Visitor Agreement.
Also, what about your tranny fluid?
For replacement tire comments, the following is a very informative forum.
"Tires, tires, tires" Jul 7, 2003 6:26pm
It was surprisingly easy. All you have to do is take off the wheel, remove 4 bolts holding the brake piston and caliper and 2 small screws holding the brake rotor on. I took the rotors to Kragen and they resurfaced both rotors for an even $20!
I put the rotors back on and put everything back together and sure enough, my steering jitter was gone.
If you suspect that your rotors are warped, don't wait as long as I did before you visit the dealer. If you're past the 12k point, consider doing it yourself.
I need your suggestion and advice. sorry in advance if I posted in the wrong discussion group. Thanks all.
I am currently in the process of moving out of state. The problem is thatI have 2 cars to move. One is the new accord and other one is 92 toyota corolla 4 dr sedan. The moving distance is about 800 miles, and don't want to spend the $$ to use car moving company. So I would like to know the following qestion.
1) is it possible to tow 92 corolla using the tow hitch and tow dolly? also generally who makes good tow hitch for accords?
2) would you recommend it and why?
test007
Quite a while ago, I used to work weekends and summers at my dad's service station and always looked forward to customers with the front disc brake jobs. I always found them to be much easier and quicker to repair than the shoe/drum systems.
Front disc brakes have been around for quite awhile (late 70's-80's???) and I don't remember hearing people complaining a lot back then. Maybe the professionals on this board can shed some insight.
What do you guys and gals think?
I used a torque wrench to put all of the bolts back on. 80ftlb for the wheel lug nuts and 40ftlb for the brake bolts. I hand tightened the two philips screws holding the brakes in place.
I'm no professional mechanic, but I agree - my 1968 Ford Torino had front disk brakes, and all cars afterwards. And only in the last few years have I ever heard of warped rotors within a few thousand miles.
I know, abuse could cause some of them. But I would think that someone that would 'ride' the brakes or make severe panic stops or drive so aggressively that the brakes heat up and fade - I would think there should be brake pad problems before they should be rotor warping problems.
We've had fools with overpowered air wrenches for many years. But my personal opinion is that with normal brake usage, water hitting the rotor should not cause warping. If it does, then this is a design problem and should be corrected.....
P.S. I've driven a Cad Seville just off a 3 year lease with just over 6,000 miles (why did this person even need a car??? But the car had excessive brake shimmy, indicating rotor problems. What could cause this????? Maybe seldom driving the car, and it was from a northern city with salted winter streets, cause the slides on the calipers to bind up???? But something seems to still be built weak to have this problem with this low milage.....
Anyone with metallurgy knowledge care to comment ?
1. Maybe 70% of the time when I push in the clutch, I can hear a quick "whisp" (psssht) sound, almost hydraulic-leak-like in nature. What might this be?
2. When I start the car, it starts very quickly and a bit dramatically. Not violently, but not at all like my '00 Accord. Anything to be concerned about?
3. When I go over speed bumps, there is one back forth rocking of the body on the suspension (i.e., not rocking front to back several times, but once. I also noticed that me shifting weight in the car easily rocks the car a bit. What might be the cause?
4. Finally, what does it take to convert an older car to using the current AC stuff? (R134a?)
My 03 Accord EX-V needed rotors turned at 8k. fourth accord and first real stupid bad engineering problem. This is not a fluke as dealer did do all work under less than 12k adjustment warranty. I wonder how long they will last? I did not miss my 3.2 TL at first but now I am starting to wonder. Otherwise, car problems are stupid temperature gage (always high) and what I call loose steering--floaty buicky.
INKY
I believe filing complaint against Honda will help. With large number of such instances, NHTSA may look into the issue and may either ask for a recall from Honda or at least have the problems repaired for free.
The CL and the Accord though similar are slightly different but that is probably splitting hairs.
I would characterize the steering as light not loose. The slightest change in the direction of the wheel and the vehicle will move off straight and center of the road. This is vastly different that a Ford F150 and Toyota Avalon that I have owned that both had 2" of play in either direction of the steering wheel without making a difference to the way the vehicle tracked.
If you search "transmission" in this forum, you will see quite a few non-2000/01 accords with tranny problems.
Hmmm.
My 92 accord make a continuous knuckling clunking sound from the right front wheel (i think) when i am slowly accelerating and turning left(ie from a stop sign).
... This could be related to CV joints, have them checked out, could be time to replace them. Good luck
While hanging around the showroom, I took a look at the coupe, and found the lack of side protective molding and small windows really bugged me. The door handles bothered me as well. Why would the leave out something as useful as the side molding?
As for the quick start I dont think this is anything to worry about
The extra bounce could be a braoken front coil spring which we see alot of now a days in those as they get old or a worn strut. Check it out it is easy to spot a break or leak at the strut.
As for the AC retro it is easy and worth it I have done it to both of my 92 accords...Sorry for the delay I have had alot of softball games to all hours of the night lately...
Just look at Edmunds long-term test where a Honda dealer tried to charge Edmunds for a check engine diagnostic while under warranty!
I took delivery of the car with two miles on it. Today has only 84 miles. I use it for pleasure as second car, so I don't drive it to much. I work the graveyard shift, so I only do 12 miles daily for 5 days/week and I used my primary car to do this. I ordered a lot of accessories from Handa.com, such as, body side trim, moonroof visor, exhaust tip, birds eye trim, cargo tray, mud guards,door visors and doors guards, I'm still waiting for them, but I would like to see how its looks after I put them on. I bought the car in Hollywood FL. I got it for $100.00 under invoice + TT L. I'm still learning all the features on this car. But so far is a marvellous driving experience. I sold my baby a 1992 Mitsubihi Eclipse GS 5sp with 72,000 miles on the clock and in pristine conditions to buy this Accord and WOW, what a difference! I'm sorry for the long of my post but I wanted to share my experience with all of you.
I read a article when this model of Accord was released, Honda claim because its engine uses 64-bit computer and multiple knocking sensors, this V6 can still use 87 gas even this engine has relatively high compression ratio. I aslo notice that the similar but not the same engine used in Acura TL, which is 3.2 liters, requires to use 93 gasoline.
Anyone with his or her thought on this, please post. By the way, I will try to use 93 gas this weeken and see the problem goes away. And my Honda dealer admits that the wind noise for 2003 Accord is louder than the old Accord because the design of the window is differnt.
After years of hearing the loud wind noise in earlier models, Honda test engineers have suffered from hearing problem. Finally they think they made a honda which is quieter!
Have fun guys.
On the Honda V6 engines (including the 3.2l and 3.5l) when the timing belt or any of the other drive belts are replaced, does the oil pan have to be removed and the oil drained? Thanks.
Let us know how u come out.
IF no luck at all-would suggest getting someone who knows honda trannies to rebuild-got a quote from a local tranny guy who knows his stuff to rebuild replacing all "soft" parts including clutches, some bearings and the speed sensors for under $1,500. Don't touch the franchise places-they don't know squat and are well to be avoided.
I put a scratch in my 03 EX-L sedan about a month or two after I took delivery. I did it myself with the metal tip of my hose while washing the car! Anyway it was a scratch about an inch long on the forward aspect of the fender flare on the driver's side, through the clear coat. I took the car to the dealer and told them what happened (Leith Honda in Raleigh, NC). They have a detailing guy who comes to the dealership a couple of days a week and he was able to sand the scratch out of the clear coat. He also needed to spray a little paint in one small area. Anyway, he only asked for $5 and did the repair while I waited. I can't even tell where the scratch was any more and I am very meticulous about the upkeep on my new baby. This is something I would not recommend doing by yourself unless you have experience - there is a definite art to what he did. BTW - he did mention that the metallic paints (I have the desert mist) are a lot harder to color match that the flat colors. Hope this helps.
Matt
