I mean, it didn't squeak at all until it was two years old. When it did squeak it wasn't bad, it was just a squeak under certain conditions.
Yes, Honda "should" have designed it so it never ever squeaks.
"Having to apply silicone every few months is ridiculous"
Personally I think there are much more important things in life to fret over. It took me less time to wipe on the silicone then I spend brushing my teeth.
We all all different...to me it's much ado about nothing! Life is short, folks!
I'm not a mechanic, but I know white smoke means unburned fuel getting through the combustion chamber, not burning oil.
Hope that points you in the right direction.
Is the smoke...moisture or actual smoke? Here in Canada it's cool quite often, especially in the mornings. Most of the cars emit moisture (white) while it's warming up. Could this be your issue/problem too???
I have been reading through all of these messages and I guess I should of read this site first before I purchased. Anyway, I bought the car with 15,000 km on it and now I have 50,000 km. I have been adhering to the normal maintenance routine but I am concerned regarding brakes and transmissions. Do I have anything to worry about. I have not had any problems with the vehicle and I have purchased the extended warranty for the vehicle. I have heard that this type of car would be notorious for transmission and brake problems. I would really appreciate if someone who owns this type of car could provide some knowledgeable feedback to me regarding what type of maintenance that I will need to take care of other than the normal maintenance.
My car's manual doesn't say anything about a "squeak" or noise in my moon roof. Doesn't that mean that Honda didn't put it into the car. And if they didn't put it in, why is it there? And if its there by mistake, shouldn't the dealer take it out? Or should we pay the dealer for these extra "features". Then again, my squeak doesn't make much noise. How can I adjust it?
'Very confusing....
But, you are correct. In a perfect world, a moonroof should never squeak.
I just don't see this as a "problem" like others do, that's all,
pblevine, maybe this will clear things up for you as well. I brush my teeth twice and sometimes three times a day. If I had to lube my moonroof that often then it WOULD be a MAJOR problem!
The car is a 97 Accord SE, auto tranny, with 42,500 miles. This is the first brake pad change on the car. How many miles are most people getting out of a set of pads?
Also had developed a hole in the muffler and the B pipe...this is not going to be a cheap inspection. I can't really complain, it will be the first real money I put in the car beyond regular filter and fluid maintenance.
Also I just replaced my exhaust system from the cat back. The pipes from Honda cost around $300. A friend went to a guy with a pipe bending machine and got it done for 150-no honda parts but it is much cheaper if you can find a local to do the pipe work. Also if the pipe behind the cat has to be replaced the dealer will tell you he has to replace the cat cause the studs are rusted off-that is a few hundred more. Don't like the sound of this dealer-particularly when he wants to turn the rotors-would find somebody else.
On the other hand, my parent's have gotten over 80K on just front brake pads on their car. How long your pads last basically depends on your driving habits.
But since it is a 91, it may not be worth it.
Good Luck
I haven't bought the Haynes manual for this vehicle yet, since the only ones available include 98,99 models only. I know they are mostly identical to my 01 model, but I prefer to wait until my year is included. I suppose I could buy the shop manual, but that is somewhat expensive.
So how about it. Anyone out there drained their coolant yet?
Also please be very careful of how you dispose of used coolant-stuff attracts animals cause it seems to be sweet and they die a horrid death and it makes big problems with ground water.
Hope somebody can answer your question-just about time to change coolant in my i4
Make sure to give
Year
Make
Model
Trim Level
Color
Miles
General Condition (ie rust, tires, paint condition)
Location
Good Luck
While I know this is not the same issue as was recalled in earlier models, I just wanted to see if anyone else had any issues.
http://www.superhonda.com/forum/showthread.php?s=a4b2e84a73a99a0b34e7caef9ad92f29&threadid=59738
Can you believe that the severe mileage replacement for this coolant is listed as 120k on an '01 model in the users manual?
Thank you in advance.
Next time I am in the local honda dealership-know the tech well there-will get one to show me which drain to use to drain the coolant.
GET IT INSPECTED BY A SHOP !
It could be something minor or it could be something ready to fall apart! Don't wait until a wheel falls off!
Struts and ball joints rarely fail on these but, still, 152,000 miles is a lot!
There are other suspects, including a bad trunk seal, but start with the roof drains.
