Visitor Agreement.
I wonder where all the coolant went before the car overheated.
This is very disappointing. Anyone else had either of these problems?
Dale
good luck
The mount was shot and I had the part for it.
Since then, the same vibration seems to go away.
I should have replaced it a couple years ago when the vibration started getting worse.
http://www.northcoasttuners.com/TSB/04-037.pdf
Your sounds may be due to something loose and rattling around in your trunk or under a seat upon acceleration. Also, check your rear seatbacks to make sure that they are fully latched in the upright position.
Also, are your electric fans kicking in? Another thing to check.
Mrbill
The good news is your head gasket is still OK after a massive overheat.
Otherwise, you would have seen white smoke coming out of the tail pipe.
You already refilled the radiator (to the neck) & reserved tank. Correct?
Here is how I would do to check for leaks and a stuck closed thermostat.
Start the car & turn on the heat. Rev the engine up & pay attention to the temp gauge. If the car starts overheating, you have a stuck closed thermostat.
While waiting for the engine heating up, look around/under the engine for any leak.
BTW, how is your water pump? When was the last time it got replaced? Check for any leak there, too.
Is anyone experiencing the same foul smell from their AC? How do I get this resolved?
Many thanks.
You are correct. Coolant doesn't evaporate. It's leaking somewhere.
The other option is to take it in and see what the dealer can do for you since it is so new, but honestly, you probably aren't going to hear anything different from them.
If you are talking about the "recirculate" button, has a picture of a car on it with a U-shaped arrow...then that will not affect MPG. Having your A/C on will lower your MPG in general but it can be more fuel efficient to have your A/C on instead of having the windows open at highway speeds.
hope that helped
Note - you do NOT want to use recirc in the winter time. Your windows fog up because of humid air in the car - recirculating that air is only going to make the situation worse. Take fresh air in the winter, and recirced in the summer (for ac).
The V6 Accord still uses a timing belt............Richard
I thought 03 and 04 had belts with 105k intervals, while 05 has a chain. I'm not positive, but that is what my dealer says. We have an 03 LX and a 05 EX.
Thanks for your feedback. I will try your suggestions.
A needle temp gauge would have saved me the gasket.
This problem with a bad smell is common with all air conditioners in all cars and is because when you shutdown your automobile after running the air conditioner, the condensate or moisture forms on the condenser in the automobile. It does not evaporate readily and thus sits there in a cool and dark place and thus becomes a musty and moldy smelling product.
Two ways to aleviate it is to use your recirculate mode. Other techniques are as your approach downtime in your automobile is turn keep the air conditioner on, turn up the heat and switch to outside air to burn off the condensate on the condenser coil in the automobile. However, depending on the time of day and outside temperature this may or may not work.
You are sort of stuck between a rock and hard place. This is a common problem with all automobiles, not just Hondas.
I just bought a new 2005 LX Accord and the steering wheel doesn't seem perfectly centered like I'm used to in other cars. It doesn't seem to affect the alignment of the car (I think). it seems the steering wheel is slightly to the right and not dead center. Is this normal or should I get it adjusted from the dealer or will they just ignore it? if i bring it in, will they screw with something else. I dont want any new headaches.
thanks in advance.
Since you state that you can change LED from yellow to blue how do you do this ?? does it say in manual with the instruction how to ?? can you tell me how to do it if it doesn't in the manual?? Thank You,
the whole car starts to shake and vibrate when the AC compressor kicks
in. The engine normally idles at about 7500rpm. When the AC compressor
kicks on, the RPM drops which causes the shaking. Is it simple to have
a mechanic raise the idle speed of the engine a bit? Anyone else
experience this problem with 94-97 accords? Thanks
cruise on,
MidCow
