Also, sometimes when I park in Sun for 5-6 hrs straight, my car cranks but does not start. Found several TSBs about this on NHTSA.
I love the car and its maneuverability and responsiveness, though.
What do you guys think? Any suggestions?
I don't often think that an SUV is the answer, but this may be a case where one is. These are, after all, nothing more than tall station wagons.
Maybe you should try to find a car that is easy to repair. Go to a local service center that you trust and ask them which cars are easiest to fix. If you buy a car like that, at least the problems you have will be simpler to fix.
For me, the most important thing is to buy a car that I truly enjoy driving. Reliability is secondary.
BTW, auburn63 = Auburn Tigers???
Couple of months back I had two lug nuts replaced by a cheap shop on my 90 Accord 189k, who over tightened the flange bolt on the wheels. That caused the warped rotors. Steering wobbled when I braked around 70mph, but very small shake less than 50. I took the car to local honda dealer who recommended disk resurface and new pads, I also had alignment done. By the way I have brand new tires, balanced.
Before I took back the car the service guy told me that the disk is now almost down to legal limit. After the resurface the shake was completely gone form driving but as soon as I hit the brake a SEVERE shake?? Took it back to the dealer and they claimed innocence i.e. they informed me about the brake disk being cut to minimum and if there is still shake disks have to be replaced. The agreed to cut the labor in half if I choose to have it done. That $350 included only disk remplacement and they warned that at these miles wheel bearings will have to be replaced too. Quoted me $100 for each wheel bearing, honda list price is $49.42. I decide to wait.
Hang on here with me guys, its a long one. Being p***ed at there laughable prices, I have original honda service manual so I decide to tackle it myself, not gona spend $500+ dollars. So now I have replaced new brake disks with wheel bearings and pads. Brake wobble/shake is completely gone when I press the padle, but now I have again steering shake on normal driving over 55mph.
Question is what have I done wrong during replacement of rotors that is causing the steering shake. I have torqued each and every nut and bolt according to honda specs. What then is wrong?? Sorry about the long and frustrating post. Any ideas...
--> http://www.hondabeat.com/hbeat/highmiles.cfm
The new paint (PPG) adhered well on this old steel bucket. The body shop had the car for almost four months.
The clutch noise is probably just the pivot ball that the clutch arm pivots on and will not cause much harm. Other than that if it is like a "errt" sound then it is the clutch springs and again usaly dont mean much. The clutch will slip, give a high hard pedal and or chatter badly when it is bad. Let it ride and see how it feels and sounds. Also Auburn as in Tigers/WarEagles, college in Alabama.
maq4463
Sounds as if you just need to have the tires re-balanced at this point. A shimmy without touching the brakes is rarely a brake shimmy.
dash400m
Thats great man, the moon mobile is still looking new and ready to go when NASA needs it..lol..Keep on rollin'
I'm a Bama boy myself, ROLL TIDE!! However, my sister graduated from AU and I have a lot of respect for the school and the program (unlike most Bama fans!). As long as it's not the Iron Bowl, GO TIGERS!!
The sensor tells you before any serious damage is done. Replaced the pads, cleaned up the rotors and am good for another 37k miles.
I treat this car like a rented mule. Heavy traffic, lots of stops and starts, high speed spurts when I can, on and off the breaks, fast cornering... no problems... I do the pms' evry 3k or less. I must be lucky judging from the problems found here..
How can I fix this? What is causing this?
fluid levels
That is a range of acceptance on the stick with the top being the full correct level and the bottom being the lowest that you should go without adding. I usally try to keep all at the full mark unless I am just a few miles away from a fluid change..
thanks a bunch
WIll ask the service dept if they know if a kit for this japan made vehicle.
Thanks a lot-will let you know the outcome.
I have a '97 Accord. When it got to about 24,000 miles, the passenger side front window would stick going down. This problem would get worse in cold weather. The only solution Honda had was to lubricate the window run seal. This would make the problem go away for about nine months or so, then it would return.
At 70,000 miles, the passenger side door lock went. It needed a new actuator - a $210 repair.
The car now has 76,000 miles, and the passenger side car window is sticking again, and the door will not open from the outside (power lock is screwed up). The last time I was at Honda, they said that to fix the passenger side window problem permanently would require a new window channel and regulator - $360 installed.
Since I had the original problem at 24,000 miles, I am assuming that if I pay $360 to resolve the problem, the best I can hope for is a window that won't stick for 24,000 miles, at which point I can plunk down another $360.
Has anyone else experienced this sort of problem? Or did I get stuck with a lemon?
How are the 2002 Honda Accord paint jobs? I personally like the Camry ride better--for me soft, and non-sporty is just fine, but if the paint is goin g to crap out on me, well to heck with it.
Today a transmission specialist confirmed my garage mechanic's opinion. So tomorrow it is off to the dealer to see what they say. Sure wish it was still under warranty... but if I can prove this is a known problem I'll push for them to pick up some of the tab if not all of it.
By the way, transmission specialist says at this stage car should not be driven far. He says transmission was not shifting into overdrive when it should. Am I getting the shaft here?
Part of the problem with Honda is their lousy 3 year 36K power train warranty as compared to Toyota, Subaru, and Izuzu etc.
I do hope your Solara remains flawless.
www.latimes.com/la-hy-acura11sep11.story
An excerpt:
"Spencer said Honda is confident the problems have been solved.
He said Honda owners with transmission concerns should call the company's customer service hotline at (800) 999-1009; Acura owners should call (800) 382-2238.
"We are definitely keeping an eye on this, and if it looks like the issue is growing, we'll take other steps" that could include extending warranties for replacement transmissions that now are covered only by the remainder of the original new-car powertrain warranty of five years or 50,000 miles, Spencer said."
I can't imagine what the problem could be but let them drive it to see what's going on.
