal to use a quart every 1000 miles and nobody thought anything of that.
    On my Hondas, I rarely if ever check my oil. I usually change my oil between 4-5 thousand miles and it's NEVER low.
    It sounds like the poster thinks cars shouldn't use ANY oil at all and the Chevy dealer probably didn't do a good job or pick the right words when it was explained.
    it's just that with a Honda Accord that had over 150K and a Toyota Corolla that had over 180K, neither vehicle burned 1/2 quart between oil changes spaced about 4K apart. Maybe I've been lucky or something...
    now I did own a VW Jetta once upon a time, and that did burn some oil, maybe a quart between changes, again spaced about 4K miles apart, but I thought that was a characteristic of that vehicle's engine.
    always smart to check your oil every couple of gas tank refills.
  • chucko3chucko3 Member Posts: 793
    My 89 Accord has over 207K and still hasn't burnt more than a pint of oil in 6K/6 month oil change period.
    Lucky guy. My 95 Accord EX engine only lasted until almost 200K miles. But my 92 Accord LX that I gave to my relative still runs now at about 260K + miles.
  • 88buck88buck Member Posts: 3
    Chucko3, when you say igniter..is that also the coil?
  • kekzaarkekzaar Member Posts: 3
    Hey guys! Hoping to get some answers! I was just given a 1994 Honda Accord by my cousin, but he didn't know much about cars either. I'm looking to just check things under the hood and I wanted to know where the tank for antifreeze and water would go..... yes, I know it's a stupid question to you guys and an embarrassing one for me.
    There's a tank near the front (of the car) on the left side that I believe is for the coolant, but I just wanted to be safe before pouring anything into it.
    And yes, I did find where you put the windshield fluid, that one was luckily marked :P
    No, it's not the coil. It's #10 from the diagram. Since the part is expensive, see if
    you can get it from a junk yard and try it first.
    http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=Acco- rd&catcgry2=1988&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=DISTRIBUTOR+%28CARB.%29+%28TEC%29-
  • hondalovahondalova Member Posts: 189
    I understand what you are saying - you are right - to a point, but I have to respectfully disagree with you on what volume of oil consumption is "normal." I have owned many many different cars from many many different manufacturers - 4 cylinders, 6 cylinders, 8 cylinders, Japanese and American. NEVER have I had a car consume oil like my wife's Chevy Venture. Until this car, the worst I ever owned was an '84 Camaro with the 2.8L V-6 that went through about 2-3 pints every 4-5000 miles (and THAT didn't start until around 90,000 miles - before that it barely consumed any oil at all).
    My '91 Accord 4 cyl, my 79 Celica GT Liftback 4 cyl., my '99 Maxima 6 cyl., even my '85 Ford Mustang GT (5.0L V-8), all went well over 100,000 miles without losing more than a 1-2 pints per oil change (4,000 mile intervals).
    A quart every 2500 miles is in local traffic - on a 1500 mile highway trip upstate when the car had only 750 miles on it, it consumed almost 2 quarts. The car stinks like burning oil all the time (have to close the window its so bad sometimes). Under hard acceleration at high rpm, engine sounds like its piston slapping. But dealer(s) say "within normal operating limits - technician cannot duplicate condition." Oh - twice they told me they removed a plastic bag from the exhaust assembly under the car (maybe the 1st time, but not the 2nd - I check before I bring it in now b/c I don't like to be made to look stupid).
    On the bright side, the engine is dry as a bone on the outside and the extended warranty covered the intake manifold gasket problem these cars suffer from at 38,000 miles. But I shudder to think what the rings and the valve seats must look like in there.
    The car is well maintained - mostly highway miles, oil change every 4,000 miles, annual tune-up and air/gas filter services, etc. - all done by the selling Chevy dealer. Other than the oil consumption and the dreaded intake manifold gasket problem (thank heaven for extended warranty - the only time I've ever bought one), the van's been a good vehicle. Only CHEVY (and you guys) say this kind of oil consumption is normal operation - but I've been to other Venture owner's billboards (Minivan Magazine and Edmunds) and everywhere I've posted it except here people have told me to go back to the dealer b/c that's not right.
    The wife's in school right now but, when she starts showin' me da' money I'm thinkin' either a CRV, an Odyssey, or a Pilot for her is on my short shopping list. I'd also consider a Toyota Highlander or a Jeep (mmmm....HEMI...!)
  • hermannhermann Member Posts: 38
    In the past I have owned 2 Ford Taurus Sedans.( I know, but the pre-1996 had a marvelously balanced suspension.) They were 1986 and 1994 models. Both had the 3.0L Vulcan Engine. They both used a quart of oil every 1500 miles like clockwork.. Other than this problem these were both very reliable vehicles.
  • tinatinatinatina Member Posts: 388
    I have owned a 2004 Accord LX sedan for about 1 year and have over 12k miles on it. So far, I have had the following issues, which were fixed.
    Air Bag Recall.
    Headliner replaced due to squeaking and rattles.
    Trim panels replaced.
    Interior Loose weatherstrip kept falling off. I finally fixed it on my own even though 2 dealerships were not able to fix it. I read the shop manual and attached it properly, so no more loose weatherstripping!
    Pluses of the 2004 Accord over my previous 2000 Accord:
    Better HP and acceleration
    Very smooth transmission shifting.
    Minuses:
    Dealer service - awful at 2 dealerships. Customer (Dis) Service - useless!
    Fit and finish problems are un-Honda like - I still have some rattles coming from the A-panel or the sill panel, which I will fix on my own with some foam tape.
    Using a quart of oil every 1500 miles isn't really a "problem".
    Most of the cars I've owned in recent times haven't required any oil between changes but a few have. I just don't understand why that's a big deal?
    My 1984 Z-28 ran like a top but it would usually need a quart of oil added around the 2000-2500 mile mark. It never got any worse and I never gave that a thought since it was completely normal.
    A quart of oil doesn't cost much to add once in awhile.
  • whitecloud1whitecloud1 Member Posts: 268
    For me, unless I have a warrenty, I would go to who I trust. Whoever you go to, the thing to do is to not tell them what you think is wrong, just describe the symptoms. Brake systems are the same as 20 years ago. ABS is an enhancement, not to be treated any different.
  • maclizardmaclizard Member Posts: 1
    I bought new struts to replace on my 98 honda accord, but am much more familiar with volkswagens and subarus. Im not totally sure how to access the top of the strut tower in the back of the car, and don't want to start tearing out the rear deck unless I am sure Im not going to break something in the process...any help?
    The reserved tank is on the right side (passenger side) of the car. Its cap has a
    hose connecting to the radiator. The fluid in the tank is green. The level should be between High and Low when engine is cold.
  • srobaksrobak Member Posts: 96
    Unless you are driving a 2 stroke vehicle, you should not have ANY oil CONSUMPTION what so ever.
    The lubrication system on a 4 stroke engine (ie what is in your honda or your chevy) is a sealed system. Nothing is supposed to leave that system, and nothing is supposed to be introduced to that system under normal operation. Oil will "thin" over time as it loses it's viscocity, and that is why you do oil changes every 3 to 5k. The less viscocity, the more metal directly scrapes against other metal without a liquid, lubricating barrier. This is BAD. Any way you shape it.
    If your car is eating a pint or a quart of oil every 1500 miles and has less than 80k on it, this too is BAD. It means your sealed system is no longer sealed. If you have no oil leaks (check drain plug, valve covers, front and rear main seals, upper and lower block seals, oil pan gasket), and no contamination of your coolant (oil/dark spots in your otherwise green coolant), then you have some bad piston rings or valve seals and oil is leaking into the cylinders and being burnt off. A quart of oil in 1500 miles is an extremely high rate of consumption and it means you have a very bad leak somewhere in your system. Once you get a lot of miles on your engine, the rings will wear enough where oil will blow by a bit and you should get minor consumption (less than 1qt every 5k).
    When you get on the gas - do you see blue smoke exiting your tailpipe? If so - then you are burning oil. If you do not see it, yet still get the smell and you cannot see any leaks on the front side of your engine - then check the back side... it is likely leaking from the valve covers or upper seal and landing on your hot exhaust, making the smell. This is bad - if your leak is as high as you indicate - it is only a matter of time before the exhaust is hot enough and there is enough oil where it ignites and causes an engine fire. If not extinquished within the first minute, you can kiss your entire car goodbye.
    The slapping sound you are hearing is likely to be a lifter or two without oil, or it could be mostly burnt/destroyed rings allowing movement of the piston. This should be accompanied by a lot of engine vibration, and over time this will do enough damage to the piston and the cylinder wall where you will be looking at a full engine rebuild.
    The dealer is LYING to you. Take it somewhere else for a 2nd opinion and demand the dealer make good on the warranty. Also get on the phone to GM offices and inform them of the dealer giving false diagnosis and attempting to circumvent warranty coverages. Find the problem and fix it, or else get rid of that car NOW. You will regret it if you don't.
    does the chevy have a pcv valve?
    i remember reading another poster's comments somewhere about oil consumption and the pcv valve operation.
    this web-site seems to suggest the pcv valve operation can impact oil consumption:
    http://www.mightyautoparts.com/pdf/articles/tt122.pdf
  • midnightcowboymidnightcowboy Member Posts: 1,978
    Actually there is friction and the system isn't perfectly sealed. The piston rings seat and do a good job of sealing but nothing is perfect. The perfection further breaks down as engineers strive to have closer tolerances and more horspoewr per cubic Inch ( or liter). There is some oil burning and some oil leakage.
    The real problem is that there is a big discrepency between what is really "normal" and what a car vendor will do something about, e.g. worst case replace the engine. Car vendors don't pay their lawyers to write warranties so that they will lose money. I agree one quart of oil every 1,500 miles is very high, but even so some manayfacturers warraties protect them clear down to 1 quart per 1,000 miles as being within normal limits.
    YOLMV ( Your oil Leakage May Vary),
    crus'n in 6th :shades:
    MidCow
    P.S. - Any dealer car will miles on it, especially demos are suspect. Most if not all test ride miles are very very hard miles.
    What do you think happens to the oil that adheres to the cylinder walls. Of course, some it naturally burns off. All cars HAVE to use SOME oil!
    The original poster was complaining about a quart every 2500 miles! That is nothing, and even a quart every 1500 miles is NOT an "extremely high rate of consumption".
    A car that uses that little oil isn't going to belch blue smoke either. If you see blue smoke, you are REALLY burning oil!
    You probably wouldn't like a Rotary Mazda. These NEED to use some oil and it'a bad thing if they don't. the two I had would use a quart every 1000-1500 miles whaich was a GOOD thing!
    Unless things get markedly worse, the poster has nothing to "fix"!
    "Most if not all test ride miles are very very hard miles"
    Not when I'm along they aren't. I keep a choke chain on people when I need to and I won't tolerate abuse or people who scare me!
    The overwhelming percentage of people drive as they normally do.
  • markpl16markpl16 Member Posts: 3
    I currently have an Accord (03 V6) and i absolutely hate it,i had the following problems:
    -Radio went out.. the lights in it.
    -Trans blew at 42,000 (luckily i had the extended warranty)
    -Had to change suspension
    The good thing about it is that it still drives, hopefully it will until i get the Subaru STI in about 2 weeks.
    The early Taurus sedans drove beautiful. A lot like the current generation Accord but with more accurate but a heavier feel at the wheel. I gladly lived with the MODEST oil consumption as to let some "I could care less mechanic" "take a crack at it" who might create more problems than he would solve. Never fouled the plugs in either engine and never had any catalytic converter problems, and the exhaust must have received a nice light constant lubrication as they both lasted 100K plus. Plus oil was a buck a quart back then at Wal-Mart. Never noticed any oil leaks on the ground either..
    My advice is unless it is a safety hazard or belching blue smoke quit losing sleep over it .
  • jon48jon48 Member Posts: 6
    Up date on the CO problem.
    The Converter was only half the problem. After I removed the converter and replaced it ,I retested the car and the results were worse. However I noticed that the back end of the old converter was missing most of the internals of the converter. They had to go somewhere ,so I changed the muffler and sure enough it was pluged up. It was a wonder it ran al all.
    You can have the best overhaul in the world but if the air going in cannot get out you wont get a good emmissions test.
    Co and HC levels now in the .1 and .5 % range and gas mileage around 27mpg city. Have yet to test Hwy.
    Thanks for the forum. I hope this helps someone else. ;);)
    Not doing this as a personal attack or anything, but if you actually believe this for any car under 70 or 80k, then you have no business being in the car business. Any mechanic worth his salt will tell you hands down that this is "not good" and that it is a very high rate of consumption. I guess that is why you sell them and don't work on them.
    I really hope you do not try to pass this stuff off onto people you are trying to sell Hondas to. God help them if you do, because when their engine starts going south due to their lack of followup and maintenance, they will say it is "acceptable".
    Un-cool... :mad: :sick: :lemon:
  • atlantabennyatlantabenny Member Posts: 735
    A quart's worth of oil loss @1,500 miles suggests that at 5,000 miles - the likely average drain interval among all users - more than 3 quarts or 73% of the total crankcase capacity would have disappeared.
    Acceptable for a 2nd-tier car ? Maybe. For a Honda ? Not IMO.
    Our 6 Honda vehicles over the years would show a loss of 1/4 of a quart at 7,000 miles, which is my drain interval. There's something seriously wrong with a Honda engine that looses a quart @1,500 miles.
    27 mpg city is very good. My 89LXi averages a bit over 28 mpg City & Highway.
    If mine passes the emission test this coming October, I will keep it another winter.
    Just had the header pipe replaced last month.
    How many miles on your 89 LXi already, Chucko3?
    I'm not sure how and why you consider yourself such an expert on this but anyone in the business of repairing cars and overhauling engines will agree with me.
    Using a quart of oil in 2500 miles is nothing to worry about.
    You can think whatever you want to. I don't need insults from a person I seriously doubt has my experience in and around shops for more years than I'll admit.
  • altair4altair4 Member Posts: 1,469
    You wrote:
    "A quart's worth of oil loss 1,500 miles suggests that at 5,000 miles - the likely average drain interval among all users - more than 3 quarts or 73% of the total crankcase capacity would have disappeared."
    That's why the owner's manual recommends checking your oil level regularly. Our 97 Accord is at 93,000 miles. Oil consumption between changes is negligible, but I still check the oil every other fill up. I use Mobil 1 5w-30 with a 5,000 mile oil change interval.
  • nychrisnychris Member Posts: 5
    Hey all,
    The heat shield that covers what I believe to be my catalytic converter broke off the other night. Do i need to have it replaced/reattached? Is there any risk of damage or corrosion to the now exposed catalytic conveter? Can i just get the heat shield alone replaced? How much should I expect to pay?
  • rfrfrfrf Member Posts: 31
    Does anyone use this or a similar product to clean the injectors?
    I have repaired with heat resistant metal wire ... with success ... on a number of diff makes and models
  • yankeryanker Member Posts: 156
    I checked the reviews for the Accord yesterday in another site. Fully 1/3 of them complained about brakes ,rotors ,back brakes whatever. My own car was in for a check and I received a call asking for more time to turn the brakes and replace the back brakes. I was surprised as ,yes ,they were noisy and rough. But a huge number of people on YAHOO's evaluation complained about the brakes.
  • imidazol97imidazol97 Member Posts: 27,675
    Try Techron by Chevron Oil and Gas company. It's sold at their stations and sold at PepBoys and Advanced Auto, etc. There's an injector cleaner and fuel system cleaner. Follow directions and put in with an almost empty tank and add gasoline up to the number of gallons for the size you buy, 12 or 20 gallons. Add premium fuel from quality station for best results. If needed, repeat one time on next fuel fill after running most out of tank again.
    Recommended by a mechanic and this has worked for me. I put it in at about 25K. Less often when I've been buying only quality fuels (Shell, Mobile in my area).
    206485.
    If it's the top cover, then you need to replaced it. If the bottom one, I wouldn't
    worry about it. I took mine off from my 89 many many years ago due to a rattling noise at certain RPMs. After 16+ years, the car still has the original cat.
    Yes, you can just get the heat shield replaced alone.
    I've got nearly 20 years of wrenching on cars as experience. Sure - I am a shadetree mechanic, but I know my way around cars, trucks, bikes, 4 wheelers and snowmobiles quite well. Oil consumption isn't necessarily brand-based either... Here are some of those cars over the 20 years...
    78 BMW 535i - restored it, crate engine, put 20k on it, never used a drop.
    87 Grand Am, 2.5 liter engine had 198,000 miles when I sold it and never used more than half a quart even at that high of mileage. No major engine work or rebuilds ever. It had a valve cover gasket start leaking at about 120k. Took 10 minutes to replace that, and all was well.
    92 Lincoln Continental - 189,000, about a pint per 3500, but it has a saturated oil pan gasket which is the source of this loss. This car has power steering leaks, transmission and air suspension issues which will be taken care of when I restore the car starting this fall.
    92 GMC Typhoon - 4.3l turbov6, 85,000 when I sold it, used half a quart every oil change. Engine was beaten pretty hard when I got it, and I wasn't very nice to it either. Leaky lower seal.
    96 Taurus, 3l v6 120,000 - never leaves crosshatches between changes (ie: less than half a quart). Still have this car.
    04 Taurus, 3l v6 28,000 - doesn't use a drop. Measured it 2 oil changes ago in fact...
    05 Accord, 4 cyl, 8,000 - doesn't use a drop.
    The Grand Am was 15 years old when I finally sold it. Best car I ever owned - left me stranded one time due to an ex taking it off-road and putting a hole through the oil pan and not telling me.
    I think your "experience around shops" consists of actually swallowing the crap that the mechanics have been telling you by saying that a quart every 1500 to 2500 is acceptable and normal. Even if your car has 200k on it, it should not use oil that fast. You are dropping it or burning it, and neither is good. The only mechanics that are going to agree with you are those who work in your shop and don't want to do the warranty work.
    Take care of your cars, and even with high mileage they will not use oil like what this guy is trying to say. I might note that none of the above high mileage cars has ever had any major engine work, nor rebuilds. No rings, boring or pistons.
    If you need a quart or more between changes - then you have some serious problems and you need to get them identified and repaired.
  • dmilacekdmilacek Member Posts: 7
    2003 EX Accord with automatic trans. The problem is that it downshifts hard and searches for a correct gear. Anytime that you are not accelerating, the trans starts downshifting and upshifting. If you are slowing down and combine the hard downshift with the grabby brakes, it throws everybody forward.
  • dwynnedwynne Member Posts: 4,018
    The holes are under the opening (the mouth) of the grill area. The plate holder bolts to that with the bolts going up toward the top of the car.
    If you had asked earlier you could have come by and taken my plate holder from the garage with you :-)
    If the dealer will not give you one or sell it to you cheap, I can send it your way.
    Dennis
    I complained to the Chevy dealer about the oil consumption in my 2000 'vette convertible. They did an "oil consumption study" and told me later than using 3/4 qt of oil in 750 miles was "normal for a high performance motor". I still have the work order from the dealer someplace - I saved it. I didn't save the car, I sold it and got an S2000. Much for fun, and you don't have to fill the oil up so often :-)
    Dennis
    Sounds like it's time for a new car. I would find that unacceptable.
    I'm following the 10,000 mile interval on our Civic and Accord and although the Civic started out burning about a quart per 3500-4000 during break-in, it has nearly stopped burning it altogether. It's been 7500 miles and it's about 1/2 a quart low.
    3/4ths in 750 miles??? That is the most insane thing I have ever heard. Imagine if high performance stock car engines did that at the rpms and loads they run under... race would be over in 20 laps.
    See THIS is the kinda crap that makes me do my repairs. I sure hope I don't have that kinda feedback on any warranty items I bring my Accord in for.
