Visitor Agreement.
(i tried using the fuel injector fluid, and the car started right up. but if there is a problem i want to fix it, and not just keep buying the fuel injector fluid.)
Here's a link for replacement, etc: http://home.earthlink.net/~michaelpkeefe/HowTo_MainRelay.htm
You have a chip in your hood because you ran into a stone or other debris kicked into the air by a truck or other vehicle. Why would you presume that it has to do with the design of your vehicle?
This happens to every brand of car, thousands of times a day, all over the globe. Sorry, but it just happened to be your turn this time.
I find this statement to be absurd. My major reason for buying a 2005 LX was based on the way it drives. (The standard curtain air bags was another reason.) I found the Camry's handling vague. There is very little feedback from the road and the steering seemed almost loose. The mild sensation of sway produced during sharp turns was particularly disturbing to me. It is most definitely quiet and soft.
For whatever reason, I happen to be one of those drivers who likes a firm ride.
TIAFTH.
Fix the brakes. That's why the idiot light is on. Has nothing to do with the lights.
No. No, man. If the '98 is like my '97, it has two brake warning lights. The first is for brake hydraulic malfunctions and when the parking brake is on. The second, located on the little car diagram (the one that shows when a door is open etc), has a warning when a brake light bulb has burned out. I have no idea why changing out the failed bulb hasn't resolved the light (if in fact that's the one that is lit).
If it's the other warning light, then you are right.
my honda accord 89, have the brake lamp, light on, in the panel.
when you start the car, it checks the doors, there, in car picture, by the trunk, theres this red letters that says break lamp.
Someone knows what it means?
I have a leak in the lens, so when it gets really wet the lamp goes on.
I guess there is a short.
It goes out when it dries out.
A few years ago, the dealer said I had brake light wires corroded (sp).
They fixed it.
Now my light is on because my left light is out.
I bought the replacement bulb, but have found the old one corroded to the socket.
I guess I need to buy the socket too.
S
1. The brake fluid level is low in the reservoir.
2. Your parking brake is on.
Other things to check is the hub cap if your car has them, or the center insert in the aluminum wheels. Either of those can make noise if they are loose.
has 67K miles on it now.
Don't forget the alignment after replacing the shaft.
Damn, I'm having exactly the same problem with my Accord 03 cruise control. I haven't used the cruise control for a while and now when I turn the switch ON, it stays ON alright but when I press the SET button, the green light is on for a few seconds and off right away. The cruise never engages.
What could possibly be wrong with this car? I also noticed some engine hesitation when I try to accelerate (car kind of vibrate at it struggles to gain speed).
I'm worried.
Thanks, ramida
One shop has lifetime parts, 6mo 6k labor warranty. Other has 12mo 12k parts and labor warranty. Which could be better?
96 accord dx, 109k miles.
Thanx so much!
what is NTB?
If you were going to do it yourself, it doesn't cost much for the boots, I paid $32 for all 4 boots for the front of my 88 Accord. Its all labor.
Mrbill
What does it mean by have rebuilt shaft installed then to have it rebuilt again? Am I gonna take the old shaft welded and take it back home?
National Tire and Battery. Used to be a part of an old name hardware store chain, Western Auto, I think.
Bought partly by sears at the time. Then later totally owned by Sears.
Several years ago Sears closed a lot of their stores that were near Sears stores. Some locations were bought by another tire company.
With over 100K miles, it's better to replace the shaft than replace the boot.
You are probably accidently pressing and holding, the left Door Open button on your key. Holding the button in will first open the door locks and then open the windows to ventilate the car before you get in.
I replaced all the brake lights and the light went out. That said, removing the carpet without damage was a challenge.
Does anyone here know if there is a place here or else where, where I can vent about the problems I have been having with this car?
But your post has really helped me understand the real problem...Me and my friends were thinking that it is a AC problem and started it could be a big problem..but as you said it is not...
I don't want to seem like an advertiser so I'll just say that if you type in "car grilles" in Google, a bunch of links will come up. These should help you with your problem.
Good luck!
Did you get the entire in-dash navigation unit, including the 6-CD Changer? Is it the exact dimensions of your non-navigation radio unit? If not, you may have a bit of customization to do. Did you get the satellite antenna that's mounted in the rear parcel shelf? Did you get the ceiling console-mounted microphone for voice activated guidance? Did you get a steering wheel with the two buttons needed for the voice activated guidance? The navigation unit can't work without those items.
I believe that you may be the first one in this forum who's actually bought such components. So, you may not get much installation help here.
I hope that you are aware of the fact that the navigation system also integrates with the audio and climate control systems, providing voice command control over them too. You may have to buy a bunch more components before this all works out.
Best of luck. It's a great system, but probably best purchased factory-installed.
I had the same issues with steering with my accord 03 when I got it and it came down to this.. the tires that come with the vehicle are absolute crap. I got new tires Faulken Ziex and my handling in every weather condition went from crappy to superior. It feels like I have a sports car now.
NEM
If someone can help me, I have a 90 Accord EX ehich for the last 3 years it has been giving me problems starting. I was overseas so my wife jsut let the car sit in front of the house. I have already replaced the main fuel relay. Here is my problem, the car won't start (as if has a low battery) I push the car just enough to get it rolling and pop the cluck (not fast enough so get it running) tunr the key and the car starts like a champ. What is going on with it, it is enoying since sometimes I can't tactically park the car on a hill where no one parks in front of me so I can let it roll. Battery is good, I had the alternator tested with battery also and it was good. I will appreciate some helpo since I don't want to get rid of it. :mad:
