Visitor Agreement.
To me it sounds like the tires may be finding a groove in the road or something...?
My EX V-6 coupe doesn't do this.
Do have someone from the dealership drive it.
I get the same interference through my PC speakers if my cell phone is too close to it as well as through the radio in my Ody.
I accept as normal since it happens in so many places.
Buy the way, Honda dealer quoted $5300 to replace the transmission.
What luck have you had with Honda picking up the cost of repairs? It is out of warranty.
Thanks again.
We have owned two cars from the previous gen series ['98 4 cyl and '01 V6], and they both tracked like a train on the highway.
I'm also puzzled about a reluctance to ask the dealer to do his job, but whatever...find a good tire place and have them do it.
Also Honda does deliver a lot of road feel-that is why I really like Honda's handling characteristics-have to drive in lots of snow/rain/ice and really hate driving in those conditions in cars that completely isolate you from the road-you know you are having problems when the car is sideways and there is damn little you can do to correct the problem.
My guess is that you are accustomed to not getting so much feedback from the road. But have someone check the front end-loosing steering at highway speeds would be a unwanted thrill.
good luck and let us know what u find.
hbund216: That’s exactly what I’m talking about. If it went away for you automatically then I’d think it’s a tire/alignment issue that disappeared once the tires got a little worn. Thanks!
bburton1: I’ve owned a 98 prelude in the past and currently own an S2000 so I’m quite used to road feedback ;-)
Thank you all!
BTW, there's something else happening to my car recently, when i'm stopped at a red light in D with the headlights on OR the A/C on, the steering wheel vibrates pretty bad, you don't have to put hands on the wheel to feel it, it's actually visible, oh yea, and if the fan is running, it vibrates too, it's like if any additional electricity is required, it vibrates, feels like the engine load is huge and it's choking or something. =P. but without any of those things, it doesn't really vibrates at all, and the vibration doesn't go too much further than the steering wheel so i've just learned to not rest my hands on the wheel when i'm stopped. is there any kind of maintenance that can be done to stop it? everybody? any ideas? thx thx thx thx.
http://www.buffalonews.com/editorial/20020914/1036070.asp
Ouch, dealers like any repair facility are all differant and not all are like vacuum cleaners.
cokane5227
Those vibs have been with Honda for years and are usally do to the rubber mounts getting older and more broke in than when new. Sometimes we find bad motor maounts also so you may want to check them out. Mostly the front one or the rear one. Sometimes the rear one will slip out of place which when looked at closely you can see the metal edge ontop of its lip. Also check the vacuum hose that goes to it and the linkage.If all looks fine then it is probably a normal amount that can be minimized by adjusting the idle up a bit..
The dealer's service department is worthless. They claim they can't find anything wrong with the car. They act like I'm imagining the problems. I spoke to a lawyer about filing a complaint under my state's lemon law. Its alot of time consuming aggravation. I should have bought a Camry.
From the LA Times,
"Mike Spencer, a spokesman for Acura, Honda's sport-luxury division, confirmed that there has been a "higher than normal incidence" of problems with two Honda-built automatic transmissions. "
"The two transmissions are the five-speed used in V-6-equipped Acuras since the 2000 model year and in Honda Odysseys since the 2002 model year; and the four-speed automatic used in V-6 Honda Accords since 2000 and in 2000 and 2001 Odysseys. "
As for the steering having a mind of its own. This could be torque steer. Front wheel drive cars with enough power will do this on hard acceleration. I could get my 89 Hyundai to do it.
Does anyone have knowledge in how to close the moonroof? thanks in advance.
Who wants to buy a new car, then get a rebuilt tranny put in it?
iota67: Try this, open the roof all the way (as much as possible), then close it while using your hand to push it forward (or have someone do it from outside the car). It used to work for me with the prelude. It probably just needs some lube (which should have been taken care of by the service people when they last serviced the car).
Actually, the correct term is remanufactured, because no parts other than the housing are reused. And I believe the articles states that this is common practice when a transmission is replaced.
I check the engine and transmission oil, both look normal. The car drives normal too.
What do you think could be the problem(s)?
That's a pretty broad brush you paint with, asethi. I actually have been very satisfied with my local Honda dealership's service dept. They have treated me well, did things right as far as I can tell and have not tried to "upsell" me to additional unneeded repairs. And I can certainly not say that about all of the dealerships in my area.
The point is, when the cars are new you can get away with poor service but it will show later as they start to get older (and the factory warranty expires :-) ). Most dealerships have nice smiley faces sitting behind the service counters, it's what goes on behind the "wall" that i'm talking about. Also, you won't know how good a service department is till you take your car to them with a problem that needs serious diagnostics skills.
While I didn't see much that would help you directly, it may give you some resources on where to go within Honda corporate. The guys at this web site have WAAYYY more experience than what I've seen in this forum.
Good luck!
Bottom line is this-sales and service departments depend upon the people running them. But I must admit it is fun to encounter some of the less than honest sales/service people out there and then ram their noses in their offal. Still would like to encounter the honda service dept that charges $60+ to reset the service lights-now that one takes the cake.
Probably more fun to refer people to good sales and service people.
http://www.acura-cl.com/forums/forumdisplay.php?s=3ed9e22475c1ce085c892d221d449c29&forumid=126
gc1492 should really look at item 4. The Acura rep refunded the cost of the extended warranty and guaranteed the replacement transmission in writing. I hope gc1492 runs into someone like this or that offers like this aren't limited to Acura owners.
Item 3 was very interesting - read and draw your own conclusion. It's long, but worth it.
thanks!
Just thank your pols for that one-move is afoot per the 2002 $170 billion farm bill to increase the ethanol content to 25%. If that happens will be lots of really bad smells out there-something rotten in Wash.
good luck to people with wandering hondas-let us know if you solve the problem.
I went to Honda dealer in Manchester, NH to pick up my unrepaired Accord. At this point Honda USA was offering 1/2 discount on part only. I escalated call to supervisor who contacted me while I stood in the Showroom among all the nice new Honda Accords and potential customers. Supervisor informed me that Honda would do nothing more.....SHE is the person etc. I asked for HER boss, she was crushed and refused to give me the name.
Being a very dissatified customer I walked into the General Managers office, cell phone in hand and asked her to repeat.. Got the names! SHE called this morning with a new offer from HONDA. I am still writing to President and HONDA dealer owner, etc.
So anyone who has this problem please contact me on this forum... I will add your case to my file, and lets see what we can do. Honda says this is small % of cars. I think it's bigger than they are admitting, and it's 100% of my car. Tell your friends and neighbors folks and keep those posts coming.
Thanks again and any links to more information are greatly appreciated.
Did a front disc brake job on my 91 Accord. No problems at all - I thought. I drove it the following day, made about 7 or 8 stops no problem. Then, I needed to brake again, and the pedal went right to the floor. Pumping did nothing to build pressure. Limped home, checked all the wheel cylinders....no leaks. Was recommended to replace master cylinder, as it may have been damaged when I backed up the piston on the caliper. Replaced/bleed entire system. Pedal feels exactly the same.
Any ideas what to look at next? I'm wondering if the brake booster may have bit it, or if I have a vacuum leak somewhere, though I don't really hear a hissing sound when the engine runs. The only thing I did notice, while bleeding the brakes, engine turned off, was that just as I hit bottom, I would hear a whining sound. I don't know if that is just the brake pedal rubbing under the dash or what.
Other question is could the issue be the ABS? HELP!!!!
Is there anything I could have seriously damaged by doing something so incredibly stupid? Thanks. Your input will either make me feel worse or relieve my tension somewhat, but don't let that affect your answers. Be honest!
I can't believe the supervisor fell on her sword with that stance. Your request was very reasonable - why should a customer pick up full price for labor for a transmission problem that might have started while the product was still under warranty? But while the customer and rep are negotiating, no one knows if a defect is involved because of Honda's current "return the transmission to HQ" in-warranty centric policy. It really seems like Honda hasn't considered the beyond-the-warranty ramifications at all in this case.
Honda hasn't provided a service bulletin to advise dealers and service reps on what to look for, so your dealer can't tell if your problem is defect related. So gc1492's customer rep is negotiating in the dark as much as the gc1492 is.
You can't get a refund if you paid for the repair and Honda later figures out it was defect related. According to what the Acura Customer Service rep told Copland007, Honda has no way of keeping track of the transmissions that are returned.
Honda's policy is really putting everyone concerned in a box. They are forcing the consumer to take the adversarial stance that Honda's product was flawed, just in case. While I don't want to rip Honda off, I sure don't want to pay for a repair due to what they acknowledge was a design problem.
While at the gas station, did you happen to add any fluids that may have spilled onto the engine? That also would emit a strong smell as the engine heated up.
Good luck!
Tom
If it's constant, then it should do it the morning after you leave the car at the dealer.
The other, more serious, problem is a defective steering wheel/column. It appears that the whole steering column is a few degrees off-kilter. The result is that when holding the wheel at the 3 and 9 o'clock position, the left side of the steering wheel is further out from the dash board than the right side. My dealer acknowledged the problem this morning but said there was nothing they could do. They said they compared it with other 2003 Accords on the lot and that all of the them were the same way.
As you can imagine, I am not happy about this and will be pursuing a resolution to the problem with Honda.
Potential 2003 Accord buyers should be especially vigilant in examining their cars for these and other defects prior to signing any purchase or lease contracts.
