Visitor Agreement.
I really don't know that much about cars, but all cars need their timing belts replaced, right? Also, when should I get mine replaced? Immediately?
Anyway, sorry to sound dumb, as I only know very basic info, and thanks for your input!
Does anyone know what a cam follower is? i guess its broke in half and something about a needle bearing as well.
everything looks good so far. What should I pay attention to, any Accord specific problems?
You are wrong. It should be:
- Older model Honda: Insert key to hole to reset it.
- Newer model Honda: (1) Turn on ignition key (but do not start engine), (2) Press and hold trip odometer reset handle 1 minute or more until "Mtn. Req." light goes off.
Anyone have any ideas whats wrong with the car and why its doing this? I was able to drive it home fine. :confuse:
Otherwise of course, you could have a trustworthy mechanic check it over real quick.
good luck, and let us know what happens
let us know
My questions are -
1.) What was it that rattled?
2.) Should I get my car checked out, if after all that, there seem to be no problems?
The car (as noted) is a 1994 Accord LX with 103000 miles on it. Thanks ot anyone who can answer.
-Chris
Leah
I have a 2001 Accord, it has 49,000 miles on it. I had my 45k mi maintenance done last month. Now my check engine light is on. It came on last month, but went away on its on. I was told it was probably the gas cap not being tightened.
It is back on now, it stayed on for 2 days went off and now has been on for about 3 days. Now the CEL is back on, I went to the AutoZone near my house, and they gave me a code of P1259. The guy looked it up and he mentioned something about the "Kill switch, this happens when you get in an accident, the car is suppose to shutdown." I have not been in an accident and I have gotten the car maintenanced on schedule.
If anyone has an knowledge of the code or of how serious it is I would appreciate it.
I know I am going to have to pay $100 for the dealer just to "diagnose" it.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=Acco- - - rd&catcgry2=2004&catcgry3=2DR+EX+V6+NAVI&catcgry4=KA5AT&catcgry5=MIRROR
Sorry, I cant tell you how to take it off. Mine has been creating a slight wind whistle lately so, if you don't mind being a guinea pig, I'd be interested in how you remove yours. It appears to be just a snap-on component. Mine's quite flexible.
It's not a lurch, but the car feels like it lurches. Even a nudge seems weird. I've driven several 4 cylinder cars over the years and have never experienced this. I have to literally step on the brake pedal and even when i do, it nudges/lurches a bit.
i was hoping there would be other owners who have the same "problem" so that i can feel rest assured that this is a Honda problem.
Same things happend about 2 weeks ago. I was going down the road, and it shut off completly. But this time, it wouldn't start at all, so it sat tehre for a day and a half until we towed it.
Also in the past, it just has not started at all. I'll sit there, clutch all the way down, key turned in and it just sits turning over, and nothing works, but then i would go back about anywhere from 20 minuetes to an hour later and it would catch and start right up.
Since buying the car 2 years ago, ive had a new clutch put in, new distributor, new rotor (and a lot more done to it). Ive taken it to the local Honda dealership, and 2 local garages that specialize in foreign cars, and they can't diagnose the problem.
I am posting this wondering if anyone else has had any of these problems, and if you have, how have you fixed them?
I know thats probably not the proper test but it seemd to tell me the problem. While i was driving this morning I really slamed on the gas and when the RPMS got up high before shifting the lights on the dash turned off(the warning lights that were on before) however the wining noise got to be more high pitch and noticable. Maybe the alternator put out enough juice to reset the computer?? Either way, I took it into honda to have it replaced. If it ends up being something else I will keep you guys posted.
That's another reason gas is more expensive in Europe - they have no low octane gas like 87.
you might have lost something in the way of the plastic shielding that protects the front bottom portion of the engine (forgot what it's called) from road debris, or maybe one of your wheels made contact with a wheel well liner it deformed, rattled for a while then popped back into place.
it's possible you made contact with the cat convertor, muffler and exhaust piping -momentarily dislodged the assembly so it wasn't hanging down on it's hangers properly, making contact with the body, and eventually it popped back into place.
who knows? i doubt anyone can tell you with certainty...this is what happened... nor, ...no worries... without being able to look at the vehicle.
why not go to an independant specializing in honda repairs and have them put it on a lift to visually check it out? they'll probably do that for free.
P1259: Immobilizer to PCM signal error problem
That is the code and the error that I got from Autozone when they checked the Check Engine Light.
I have a 90 accord and the helm manual for it and code 8 = TDC Position Sensor.
Good luck...
Re P1259, try here:
http://www.asashop.org/autoinc/jan2005/techtips.cfm
From an all-acura website:
"For those of us who can never go fast enough, uttering the words “my VTEC isn’t working” is one of the most depressing things to say. This problem is usually rears its ugly head by sending an error code (P1259) to your ECU. A few common problems people run into are: insufficient oiling, VTEC pressure switch or solenoid malfunction.
If you ever receive this error, don’t immediately freak out. It’s common for older engines to burn/loss oil (especially the ones which have been abused!). Given enough time you engine will lose so much oil that it doesn’t have sufficient oil pressure to activate VTEC. When this happens, as you could imagine, VTEC stops working and your check engine light will come on. To remedy this problem, simply check your oil level and refill it to full and then reset your ECU codes and you’re good to go."
You should also Google for "P1259". There are lots of links. An even better solution would be to consult with the Service Adviser at your nearest Honda dealer.
keep us posted if possible
