"Spencer said Honda engineers identified the root of the problems a few months ago and have redesigned the transmissions.
The four-speed models were afflicted with a bad bearing that could break apart, scattering fragments of metal that clogged fluid passageways in the transmission, causing it to shift erratically, he said.
The five-speed models typically were damaged by premature wear of the third-gear clutch pack. As the clutch friction material abraded, it scattered bits inside the transmission case, clogging fluid lines and causing erratic shifting."
this is from LA times, article on sept 11 2002.... here is the link..
http://www.cartrackers.com/Forums/live/Toyota/208.html
about half way down...
And, my driver's door is making noise when the window is closed - almost like the door is flexing.
I am so disappointed about this. Anyone getting an adequate fix of these problems at your dealership (ex 4cyl at, with a "j" vin)
as far as the driver's door, I have more like a squeaking of the window against the rubber molding. BUT this goes away the longer I drive.
I love the car, but I am finding that unless you drive on the smoothest seamless asphalt highway, you will probably experience some kind of squeak or rattle; something my jeep liberty never does on any road surface.
http://homepage.mac.com/julioardz/pages/accord/rattlefix/index.ht- m
I have a 5 month old '03 Accord EX-V6 with 5000 miles on it; I have had to top off the coolant every 3 to 4 weeks because it will be low. There are no coolant leaks on the ground that I can see.
This has been happening since I first bought the car; have you seen/heard anything like this on the '03 accord v6's? I am taking it into the service department tomorrow to see if they can fine the leak/problem.
If anyone has the same problem please let me know what they did to resolve the problem.
I know that when the car is hot, the coolant will go up. But the more I drive it, the lower the level will be so I am almost certain there is a slight leak or it is going inside the engine.
If not, check your dipstick, if the oil is milky, head gasket is leaking.
Has your car been running a little hot? Maybe the thermostat is sticking(not opening all the way) ...
Old car troubleshooting tricks, but some still work... =o)
Last option... when you park the car at home after it is hot, try leaving it idling in the driveway, rev it a couple of times, and see if it drips, if it does, it could be a leaky water pump seal/bearing, and last I had that problem, no puddles, etc, just leaked a little as I drove the car...
After my visit with the dealer, they could not find any leaks. The did pressure test the system, but they seem to think that there was an air bubble in the system. So they bled the air out of the coolant and filled the resevoir.
I now notice that the water hoses are very tight. Where initially the hoses weren't so tight. Is this normal?
- Above the driver's door along the headliner by the grab handle
- Where the A-pillar meets the dash on the passenger side
I also have the following issues:
- The top piece (knob) of the manual shifter rotates without much force when it gets above 70 degrees inside the car
- When starting the car, I sometimes hear an electrical "shorting" noise coming from the left side of the dash. It happens intermittently , regardless of outside temperature or whether or not the car has been driven that day.
None of these issues are overly irritating, but they do exist. I am still not sure if I want the technicians tearing apart my car to solve these rattles - I would rather do it myself. Has anyone else been able to resolve similar issues or if they took their car to the dealer, what did the dealer do to fix the problem?
I really like this car and just want to get it right. Thanks.
i get the clunk noise with i shift into drive after rolling downhill in neutral.
a high pitch snap that sounds like you ran over a beer can.
i have no idea what it is?
anybody?
my transmission is a whippy shifter, a little jerky and has so from day one.
Has anyone used the Honda Touch up pen to fill in small rock chips?
I tried to fill in some chips by following the recommended instructions included with the pen. After dabbing the pen it left pretty big “blobs”, so I tried again, but first wiped most of the paint off the tip of the pen. The end result still looks like a small blob of paint. The odd thing about the pen instructions is that it explicitly says NOT to drag the pen across the paint surface. Without some dragging or brushing it doesn’t have a smooth finish. Perhaps the touch up paint with the brush applicator is better.
When applying touch up should the paint repair look invisible or am I naïve to think that the touch up area will be a seamless match to the rest of the finish?
I did NOT have to respond either, but I wanted to!
I left the following reply on an another string (same subject) because many there reported the same delay....
___________________
All: I thought as you did, "this is normal, my other Honda did this, it's unique to Honda design, but it runs great once it is in D......"
All I can say is this: I expected to hear Honda service say, "It's normal" but they did not. What motivation could they possibly have to offer me a $4000 tranny job for free? I could see where they would be motivated to tell me, "everything is fine" hoping that it holds out past 36,000 miles.....
Another data point for you all. Every time I was in for add ons or this oil change, my salesman would loan me his demo car with auto tranny... Guess what? No delay, no double engagement. Armed with these two facts, I have to believe that something is amiss in the transmission.
Other thoughts?
As always, Thanks
mike
the location of the part is not obvious if you have cruise control
it is under the dash to the left of the steering wheel column.
if you have cruise control if is hidden behind the unit. rectangular metal box with two bolts relay is above it the relay is screwed into the dashboard from the top. god knows how it comes out i just plugged in the new one and tucked it in. to remove 8 pin wire harness, one piece use two pliers one to take the stress of the retaining snap and one to pull. flash lite in mouth and you are on your back under the steering wheel. good luck. this is a common problem although the books dont say clearly where the relay is, a repair guy at the dealer knew the location. there is enough slack in the wires to plug it in and tuck it under the dash.
any one else have this?
(the entire ignition must be replaced, so they say) i have photos of the original and defective copy you may view the picture of the two keys here.
http://albums.photo.epson.com/j/AlbumIndex?u=4058736&a=308715- 22&f=0
note length of key and space near thumbpad. the locksmith sawed away the metal shown and was able to remove the key. i contacted true value to inform them. as well as honda
ignition key in starting position longer than any
other V6 cars for the engine to start.
Does anyone notice the same thing?
I have a wiper problem ever since I own the 2000 Accord Ex. The problem is the wiper blades seem to worn out so quickly. The new blades work fine for a few weeks and that's it. I don't have a clear view anymore. Of course, I've been trying to use the original part from Honda. I've just spoken with one of my friends who just bought a new 2003 Odyssey and he does have the same problem. Is this a common problem with Honda ? Or, please advise if you know of any solution to this problem.
Thanks and have a nice day !
p.s. it was not fun driving the last few days with all the rain from Isabel and a few-week-old wiper
I know people who have bought aftermarket ones and wound up switching back to factory ones.
windshield. Too much wax on it?
I had the same problem.
I remember reading somewhere in the car talk. It
says clean the windshield using newspaper & vinegar a few times.
I gave it a try. And the problem went away.
Took him 10 minutes to replace the master relay but he also wanted to attach it to the computer to make sure everything else is ok. No problems since then... :-)
Could this be fixed with a GOOD alignment or could it be something else?
