A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
All Accords are FWD and all V-6 Accords have traction control, it is not available on the I4 Accords for 2005.
With lots of snow I HIGHLY recommend getting a "winter tire package" from the TireRack.com . Four spare wheel with 4 snow tires then just change them over each year (no re-mounting and balancing fees). Four grippy snow tires make a WORLD of difference VS the all season tires that come on the car.
Dennis
http://www.vtec.net/news/news-item?news_item_id=53478
I would change the fluid itself and check any related sensors first just to be sure. However, to change the fluid near-totally you would either have to do the (partial change + short drive) x 3 method or do a complete flush/fill.
Also, does the car itself take that long to warm up, 5-10 mins for it to be above the "C" mark? Or is it only the tranny that takes that long to start working more normally?
good luck
What do you think is it??
Chugging> perhaps some bad gas? Put a couple cans of HEET in the tank asap - this will absorb any moisture that may be in there. If it does it again within the next tank or two, then perhaps get it looked at, otherwise it may be nothing. I had a Lincoln that would idle rough about once a month until I shut it off and restarted it. 3 different mechanics could never figure out why.
How about try this and let us know if you still hear the thumb: slowly and firmly
pump the brake pedal a few times before you put the car into R or D in the
morning.
Lately I stopped pumping the brakes before driving out and I heard the noise.
I will try it again the next time I drive mine (next Friday). Gotta piling up mileages on my 89. Aiming for 210K.
It blows cool and will eventually get cold on a long drive but will not blow cold just driving around town. After changing the O-Ring I paid the place next door to my job to pull a vaccuum on it and they said it pulled and held a vaccuum fine. So I put on the retro fit couplers and started it up to add freon. The tag on the car shows it holds 30oz of freon but I was only able to put in 15oz (of oil and freon, a premix can). And the guage now shows it to be overcharged a bit.
But it does blow pretty cool, and gets cold on a long 10 mile or longer drive.
Any ideas? Please help because it's darn hot and I'm broke of course!
Tuesday they are supposed to call me when they arrive and no one calls me all day long so I am walking out to my car and I see a piece of paper on the windshield from the glass repair company stating that the work has been completed, ect ect.
I was not expecting a flawless fix at all. I expected to see some weird little light bending through the clear resin patch.... What I have now looks like they filled the hole with Elmers glue or some semi-transparent white paint... Not good. Sure the hole is gone and it's got a hard material in it now... But I've got what looks like perpetual dirt on the windshield now (looks like a big bird dropping kind of) and it's in that annoying position where it's always in the corner of my eye when I am driving.
Would love to pay the $250 to get a new windshield and it's probably worth it just to stop being bothered by this "dirt" looking thing on my windshield... But then there's the issues of what if they both up the replacement?
I miss my old Civic... It could have been hit by a boulder and I would not have cared about it so long as it drove.
I think you need quotes around "professional" after they way they fixed it. As was mentioned I would call the insurance company and complain.
Dennis
I can't judge because I haven't seen it, but I do know with rattles, noises, problems, I keep noticing them when I wouldn't normally note them once they've been a problem.
Good luck. Your insurance company will probably treat you right. I had a windshield replace and the company compressed the foam on the dashboard and left an indention. A year later my insurance company offered to replace the pad.
Did you try looking behind the trunk liner to see if you can release the filler door from there?
GOOD LUCK
(also does anyone use fuel injector gas treatment?is it worth putting in every other fuel up or a waste of money?)
Your nick reminded me, older Hondas (especially accords) used to not run as well with Bosch sparkplugs (especially the platinums) installed. This was doubly true for the 90-93 accords. Changing out the plugs or at least pulling them out to check might not be a bad idea in any case. Perhaps your missing performance lies somewhere in the tune-up items section.
down on the lever in the car, and try to pry the door open. It should not be hard to open as I doubt the cable is actually broken. I've had to do this for years with my Mazda Protege. Then just close the door back 'til next time. You might want to have a cloth to use with the key/screwdriver seeing as your car is near new and I know you don't want to damage the paint.
Hah! I had the same problem with the same car ('92 Protege)! What I actually did was use a piece a string with a loop on it to pull up on the gas filler release lever while simultaneously pushing on the hinged edge of the filler door so it would open. It looked utterly stupid, but it worked and I wasn't going to sink any money into a car with 150K on the odometer.
The sound come up after I turn (from my drive way to the street) while I'm steering back - almost between the 1st and 2nd gear.
Tomorrow I'll try to drive on 1st gear and shift manually to D or 2nd and see if it happens again.
and gently step on the gas pedal. Then one can feel a slight thump at the gas pedal. It doesn't happen all the time though.
I don't know what it is, but it doesn't affect the handling of the car. So I wouldn't
worry about it.
It's my understanding that the V6 Accords use a "drive by wire" for the gas pedal. With that in mind, I'm puzzled why you feel anything in the pedal. I would think that any vibration from the engine would be totally isolated in the pedal, since they are not cable connected.
I have a 04 4 cyl Accord, and I also hear a noise a few seconds after the car is started. I'm not sure what it is yet, but I'm thinking it's the A/C clutch kicking in, will have to do some playing around and see if starting the car with the climate control in the manual mode makes a difference.
Mrbill
http://home.earthlink.net/~jkessel55/Honda Transmissions.htm
As for the creaking noise from the window, mine is on the front passenger side, but still the same as you describe. In fact, I have my car at the dealer today and they said they lubricated the rubber gasket that goes around the window because it appeared to be a little dry. So we'll see if that solves the problem.
I've had my car in to the dealer at least 3 times for the whistling noise, and they cannot diagnose the problem (including today). They hear it, but cannot find the source. This is driving me crazy. I have to keep the radio or CD player turned up high to avoid hearing the whining/whistling sound. It started out when I drove between 60-70 MPH; now I hear it between 40-60 MPH.
I want to know if anyone else is having this problem too. Maybe we should contact Honda headquarters about this?
I was driving home last night and my speedo quit working. Two minutes later the yellow/orange check engine light came on. I pulled over and checked the oil and it was fine. It didn't start running bad or anything. Today the speedo still doesn't work and the check engine light came on after about 8 minutes of driving the car.
Any clue what is "wrong"?
Thanks! Leah
Could this be your problem too?
It sounds like it's coming from the sunroof, but it's definitely associated with the accelerator, so I suspect it's just the car's acoustics that are making it sound like it's coming from the sunroof. I can still hear it when I close the sliding sunscreen, but it's definitely quieter. Occasionally, I can hear it even if the sunroof is wide open.
I took it to my dealer this week, but they couldn't do anything. I'm not sure they ever actually heard the sound. Of course, when I went for a drive with the technician, it didn't make the sound!
good luck
In Europe, RON is most commonly used to specify octane rating. This is the source of some confusion among owners of some European cars. Fuel with 91 RON in Europe is roughly equivalent to 87 AKI and fuel with 95 RON is roughly 91 AKI. So a car sold in the US and requiring 91 AKI would be specified as requiring 95 RON if it were sold in Europe.
Sounds like either it has been a bunch of miles since the last change and/or the person who did the change didn't reset the "service monitor". Look in the owner's manual, but I think on your car this would come on every 7,500 miles if not reset. On my 2001 S2000 the light just comes on and stays on once it has been tripped - if I recall correctly.
Dennis
Do you have any ideas what causes that LOUD and irritating noise? What am I supposed to do??? Replacing more stuff?? Any wisdom??
Any ideas as to what this could be? The car still runs fine but I'm not taking any chances.
Steve
