Visitor Agreement.
How did they do it? Mine was welded but not cured. The vehicle is in the service now and they are taking it apart as we speak. It was supposed to be test driven and fixed in a day!
I am glad to hear that you are happy Honda owner again.
If feels like heating from the lower leg isn't warm enough, it almost feels like NO HEAT is coming out.
Does anyone have this problem??
Let me know.
James,
I thought my 03 had that heating problem until I noticed my 89 did the same thing.
When the temp goes up above 20F, then I can feel the hot air.
Why not?
jelly
Again, not a big issue, just a nitpick (for those of you who get your dander up when someone points out a dislike...)
Don't close the vents beside the windows as you will get the side windows fogging/icing up alot quicker.
Try the settings for defoger&legs or only legs to get more air to your legs. This works really well for me.
The heat in my 04' Ex V6 is amazing. -30 C outside with a windchill of -45 and I'm just scorching in the car. I have to reduce the heat or my hands feel like they are burning.
I've also got heated seats and it gets REALY warm as well.
However, I prefer it being underheated to being overheated (makes me sleepy).
The heat is great everywhere else, including the seat heaters.
Car pulling to the left and right sides issue:
Try and see if dealer can fix. If all is testing OK, then it's those darned low resistance rolling tires. I've changed mine to winter tires and ALL the pulling has gone away.
Cheers
About the tires causing the pulling/drifitng issues. Are you referring to the stock tires on the 03-04 accords also, I think they are michelins on all sedans. So this drifting can be attributed to low resistance tires?
What are low resistance tires anyways?
Just as I would come to a stop, the tires would pull even harder to the side, depending on the slope in the road. Even when I was stopped slowly. I knew of this issue when buying the model but it was not enough to turn me away. I knew the car was just too good otherwise. I also knew that I could change the tires and it probably would go away...and it did.
I have the Michelin Actic Alpins on them now.
Cheers..
It's tires that are designed to give you high mileage. They roll a lot easier..with less resistance.. and hence better milage.
Cheers..
Something is wrong-maybe just a valve out of adjustment-would not drive it much till you can have someone who knows these engines to listen to the ping. Let us know what you find.
kind of also has a rotten egg type of smell...
not nice at all...
Other places say that premium is waste if manual calls for regular.
Manual does say minimum 87, not required, i dont know anymore!
Any thoughts?
The v6 has a dual-stage knock sensor and can adjust timing and utilize higer octane to produce a tiny bit more hp.
The 4-cyl gains nothing.
I fill up full tank, then it only runs about 300 miles to empty tank.
Does anyone feel the same ?
What do you think about the MPGs?
when you say it went 300 miles till an empty tank, i assume you didn't actually run out of gas right? thus yo shouldn't asssume you're not getting 24/34 gas mileage.
am i nuts?
If you have that consider your driving conditions and style. Calculate your real mileage based on how much you fill up and actual miles driven between fillups.
I drive my car rather infrequently and 30% City/70% highway. I go about 360 miles on a tank before the gas light comes on. That has always averaged about 29.5 mpg. I wish I was getting 34 also.
What are you actually getting?
5000k is 5,000,000 or 5 million miles. Thats a lot of miles!
But those Hondas are up to it. Check CR ratings!!!
I think the battery, tires, breaks and muffler are NOT covered by the extended warrantee.
I did not get one but you should think what is best for you. When was the last time you spent $900 on auto repairs between 36k & 72k miles (in your case 60k miles) that was not one of the above repairs?
1) The original factory warranty covers the car as best as possible, except that it doesn't provide a free loaner during overnight warranty service.
2) An extended warranty upfront therefore unncessarily duplicates the factory warranty until the 3/36 point for the Accord, with the exception of the free loaner.
3) Major consideration: if the extended warranty is non-Honda provided (meaning one of those 3rd party all-brands warrantors) and the provider shuts down before the term is up, a pro-rated refund is obviously in doubt (oxymoron ?).
4) If for some reason the car needs to be sold earlier than planned, the used car market gives little consideration to an extended warranty.
5) Even if 4) is not the case, one can buy an extended warranty shortly before the original runs out, at about 35 months / 35k miles. The price of the extended warranty may even be lower then !
My advice: unless the free loaner is vitally important (probably not since the Accord isn't prone to warranty work), bank/invest the money, buy the E.W. before the original factory warranty ends, and come out ahead.
I bet it will be low. If it is, fill it to the neck and fill the reservoir to between Hi and Low.
I can't believe they would try to charge for fixing what shouldn't have gone wrong on a brand new car, no matter what brand it is... they get paid by the company for the service under warranty.
Check the paper work you hopefully got from the dealer-can't believe a honda service guy would not give you the code. Have always had good luck with honda service people-can't say the same about the sales side though except for the small town dealers.
Should I consider another Honda/Accord? (I was thinking of a Toyota Highlander.) But, my 01 v6 accord (top of the line) isn't worth too much and interest rates are lower than when I purchased. New car = new warantee; I thought I knew what I was buying the last time.
I looked at restyled 03 Accord when they came in and it was much nicer than my 01, so I'm sure the 04 is even nicer. But is it better?
They gotta be kidding me!!
Find yourself another Honda service.
