Honda Accord Problems 2000-2005
1211212214216217256
  • fliu01fliu01 Member Posts: 1
    My 97Honda Accord EX has two problems:
    1. The A/C doesn't work. The freon tank is still has coolant, so the problem is probably electrical.
    2. There's a hole somewhere b/n the engine and the muffler - the car is LOUD.
    Can anyone point me in the right direction of a honda mechanic that won't rip me off?
    frank
  • mrbill1957mrbill1957 Member Posts: 823
    That is something that the dealer will need to re-align. It's not a big deal, and it should not screw anything up. They will have to put it on an alignment machine to correctly adjust it. I had the same issue on a new truck and car, and it took less then 30 min to correct.
    Mrbill
  • dwynnedwynne Member Posts: 4,018
    If it is hot out and hotter in your car (it WILL be hotter in your car) then when you get in and start you:
    1) Turn on the A/C in fresh air mode - since the air inside of the car is TONS hotter than the outside air you want to try to cool the outside air.
    2) Open the sunroof (if equipped) and roll down some windows - either partially or all the way if your hair (if equipped) can stand the wind. The faster you get the super-heated inside air out the quicker the car will cool.
    3) Once you have the interior of the car down to outside temperate (this can take a few minutes) THEN switch the control to recirculate to finish cooling down the car.
    4) Once you have cooled off, go back to fresh air mode. This gets the moisture out of the system lot better. Also, if you run in recirculate mode and a low fan speed you can ice up the coil (to be honest I have not seen this since we quit using Freon).
    Some cars have carbon cabin filters and some even have "smart" sensors that will switch to recirculate if they detect certain things in the fresh air. Some work pretty good.
    It is amazing to me when I see folks get into a car that is 150 degrees and set it for "max a/c" or hit the recirculate button thinking it will cool them down quicker.
    As far as the smell goes, what lorryfan finds nasty could be anything from a dead critter to something leaking out of the motor to normal smells - I can't tell through the Internet what it smells like :-) I would get someone else to smell it and maybe run by the dealer. I think the car is NEW so I would bet it is way too young for a huge mildew/mold problem.
    Dennis
  • prince2100prince2100 Member Posts: 23
    I had the service manager drive it today. he said it is slightly off-center but not a safety concern and says i need to drop the car off in a week and it will take a few hours to fix. seems like a hassle. he said after they correct the steering they will have to drive it also to make sure. i guess u got lucky by getting it fixed in 30 minutes. i hate having my new 2005 LX messed with so soon.
  • snakerbillsnakerbill Member Posts: 272
    Paint it blue.
  • chucko3chucko3 Member Posts: 793
    Yep. When that temp light lit up, it was too late. That's why I like a temp gauge better than a temp light. By looking at the needle I can tell when the car starts overheating and make necessary repairs before doing further damage to the
    engine.
  • temj12temj12 Member Posts: 450
    Why in the hell would it take a few hours? I have had this done and as the responder said it is no big deal. Honestly, then they have to drive it. Why? And if they do, how long does that take--10 minutes.
  • lastwraithlastwraith Member Posts: 350
    Gonna go ahead and assume you meant 750RPM ;)
    In all of my cars the idle would kick up when you activated the a/c to counteract the extra load. I would imagine this is still the case. Perhaps that idle kick up valve or whatever it is has simply failed?
  • dhski04dhski04 Member Posts: 10
    I have a 2000 Accord V6 Coupe with about 80k miles on it. I live in Illinois and recently we have had some hot, humid weather (upper 80's) and my car won't start when it has been sitting out in the heat of the day. The problem is predictably tied to the heat of the day. It starts up fine and drives great to work in the morning when it is cool. At lunch, it will not start. I turn the key and it sounds like it is going to fire up but it doesn't. I am positive it is not a battery problem because the crank is really strong. After work around 3:30 or so, I've always been able to start it, but it takes several minutes of trying to start it. Once I get it going, it runs great. (I have noticed a sharp decrease in gas milage, but I think this might be more related to the fact that I've been doing more city driving). I took it to a repair shop and they said they couldn't find anything wrong and that it started for them (not as hot today I don't think). As I said, I can predict when it is not going to start, it isn't an intermittent issue...any ideas?
  • jon48jon48 Member Posts: 6
    The car had 115,00 miles on it when I overhauled it. Everything mic'ed in at new tolerances. The only reason I went that far was the oil leaks caused by the previous owner switching from synthetic oil back to regular oil. Just passed 120,000 miles. So far really satisfied eith results.
    Jon
  • jaybob6jaybob6 Member Posts: 1
    I just bought a 91 accord 2 door. The engine heats up to half way on the temp gauge within 5 minutes of starting the car. When i stop it the gauge stays the same and i never heard the fans kick on, but when i open the hood it feels very hot. I do not have owners manual so I dont know at what temp the fans kick on. Can someone please help.
  • spamanspaman Member Posts: 6
    Sounds like the idle adjust is wrong and can not catch up to the extra load brought on with the AC Compressor coming on. Make sure your idle is at the correct RPM. If that is, then the mechanism that tells the engine to turn up the RPM for the load is reacting late. The mechanism that does this may have failed.
    Sounds like vapor lock due to heat. I had a 2000 V6 that did the same thing occasionally during hot weather. I got in the habit of putting in fuel injector cleaner in the tank of gas after a oil change and that seem to do the trick. You may have fuel injectors that are clogging and not getting enough fuel in the system, especially during the hot weather. Under normal conditions, the fuel stream during start up is fine, but in hot weather it is vaporizing in the system too quickly.
  • srobaksrobak Member Posts: 96
    One thing I noticed on my 05 4 cyl is that it does not heat up very easily to the point of spinning up the fans. At a certain temp (180 I think) - the thermostat kicks open and heated water flows out of the engine and into the radiator. Consequently - cooler water flows out of the radiator and into the engine. If the temp drops enough, the thermostat will close and stop circulating water until it heats up again. If the thermostat stays open, it will just cycle water around, cooling it a little as it runs down the radiator. I ran my accord for 20 minutes at idle in park on a hot day with nothing else running and the hood open and the fans never kicked on. The temp guage hovered right around center the whole time... just cycling water through was enough to keep it at a respectable temp without kicking on the fans - which likely engage at a higher temp. This might be what is happening to your car.
    Flip on the AC, turn on some load-generating accessories, drive it around the block - they may kick on. If it feels hot - it's because it is.... 180 degrees or so at least :)
    Don't flip on the AC or you will turn on both fans which will take some heat off the engine. Just let the car sit idle after a long ride. The fan will turn on then.
    Your fans didn't turn on because you let the hood open. Heat goes up.
  • keungkeung Member Posts: 28
    If your problem is like mine, where in hot weather after driving and then letting it sit for 15-20 minutes, the problem is due to the fuel regulator and computer. The first step is to change the regulator and see if it corrects the problem. If not then the computer may need to be changed as well
    My 05 EX V6 coupe had the same problem, and it took the dealer 12 minutes to adjust the toe to center the wheel. Why are they trying to rip you off for such a simple adjustment. Even a portable toe guage will do the job, so any half way decent repair shop could do this job quickly, and not charge an arm and a leg to do so. Find another repair shop.
    I got a little more information. My wife has informed with a copy of the receipt, that we replaced fuel regulator 16740-P8A (FP #5232707) and that solved the problem. There is another problem on the forum where a fellow had a problem with the car shutting off for no reason at all and we also had this problem.
    So, we had the vapor locking in hot weather and the engine shutting off problem and replacing this part solved the problem. The car just had a problem maintaining fuel pressure because of this bad regulator. Regulator costs around $135 and labor brought the total bill to about $200.
  • zaksdad3zaksdad3 Member Posts: 14
    Thanks for the input. I used the hair dryer for about 3 mins and they with a sawing motion of the floss cut through the adhesive. Most of it came off with the badge and only had to remove a little residue. Did not damage any paint and you can't tell it was there.
    Larry
    This happening during hot weather. Have not had the car during cold yet. I removed the rear licence plate frame as others have noted but that was not it. I seem to get this rattle at speeds below 65 and it sound like the speaker cover is causing it. Will drop the seat and see. It is more of a vibration than a rattle.
    I was one of those that told you about the license plate frame. I took mine off but I don't know that it solved the problem. Even with the license plate frame off, I notice that the plate rattles when I shut the trunk. It could be that it is still rattling and I don't notice it. I have the radio on most of the time and that would drown out any rattle.
  • west7west7 Member Posts: 1
    I HAVE A 2004 HONDA ACCORD. I HAVE BROUGHT IT BACK TO THE DEALER 3X'S ALREADY TO HAVE THE BRAKES FIXED. EACH TIME I BROUGHT IT BACK THEY SAID IT WAS THE BRAKE PADS, WHICH HONDA ADMITTED THAT THEY HAD PUT THE WRONG PADS ON FROM THE START. ALTHOUGH THEY HAVE REPLACED THE PADS AND ROTORS THIS CAR HAS BEEN NOTHING BUT A PAIN SINCE I BOUGHT IT.
    NOW I HAVE ANOTHER PROBLEM, WHEN I ACCELERATE, WHETHER FROM A STAND STILL OR WHILE I'm AT A STEADY PACE, I GET A WHISTLING NOISE. I HAVE NO IDEA WHAT IT IS, ANYONE EXPERIENCE THIS?
    I recently purchased an 05 Accord 4 cylinder MT. I drove it home which was about 50 miles. It has a high pitched whistling noise. It runs so quiet that any noise like that is easy to hear. I took a trip this week and sometimes I noticed it and sometimes not. I have satellite radio so I listen to the radio a lot. I don't hear it then. I am probably not going to take it back over this because I assume that they would never find it. I have never owned a Honda before and I hope I have a better experience than you have had. Nothing is more irritating than a car that has to go in the shop constantly. That is why I left the so called "american car." If by chance, this sounds like the same thing as yours and you do solve the problem please post again.
  • hpmhpm Member Posts: 4
    One thing I haven't liked about the Accord is the fuel gauge. It isn't very accurate in my opinion. I like to fill the car up at a quarter of a tank and I always have about six to seven gallons still in the tank.
    Depending how you look at it....I guess it is a good problem to have.
  • aligatealigate Member Posts: 4
    30 year Honda/Acura Tech
    I believe that your problem is related to the fuel pump relay. This is a pattern failure associated with many Honda/Acura cars. Part price 30-60 dollars. Might be worth it to try and see. :) Also there was a bulletin on the V6 motor 3.2 litre for a fuel regulator and PCM. This is an Acura bulletin but may also apply to the Honda car.
    30 year honda/acura technician
    If the car has not been in an accident the motor mounts may be worn out. I've been seeing early failure on Acura vehicles. My own 93 accord EX benefited from new mounts with a similar problem. I recommend replacing all four mounts. The expensive mount is in the rear. Most dealers will try to talk you out of this due to the time involved, it did fix my problem! :)
  • tfontfon Member Posts: 4
    I have a '99 Accord and I just need to know how to change the headlight.
  • altair4altair4 Member Posts: 1,469
    The owner's manual in my '97 Accord has instructions to change the headlights. Doesn't your manual tell you how to do this?
  • bobstbobst Member Posts: 1,776
    From what I can tell, two Honda owners complain about a whistling noise. Neither of them have taken their cars to the dealer to have the problem addressed.
  • missmichellemissmichelle Member Posts: 1
    Hey you guys! I wanted to ask about my car. It is a 2002 Honda Accord. The car seems to be running fine but my check engine light came on this morning. I was just wondering if this is something routine or should I take it in to have it looked at immediately.
    You can run by AutoZone, Advanced Auto Parts, etc, etc and they will read the code for you for free. Report back with what the problem is and we can tell you the next step. It may be real obvious from the code if this a large problem or not. Some minor ones (and single fault) may clear up after several stops/starts of the engine.
    An '02 should still be under warranty? If so just run by the dealer they should read it for free and fix the problem.
    Dennis
  • mvr44mvr44 Member Posts: 1
    II have experiencing some noise/unsmooth gear changes from first to second when driving the car first thing in the morning and sometimes after the car has been parked for a time. This does not continue to happen after the car is running. Took the car to the dealer last week and of course was unable to replicate the noise, so they were unable to do anything to address the problem. This weekend the noise continued but seemed to always occur when starting up and then and accelerating to second gear while completing a turn.
    I have read on this board about "ABS self check" as maybe being part of the problem? Did own a 2002 EX6 Coupe and never had this problem. Was wondering if others had this problem and what solutions there were for this problem?
    Going to dealer once again today.
    Other than that, I have enjoyed the car.
  • sandpsandp Member Posts: 2
    Hi, I have a problem with my 2000 Honda Accord V6 car. After a fuel emmisions test which the car passed, we fueled the car to full tank. After driving around for a bit, the check engine light came on. When the car reaches about half tank fuel the check engine light goes away and comes back on when the fuel level goes down further to about 1/3rd level. I am puzzled as to what might cause this problem. It happens consistently (we have since driven around in the car and refueled too). The car performance otherwise is good. Ive not had this problem with the car before in the car. The car has about 55K miles. Please advise on the best course of action. The Honda dealers want 90$ to diagnose the problem and then pay additional for parts. Can you give me an idea of what to look for to diagnose the problem and how to fix it please? Thanks!
  • tomn4tomn4 Member Posts: 1
    I have an 94 Honda Accord, and as soon as the gas gauge shows 1/2 of a tank. The car will not run any longer. If it is above 1/2 of a tank, there is no problem. Has anyone else had this problem? If anyone knows the solution, please let me know.
    Thank You
    Tom
    nope
    Transmissions behave better after they have warmed up a bit... might be worth it to check trans fluid levels however. When was the last time you had the trans fluid and filters changed? If it is an 02, it may be due if never before. Otherwise take it back to the dealer the night before, tell them to leave it sit overnight and to diag it first thing in the morning (before it gets too warm out).
    Put 2 containers of gas-line anti-freeze/water absorbant in the tank the next time you fill up. Run the tank through and report how the following tank does.
  • hondalovahondalova Member Posts: 189
    I have an '04 EX-V6 Coupe with MT - I complained about the exact same problem - dealer could not find it. I finally put a piece of towling folded flat in the bottom of a soup can and dropped a printing press block letter into it. I took it to the dealer and shook it for him: "THAT's the sound you should be looking for." They isolated a number of different things in the trunk, ground down the flanges on the tops of the rear strut (shock?) towers, even pried apart some of the body panels to quell body flex (which these cars seems to suffer from rather noisily). I also made sure that the scissor jack was tightly in its cubby by turning the top until it expanded tightly into its space. Still had it - I threatened to call Honda.
    One day though, I had to carry something flat in the trunk. Coming home, I forgot to re-hang the cargo net. I noticed no more noise! I reconnected the cargo net to the top pins where it hangs in the trunk and the noise re-appeared. Since I took the cargo net down, I can still hear that noise very faintly now and again over a really severe bump, but it has largely stopped.
    Go figure, right? I'm guessing maybe something about the cargo net was causing or inhibiting either the flex of the trunk interior or the panel that covers the spare tire - but I'm just guessing - I have no #@$%^&*() clue at this point. :confuse:
    I had a '91 Accord EX Sedan that I hit a skunk with. It's last dying act was to spray the underside of my car. He must've gotten a good shot at just the right angle or placement, because from that moment forward, my air-vents smelled like skunk in the worst way. I drove around with the fan on high, sprayed lysol in the vents, even stuck a vaccum cleaner hose inside the vent. Ultimately, I had to have somebody spray some type of aerosolized anti-skunk deoderizer into the air intakes from under the car on a lift, while the fan was running. Even then, it still smelled faintly like skunk on hot days for a long time after that.
    But I LOVED that car - couldn't kill it - sold it with well over 100K on it and mostly everything original. Just goes to show - even a Honda that stinks is still better than most other cars!
    Isn't there a solenoid or something that raises the idle when the A/C kicks on? Maybe that's what needs replacing.
  • fukufuku Member Posts: 1
    I live in Miami and I am thinkng of going driving to Canada. I just changed the timing belts and the joints on the engine block(top of the engine...). Car runs smoothly. To be honest, I cannot complaint. Does anyone know what else I should before starting driving to Canada? Any major replacement or checking?
    And another question. Once in a while the green light on the dash board goes on! the manual says I should go to the dealer and check the transmission, which I did. Transmission turned out to be ok. I changed the radiator and the green light hasn't come on since .
    Cheers,
    Francis
  • vz1vz1 Member Posts: 1
    I need the help from better car experts than I am :)
    I got a strange problem with our 2004 Accord V6 (38,000 km).
    We are having hot weather now (32C). Yesterday my wife told me that the car developed some continuous scratching noise during the left turns, from the right side under the hood.
    I initially (remotely) suspected that some part (plastic cover, etc.) got loose, and the wheel is touching it when turning.
    After inspecting the car, I found no traces of wheel contacting the body. The noise was definitely there, and while turning to the left only! Going straight or turning right was OK.
    Shortly thereafter, I found that the water (I assume it was the water - no smell, no color) is leaking from under the right side of the dash to the front passenger floor. After a half-an-hour ride the water was all over the rug.
    When I turned AC off, the left-turn noise and water-dripping continued. After I completely shut the whole HVAC system, all stopped! No noise, no water in the cabin. I assumed that some mechanical part movement during the left turn may cause the contact of something with something, and the subsequent problem with water.
    So I went to the dealership today. First, they said they never heard about such left vs. right-side oriented problem with AC (they suggested it's AC).
    Then they checked something and told me they found the problem - the AC drain plug was clogged with leaves etc., and that caused the noise and the leakage into the cabin. I asked why it's only while turning to the left - the service advisor told me something like "the water inside whirls to the left, so it splashes out while left-turning". Of course, it was not a good explanation, but I decided that the main thing for me to get the thing fixed, so didn't ask more questions. They suggested that they "clean out AC overflow drain tube" (as in the invoice), and also replace AC dust and pollen filter, as it got dirty or whatever during the ordeal (and this replacement is scheduled for 48,000 km maintenance anyway, so they will not do that then). OK, I said.
    Got back there at lunch time, paid the invoice, and picked up the car. Immediately after I went out, I found that all the problems are still there! The noise and the water coming inside. There were differences though: the noise acquired the hissing tone, and now it went on not only when left-turning, but also when changing lanes to the left!
    I had no time to go back. I called the dealership and asked what exactly did they fix and I pay for, and asked for their advice on how to operate the car safely in that condition (should I turn HVAC off?). They said they will ask the mechanic and call me back. They never called me back for next 4 hours. I called them and learned that mechanic left for a while, and they will be closed in 15 minutes, so they have no info for me, and that's why they didn't call.
    I tried to be polite and demanded the explanation anyway. They called me back in 5 minutes (the mechanic came back to work), and said that the mechanic made a test drive, and everything was fine. Also they told me that it is OK to have AC on even if there is such noise and water comes to the cabin, it is safe.
    I am coming back to the dealership tomorrow.
    My questions are:
    - What is that problem? Did anybody have anything similar?
    - Is it safe to have AC on in these conditions?
    - Was it necessary to change AC filter?
    - Should I stay away from that dealership? :mad:
    Thanks a lot in advance, and sorry for the long post.
    Water comes to the cabin? They gotta be kidding. :mad:
    If it continues leaking into the cabin, have it fixed (by other dealer) ASAP.
    Electrical components inside the cabin don't react well to water.
    There may be some water left over after they fixed the drain.
    Does the sound like a squeaking belt? You could have a loose AC belt.
    With the car in Park and the AC on, turn the steering wheel to the left, see if you can hear the noise.
    Also let the AC run for several minutes. Turn the car off. Wait for some time and
    check if there is a puddle somewhere underneath the engine. If there is, the clogged drain is fixed.
    I assume it is hot an humid where you are? Man, it sure is here.
    The A/C system evaporator is inside the dash - with the A/C on it cools the air and removes the moisture from the air. This condensate drips off the coil and into the plastic housing then is SUPPOSED to drain out the bottom of the car via a rubber tube. If the tube becomes clogged then the water will either fill up the housing and "drown" the evaporator (at which point it will cease cooling the car) or it will overflow into the car - and sometimes both.
    Sounds like they cleaned the crud out of the tube but did not get it all and it stopped up again. I am not sure if you can see the housing and drain tube on you car is located - it may be possible to pull the tube off the housing and drain the housing yourself (using a bowl or something to catch the water). On my old '83 GTI this used to happen a lot and I would have to pull the tube and use something like a stick or pen to clean the blockage in the tube and in the housing.
    Your car would seem too new to be having this problem, however.
    Dennis
    In a '94 accord, yes. Leaves and other debris blocked the AC drain line. As I made corners, the condensate which should have been going to the ground would end up in/on my floor board. To fix it, they blew air up the drain tube.
    You know it's blocked if you have the car stopped, the AC is on, but when you look under the car, there isn't water drops comming down at a good rate as the AC runs.
    Now then, if your car is relatively recent model (04) and you are pretty sure you haven't been parking under pine trees or the like, and when you open the hood, the area below the windshield hasn't trapped much debris, you might be dealing with a collapsed drain tube. They blow air through it, and it opens, drains alot of water, then collapses again (maybe it's crimped).
    They should replace the drain tube probably.
  • bblachabblacha Member Posts: 160
    Definitely have the ignition checked out. A mechanic at a Honda shop told me, he sees a lot of Hondas of those years with ignition parts wearing out, especially igniters and rotor/caps.
  • shortbusdrivershortbusdriver Member Posts: 1
    Just got a new '05 accord (pretty much base, 4cyl, cloth interior, etc) and I'm looking for the shop manual for it. I'd like to be able to do some basic maintainence myself, and a shop manual has been a great help for other cars I've had. Can anybody provide a link or some information as to where I can get one of these?
    More questions: the car does not have power locks, nor does it have more than the 2 front kick panel speakers. I see that the wiring is in place for the rear 6x9 speakers, but I would like to add a set of components for the front, using the stock placement for the tweeters (up in the windshield corners on the dash). How nasty of a job is it to get to that? Is the wiring in place already? As for the power locks, same question: is the hardware in place already, and its just a matter of adding the wiring and the switches? I'd be more than willing to rip apart the interior if thats the case.
    Thanks for the help.
    You can pick up a repair manual at:
    http://www.handa-accessories.com
  • laffelady0813laffelady0813 Member Posts: 5
    The paint on my '05 Accord stinks. I believe that the whole car should be shipped back to China and never be allowed in the US again. I wish I had never heard of Honda.
  • korvsjapkorvsjap Member Posts: 4
    I just purchased a Honda Accord EX-L (4cylinder) automatic.
    I'm a bit sensitive when it comes to cars that I own. I tend to feel, hear and sense things that others wouldn't even consider or notice.
    When i'm at stop with the A/C on, the car vibrates a bit, which is normal. However, when the compressor kicks in, the vibration increases a bit, which is normal. Then the compressor cuts off and that's when the car lurches. I tried depressing the brake harder, but it still does it but not as much. I don't see this as normal because who literally steps on their brakes at stop?
    Anyone else having this problem? Am I being overly sensitive? Before, this is my first 4 clyinder in about 10 years. However, the previous 4 cylinders I've owned (hyundai sonata's) didn't have this type of problem.
