Visitor Agreement.
Only a slight rattle in the exhaust-suspect it is one of those built in heat shields-will get some AL clothesline wire and that will fix it.
Again if u do it right-replacing the exhaust on one of these puppies is a 2 hour job
There is no reason this should have lingering effects if the car is properly repaired. However, that is a big "if" - you need to make it clear to them what your expectations are, and I would hold out for an extended warranty on any items related to the incident, including long-tern corrosion/odors/etc.
I have a 1992 Accord EX with 107k on board. Lately, whenever I am turning over a dip or a bump (e.g. parking on uphill roadside) the suspension makes some noise. Is the normal or could this be the sign of smthg more dangerous? The noise is less if the steering wheel is straight.
-Sukal
The mold issue is being blown way out of proportion with houses, let's not extend the hysteria to cars.
I bought the replacement door handle assembly from my local Honda dealer, in the hopes that it would be a simple repair, and I could figure it out myself. (This was a very optimistic hope - I am not really that handy.) I got as far as removing the screw that keeps the door handle assembly permanently attached, and wiggling out the door handle a little bit. I cannot seem to get the plastic moulding out though. I tried levering it out with a screwdriver, and that didn't work.
Does anyone have any tips for me on how to do this repair myself? Or is it harder than it looks, and I should just go ahead and take it to the dealer or a local repair shop?
There should be a couple of screws holding the plastic door panel to the metal frame underneath, and about 7 or 8 plastic pop-off screws around the rim of the door panel. Once you get the panel off, you'll see it's pretty easy.
Here's some links to check out:
http://www.hondaautomotiveparts.com/instal/instal.htm
They have some picture illustrations on the site. If you surf around a bit, you may be able to get a better idea of how to fix your door.
They don't have info. for the 92 model, but essentially, the door panels should be attached in similar locations to the door frame and should have similar retaining clips, etc.
Also, you may want to ask on superhonda.com.
I'm sure on there someone can give you much better step by step instructions of how to repair your problem.
Sounds like you had a good time this summer, glad to have been of some help.
sukal
Depending on what kind of a noise it is and how severe it sounds. If it is like a dry rubber sound/ bed creak like sound then it could be bad sway bar bushing. If it is nore of a clunk then it could be a bad ball joint. If it is a click then possibly an axle. What does the noise sound like and feel like if you can feel it.
I also wanted to ask you 1 more thing. I am a student and do not have much cash to spare, however I am very interested in keeping my car in good condition. My car (1992 Accord EX) has 107000 miles on it, I bought it used and do not know the maintenance history. However, I am sure that the timing belt has not been changed ?
How important is it to get it replaced right now ? Can I put if off, say till 115000 miles ?
Along with the timing belt, should I also get other things replaced (water pump?) I have already done a transmission flush, changed spark plugs and brake fluid. I also change oil/filter at 3000 miles, sometimes even less.
Thanks in advance...
It seems like the Temperature button (dial) is cracked/broken on my 94 Accord. Is there a way to buy this dial from the dealer? Might have to go to a junkyard.
To take it out. Do you just pull it out?
Thanks again
We have had to replace the temp dial more than once on our 92 Accord. (Yes, the same one with the broken door handle. I swear, the car will just fall to pieces before the engine ever calls it quits!) We bought the dial from the dealer - no problem, and it was cheap. Just pull off the old one, and stick the new one on. (Or, if you're lazy, you can do what my husband did, and just pull off the climate mode dial and use that one to adjust the heat.)
Ok sounds like possibly an upper ball joint or a strut but it should be atleast checked to make sure it is not dangerous. ..As for the t-belt, they are supposed to be changed at 90,000 so I would do it as soon as possible but if that means rolling the dice till you can come up with the cash then thats the way it is. Should also do the water pump and external belts at the same time. Good luck
mack20
A dealer will sell that and yes it pulls right off. The only thing is to make sure the little metal clip comes off also with the old knob or the new one will not want to go on.
Thanks again
-Sukal
Maybe there was more to the problem than they let on....
I'm asking because sometimes you don't have the luxury of driving sedately for awhile to get the engine warmed up. For example, if you have to hit a highway on-ramp right away and merge into traffic.
They told me it could be my driving style?????
just bought a 2002 EX V6 last week. Have a problem and wondering if anyone has ideas. Driver side window...when I close it I hear a buzzing noise that gets distinctly louder as it gets closer to the closed position. Sort of like there is increased friction as the glass nears the closing point. No problems on the other side windows.
Intend to take it in for service next week, but was wondering if anyone has had a similar problem and if it was an easy fix or not.
Thanks in advance.
I took your advise and got the timing belt, water pump and the drive belts replaced. It set me back by $525. Also got the coolant flushed and replaced; and rotated the tires.
Regarding the noise, the dealer told me that the sway bar bushings need to be replaced. Parts and labor add up to $170 :-( Isnt it too much? I am going broke. Should I shop around or is this a good quote ? I do not know whether the dealer is ripping me off or if this is a genuine cost. Any suggestions?
-Sukal
I have noticed that when reversing it is making a high pitched sound (screeching) and very loud for a few seconds which i thought is coming from the rear left wheels. Also, when turning to the left it makes a lower pitched and less louder sound on the front left tire. I was not applying any brakes to produce this sound just to make sure it is not because of the brakes.
I am little bit worried because I may have caused this. I have no way of knowing if this problem has been there before because my friend is out of the country.
Could somebody tell me what could possibly be wrong?
And another by-product of the change in toe is the car will not track as well.
You may be able to just lube the bushings to get the noise to stop unless they are all cracked up or broken. If you are not able to do so yourself then you could go and get another quote for referance.
wolverine_x
Sounds like the brake sensors are hitting. Usally when they first start hitting they will make a noise that goes away when you hit the brakes. If it is a 4 wheel disc brake car then it probably will be the rears because they sound more like you described than the front.Good luck
I will be returning the car tomorrow but I need to update my friend about his car. I may probably bring in for check before I return. Sounds like the right thing to do, if indeed I caused this.
Now that the sound is duplicated when brakes are applied, could it be on the brakes? The car is having 40,000 miles on the odo. Seems pretty early for brakes to wear that soon, Dont you think?
Auburn, many thanks for the quick reply and for the others too.
Tom
We just bought a 1998 Accord LX. On the dash under the far-left air vent, is the cruise control button. On it there is a space for a light, however, since we have bought it there has never been a light there. Did it, at one time, ever light up?
Your problem is not all that bad, not dirt cheap but not diamond expensive either. Sound like the shift cable is in need of replacement. They tend to bind as they get old going into and out of park.
wolverine_x
Still sounds like it is going to be a brake problem to me. 40k is about right for rear disc and or front disc depending on braking habbits. Rear shoes on these cars last forever.
th83
White smoke out the tail pipe is almost always coolant getting into the cylynders. Did you over heat or run the car hot after the accident? Was there any loss of coolant in the accident? Are you sure that it is white smoke and not just the normal condensation smoke on a cold motor? Good luck
I live in a small town and there are not many mechanics who deal with imports here but I will anyway try to get a second quote.
According to the dealer here, I have lost my right sway bar bushing (Is that possible ???) and the left one is all cracked up. If that is indeed the case; what is a reasonable price for parts and labor for putting a new pair in ?
I also seem to have lost wheel alignment, after I got the tires rotated. The car is pulling to the right. (missing bush ???). I swapped the right and left tires but still it is pulling to the right. Funny thing is it was fine till I got the tires rotated.
