Also keep in mind that the mileage for all cars goes down a bit in cold weather.
I'm assuming that the crystals have frozen.
The only problem I have had with my brakes is the rotors warping way too soon. But Honda has apparently changed pad materials to correct this design defect.
My 03 accord LX v6 now becomes more and more noisy. At 70 miles, the wind noise is loud as if the windows were not there.
In the early days, the noise is not this bad.
I can hear the noise is from around the pillar. My wife in the backseat complains too.
However, this is your car and your money so you can use diesel if you want. You may not get far but you get the picture....
1. Driving mix highway/city and length of trips.
If you drove mostly highway miles but in short (<10 miles) trips with cold engine to start you can not expect the EPA highway estimate - all in one trip you should. With a previous vehicle the mileage went from 20 to 23 when my work location changed from 8 to 26 miles each way.
2. Weather and seasonal. In Seattle my Prelude mileage was 32 in late summer and dropped of to 28 by end of February year after year. My Accord is showing the same pattern since new in May. Varies by location and could be opposite in some places, such as Phoenix.
3. Vehicle condition- engine tuning, tire inflation, gross weight, etc
4. Driving style: lead foot and 75+ on highway vs. eggshell starts and staying within 10mph of speed limit.
If poor mileage can not be accounted for by the four reasons above, the car should have a checkup. Do not wait for a "break in" miracle.
Oh, so as to not sound pretentious, I'm in the USAF and it's not specifically MY plane.
berbel
Next he'll try to say "fine we'll do a one time good will exchange/fix" like they are doing you some kind of huge favor by fixing your broken, under warranty car.
GRRRR. that kind of junk makes me angry.
I suggest you try to find a different dealership to work with. It can make all the difference.
Also FYI-this maybe an old husbands tale but some have said topping off your fuel tank can cause big problems with your emissions system-Honda replaced a lot of my emissions system under extended warranty but now I do not top off my tank-used to fill it all way up for long trips-no more.
My local autozone store will read the cel free of charge. Take note however-their parts prices are sometimes higher than Honda dealer prices.
No problems since.
I see your posts date from March 2003. I bought my 2003 Accord L4 4 door manual on Oct 1,2003. Car was made in the US sometime in April 2003.
I am curios what can be done about it if anything? I wonder what Jonesok1 managed to do with his car? Is it possible to return car? Are there any safety concerns about it or not? Someone said that it can be fixed by welding some kind of bar(s) underneath the car???? How accessible part they are intending to weld actually is? I requested to be present in the service where they gonna do it! Honda Canada said it is up to the service to decide due to safety concerns? Yeh right!
Any suggestion would appreciated
I am willing to go public, big time coz it pisses me off when big corporations treat people like crash dummies. Anyone wants to join
i purchased 04 accord coupe recently and was offered by the dealer to install an alarm for
$500 dollars. did i over pay?
also after the installation i started hearing very faint and high pitch humming noise. the noise becomes more audible as the engine rev goes up. does this have anything to do with wiring mistake during the installation of the alarm?
It may have been incorrect for the service people to term the problem as a missing part or missing weld, but it sounds like you should let them do the work to fix your car and move on.
And I think it is entirely reasonable for the dealer not to let you onto the floor when the work is being done. To do so would be begging for a liability issue and probably insurance problems - I'm sure their policy does not allow them to have customers on the floor.
We never took the car through an automatic car wash. Just poor workmanship by Honda. Then the right door trim around the front window started to bubble. Dealer attempted to fix. Worse than before. Had to reorder part. The third time they broke the inside door release cable while taking the trim off. End result five trips to the dealer for what should have been minor repairs.
Then the straw that broke the camel's back. The infamous Popping Noise appeared after about three months of ownership. The technician actually heard it. This was a surprise to us.
The fix---they got up between the floorpan and the firewall and bent sheetmetal away from some of the welds that were causing the noise. I said this was not the proper way to fix the problem. They insisted that they had some previous year Civics with the same problem and this was the cure.
Well it did work for about two months. Then as I suspected the Popping Noise reappeared--louder than ever--Car went back to dealer. I informed them that I was well aware of how it should be fixed. Flat weld the two parts together. Guess what. This time they couldn't hear the loud noise. They added some foam insulation in the A pillar.
Continued to drive the car for awhile, then numerous other rattles started. I liked the power, the automatic and the features, but the rattles and Popping sound was just too much. Yes I know I could have fought longer. This dealer has received Honda of Canada's top service award for five straight years. How they achieved this is beyond me. We had the car for seven months and was in their shop seventeen times.
There is certainly a lot of truth in the saying "Do not buy a first year car." Even a Honda. Too many teething problems.
I wish you the best of luck in having the Popping Noise fixed correctly.
Now a Toyota owner.
Keep feeling me in on this issue, I need as many information as possible.
I wonder how much is for Honda to have someone 17 times in the service.
bojo, maybe you need to talk to a different dealer, since there is a permanent fix for the problem.
I see you said you have the I4 Sedan. I thought this was only a problem with the V6 models?
Anyway, be persistent, or try another dealership, and my important, stay rational.
One that I believe you are talking about there is a permanent fix. That one is described in TSB 03-58 dated September 23,2003 by American Honda. However, jonesok1 mentioned the other one that is located in the area that is just below the windshield, in an area that cannot be accessed because it is enclosed by welds, below the windshield and in front of the door. The A frame pillar descends into the lower front fender area. You need to strip the car to the chassis to get there.
How they gonna fix it by taking car to a body shop and weld steel bar(s) under the driver side floorboard to keep the body from flexing???
I have to figure that out first.
Maybe the cheapest way to fix the problem is to trade it in for Toyota or something before they screw things up so badly that cannot be fixed any more.
Very unfortunate I like the new engine for now.
Thanks for your reply pj23.
Anyway, good luck to you.
Most LCDs have an operating temperature between 0
and 50 degrees Celsius. There are a few which can go to -10.
So if the temperature falls below 32F, you will experience a slow response.
Any ideas on what this could be? Just too damn cold? I've checked the battery and its fine, the car is garaged and I'm thinking it might be the fuel filter or something, don't think i've changed that ever. Also, does anyone know what the flashing D4 means? Rather curious.
BTW I just installed leather seats in my car. Looks great. I told you guys I want to like this car. I noticed that metal panel inside the back seat (back rest) was totally rusty. Amazing but true! Guy that was doing that for me said that all Japanese and US made cars are like mine. European cars are different. Check on yours it is easy, there is a velcro on the back rest on the trunk side of the seat.
I declined, having observed no problems from brake dust, and also suspecting them of accelerating the maintenance schedule to enhance their own revenues (for example they recommend an oil change every 3,000 miles when Honda says 5,000.)
Do other readers recommend preventive maintenance for brake dust? How often? Is there a disadvantage in waiting until I hear a squeaking noise when braking? $30 isn't much, it's more the principle of letting people tack on unnecessary work every time I go in. Thank you.
I will take any advice I can get at this time because my next step is the Corporation if I continue to have these completly unnecessary problems.
One time the CEL on my 89 Accord came on while I was driving. Stopped the car and found one loose wire at one spark plug. Pushed it back in and started the car again. The CEL went away.
