I have a 1986, yes a 1986 Honda Accord LX 5-speed sedan that I purchased in Nov. of 1985. My wonderful aging dinosaur has been the best car I have ever owned. I replaced the clutch for the first time at 150,000 miles and had major carborater work done at 190,000. Two months ago I had the altinater rebuilt and now my baby has been suffering from a low idle, burning and leaking oil(I keep an eye on the oil level)steadily for the last year. For the last two days it has been loosing power if the idle drops below 0.5 rpm and acts as if it is flooded. To start the car I depress the accellarator to the floor and crank - it starts again and I drive nervous of the next stop I have to make. An acquaintance said I should take it in and have the "puff valve" checked. Is it possible that just a tune-up would solve this. Should I keep this wonderful car, perhaps put a used engine in and paint it's oxidized surface or call it quits.
The current mileage is 204,000 on my 86 Honda Accord. It's just broken in isn't it!
I just bought a new Honda Accord LX 2.3 a few
weeks ago. Everything seemed to be fine sofar except that the vehicle tends to pull right at freeway speed(65 mph.) If I keep my steering wheel straight, then the vehicle pulls gradually to the right after~30 secs.
Any advice or insight into how to fix this problem
is greatly appreciated. My email is dnguyen65@hotmail.com.
Duke
car pulls to the left-you have a tire problem. When tires have belt problems, they will have a lot of rolling resistance. It is amazing how much a tire problem can affect steering.
The alighnment could be off enough to affect steering-again not likely-my guess would be there is a tire pressure differential-some vehicles are shipped with @40 PSI or more to keep the tires from getting flat spots during transit-the guy responsible for preppring the car could have screwed up.
Let us know what you find.
If someone could let me know if I should take the car in to the dealer now or wait until 3000 miles, I would appreciate it!
I think chancing oil at 3K intervals is waisting of money and resources. I use synt.oil and get it chanced every 7.5K. Believe it or not, drained oil still comes out as clear as new bottle.
Just relax and enjoy your car.
I've set off my alarm a couple of times by pressing the panic button by mistake. This happened when I had the key & remote in my pocket and probably leaned against something.
The car has 116,000 miles on it.
I also don't know if the timing belt was ever changed, Is there any way to access the belt for inspection that a home mechanic can do? Thanks for any suggestions.
Is this fluctuation normal and the dealer is changing the gasket as a precaution? I'm very surprised that gaskets have to be replaced. My car only has about 16000 miles. I've own many cars (mostly domestics), but this is the first time stuffs like this have to be replaced at only 16000miles.
Please let me know. Thanks.
What gasket are they going to replace? Maybe the thermostat gasket?
Terminalis,
As others have already said it is normal for those levels to fluctuate.I have not yet seen any 2000 Accords need a head gasket. However there is a crossover manifold peice that is known to leak. I think they call it the EGR manifold, but I know it is on the trans side and toward the front.So if this is the part they are talking about then it is a good chance that it is leaking/seaping.That really wouldnt cause the fluctuation but never the less would be a necessary repair.Find out what gaskets they are talking about and let me know.
-bwj
Hope that is the problem-cheap fix hopefully.
I have a 2000 Accord DX manual - it's about a year old now. Lately, when I shift from 1st into 2nd and let up the clutch, my car makes what I would describe as a quiet screeching noise, just as the clutch comes all the way up.
Same deal 2nd into 3rd and the problem is most noticeable when the car has just been started.
Any thoughts would be appreciated on what might be wrong.
The part number 19411-P8A-A01 is for the coolant/EGR manifold. So that is nothing major just a small gasket replacement.A few things have to be moved out of the way in order to gain acces but its no big thing..Good luck..
Silveraccord,
If the sound is from under the hood then it most likely is the clutch plate springs squeaking a bit. Unless the noise is real loud or bad then there is no need for repair because they sometimes stop making noise on their own.If they are real noisy then have it diagnosed by a tech and replaced if necessary.If the noise is under the dash then it is the clutch return spring at the pedal.Some lubricant will take care of that one.Good luck
Have heard same model I4's making a similiar noise-heard someone say it was piston slap. Sounds like a valve out of adjustment to me-any ideas.
If you have any suggestions for checking wear on the rocker let me know.
thanks much
I cannot thank you enough guys. Thanks a lot again for your comments.
--terminalis
p.s. BTW, Auburn, what is the other part number for? (19412-P84-A01). You told me that 19411-PBA-A01 is for the coolant/EGR manifold.
--terminalis
PS: Sorry, guys, if what I said here is a complete [non-permissible content removed]. I'm trying to learn mechanic stuffs, ever since I bought my Accord. I don't know if I should thank Honda for this, but it's fun. Maybe I'll learn enough one day to fix cars myself.
Butch11
The rocker can be inpected only by disasseble.So try making the adjustment on a completely cold motor first and see if it is out.The spec is under the hood,but I think it is .25mm for the intake and .30mm for the exaust.
Terminalis,
The other part number is for the other side of the head.They are shaped differantly and so they have differant part numbers.As far as the noise you hear I remember seeing something similar but not sure if it was for an Accord
or not so I will check on tuesday.
Fritz1224,
I don't mind it really I don't.I just don't want people to feel like they don't need to post because I will or that I am a know it all or something.I enjoy every ones post even those who disagree....See ya
Fritz, you can delete the post for which you are apologizing if you'd like by clicking on the highlighted (linked) post number and then choosing scribble.
Might as well take this opportunity once again to thank auburn63 for his incredible patience and generosity in his willingness to share his knowledge with our community.
You are terrific, auburn, no doubt about it! Our entire community is grateful.
Pat
Thanks again for your help. I wish you're around here, so that I can take my Accord to you (and also to buy you a beer!).
Also, many thanks to those beside Auburn who have provided useful info and help. This is a great forum.
--terminalis
I called around to some dealers my area and I could not find a bulletin on such a problem. Has anyone had this problem? If not can anyone make any suggestions?
This problem is very annoying ... as most of my commute is highway driving.
Help!
year and 10,000 miles ago. Prior to this point it
used no oil and did not smoke. Now it uses about
2 quarts of oil per month and smokes quite a bit.
The smoking is greatest upon application of the
accelerator immediately following in-gear
deceleration (e.g. coasting in gear down a hill).
I took it in for a checkup and the mechanic told
me that the engine was bad. What should I look for to determine if it's the rings vs. just the valve guides? I am ready to replace the engine if
needed but would rather fix the immediate problem instead of paying the big bucks. Ideas? Thanks.
Thanks for eveybody and Auburn63.
A couple people did the following:
Hey guys this has been discussed before...do a search on throttle cables. Anyway, us 3.0 V6rs you loosen the lock nuts on the gas pedal cable (cable closest to the firewall) and then slide the cable back to remove the slack in the cable in relation to the throttle plate itself. Don't overdo it or you may have idling problems...just enough so that
the throttle plate opens at about the same time you pull on the cable. Look closely at how the linkage system is mocked up before you start. You'll notice that it has a 2 stage system of resistance in the feel of it as you pull the cable back...Honda's way of keeping old ladies from driving their cars into the traffic in front when they tip into the throttle. The first stage, as I call it, when you pull on the throttle cable is all SLACK, then the second stage is when the throttle plate linkage is CONTACTED and the plate opens...just dial out the first stage. Then enjoy your more responsive accelerator pedal guys (gals, too)!!
Another person with the following:
Hey you guys....tightening your throttle bolt isnt such a good idea. I did that at first from my friend's advice, and the pedal felt more responsive, but his uncle (who works with racing and stuff) said that it isnt good. Here is the main reason: when you turn on your engine, your car might have a tendency to "jump" into the gear that your car is shifting into. Say if you shifted to reverse, the car might jump and try to go reverse even when you dont press the pedal. And i heard from someone else also that tightening the throttle bolt isnt a good idea. So thats why i changed mine back. Just keep it on the factory setting. Just advice, i dont want you guys screwing up nice cars like ours.
Auburn63, if I do this, will this harm my car and void my warranty? Thanks.
The recomended tire presure isn't so much for the best tire wear as it is for the best ride and how they set up the car.For example,the car's speedometer and odometer are calibrated at the recomended pressure.Is there any harm ? I don't think you will see a differance in anything except maybe the ride a little,..So if pumping up the pressure a bit increases the life of your tires then that is not such a bad thing.
Liquidp,
If you do not go to tight then you will only change the cars and your response time.At fully closed throttle the plate is closed and as long as you do not go to tight and start pulling on the throttle then it will remain closed and will not know the differance.The sensor is on the throttle plate/body not the cable or pedal.As far as the warranty goes.......what do you mean my cable is too tight? How did it get that way? I only service my cars with Honda..
No it does no harm except if to tight it will cause the computer to not read correctly.Which can cause high and erratic idles as well as other performance problems are possible but if not too tight then all will be normal..
I would think that if you go much over 32 psi the ride would be quite rough.
