I installed a cradle and phone mount to rectify that issue and make it hands free as well.
Also, I sometimes feel a bit of 1st-2nd upshift delay in the new Accord's A/T under normal acceleration (whether warm or cold).
I know the accord transmission is under electronic control; but if I did not know better, I would say there was a low-pressure fluid problem in this A/T. What do all the other 4-cyl. Accord trannies out there feel like? I don't recall feeling a perceptable "going into gear" delay, or any noticable upshift delay, when I test-drove a similar Accord model at another dealer.
i've not noticed the symptoms you mention, although it seems the tranny seems to sense when i'm driving aggressively or not. it sometimes holds on to 1st longer and sometimes upshifs right away. i need to log more miles to confirm this.
like my 98-02 gen accord, it likes taking its morning coffee (meaning, warmed up) first before smoothly accepting the "r" or "d."
just to make sure, for longevity's sake, i'd fully warm the engine up before getting it into gear.
Try to remember if you had your cell phone in your hand, etc when these problems happened.
If nothing else, take it in...
The other thing I'd do (based on tblazer's post) is to try using the key by itself for a while, not on a key ring, in case anything on your key ring is causing interference.
auburn?
Anyway, getting to the headlights appeared to be a major job. What I remember, it required removing the front bumper, or the plastic cover on the bumper. Many screws, bolts, and clips. More than I would casually attempt to do.
And, these instructions were written by a young girl. She was doing major wrenching on her Honda. Impressed me.
Do a google search on 'Honda bulletin boards' or something like that. Then read a lot. Happy hunting!
he was told that they put sealant on a leak, he suspects it was just a loose gas cap.
could be other things, but could also be as simple as this one. hope it's nothing more serious.
any suggestions?
any ideas? its going to have to wait another week before going to the dealer.
new cars are a blast!
Alex
i'll use the diagram you gave me to remove the bumper, thanks again.
And yes, you can bet they want to make a sale, but all you have to do is say no. Then you'll be armed with more info. If your failure is emission related, it may still be under federal requirements. Good luck.
If you get the code from Autozone ask the honda guru in this forum for the failure description. He has been very helpful to many in here.
Have you noticed any vibrations with the car especially the steering wheel when stopped at the lights?
Also does the steering pull to the left or right?
How do you feel about the car?
Jason.
Here is a shot in the dark.. try disconnecting your negative terminal on the battery(get the radio code first) for about a minute. It should effectively "reboot" all the systems in the car, and maybe it will help.
Because I drove a 4cl Ex and the steering was perfect. I also drove the V6 and it pulled to the right.
mmm sounds like we have a problem here.
Jason.
Betcha every one of those cars had paint problems earlier and betcha not a one of those customers knew squat about the problem.
Be very vigilant when buying anything.
Dealers have the cars repaired and provided that the repair cost is below the threshold, they don't have to disclose it.
If the damage looks like it is contained within swirl marks or is associated with "spider web" markings, then the dealer caused the defect by "prepping" the car with that damn mineral oil based junk and buffing. Don't let the dealer prep the paint. Don't let them wash or wax or apply anything. They generally don't know to use 100% cotton towels and they tend to scratch the clear coat surface. When you get a new car, inspect the finish. Then "clay" it and apply your favorite wax or polymer yourself.
I had seen a post a while back reporting a similar problem in a Accord Coupe.
Is anyone else having similar problems ?
The rattle was fixed and termed "loose gasket"...not sure what that means. My driver's door also sounded like something was rolling around in it, and sure enough, a clip was loose...problem fixed.
The other problem was the mat in the CD storage area below the radio. It was coming unglued....apparently there is a service bulletin about this and a part needed to be ordered...will be in next week.
Other than that...I love the car!!! What an upgrade from an Acura Integra!
The click sounds like it's coming from the engine area, but I'm too inexperienced with the car to pinpoint it.
Also, if I go over a speed bump slowly in 1st gear, and let off the gas (which jerks the car a little), I'll hear a couple clicks (no clutch engagement going on at that point) as the car slows.
Any clues to what I can look for that might be loose?
