I would definately go somewhere else for my maintenance-sounds like these guys have your wallet targeted and they will find a way to get into it. Torn CV joint boots come to mind and that will cost you several hundred to fix.
For what it's worth, my '03 EX-L I4, purchased 12/31/02, has also been as close to perfect as I can expect. The only issue I've experienced was some noise early on (has been described here as "crinkling" or "squeaking") from the door seals, but now with 25,000 on the car, I hear nary a squeak or rattle, no matter what the temperature or the road surface.
Maybe new plastic is stiffer and tends to creak, and that goes away with time. Our car still has no rattles.
let us know if it works.
If you haven't had problems, it's probably difficult to understand the frustration of those who have had them. I've been to the dealer three times since I bought the car last April to have brake problems fixed, and the problems are beginning again. I'm not bashing Honda, but I am having problems, and so are some others. And that's what this thread is about.
It certainly doesn't make anyone feel less frustrated to hear that they simply have "unrealistic expectations." I know that cars break down, but it's still frustrating, especially with a new car.
I think that people on these boards identify strongly with their cars, and sometimes take the complaints of others a bit too personally.
If you're not having problems, you have nothing to worry about.
this used to happen in my Old's intrigue and I always had to carry lots of extra washer fluid because sometimes I just had to pull over and manually put some fluid on the windsheild.
thanks for the suggestion
Use the nozzles one or twice a week and that will keep fresher fluid near the end with alcohol in it...
Recently had the same problem as winbro desribed but just from one (driver side) nozzle. It happened twice while I was driving. When car wass parked for about 20 minites, the washer began working again. Then it frozen/clogged? again just after 5 min of driving. Kind of weird. Never had that kind of problem with '90 Accord.
One question to the board - I understand that this car has very tight suspension, but is it normal to feel every bump on a road? Again, with '90 Acoord I've never experienced this. Shoild I just get used to this, or there could be some problems?
You speak of anony's post as not offering any value to those with problems that need addressing. Perhaps not, given a purpose limited as such. But neither do posts like "#6621 of 6645 gimme back my yugo..." Reciting a laundry list of problems and expressing disgust, I would argue, does nothing to offer value to anyone.
I would also argue that this forum has a purpose other than to simply get problems solved. Namely, it is a source of information for individuals considering the purchase of a car, so that they might research their prospective purchases by visiting these forums. In that regard, both anony's post and the second half of my previous post are highly relevant, as they give a more complete picture (not a nuanced portrait) to prospective buyers.
And just for the record, prior to my '03 Accord, my dealer botched the fix of a minor paint chip on the door of my three-day-old Civic (it was delivered to me with the chip) so badly that the entire side of the car needed to be repainted and I ended up with a different car, but only after headaches and back-and-forth with the dealer. In the 9 months that I owned my '02 EX-V6, it was into the dealer for warped rotors; faulty wiring causing rough running, hesitation and a CEL under acceleration; faulty fuel system part (can't remember which exactly) causing gasoline vapors to enter the cabin any time the climate control system was on; and an idle controller issue which caused excessively high (3000+RPM) and inconsistent idle combined with a CEL which indicated the car shouldn't be driven, resulting in a 70-mile tow to my dealer to have it fixed.
Suffice it to say, I am very familiar with how frustrating car problems and dealer issues can be. But I also know that nothing is perfect and I don't expect it to be. I don't think I exaggerate when I say that it seems some are under the impression that every Honda is going to be flawless.
For those who don't have problems with their newly purchased Honda I can only say I wish we could trade places!
Bought a '99 Accord 2 years ago, mostly as a reliable car for my wife. I'm pretty good with do-it-yourself maintenance, so I tend to stay away from dealers as much as possible. The last couple of years though I've slacked a bit due to lack of time (I know, I can hear the violins). Anyway, right from the start there seemed to be an excessive amount of brake dust on the front driver's side wheel. Even after a brake change it came back soon after. Any suggestions? I saw an earlier post regarding possible torn CV joint boots, with a suggested cost of $200. How difficult a do-it-yourself job would replacing these be?
Thanks in advance.
It was interesting to learn about the problems pj32 mentioned in his post though. I'm sure a prospective buyer would be interested as well.
Don't see how brake pad dust would cause any problems so I do not see any reason to "remove" the dust. Where can it collect and if it does what will it harm. In many years of driving all kind of cars-never had a problem with brake "dust".
Think this is a way to lighten consumers wallet. Probably not as bad as the "turn your rotors" every pad change but not a good thing. So remove brake dust as a concern IMHO.
PS
I have about 21,500 miles with mine. The only problem I had was a bad cat after using bad gas. Honda installed a new one under warrantee. No hassle with my dealer about the new cat.
One other question for everyone, 3 months ago I travelled across the country with the aforementioned accord, but forgot to check the motor oil before leaving. 500 miles into the trip I realized my obvious oversight, checked the level and found it 3 quarts low!
Naturally I thought I had ruined the engine, but filled her up and found I was burning about 1 quart every 300 miles during the remainder of the trip. When I got to my destination, I got an oil/filter change, and, the point to the story, my Accord seems to have forgiven me?! I am no longer burning oil. Only thing I can guess is something had plugged the valve seat during my trip and then worked its way out after the change. Any thoughts?
And saying that I don't understand frustration with having a problematic vehicle is a bit presumptuous and untrue. While our problem child was not a Honda (the 8 new Hondas we have owned have all been exceptional) we did have a vehicle that spent the first 2 weeks of ownership in the shop and when it was traded less than 1 year and 7,000 miles later it was starting to exhibit some of the same problems again. It was a headache. However instead of spending countless nights bashing the car and the manufacturer we traded it for something that was more to our liking. Maybe many of you who are convinced Honda is the Yugo of the new millenium should do the same.
There are a lot of complaints about Accords after 03 for "most of them" to be good. The additional quality problems need to be addressed.
And my original point was that this is the Problems/Solutions thread. The place for people to discuss problems they have with their cars.
Maybe we should have another thread called "Love It, Hate It, Or Somewhere In Between?"
I never knew rubber could rattle, but someone at Honda figured out how to do it. For what it's worth, I have driven 2 other Accords (one '03 LX and one '04 LX) as loaners from the service department and both of them had this same annoying rattle. Ask your dealer to lube the door and window seals--this should quiet the noise (for a short while).
When I was looking through these boards when car shopping about a month ago, one of the first sections I would go to was the problems&solutions section. All cars have their problems, and from everything that I can tell, the Accord has far fewer than anything else in its class.
I have had a squeak and a warped rotor issue, but am completely satisfied with my car in every way.
I make these statements in here from time to time so that people shopping don't get turned off what I feel is a fantastic car.
If you don't like these statements it's only because you aren't having our (majority) experience. We add these posts not for YOU, but for the people who are contemplating purchase.
You can say that the Accord is the worst car in the world, but the truth is you got a bad one and it is the worst car you've ever owned. All accords are not this way, and I can prove it because MINE isn't.
I'll really be a happy camper when they figure out why the TCS and ABS lights stay lit on my dash!
Can most people afford to spend day after day, week after week, in the dealers service bay being frustrated, angry, and resentful over their luck in car purchases? I've noticed that most of those same people will end up trading their car after they have gone through all the trouble of trying to get things fixed long after it was obvious that things were not going to get better. Everyday they get into a vehicle that they have grown to hate because of the problems they face with the car. Everytime it makes a particular squeak or rattle or pop they are reminded of their dislike of the car. Way too much stress and anxiety for me to deal with on a daily basis.
Anony was mearely suggesting that if you have gotten to that point of frustration with your Accord maybe you could save yourself alot of heartache if you bite the bullet on the depreciation and get into a car that serves you better sooner than later. Trade now or trade later after more depreciation and payments have occurred. No brainer for me.
I've had bad luck on my past 2 vehicles. Nissan Pathfinder and Toyota Tacoma. With the Pathfinder I made the mistake of worrying and fighting the defects for 3 years before finally giving it up. With the Tacoma I learned my lesson and dumped the lemon much much sooner and was much happier about it.
You have the same database as my update. You can go to http://www.hondanavi.com for more info in updates.
If you find any errors in the database, you can report them to http://www.navtech.com/ and hopefully, they will be in the next update.
When I ordered my Accord with Navi last year, my wife felt it was a wast of money and just a geek toy. Now she wants one for her car. :-)
Moral of the story is it ain't worth the aggravation. Get rid of the lemon and find something else. Just like the BMW folks kept telling me after I ranted and raved for a few years!
Looking for dealership/corporate sympathy? Don't count on it. If they smell a lemon they give you the cold shoulder and make you seek legal council. It's their way of minimizing accountability.
It looks like the car had a loose oil plug.
A mistake I will not soon repeat.
I must admit, I didn't ask the dealership (a family member works there so I trusted them) who changed the oil when I arrived if there was an obvious problem like a loose plug, so that could have been it.
Still, I hadn't noticed any leaking at stops, etc.
Yep, all the settings that you mentioned were set to full brightness. I just remember that when I first bought the car and cranked it up - the startup screen was increadibley bright and vivid. Now, it's very dim at first, but I can leave it on for a few minutes, and it gets brighter. I'm just concerned that this may signal a trend that Nav displays dim as they get older. Maybe another 22k miles on the car will answer my question for me.
Thanks for the suggestion.
As for your comparison with Camrys, I had a 1994 and found it very reliable. To be fair, though, it should be noted that many new Camry models had reductions in overall quality in their first year out.
I hope that your dealer/technician can help with the weatherstripping and brakes.
The grinding has returned, so I plan to ask my dealer to install the new type of pad. I hope/assume that will take care of the problem.
I don't think that there is a safety problem, but the problem with the pad composition seems to eventually affect the rotors.
You might want to check with your dealer about getting the new pads. Even if the dealer isn't willing to cover the cost, it's probably worth the expense.
People who say this generation of Accord is unreliable should consider that so far there have been at least 400,000 sold. The posts we see on Edmunds are a very, very small sample of Accord owners. And it's been shown that if someone is unhappy they will tell 10 people vs. 1 person if they are completely satisfied. Excuse me for thinking someone just popping in while shopping for an Accord should realize that not every Accord is bad.
According to that TSB here are the numbers of how many accords are affected:
VEHICLES AFFECTED
2003 Accord L4
2-door:
From VIN 1HGCM7...3A000001 thru
1HGCM7...3A020335
4-door:
From VIN 1HGCM5...3A000001 thru
1HGCM5...3A068936
2003 Accord V6
2-door:
From VIN 1HGCM8...3A000001 thru
1HGCM8...3A022702
4-door:
From VIN 1HGCM6...3A000001 thru
1HGCM6...3A050879
CORRECTIVE ACTION
Add two welds so the body panels do not rub against each other.
You do the Math.
Those are the numbers for cars sold in The States only. There are no numbers (VIN) for those shipped to Canada or elsewhere. If you hear strange noise in a year or two down the road you will know that this forum served its purpose.
As I can understand the main purpose is safety issue then everything else including being played around by greedy dealers, incompetent mechanics or Honda Customer Service people. We have to protect ourselves first and force Honda to make an extra effort to meet the needs of their loyal customers, continue to make good cars as it has been the case all along and therefore preserve the value of our investment.
If I get caught by police for driving over the speed limit (I often do and that's why I drive Honda, unfortunately cant afford Ferrari) I pay fine. I dont say sorry I wasn't aware how fast I was going. If Honda is selling product with hidden defect that is against the law and they have to pay for it. Excuse and sorry cant buy me time and peace of mind. Very first time I complained about that noise I pointed out that TSB I was talking about. It took them three months, power steering pump, some kind of pressure hose, broken panel underneath the steering wheel, to finally come to conclusion that it might be that thing from TSB.
a couple of minor issues that I've noticed that
I wanted to see if others have had.
1 At night, when I turn on the headlights the
clock isn't backlit. I'm assuming it should be ?
2. When I push the master on/off for the cruise,
the light on the button doesn't come on. I've
driven with the cruise on and it still doesn't
come on. Probably just a bulb that burnt out ?
I've check the fuses and they're all ok. Anyone
else experience these issues ?
Thanks - Don
While the number of Edmunds forum contributors does not amount to an adequate sample size, still the subset of problems/complaints within the forum - and the seriousness of those problems - tells us that Honda has issues.
The brake problem, for one, is serious enough for Honda of America to call me repeatedly to go to the dealer. The warranty work has cost me 8 hours of personal productivity so far. The post-assembly welding job that others have experienced is something you don't want done in a new car. Why ? The process involves breaking rust-preventive coatings. The welds will be a rust starting point down the road.
This post's bottom line: if you're a new Honda shopper, you're best aware that there's a higher chance than before that your Accord will have problems.
Still no popping noise yet.
Had to crank twice this morning .
It's understandable. The car had been sitting for a week with temp
outside below freezing all week.
http://ca.msnusers.com/Tesliana/hondaunderneath.msnw?albuml
It is hard to see those lines where they are going to do the welding but I will leave it to the Service to find their way around.
You may have to click couple of times or more before photos show up.
The Honda technicians have also verified that it's a problem with the pads, not with rust, and that it isn't normal.
The brake problems aren't rust. Nice try.
I've said it before, but take the percent of people who don't use computers, and then out of those who do the number who stumble onto these town hall discussions, then the percent of those who actually found Accord Problems discussion, then the percent who post out of all those who do have problems...
there are problems with 03 04.
Just to mention, the transmission started to leak at 8,000 miles which i was told was a faulty banjo fitting. The car has so far been a huge disappointment being in for repairs over the past 11 months for 11 days. I was hopingto keep this car for a while but as soon as evreything is fixed...something else breaks or falls apart. The only saving grace is that the service department has been very good at diagnosing and fixing the problems.
