Since it hasn't acted up within the past couple of weeks and the speaker sounds fine otherwise, I decided for the time being not to take it in to the dealer.
Does your idle "hunt" at all? Might not be the problem in your case, but you never know.
Brian
"I've a 03 ExV6 Accord with about 1k miles on it now. Almost every time when I start it in very cold morning, it gives me some kind of grinding sound right after the engine starts. I won't have the problem when the engine is warm. I was thinking to bring it to the dealer, but they may not be able to replicate it since it happens only in the first start in cold morning. Any suggestion on what I should do ?"
Ironically, everything's probably okay. Power steering fluids (not just on Hondas, either!) make strange noises - not unlike hideously grinding metal - when very cold. The tip-off is your reference that the noise subsides fairly quickly. However, you are wrong in one aspect. The dealer CAN replicate the problem through the simple expedieint of keeping your car overnight. I -would- call or take it in if only to describe the condition. I'll bet they tell you the same thing I told you, though.
i'll bring the car to dealer and see what they say about it. But one thing I tried this morning(~7F) was to wait for all the lights in the speedometer to go away before I started the car, and I did not get the noise. Will try again more often to see if this is consistent. Thanks.
Driver's side dash noise is still there - will tell the dealer about the A-pillar clip and another poster's discovery that the hood's rubber damper was transmitting noise to the interior.
Is this normal? Any ideas why?
We have a 99 lx 4cyl with five speed and 46000 miles and never had a vibration. Plenty in an old Mercedes diesel but not in the Accord.
Do you guys think there is any significant difference. What kind of problems might using Dextron cause.
They also said there is a bolt on oil filter kit available for automatic transmissions that have been having problems. The re built ones are coming with this filter.
Eric
The accord 03 and the crv have the same eng. so I will not be surprise if they have the same problem with the accords too.
Greetings from sunny Miami.
Fig.
"Fig"
Seems like they didn't do anything to it. Lemon Law in AL is 30 days. Coincidence that on day 29 it was suddenly ready?
Question for jrock80-- did they ever figure yours out? As of Jan 25, post # 4081 you mentioned that you were looking at Lemon Law also for this same exact problem.
Any suggestions appreciated.
If I remember right, the kit cost $60 or $80. I think he said it had a spin on type filter like my Subaru.
Eric
http://www.brake-noise.com/
with this annoying problem. I was also told this was "characteristic" of the car. I don't think we should accept this response. Why don't you go
into the dealership & let them know that this is
unacceptable & maybe kick something to let them know you are serious.(This didn't work for me)
Maybe we can do a class action complaint. please let me know the outcome. Do you have your ac on? Try turning that off.
I recently had my Accord ATF fluid replaced with Dextron III. Both my mechanic and a transmission shop said Dextron was fine. However...
A few months later, when the shift lever is put in D-4, only the third gear is used. The car is sluggish from a stop, and over-revs at highway speed. I can get first gear if I put the shift lever into "1", but I can't get second gear with any method. Also, there is about a second delay after putting the shifter in reverse before the transmission actually shifts.
Could this be a problem with not using Honda ATF? Any chance installing Honda ATF might fix it?
Some have suggested that this is a transmission communication problem. They said this is a "limp home" mode caused because the tranny doesn't know what gear to be in. Any idea how to see if it is the transmission computer? How much does it cost to fix a computer. A transmission shop wants to open the whole thing up, to a tune of $1400-$2000.
If you are very lucky the clutches in your tranny are not damaged enough and they may recover. However if they and or other parts are damaged-the vast majority of the "tranny" shops out there are ill equipped to work on a Honda tranny. Have seen too many horror shows with those people repairing GM auto trannies and they are fairly simple comapred to a Honda 4 speed AT.
I would suggest buying a used tranny out of a wreck-see it in the wreck and remove it yourself-you can see the mileage and condition of the vehicle-before I would trust a tranny shop to do a rebuild. If Honda does the rebuild-have heard prices of 3/4K.
Stories like this make my blood run cold. These guys probably thought they were saving you a couple of bucks but the harm is done-intentional or not.
Let us know how you come out.
Oh have you gotten a CEL code light yet? Should have.
