I fixed this by replacing the starter relay, cost me $7.00. It was easy on the F150, it was mounted right by the battery on the inside fender wall at the top.
I've never had to find these on a Honda, but if you follow the positive battery cable from the battery, it should lead you to it.
Thanks in advance for your response.
re main relay. I checked into this theory at a couple of dealers . It seems this fix is for cars that die while they are running. My car has never stalled or died in 12 years (unless my foot slips off the clutch - happens when it is snowy).
Turning key too fast. I am turning the key same as I always have, and I did try to vary the speed when in didn't start. I also tried pausing between tries and turning slowly, as well as turning very fast.
Dead spot on the starter. This may be the problem. I called back the electric shop where I took my car (nearest Honda dealer is about 180 miles away) He just rebuilt the solenoid plunger system and did not even check the rest of the starter. He says it is quite a job to get to the brushes, and he has never seen them go bad on a nippondenso. He will look at it again today
Starter relay. I hope it is something that inexpensive. I mentioned this to the electric guy, and he said that if I hear the single click with every unsuccessfull key turn, then the starter is getting its signal to start.
Thanks again for the input everyone. I will post when I find out more.
The forum seems to be acting up. I thought I lost a post, and retyped it (sort of) now that post is gone, but the one I thought I lost is here. Don't know if this one will show up or not.
Absolutely untrue!!! That's exactly what I felt with my vehicle. Another "expert" told me the same thing, "if you hear the click, then the relay is working". In my case this was false. Thank god because I was already to replace the starter motor, which is about 400-500 bucks on my Ford.
Unless you can pin it down exactly, replace the cheap and easy things first. Start with the relay, then the cable that leads from the relay to the starter, then the starter motor itself.
When I took the relay out, I noticed some corrosion at the bottom of the terminal. If yours is getting like this, then it's possible to have "flaky" electrical problems. Don't know if this would cause the problem you mentioned with your radio, depends on how it's connected.
dudleyr
That could be an early sign of your ignition switch (electrical portion) going bad. Which could also effect the starting of the car at times but that part of your complaint still sounds like the starter or its solenoid that is mounted on it.
The first time this happened it was also coming downhill. Except it took about 5 minutes before I could restart. The starter works - the engine just would not turn over.
Any ideas on what it could be?
So there they were sitting in the car, with the engine runnnig, and they tapped the key in the ignition --- the engine went dead. They tried again after restarting but could not recreate. But are pretty sure that is the problem.
So they have put in a new ignition switch and are letting me try it for week. If the car does not stall again case closed and I get charged $85 CAN. If it does happen again no charge, but back to the drawing board. According to Honda the entire fuel system is OK. So lets hope it is just the switch. Will let you know after a week.
When walking into any car dealer I hold very tighly onto my wallet-just like I would in any high crime area. I do like the chuckle I get when they make their pitch though.
Just wondering. I usually use those "Lube, Oil and Filter places" for my oil changes.
What does Lube mean? Usually I just take in it and they change the oil and check the
fluid levels. They dont lube anything! I have an 87 Accord, and there are some squeaks coming from the suspension. From an earlier post by Auburn it seems I just need to lube the
suspension. Do I have to take it to a mechanic or can those guys at the Lube Oil and Filter place do it?
T H A N K Y O U ! ! ! !
Happy Holidays...
R.
The howling will eventually go away as you wear away the cups on the outside edge of your front tires. Ever once in a while I hear a car going by that just howls-must have cups .5" deep on those puppies. Check your COLD tire pressure, I keep 34# in mine-better mileage and tires last longer.
The brakes on my '00 starting squeaking pretty badly at about 30k, especially in bumper to bumper traffic. I took it in and the mechanic said the pads were dirty, so he dusted them. That didn't help the noise, so I took it back in and they changed the pads and resurfaced the rotors. Although the car brakes a lot smoother now, that fingernails-on-the-chalkboard, ear-irritating sqeaking is still 100% there! I'm taking the car back in this weekend, so I'm just wondering if anyone knows what I should expect and if anyone else has this problem!
Then the nextday, it lit up again... any suggestions why this might happen?
should i worry bat this? since there is no performance difference in the car.
is it true?
http://www.batauto.com/honda.html
john
Thanks to bburton1 on the tire cupping tip. I had the tires checked before taking it to the dealer and they are wearing evenly - - no cupping to be found.
1. sunroof (i know many of you have the same problem
2. driver's side door (no idea where its coming from
3. center of dash board
If anyone out there has had these fixed, please tell me how ya did it, cause the dealership keeps jerking me around "we can't reproduce the problem"
I noticed some brushing sound from my 00 Accord EX rear brakes yesterday. I brought the car
in for a tire rotation. When I got home, I jacked
ip the car and turned the rear tires and noticed the on-off brushing sound. It seems like at some
location the rotor disc brushes the brake pad
and at other places they don't contact. Of course
I released the parking brake when checking this.
The two rear tires will rotate and stop pretty
quick because the disc is contacting the pad from time to time. I checked my wife's Civic and its
two rear tires turn easily and there is no brushing sound.
I'm not sure if this is normal or not. The dealer mechanic said eventually it will go away when the patter on the disc is formed. I don't
believe this. Does anyone have any solution or is it normal? Thanks.
Kevin
Otherwise, it is perfectly true that the pads will always make light contact with the rotors, which can cause a slight swishing sound. But it should be consistent, and this sounds like someone may have used an air gun on your wheels that was just plain off...
And the Civic uses rear drums - there should be no contact between shoes and drums when the brakes are off. With disc brakes, there is always light contact between pads and rotors - different designs for good engineering reasons.
They found nothing, whether they looked at is questionable, so in disgust I just took the car back. Well this past Saturday I took the car for annual rust check. On the way home the engine cut out again - on a slight down hill going no faster then 50 km/h (30 mph?. I thought maybe I should stop at a car store and buy some stuff to to put in the gas to clean the injector or whatever (I was desperate!) Well it failed another four times - down hills, at stop lights, going around slight curves. It final would not go any further - the starter was going, but the engine would not catch. So I get towed to the dealership. They say its the ignition coil. Car works fine.
Until Christmas Eve, and bingo right around one of the places where it failed before (I have lost count after 10) I could feel it start - the car was at 2000 rpm, seemed to be sluggish at 50 km/h, then the weird part is the car became very calm and quiet (still showing 2000 rpm). Whack, the rpm dropped to zero, warning lights came on, and I was lucky enough to coast across three lanes of traffic and turned onto a side street( I am getting really good at this!) Tried to restart - but the engine would not catch.
So I was towed to the dealership - where the car now sits until they open after Christmas.
I am losing the game this far, its not the ignition switch or ignition coil (unless they use defective parts). I am at the point all I want them to do is fixed the car so I can get rid of it. (I get the feeling that since the car is in such good condition with low mileage the dealership or the mechanic are eyeing it, hoping I will just trade it in for a new one! Then they will fix it with a $2.00 part. I always say you dance with devil when you buy the car and you keep on dancing with him when you get is serviced)
Happy Holidays to all and thanks for listening (this is good therapy). Will keep you posted. Any ideas are welcomed.
http://www.batauto.com/cgi-bin/Forum/db_TalkToMeV2.cgi?forum_name=imports
