Visitor Agreement.
40% of your braking supposedly is done by the back brakes, but the back brakes also are about 1/2 the size of the fronts, and heat up much faster than the front brakes due to smaller rotor size and the smaller pads. I would probably have the front brakes inspected for wear as well, as you may very well need front pads.
$225 is not horrifically expensive if they are doing both sides... figure about $50 or so for pads, the autoshop will usually charge about $10.00 ea to turn the rotors, and about 1-1.5 hours of work for both rears. Also ask them if they are going to adjust the parking brake while they are down there... =o)
Yes, I know that is $150 in labor, but you could buy the shop manual($100.00 from helminc), hopefully you have the tools, a c-clamp to compress the caliper, 5-10 for brake fluid, anti squeak compound, lithium grease, etc., and another buddy so that you can bleed the system, if not, $40.00 for a one man vacuum bleeder kit.
I generally do my brakes themselves and have helped many a friend learn how to do it (in exchange for a hearty meal)... haven't had a problem yet...
Just don't do what my buddy did (on his own) if you decide to do it yourself... when the calipers(and pads) are off the car, don't press the brake pedal "to see how firm they are" ...
good luck codog... let us know what you decide.
I'm not quite ready to jump ship yet on my Accord. Instead, like FredV1 said, I hope Honda will figure out the cause of all these noises and get some sort of fix going for them. I'm planning to keep this car for a good 200,000 miles so if it's making these noises at 3,000 miles I can only imagine what it will sound like at 200,000...or even 50,000 for that matter!
Starting from about 400 miles, I heard a 'ka-cha' sound from under the hood, when the transmission shift from 1st to 2nd gear (automatically, of course). This occurs only when the car was first started and making its first shifting. Should I be worried? Does this indicate something waiting to happen?
Any advice/comments?
Also, do you feel like the car is wobbly also. I think that my car is quite wobbly at low speeds and its seems like the driver side that is wobbly.
About the seat shifting to the left, I hope you figure out what that is and choose to share it with us. What you are describing is funny though because it impossible in that you say the seat shifts on direction but never shifts back. It would eventually shift its way out the door.
As soon as I have time to get into the dealer, I'll report back about this.
That said, 1) the $100 check-up was unnecessary. If memory serves, Honda requires only oil & filter change plus tire rotation at the 10k mark. There may be other minor items but nothing that an owner can't do. 2) With engine stopped, turn key to off then back to on (last position before cranking engine, when all warning lights are on). Without cranking engine, depress trip reset pin for 10 seconds or until "Maint. Req'd" light goes off. Next time it'll show again is for the next oil change reminder.
There's absolute nothing unethical about resetting the light, or doing anything that's within Honda's maintenance requirements yourself. For the first 36k miles/3 years, the dealer is there essentially for warranty-related repairs. Maintenance work can be done outside the dealership since no Honda-specific expertise is required for the items (like checking CV boots, brakes, etc.). Hondas are generally reliable cars, so the first 36k miles should be trouble-free as per my experience with our 6th gen Accords.
By turning a rotor you are reducing the amount of metal and reducing the life and replacing them can be expensive-just wish somebody would tell me I need to have my rotors turned-really like tearing that type of jerk a new one.
Sometimes, depending on the car, the $10 to turn the rotors isn't really even worth it. Changed my buddy's rotors on an '00 Cavalier, and for $16, they were new, $10 to turn them... lol.
Of course, many of these newer cars have no meat on the rotors(usually not even enough to turn once)...
My '01 just recently saw the inside of a dealership for it's first service. The 105K mile timing belt/water pump service.
Just change the oil/filter regularly, replace air filter @20K-30K, trans fluid every 30K-45K (use Honda ATF-Z1 only), clean throttlebody plate at 50K or whenever it starts to stick, replace coolant every 60K (using longlife coolant-green stuff), tire rotation @5K-7.5K intervals and you'll have a very well maintained vehicle and a vehicle that is still a joy to drive well past the 100K mark. BTW all of this stuff is in the owners manual.
This morning when i shift from P to D, I heard a loud "clung" sound coming under the front part of the car. I also felt that I need pull hard, and the stick seems to stuck. My parking place has a slight up slope (<10 degree). I did not experience this before. Then I try on flat road, the shift is quite smooth and no sound. Any one can advise whether it is normal or something is wrong. Thanks.
Good luck with whatevere you choose.
I do stand corrected on my Honda's year. It was a 2002 model instead of 2003. Sorry.
I have not taken it to the dealer.
What do u plan to do? let me know how it goes.
Sorry you had all those problems with your 2002 SE. Conversely, our 2002 SE-V6 (Canadian market exclusive) has been almost flawless through 15,000 miles other than a couple of misaligned body panels and the infamous Honda rattly moonroof gasket.
Has anyone contacted Honda and received any replies on the issues we have all complained about?
In Honda's defense, I did not contact them. When I took the auto back to have it serviced for some of the items, the technicians (of course) told me they could find nothing wrong with the car, so I figured talking to Honda would be more of the same. After reading some of the common complaints here, seems like Honda may have some work ahead of them.
Hji, the noise you heard is your parking pawl disengaging from the drive gear. When on an incline/decline, if you don't set your parking brake firm enough, your car will roll slightly, putting pressure on the pawl making it harder to pull out of park.
Therefore, the way to prevent this from happening is to firmly engage the parking brake(Afterwards, I like to shift into neutral first to ensure the car won't roll), then shift into park. this will prevent pressure from being applied to the parking brake while you are parked. Then when you get back in the car, shift out of park first, then release parking brake.
Hope this helps.
I wouldn't worry too much about it, but if you are worried ask your dealer how to set the light off next time you go in for an oil change.
It is the other way around.
Set your parking brake FIRMLY before shifting into Park.
Shift into Drive before releasing parking brake.
hji, sorry for confusing you. Hopefully you haven't driven around all day with the parking brake on!
I just slapped a $20 pair of Albany pads from Autozone, the noise went away and the brakes work fine. I was surprised how much more both inner pads were worn (down to the indicator). I couldn't believe how easy it was, it took me about an hour. Honestly, I'm disappionted that the original pads only lasted 36k miles. I got 75k from my 93 Probe GT
One question, Autozone had two different brake pad manufacturers available, one was Albany for $20, and another manufacturer for $40. Is there a noticable difference between the pads to warrant spending twice as much? I figured maybe I'd go with the more expensive pads when I do the front brakes if it's worth it
Well, I took my car to the dealer and they said the infamous couldn't recreate the noise. But they were very helpful and told the closest thing that he can think of was something wrong with the welding spots, which i do not concur with. I have read a lot and many people are saying its the ABS check, which could be considering it only happens when the car has been sitting for a long time and only happens when we start and move the car.
I also read around where ppl were talking about the tire pressure. I checked mine out and it was around 40 which was way too high although the max. press. is 44. The manual says 32 front and 30 back. I dont have any rattling or noise with my car and the V6 is very powerful, but sometimes its a bumpy ride and I think its just the freeway because I rode in other cars which were jolting too.
Altogther, I really love this car a lot of nice features and I think u just have to get used to it when you are driving have a feel for the car. I know I had to adjust from a 1990 accord to the 2004.
I fully understand and accept the occasional failed tranny, steering rack, motor etc. but as far as squeaks & rattles go, given today's higher quality materials, fastening devices and precision tooling, there really should be no excuse for rattles in any car.
Overall, i like it very much and look forward to driving it. It is powerful. The interior is plush. It has most of everything i need (Just find out this morning I need heated steering wheel, too), well, can not expect everything, BMW5 does not even have lumbar support. What can u say.
Enjoy your car!
It's still under warranty.
My dealer is fantastic to deal with. I always get a loaner or a rental car, and they are always friendly and determined to make my issues with the car disappear.
If I didn't already have an Accord and know better. I might believe that crap.
