Honda Accord Problems 2000-2005
12829313334256
  • peggyppeggyp Member Posts: 7
    the antenna does not work. it will not go up. what can I do besides putting a new motor in?. i do not want to spend the money. i know honda antennas are notorious for not working. can that be taken out and just put a stationary one on?. can't use the radio without it.
  • auburn63auburn63 Member Posts: 1,162
    If the power antenna is inop and it is the motor and not just a broken mast. Take out the antenna and try putting in a Honda manual antenna.
  • jrct9454jrct9454 Member Posts: 2,363
    Nothing unique about Honda - all power antennas quit at some point. It's one of the reason MB stopped using them. Auburn's suggestion is the only one that makes sense, and what we did on our 91 wagon...get a fixed antenna, set at a length that works and doesn't offend your sensibilities, and move on...
  • fritz1224fritz1224 Member Posts: 398
    Well, if I had known about this before hand I probably would have waited longer before doing the first one. I wouldn't have taken the chance. But since no one told me and no information was available in the manual, I'm not going to worry about it. I just wonder how many other owners find this out after the fact. I even told the Honda tech I was planning on doing the first one at 500 and he never said a word.
  • scooter64scooter64 Member Posts: 21
    Anyone ever have a problem with stalling in wet weather while depressing the clutch pedal and brake at the same time? It's happened to me about 5 or 6 times now. Never happens in dry weather, just in rain and wet snow. I hate to bring it to the dealer since it only happens under those conditions. By the way, it almost got me killed when I stalled in front of an oncoming snow plow!
  • muvb14muvb14 Member Posts: 11
    Hi, I have a 2001 Accord v6 ex, silver color. It seems as if I barely need to touch the rear or front bumper and the paint will come off to the black bumper color. I had a 94 accord that a banged the crap out of and while it got scratched, it was less noticable because you never saw that black of the bumper. Does anyone else have this problem? The paint on the bumper where it peels when I barely touch it seems as thin as can be. Could this be just a problem with my cars paint job or has anyone else had this problem?
  • silvercoupesilvercoupe Member Posts: 326
    I changed the oil in my 2000 4 cylinder at 1,000 miles. At 20,000 miles it uses no oil and runs fine. At the time I had not heard about the break in oil. If I'd know, I would have waited until 3,500 miles for the first oil change.
  • ravynravyn Member Posts: 101
    no, you're not alone.. adg and i have both posted about the bad paint, as well as several others. i wish i was one of the people who haven't had problems. though i'm not happy about the paint on the bumper, i'd be more likely to let that slide as opposed to the paint on the hood/roof/front side fenders of my car..since the bumper is all plastic.
    it's the quality of the paint everywhere else that really p*sses me off.
    but yeah, even on my back bumper. i have scratches and dings to a WHITE undercoat (that's also beyond me) from people bumper-parking.
    i wonder at how adg44 got such a fast resolution from honda, even if it wasn't what he was looking for. it's been a month since the main honda office in CA has called me back, and i just keep getting angrier.. =P
    Mine is signet silver and I used some bug and tar remover on the lower part of the rear bumper. Seems like the paint has rubbed off and there is a light yellow color shaped like the pattern of the tar spot that I was trying to remove. Luckily, it is a very inconspicuous location and only seen with close inspection.
    Silvercoupe, glad to hear no problems with your "premature" oil change as well. This was my first brand new car and I was determined to maintain it well. Somewhat disheartening to learn my zeal could have had negative consequences, but I really don't think it will. What's even worse is the lack of information concerning this issue when I bought it.
  • amwebb2000amwebb2000 Member Posts: 2
    I had the brakes and rotors replaced on my 94 accord because the steering vibrated when I depressed the brakes. The rotors had already been turned, twice and pads replaced. When I hit brake from speeds in excess of 30 mph It is still vibrating. This can be seen in the steering wheel. Please help me. Thank you
  • lancerfixerlancerfixer Member Posts: 1,284
    Bad idea. Go ahead and replace them entirely. While you're at it, check wheel alignment and balancing, too.
    p.s. Get OEM rotors! Don't cheap out and go to Midas or someplace like that.
    I should have stated that the rotors had been turned twice to fix the vibration problem. THEN, it was decided that they needed to be replaced. This was done today. the car is in the same shape as before. I don't know what kind of rotor they are but they are supposed to have a lifetime warranty ( somthing from Uniroyal. (hubby ook it there against my judgemet)). Im taking it to a honda place in the morning. I spoke with a tech today who agrees that if the rotors are china made then this could be the problem or it could be a suspension problem. The car has 94k miles.
  • hectorochoahectorochoa Member Posts: 4
    I own a 2001 Accord and the owner's manual says to use 5W-20 motor oil. First of all, I cannot find it at any stores near me. Second, it seems like a very light-weight oil to use in a car with such a small, high-revving engine. I suspect this is a way for Honda to market and sell us their oil and filters.
    Would it harm my engine in any way to use 5W-30 or 10W-30 motor oil instead? Please consider that I live in a warm climate where it gets to be very hot during the summer.
    We have talked this one nearly to death, but in the interest of saving you the time of paging back several hundred messages:
    Don't fuss over the 5-20 recommendation; it's what they put in the crankcase initially, and what they had in the crankcase during the EPA test to get the best possible results in the fuel consumption tests. Any SJ oil with at least a low viscosity of 5 will do; my dealer and I have agreed on Castrol Syntec 5-50 synthetic, which I bring to the shop myself [it's easily available at the discounters], and which gives me peace of mind for both our 100F summers and 30F winters.
    Right up until quite recently, a lot of dealers didn't have the 5-20 available in their shops - you don't suppose that stopped them from changing the oil in '01s?
  • spokanespokane Member Posts: 514
    I believe you, bobgordon, but the Honda people in my area are not clear on the break-in oil usage. If you were putting a new engine in a Honda, would you be able to obtain some of this oil? Do you have a part number?
    I have replaced the original oil in a dozen or so new cars (Honda and others) within the first 1000 miles and was able to monitor their performance for several years following. None of these engines experienced any internal problems or used more than 0.1 qt per thousand miles. I attribute this success to oil change intervals of 3500 miles or less (as bobgordon advocates) and care to avoid any overheating. I am confident that the "early" first oil change did no harm but also expect it didn't really help.
  • mack20mack20 Member Posts: 40
    Hi...
    Thanks for anwering all my questions in the past!
    The power antenna on my 94 Accord got bent. (Garage door wasnt fully open). There is a
    90degree bend approximately 5 inches from the top of the antenna. The antenna motor
    now makes a grinding sound when both going up and down.
    A few questions.
    1) How expensive is it to get another antenna installed (i.e time wise & part cost)?
    2) How do you take off the old antenna. I was reading that there is a locknut and washer. How do you open the locknut? is it some kind of special tool? I dont want to damage anything more! I have installed an aftermarket stereo. I just noticed the stereo has no off button toi stop the antenna from coming up. I just want to prevent damage to my antenna motor by removing the antenna.
    3) Is this job dealership dependant? I like the dealership, but they are really busy down here...
    Oh well....this is just a pain.
    I await your advice!!
  • mmanojmmanoj Member Posts: 1
    Hi all,
    I am having a problem with my 93 accord LX. The engine temperature is going up whenever I switch on the a/c (It is normal with just the fans on). Any ideas. Please help.
  • blume1blume1 Member Posts: 25
    My " engine thump at cold start" was fixed today, as was my check engine light (twice in 1600 miles). The fix for the thump is different for the 2001's as opposed to the earlier mod years of this generation. The kit is different. The check engine light was a defective valve that normally detects a loose gas cap. the second time it set a code --fixed!
    It is refreshing to have a service dept. who really cares about the customer -- even knowing the customer did not buy the car there. Dealer name-- Raegen Honda, Jefferson City Mo.
    In theory the antenna is easy to replace. There is a special tool but you can usally use needle nose pliers and twist of the nut, then turn on radio and pull out antenna mast with cord.Now, it is not always that easy as the antenna gets corroded in the housing(tube) and usally breaks off inside there if you are not carefull.If all you want is to get the antenna up and leave it there, then turn on the radio, pull it up all the way and then inside the trunk pull back the linning and unplug the antennas power connector.
    Good luck
    Auburn63....you are the best!! Thanks for answering my power antenna questions!
    I talked to a service tech at my local dealership. They would have to order
    in a new antenna in 3-4 days. Additionaly, the antenna alone costs around
    $79 Canadian dollars. Another half-hour for labour....total cost around $120
    The service advisor at the dealership was pretty helpful. He told me it was a
    relatively easy job....
    I'll try straightening out the antenna first. If it breaks then maybe i'll try
    my luck at a junk-yard.
    Thanks again for all your help! This is the 3rd or 4th time you have answered
    my questions!
  • m9431m9431 Member Posts: 38
    Help--my new Accord 4-cylinder 5-speed has been back to the dealer 5 times, evening involving factory techs, THEY CAN'T REPAIR IT! The problem is that the engine hesitates and stumbles. Usually at lower RPMs, it can feel like it's not getting enough fuel; poor low-end torque. They are unwilling to replace components that are likely suspects. Honda hasn't been very helpful, now suggesting that I trade it in and buy another! This may just be my last Honda; I'm so fed up with this vehicle and Honda.
    Mack20,
    You welcome I am always glad to try and help...
    m9431
    We haven't seen any of them do what you are complaining about as of yet. We did have one or two that did that one time a day within the first 5 min of driving. Which that turned out to be a normal event due to the evap test and timing of that with a decel or stop or slight hick up during accel at same time as test. Other than that sounds strange, have they replaced the pcm/ecm ? Or any other component as of yet? What have they done that you know of ? If you feel like it post some more info on your situation..
  • stump21stump21 Member Posts: 41
    Sorry if this problem has been mentioned before, but I am too impatient to read thought the past 1500 messages. My car is a 1997 Accord SE. A/C condensation water has started to leak inside the car on the passenger side floor. Anyone know why this is happening? The car has 44,000 miles on it and I have never had a serious problem with it. The drain outside the car is not plugged. Thanks!
  • bullit71bullit71 Member Posts: 5
    I have a '98 Accord LX V6 Coupe with 68,000 miles on it, have followed the recommended service schedule, and the car now has the following problems:
    1. transmission shifts hard when cold from 1st to 2nd gear -- honda service has diagnosed that I need a new transmission -- cost (retail) $5,998
    2. whine coming from engine when I turn lights & AC on -- honda service has diagnosed that it is due to a bad bearing in the alternator (a GM Delphi unit) and that I need a new tensioner belt --
    cost: $525 alternator/$175 tensioner belt
    3. The fuel gauge reads improperly (the fuel tank sending unit replaced has already been replaced once before) -- honda service has not been able to find the cause
    4. grinding noise coming from right front wheel -- honda service has diagnosed that I need new front brake pads and rotors. cost:$466
    (this is my second set of front brake pads and have already gone through 2 sets of rear brake pads)
    In addition, the "check engine light" has come on in the past on 3 different occasions -- EGR port has been cleaned twice and the EGR valve, PCV hose, and intake manifold chamber have all been replaced
    This is my 5th honda (my 3rd Accord) and I haven't experienced these problems (except for replacing the brake pads and rotots) on any of the other cars. This is getting expensive & I'm getting tired of walking. Users ronga, motiwala, kbarry, Z_, dano38,purma1_us -- I feel your pain. If anyone has any advice on how to get American Honda to pay for out-of-warranty repairs it would be greatly appreciated. Thanks.
  • ucat4ucat4 Member Posts: 1
    I recently test drove an Accord V6 LX and I heard a feint "whining" sound coming from the engine when I accelerated. The sound was similar to the sound a radio puts out with a bad ground connection. With all of these transmission issues, I was kinda leary and did not purchase the car. I did test drive another V6 and did not hear that sound. Does anyone know if this is normal or what it may have been? Someone said it might have been the "Grade Logic Control".
    There is a ground wire/strap that if it is on the right fender and connects assros to the motor near the power steering that can cause that kind of a whine. We usally move the ground to the front of the car and the noise goes away. Other than that I haven't heard any other noises like that from these cars..
  • keytonekeytone Member Posts: 1
    I am comparing the Honda Accord LX 5sp (2001) vs. the Saturn L-200 (2002). The Saturn looks REAL GOOD compared to the accord but the Honda reliability is there. Not much history for the Saturn. They've made improvements on the Saturn though, from '01. Similar prices for both. Why is there a put down for the Saturn on the 'Build Quality'
    Any info is helpful.
  • prodigyprodigy Member Posts: 7
    ucat4 and auburn63. I have a 2000 v6 and have also experienced the whining. It occurrs between 35 and 40 mph and only when the auto trans is in top gear. I can manually down shift and the noise goes away. It sounds like transmission gear noise and is not very loud. Any thoughts as to what this is? I plan to call it to the dealers attention on the next oil change. Any recommendations on what I should look for or tell the dealer?
  • bobgordonbobgordon Member Posts: 156
    Spokane,
    Sorry I didn't get back to you sooner. I just got back from a MUCH needed vacation.
    As per your question. I have never seen the oil Honda uses in there factory engines sold on the open market. You have obviously answered a lot of peoples questions. I am glad to see the study you did on engine oil usage did not turn up anything abnormal. Why Honda decided to use a special oil for engine break in???? My only guess is that as we all know it's an all aluminum engine. Maybe they (Honda) feel that this oil will minimize wear during the critical break in period.
    Stump21,
    Check that any caulking or foam around the steel A/C tubes going into the car is still intact. Not sure where you live but the heat and humidity we have been experiencing lately has a tendency to create a lot of condensation around the A/C components. Since you checked the drain, and that flows freely, you also could have a separation in the blower housing allowing water to exit there. These are a few places to start. Hope this helps.
    Thanks, Bobgordon. Varied reports from service departments for different makes of cars has led me to watch for facts on break-in oil - so I often "jump in" whenever the subject arises. Only Volkswagen seems adamant in their insistence that break-in oil must be left in the engine for quite a few miles. I am convinced that the key point regarding engine oil is as you said earlier - frequent changes of the oil and filter are an inexpensive way of assuring long engine life. Perhaps excluding VW, whether or not the original factory oil is changed at a shorter interval is surely less important than the long-term care of the engine's lube system.
    The click you describe is normal.
    Our '01 EX V6 varies from 20-22 mpg around town to 25-28 on trips. Tire pressures are the factory recommended 30 psi; AC is on about 80% of the time.
  • dcddcd Member Posts: 25
    1998 LX-V6 coupe 40,000 miles:
    At times the engine doesn't even seem to have the power of a 4-cylinder. Check Engine light was on, I took it in and paid $150 to clean carbon out of the intake (or something like that) and the light is not on now but problem did not go away. Often it will downshift just to accelerate lightly from 30 - 45 mph. It is really hesitant at times. Anybody experience this?
    Also am experiencing transmission shutter in overdrive at about 1700 rpm (55 mph). Very annoying when cruise is set at 55 mph.
    I have Honda Care warranty, but am wondering if it will pay anything. It would not cover the previously mentioned $150 cleaning (which would have been $300 w/o much complaining to the dealership).
    Is there hope for this car, or do I need to loose thousands of dollars to trade it. I had planned on keeping it a long time, but since I just bought it 6 months ago and did not get a very good deal on it or put much down I owe much more than what its worth. Which means the only way to keep it from being a financial disaster is to make it last a long time.
  • bburton1bburton1 Member Posts: 395
    Have had Honda Accord rotors warped by impact wrenches. If they use a torque stick in the impact wrench, that is better than nothing but can still warp the rotor. Use a click type torque wrench set at 80 foot pounds. When I have my tires replaced, I take my overpriced Snap-On Torque Wrench with me and watch the guys use that to tighten the lug nuts.
    Had to really raise cain the last time I had my tires changed-their procedures manual requires at least a 100# torque on all lug nuts. Alloy wheels apparently even require less than 80. So be careful out there when you let knuckle dragging neanderthals work on your vehicle. The rotors that get warped could be yours.
    Yeah, here's another vote for supervising at all times anybody who has pulled a wheel and is about to reattach it - best to force them to use a torque wrench, even if it means bringing it to the party yourself. Never trust the guns, no matter what they tell you...
  • 6rich6rich Member Posts: 1
    Greetings!
    I have a 1991 Accord 200,000 km on it and in the last 3 months is has been hesitating. It does not seem to matter time of day of warm or cold engine. You can be driving along and all of a sudden the engine loses power. You can push the peddle to the floor, but there is no reaction. After about 10-15 seconds, the engine will kick in and everything will be fine.
    I have taken it to many mechanics and they are unable to determine the problem. I have replaced the distributor and checked fuel line and pressure. Does anybody have any ideas out there. This is driving me crazy.
  • barnonebarnone Member Posts: 118
    j/k
    did you check the spark plugs? gas quality?
    or maybe dirt in fuel tank?
  • wdoranwdoran Member Posts: 31
    Any ideas what causes the automatic shift lever to stick going into or out of park. My wife uses two hands to free it. I checked cable length adjustment, it was find all other positions are free and transmission shifts well. Thanks.
    Bill
    Anyone else have a problem with their engine stalling in wet weather? Mine cuts out ONLY under these conditions: wet/rainy, push in clutch and brake at the same time.
    Sounds weird but it has happened me at least 4 times. Almost got me killed when it stalled in front of the snow plow!
  • gregw916gregw916 Member Posts: 1
    I've seen a couple of postings regarding transmission problems. I've noticed a couple of things that you have seen.
    Transmission "shutter" in O/D. Yeah, when I first got it in March 2001, it felt a little like the wheels were out of balance. It went away on it's own over time. It seemed also to be tied to how warm the car was, that's what gave me the clue about it's something in the engine or x-mission. Now after what I've read about v6 trans., I'm waiting for something to happen...although no problems yet!!
    I also do get the loud "clunk" when I shift from D4 into park. I figure as long as it works, I'm not going to worry about it.
    I've never heard any whining either in any of the gears. As it stands, 6500 miles, and no problems of any sort yet.
  • psrv6psrv6 Member Posts: 3
    At 600 miles, de accelerating from 50mph, the car suddenly stumbles. It felt like the car was going to stall. I didn't know what to think just happened. It did it again at 1100miles but during acceleration - cold engine. At 45mph, it felt like the car locked, loud bump, front end nosed dived and the car shook. In between these 2 occurrences, I can feel the car fluctuate at take off. Around 50mph the car has a distinct fluctuation. I have taken the car to the dealership in between these 2 occurences. I was told the fluctuations are normal at 50mph but the stall was not - the Oxygen sensors were replaced - no change. Now, my car is at the dealership - been there for 3 days. They *think* it's the torque converter or the transmission. They can't reproduce the problem. Anyone had this problem? It's not the infamous "backup klump".
    dealers almost always "can't reproduce the problem"
    In all fairness...have you ever worked as a mechanic/technician?
    The most frustrating thing for the customer and technician is the rattle or vibration that can't be replicated when the car is brought in to be fixed. This can be vexatious work trying to get the car to act up and it won't.
    We recently replaced a Prelude for a customer who kept feeling a "strange vibration" at cartain speeds but only at "certain times".
    His Prelude only had something like 2000 miles on it. We swapped cars, sold the Prelude as a used car to a happy owner who can't feel the "strange vibration" anymore than our technicians and Service Managers could.
    yes i have, and an excuse of "i can't reproduce the problem" is another way of saying "get lost! i don't wanna fix that. come back when it gets worse so i can milk more money out of ya"
    of course.. them other mechanic/technician say that phrase until they think that the customer would be gullible enough to believe some ghost diagnostic and repair
    btw, trust the hard facts, not hear-say gossips.
    Well, you are the exception. If you were ALWAYS able to reproduce the problem and fix things the first time.
    I DO trust the hard facts and am smart enough(usually) to filter through the garbage...
    But...sure, there are those mechanics and dealerships who will pretend a problem doesn't exist when in reality they are well aware that it does.
    I still believe those shops are the minority unlike your original post suggested.
  • amers3amers3 Member Posts: 8
    Good luck with your torque converter/transmission repairs! I have a '00 v6 with the shudder problem and have been taking it to the shop for a year. They've replaced the torque converter, ECM and 3 weeks ago the transmission, none of which helped one little bit! I've been test driving it with the tech in the car so he can feel the shudder, which by the way is happening at higher speeds now (not just 55), but they can't come up with a cure. Today I drove it twice for the tech while he had it hooked up to something to take readings, and the only thing they came up with is that the intake temperature is high (130). They're going to run some test on it tomorrow for the temp but if that's fine, the tech says that the guys from the Honda techline believe that the shudder is normal. Which tells me that they really don't know how to fix the problem! Why would they go to the trouble of replacing all these parts if it's normal? Can anyone answer that? How can shuddering/skipping be NORMAL? I didn't read that in my manual...
    Since my last post, the dealership dropped the transmission and opened it up. It was inspected for damaged. Since when do you diagnose a transmission problem by looking at it?
    It was put back in and test drove again. No problem. The Service Mgr drove it home last night and back this morning. Still no problem.
    The service technician told me a couple of days ago that one of the guys did get it to "act up" but she could not explain in detail what that meant. The ticket had not been updated - that was a verbal conversation between the two of them. I also find it interesting it is NOT noted in their service records.
    The shudder sounds the same as my fluctuation. It feels like a subtle rocking motion instead of a smooth ride.
    Is there a possibility that my problem could be electronic related?
  • teman99teman99 Member Posts: 19
    I puchased the Accord Coupe EX 2weeks ago and it already has 2 chips on the hood. The car was never prepped ( you could see the line marks from the tape on the hood) correccly and is going in next week. My question: Isn't this unusual for the paint to allow chips already? Does it have anything to do with not being prepped right? It really seems weird to me and to be honest I'm really pissed off.Thanks
    Tom
    No good reason your car got a poor prep job. Those tape lines do come off easily enough.
    Someone got in a hurry and did a sloppy job.
    But...if a flying rock hits your hood, it WILL leave a chip! Got a few myself!
  • maq4463maq4463 Member Posts: 45
    Just want to share my successfull experience/experiment with everyone.
    If your car does not start in hot weather after frequent startup the problem is main feul relay. Its located under the driver side dash on the left kick pannel (instead of fire wall as suggested by official honda manual). To access it you have to remove cruise control computer (its a silver color box approx 4x3 inch, don't forget to remove battery connection). Once its out of the way you see the relay held by two 10mm nuts.
    Another surprising thing that happened is that before replacing relay my clock was dead (it only worked if you press the lid on the clock) but now its working fine. Any comment on why that happened?
