Visitor Agreement.
Once the engine starts, release the gas pedal slowly.
Does the reminder light stay on until it is reset by the dealer or does it turn off after a certain number of miles? I just don't want to have pay for things like lubricating hinges that I can do myself.
I looked in the owner's manual and could not find it.
Any ideas. I consistantly read 8-10 degrees high in all weather and driving conditions.
Thanks in advance!
I think it was under temperature in the index of the 04 accord.. but it only allows a calibration of +\- 5 F, sounds like u may have a problems with the sensor, make sure nothing is blocking it, its behind the front bumper.
does it occur at different speeds? (i think the manual says u ahve to be above 20 mph for it to start adjusting, and then who knows how long after for it to get to correct temp
good luck!
I also saw another post that they had noticed that in teens or below temps it would be off also...
I couldn't find anything in my owner's manual about it. Is it a feature of the V6 only? I have an I4.
What other possibilities could it be?
thanks again for your help!!
Mine failed recently at 112K miles despite ATF-Z1 fluid changes every 15-20K. Cottman confirmed this issue and Honda dealers had been aware of this for years. Honda didn't recall these models, they extended the warranties for 00/01 model years only.
Many Accord sites, including this one, are full of reports of these failures. Use the search function.
Here's mine according2me Jan 17, 2004 1:17pm
I got to my high-mileage faster than most and I suspect that as others roll up the miles thousands more will be affected.
BTW, I'm a 27 year Honda customer. My first new Accord was a '77 hatchback and I've been an avid Honda spokesman about their products in the past. Unfortunately it seems the bean-counters now rule the roost.
I have just a short warranty period left. I want my dealer to fix this. The other message said that the dealer re-centered the steering wheel cover by remounting the air bag assembly--apparently it wasn't mounted properly.
Have any of you had this problem? Is it just cosmetic or is it indicative of a problem, i.e. with the air bag, or has the air bag been deployed even though the car had a clean, no accidents reported CARFAX? (Which I know is not foolproof!)
I appreciate any feedback. Thank you.
i can check my manual and let u know the page numbers, if i remember correctly i think u just hold down the trip button while the car is on and it cycles from -5 to +5 and u release it when the adjustment u want is there, but im not completely sure, ill check up on it for u
This is my first Honda. Do all Honda dealers try to push this 30k service package? They wanted to charge me $380.00. Should I be looking for another Honda dealer for my service? I also have a Nissan and have never had this problem with their Dealerships, trying to sell me things I didn't need.
I have a 98 4cyl. I can't see Honda going backwards and requiring a valve adjust. The engine does seem noisy sometimes when I first start up but it quiets after a few minutes.
Thanks for looking it up.
Receipt says the following:
"Client states check engine light is on. Tech scanned for engine light being on. Had Code P0715 Input shaft speed shaft circuit. Performed tests and there is internal problems with ECM (computer). Ordered new computer."
I'm under an extended warranty and this looks to be completely covered. I didn't have a chance to really talk with anyone about this...what is this (input shaft speed circuit)? Where is this? Why would the ECM go bad?
Just curious...I'm not doing the job because of the warranty, but wanted to take the opportunity to learn a bit. Thanks for sharing knowledge!
PS: In 6.5 years of ownership, this is the first time I'm tapping that HondaCare extended warranty (which cost just about the same as this ECM ~ $800).
As I noted earlier, the dealer that repaired mine has been seeing these bearing failures for years with this generation and had contacted Honda support years ago to inquire about what they had been experiencing in the field.
It's even addressed in the May 2001 Honda Service News bulletin (page 1) that the dealers receive from Honda.
And there is a growing number of 98/99 owners experiencing problems at the 60K-80K mileage mark even though their vehicles were maintained at their dealers.
I visit a multitude of Accord sites and the trend is unmistakable. I thought I could deter the problem with frequent transmission fluid changes. I only succeeded in delaying the failure until 112K in my 3 year old Accord.
Some may think at that mileage, that I had gotten a useful life from the drivetrain, but my expectations were at least 200K miles for this drivetrain before major failure. Especially with my frequent tranny maintenance and "easy" cruising interstate miles.
Other than this problem area, I continue to enjoy my vehicle. But, I wouldn't consider purchasing a used 6th Gen Accord unless I could verify that a reman auto tranny had already been installed or if it was a manual 5spd. JMO.
It is an irony perhaps, but as we get more and more technology to manage information, we grow less and less able to identify exact causes of failure. It just isn't worth the trouble. So, in a very literal way, "The hurrider I goes, the behinder I gets!" ;-)
If we have a Honda ECM computer engineer monitoring these boards, then you might get an answer to your "what is this (input shaft speed circuit)?" question. If not, I'm sure that many of us can give our own WAGs, but they will be worth exactly what you pay for them.
Even so, stay curious.
The speed reading circuit on the ECM failed. Instead of debugging the circuit, it's cheaper and more convienence just to replace the whole ECM.
Circuit board failure is something not unusual.
Bad electrical components (diodes, resistors, etc.), ESD, or bad soldering could be the reason.
Okay, let me phrase this in my other car's experience...we also have a VW Passat wagon. One of the control units is under the passenger seat. This model (not my particular car) has a tendency to develop a clog in one of the drain holes, allowing the carpeting to get wet under the passenger seat. This, of course, puts that control unit in harms way...
So I was looking for a systemic issue, not why this particular ECM went belly up. I wanted to see if I was in danger of frying the replacement.
To recalibrate outside temp +/-3 F here how
with key on temp display press and hold more then 8 second
you will see calibrate # come up.
I saw someone post +/-5 F which is wrong I own
2003 accord ex with navi only shown +/-3 F.
if you had 10 degree off +/- 3 will not help much
but atleast help a bit don't you think?
No problems with the stuts or steering components at all. So instead of $950 for front end rebuild and struts, it was $12.50 for a lube job.
Thanks to this message board! and auburn63 for the help.
I don't believe there is any chip out worth $500 and that it probably doesn't cost that much.
Does anyone have any ideas of what the problem might be? and how to fix it?
thanks a lot!
Chris
In my manual did not say +/-5 F where did you find this information? when I calibrate it on my car it show 3,2,1,0,-1,-2,-3 when I press and hold reset button. mine show 67 degree when I set to -3 it adjust to 61 degree just right on it. Back to 10 degree higher by set to -3 should be around 63 degree don't you think ? also it has to be some kind of tolerance on temp sensor to confirm if sensor is bad by change setting -3 to +3 temp should be change if not at all then sensor is bad.Like you said 03 and 04 may be diffrent.
Would be a good idea to look at the drive belts and see if you see any cracks in the outside of the belt when it goes around a pulley and any wear marks. If any belt starts squalling-check the adjustment immediately. Take care with how tight you tighten alternator drive belts-too tight and the bearings go-alternators are really pricey on honda's.
In Florida it is a secondary violation, meaning a cop can not pull you over for not wearing your seatbelt, he can only add the violation after stopping you for another reason, speeding, stop sign, etc...
Funny thing in Florida, its the law that you have to wear a seatbelt, but you don't have to wear a helmet if you are on a motorcycle. I guess if you ride on top of your car its O.K.
So the answer is... there is no way to turn off the warning?
anyways with 10 degrees off there is probably something wrong with the sensor.
my 03 Owner's Manual on page 64 did not say anything about +/- 3 or 5 not sure why it doesn't list in the manual good luck for you with 04 Manual.Thank you for your response
"If you are an emergency worker like a cop, fire fighter, paramedic, and you must exit your vehicle all the time rapidly. Being a cop to and from work in uniform I am expected to assist people if something occurs."
THAT is the sorriest excuse that I have ever heard for not wearing a seat belt. As an ex-state trooper, I can assure you that I never had to get out of my vehicle that fast. As to the holster, I've carried weapons in uniform and civilian clothes and have always been able to adjust one way or the other to fasten the seatbelt. Again, sorry, but it is REALLY hard to fathom that anyone would drive with buckling up, let alone a police officer(if you in fact are one).
You probably need a balance job-find a tire dealer who is not a crook and have them check it out. driving with tires out of balance is not a good thing-decreases tire wear and some say it is not good for the front end.
