Also do a search here and on the Honda group of messages-IIRC somebody said they had the same problem solved by a dealer with a "kit" that had a bunch of bolts/nuts in it. Scarey - good luck and keep us posted.
They practically melt to the windshield during summer (and we don't live in Phoenix or anything). A line of (melted) rubber from the wipers gets deposited on the bottom of the windshield, and when the wipers are used, they pick this up and spread it across the windshield, causing streaks and secondary lines of rubber at the limits of the upper travel of the blades. This is made worse by the fact that the secondary line left by the passenger side wiper is right in the middle of the driver's line of sight. The lines of melted rubber have to be removed with a razor blade to get the windshield completely clean.
I have tried both OEM and high-quality (Bosch, etc.) vendor replacements, and they all break down within a few weeks of use in summer (they last longer in winter). I have never owned another car with this problem, so I am convinced it's a design issue rather than being related to glass-cleaning or wiper blade maintenance techniques. Like a previous poster, I am a fanatic about clean glass. It's a good thing my wife (the primary driver of this car) is not.
Mazda... If you have a little bit of room at the end of travel for the driver blade, it is possible to adjust the blade position. Unbolt the blade from the motor, should be about a 16mm nut. It is slightly pressed on there and I generally wiggle the wiper arm and it should pull it straight off. It is a grooved bolt, easy enough to remove the arm, re-set the arm in a slighly different position(rotated up a bit) ... this should solve the problem with the blade sitting on the cowl.
BTW, I should clarify that the blades currently rest on top of the windshield glass, not on the textured plastic trim below the windshield. It's just that they rest on top of a portion of the windshield that has black masking integral to the inside of the glass. This masking is what generates all the extra heat.
I don't think I've ever seen a 26" blade on the shelf at a regular parts store. Maybe '03 Accord owners should try shopping at RV parts stores for that blade! I guess the hassle is worth it for the big view of the road that Accords have.
On occasion the opening on the hood freeze in winter and just pour some water on it and that will thaw it quickly.
I use needle tips(not big needles mind you) the kind used for hemming... very useful, and you can clean the wax/polish out of the edges of the holes as well.. =o)
If that doesn't work, open the hood, prop it up, and spray while looking through the crack... once, I had the hose have a leak, and would spray the engine ... easiest way to find it... imo
Andy
Make: HONDA
Model: ACCORD
Year: 2003
Service Bulletin Number: 03007
Summary Description:
HEADLINER SAGS IN THE BACK. *TT
There's also one on the NHTSA site for rear deck noise that might apply.
Jeremy
This doesn't sound like this kind of Honda engineering that I'm used to. I have a 2000 Accord which I'm keeping, and it's been flawless so far at 65K miles.
I've had other cars with pulsating brake problems, and I know how irritating it can be to hear thump-thump-thump every time the brakes are applied.
So, before I spend my $23-25K, I'd like to hear from any 2003/2004 Accord owners. Are you having pulsating problems or other problems with your brakes? How many miles do you have on your car?
Are you having other aggravations with your Accord that you find are common among Accords of the same year? Would you still buy your Accord again?
thanks!
I DID have the brakes problem, and at 5000 miles I had the rotors 'turned.' I think this was an initial installation issue and now at 9000 miles they are still quite fine.
I also had a problem with the window tint, but it's not specific to the car. Window tint is not a factory option, dealers have it done at local shops.
I still think witout a doubt this is the MOST car you can buy for the money.
Out of frustration, I went to an independent wheel and brake shop for alignment (which Honda will not pay for, so it was $60 out of my pocket.) They where able make the car track straigher than ever before, but it still drifts to the right, even on road completely flat or sloping slightly down on the left. They found that the springs of my car made the right front tire on my car ride 1/4" lower than the left front tire. They think this creates a slight problem that cannot be completely compensated for. A fix might be to get new matched springs for my front suspension. I informed my Honda dealership of this, but they said there is little they can do because all the measurements are within spec, even with the 1/4" difference. I am currently in the process of trying to get the customer service representative from American Honda Corp. to try to fix the situation, but I might be out of luck. If you want you new car's alignment to be just right, make sure the car you buy is okay before you buy it. Hope your car's front suspension is assembled more precisely than mine.
Hope that helps and congrats on your new car. Your gonna love that engine!
SDG
Jeremy
My questions......what has Honda been doing for all the others here with transmission replacements? What is your experience with creaks/rattles/electrical after the replacement?
BTW....I told the dealer and customer relations that I will not drive this Accord off the lot and expect another new Accord in its place.
I guess I wouldn't be so upset if I had not experienced what Honda USED to be able to do in Ohio since my other car is a 1985 Accord with 370,500 miles on the original engine AND transmission.
I have a EX/V6 (navi) with about 3300 miles. On the first oil change, I will have them look at it again. However, I fear that to remedy the problem, they will have to tear open the inside roofing.
If you have any fixes for this problem, please pass them along.
Ryan
my car was built in 8/03, has 1500 miles, and couldn't be more perfect.
whats the deal?
However, the dealer says it the transmission. Seems American Honda will not allow the dealer to rebuild the transmission. It has to be replaced as a complete unit so the failing transmission can be returned to Honda for them to tear it down piece by piece to troubleshoot it. I totally agree with Honda's approach. Just really disapponted that the car is having this type of issue.
I read through these posts and other sites too before my purchase of the 2003. Knew about the 2000-2002 Accord/Odyssey/TL/CL transmission issues. Hoped Honda had designed them out with the new model but obviously not.
I tought I was dreaming. My first new car, it just couldn't be that a new car had a misalignment. They will check next week when they try to fix for the second time Problem #2 (see below)
Problem #2: Front break noise at low speeds when not breaking. Got it fixed at 6000km. It's back again even though they changed the calipers. Has anyone had them fixed but had to go back again? Dealer says they will likely change disks and pads now. Will that fix it? I'll let you know.
Problem#3: Rattling dashboard noise passenger side. Kind of intermittent. But I now see I'm not the only one. I have not seen a solution to it though on this post. Is there one? If mine gets fixed properly, I'll update you.
Problem #4: Bad carpet rear right side. Got it replaced. Must have been a defect from supplier.
Problem #6: Strange vibrating noise when going from first to second gear when engine cold. Looks like I found the reason here. ABS pump "fills up" my dealer says.
Problem #7: Driver side belt height adjustment device. When driving over highway, the spring in the mechanism makes a vibrating noise. It sounds silly, but the thing is just at me ear level and it dose it especially on our not so nice Canadian roads and highways. And it's driving me nuts. Anyone experienced this? Is it just a bad one? Dealer will look into next week. I'll let you know again.
on a couple occassions my 89 Accord had the same key & shifter problem.
What I did was restarted the car while the key still stuck in the ignition, shifted to D, then
shifted back to P. The P light lit up.
If it happens again, see if you can do what I did.
Accordboy post was another premature tranny failure at low mileage, but was a different type of failure.
Jeremy
