Visitor Agreement.
Again, thanks for the help.
I would really appreciate if someone would give me a dealership and service advisor name that had ACTUALLY replaced the transmission to cure the shuddering..
I noticed many of you have especially TERMINALIS but I can't get a hold of him. If you reading this terminalis, please respond. Any others with the transmission replaced, pleased do contact me.. my email is motiwala@cs.ucf.edu
Honda recommends every 12 months/7500 miles under normal conditions, 6 months/3750 miles under severe conditions. Being the conservative type I always follow the severe schedule (actually I change the oil/oil filter every 3k). In your case changing the oil every 4 months is being very conservative . I'd definitely leave the break in oil in there for 6 months. I think Honda knows what they're doing.
'00 EX V6 sedan
Could it be the same noise as what you hear when you step on the brakes? I have noticed that on accel in park that the shift inhibitor clicks on and off to keep the car from shifting at too high of a throttle position.I am not for sure if it does it in the other positions I will have to check.....
Lancerfixer,
Glad to have been of some assistance and to see that it wasn't a costly repair..Thanks for keeping me informed it helps to know what is going bad on these cars..
1. side air bag light comes on/off with NOTHING in
passenger seat. going back to dealer for 2nd time
tomorrow, will see if they can replicate it THIS
time.
2. i smoke, and with windows cracked open in rain
(or even in a.m. with heavy dew on car), rain drips inside, down door panel. has anyone seen/bought wind/rain deflectors? where/how much?
3. above mentioned rain drips appear to stain the
leather on door panels. it wipes away, but not sure about long term.
other than these nagging things, i love this car!
great styling, awesome acceleration.
rap
miles on it. Recently, I have noticed some wind
and highway noise coming from the drivers door.
It almost sounds like the door is not closed all the way (but it is).
I called around to some dealers my area and I could not find a bulletin on such a problem. Has anyone had this problem? If not can anyone make any suggestions?
This problem is very annoying ... as most of my
commute is highway driving.
Help!
I'm getting ready to take it back to the dealer for some minor fixes, whistling pass. window, etc, and I just wanted to find out if this is normal.
Thanks for all your help.
2000-2500 rpm is extremely normal for 40-50 degree cold start. If tach. does not jump to that level when you turn the engine on, then you should worry about it. It appears to me you don't have any idling problem.
Fritz, thanks for the input.
I crossposted a similar message like this in the Sedans (Accord 4) conference.
I am used car buying and came across a 94 Accord EX w/ 90000km's. There were two turnoff's. One was that there was a rusted bolt, on the floor, close to the drivers seat. Is this a cause for concern?
Also...the engine wasnt as spotless as I have seen other 93-94 accords. By this, I mean the aluminum parts were pitted and looked worn. I have seen cars with more mileage that have engines you could eat off!
Are these two any concerns? I just wanted to post here before I take the car to my mechanic (lives 60 minutes away!!).
Thanks again!
maven11@yahoo.com
Thanks a lot.
Vinney
your input. Vinney
Ron
vinney - my car is clickless
- Anthony
e-mail me for the whole story, I don't want to bore the others here. adg44@earthlink.net
I borrowed an '01 coupe EXV6 a couple weeks ago from my dealer. It did seem slightly quieter than mine, but not a huge amount. (Mine's a sedan) It did not exhibit the dimming when operating turn signals/power door locks.
I am pretty new to cars so please be patient with me!
I was thinking of buying a 94 Accord EX.
I'm just trying to get an idea on any additional maintance i would need. For a car with 99,000km (62,000 miles).
I understand at this mileage, I would need:
1) a new timing belt (if its not already installed)
2) new waterpump (can someone tell me why I should install a new one if the old is alright?)
3) Do all the major fluids have to be changed at this mileage?
-other things that I have to look out for would be a recall on the balance shaft.
Is this a pretty good summary of what to look out for in this car?
I'm sorry...but I forgot to look at the Accord manual when I went to the dealer. If someone could help me I would appreciate it!
maven11@yahoo.com
My service advisor at the Honda dealership explained to me (during the timing belt change on my Civic) that since the water pump has to come off when the timing belt is replaced, it would be a good idea to replace the water pump at that time. You won't have to pay any additional labor charges because they are already included in the charges for the timing belt replacement. You only pay for the cost of the water pump.
I don't necessarily recommend for, nor do I recommend against, replacing the water pump at this time. You'll have to decide for yourself whether you think the old water pump will last until you get the next timing belt change or get rid of the car.
I don't know if all the fluids have to be changed at 60,000, but if you don't have access to the maintenance history of the car, it may be a good idea to have the fluids replaced. The previous owner may not have been diligent in keeping up with the maintenance schedule for that car.
Just my 2 cents worth.
What kind of condition was it in, I wonder?
Vinney
i drive a 2000 accord SE and au unusual problem cropped up yesterday while i had stopped the car. when i tried to start the car, the key wouldnt turn and appeared stuck. There was only one instance before when this seemed to happen but on that instance after a few attempts it did turn. Yesterday i had to try for over 20 minutes by pulling the key out and reinserting and so forth till it all of a sudden turned. I was wondering if this was some kind of safety measure in the key lock mechanism that had gone awry (the car came with a remote entry system and the car was unlocked when this happened). Any inputs. funnily all this seems to have started only after my first oil change and maintenance.
P.s does anyone know of an online maintenance book for the accord. The wheels were sounding wierd today and the pressure in the wheels was 22psi in wach wheel. Somehow i thought it used to be in the 30s the last time i checked it but maybe im just imagining.
thanks everybody
Add some air. Most places it's free. Check tire pressure at least once a month.
I'd also be interested in what other Honda dealerships are saying the recommended interval is. Does anyone have any info on this? Of course, I'm sure there may be some that would prefer to recommend an earlier change, not because it is recommended, but to increase their revenue.
So, you decide to "save" 45.00 and leave the old one in. Six months later, it starts leaking and you have to pay ALL of that labor over again?
no thanks!
As for tire pressures, sometimes when the dealer services your car they will adjust the tire pressure. However they don't always do it right. I've had mine way over-inflated by the dealer a couple of times. The correct pressure should be in the high-twenties or around 30 (check your owner's manual). Pump them up and monitor them for awhile. Under normal circumstances they shouldn't lose any more than a couple of pounds in a month.
