Visitor Agreement.
Note to Carguy,
If yours happens more in the mornings on first starts then I would leave it at the dealers the night before so they can start it first thing also.
Anybody know if this stuff can be obtained on the open market or is there another carbon removal system that works and does not involve a repair shop.
Point is this-if you have an accord and are getting a 90 blinking code, clean or replace the O-ring and this may fix the problem which appears to be rather common on these vehicles located in snow country.
By the way, this dealer replaced all drive belts including timing belt for $375. Dealers in the Chi area wanted over 600-OH YOU HAVE TO CHANGE THE WATER PUMP ALSO. yeah right. Nice to find a dealer you can trust.
FWIW, I understand you might as well do the waterpump while you've got the whole thing apart. It's typically less than $100 for some preventative maintenance. Same thing with changing the axles when you replace boots - you've got it apart - you might as well.
BTW, I mentioned to my dealer about the steering "sensitivity", but didn't get much of a response. At least it sounds as though your concern was acknowledged. I would like to know if they come up with anything.
Do you think this is just the distributor o-ring leaking? Appreciate your thoughts and what it might take to repair.
This is my first message to this board so bear with me here! My 1993 Honda accord wagon will NOT shift on its own any longer! I noticed this about 2 months ago when it was shifting on its own from D4 to D2 or D1.
The light is stayinh lite on D4 no matter what other gear I shift to.
I saw a suggestion somewhere to disconnect the battery and see if the electrical system will reset it somehow?!?
I am now using D2 in low speeds and move up to D4 when I reach a certain speed! I have had this car for 4 months and noticed it shifting a few times down to D2 by itself once or twice a month or two ago! HELP!
What do I do? A mechanic told me I have a very expensive problem on my hands?! I am afraid to now even talk to another mechanic because it may be something simple but it also may just be an expensive problem. Has anyone ever had this happen to THEM! I have plans to talk to another mechanic this soon!
Anyone out there with similar problems!!!!!?
Any suggestions as to what this might-this is still covered by the extended warranty. Suggestions have been bad gas cap or bad evap cannister.
Any suggetions.
Thanks much.
If it is a standard, then use the oil they recommend and make certain and fill it up to the proper level. Fill it on level ground. The differential fluid and tranny fluid are the same critter-the gears are in the tranny and not a seperate place. Change honda atf every 30K-just changed mine at 30K and the fluid was a bit dark but not smelly.
At any point in time or even now did you here a repetative clicking sound that would stop once the brake was depressed? Even if not it still sounds to me like a bad TCU (trans control unit)located on the passenger side floorboard(under carpet)next to the ECU.
bburton1
There is a hose assymbly that comes off the evap canister vent shut valve that goes down to a "T" fitting spyders crawl up in those hoses and create restrictions with there webs that get picked up by the computer and cause the P1457.Pull those hoses and check them out..
It probably won't cost that much.
A small number of early production MY 2000 V6 automatics had a defective part that was the result of a supplier [in Japan] making a material change without consulting Honda. The symptom was a very loud, unmistakable clunking sound when backing up. Suspect production was late '99 to very early '00. To my knowledge [and I just checked the TSB data base] there are no significant issues with the '98s....and my '01 V6 has been a wonderful car, I might add...
But i asked him if he changed it and he said he did. Is unlosing the timming a job that i can do my self or do i have to take the car in. And there are a few scratches on the car, but i cant find the paint number of the car (color of car is like a metalic brown). Thanx for your help.
Also it seems very slow when climbing up even slightly inclined roads. If I am at 65mph and I reach a slightly inclined portion of the freeway my speed drops to 50 mph. The same thing happens even if I floor the gas pedal to force it into a lower gear.
Has anybody else experienced similar problems. What is the solution? Are there any known TSBs?
I have a 91 Accord Ex - Automatic and was told that there was no transmission filter and it does not need to be flushed. He said they just drain and fill with new Honda ATF fluid. Is he right? Should I have it flushed?
Mike
I don't believe there are any cars currently sold in the US that have a V-4 engine. Lots of V-6 and V-8 engines, but no V-4's.
Brand new. 5000 KM.
NO START this morning. The engine cranks, but does not catch. Whinny sounding.
Have not driven the car in 4 days. Parked in my garage. Not exposed to any moisture or cold weather. No problem the last time I drove it. No
warning lights... nothing!!
All ideas and suggestions will be MOST appreciated.
Thanks as Always,
R.
P.S. Tried to start this afternoon, no luck.
We have replaced a few coils in that year for similar problems but there are other things. Have you tried anything else yet? You have probably told me/us but I forget.If not then the best thing is to go in and see what they say.As for the starter it should be fine they take alot of abuse...Good luck
scorpio007
Try cranking it with the gas pedal fully depressed for a long crank atleast 45 secs and see if it tries to catch. They sometimes will start that way.Good luck
As it stands, I do know that the 10ish second cranks I tried have NOT worked.
Someone asked if it had fuel....... a whopping full tank.
Have you (or anybody else) run into this problem with a 2001 before. If so, what was the matter and how was it solved.
Thanks !!
R
