Visitor Agreement.
In my former life, I've seen seven or eight years but never 12.
My feeling is this...anything more than four years is pushing it. Right now, my 1999 Accord still has it's original battery. It has never given me any signs of impending failure.
Still, it's pushing five years and I'm on borrowed time. I'll probably change it within the next few months or sooner if it starts showing sign of trouble.
The reason being, I don't like pushing my luck. I would MUCH rather replace it on my terms on a nice sunny day then have it simply not start on some dark rainy night when my wife has it.
Batteries aren't that expensive anyway.
Two weeks ago, they had to replace a cylinder head and valves (the car would drone loudly when it got to 65mph). Hope that makes sense. I'm glad it's all covered by warranty, but the aggravation of having it constantly in the shop is driving me crazy.
Anyone else seen these problems? Is the 03 Accord a piece of crap? I got this car for its reliability, but now I have to look at getting rid of it after the extended warranty is up. Arrrghhhh!!!
Even if you give up on your Accord, then what?
Hopefully your troubles are behind you now.
Just wish my car was as dependable as I had hoped. I guess that's why warranties are in existence! I'm not exactly giving up on Accords just yet. I think the package for the price fit me well. I just wish I could have some confidence for the next few years in the car...
I called the service department and they told me not to worry about it. My saleman called to check up on the new Honda, and when I told him about it, he told me to bring it to the New Car department so they can put the battery on a charger. Huh?
So does anyone know what 'Distill Water' means? It also says 'Maintenece Free' on the battery. I thought that meant I didn't have to worry about such things as adding water...
Jerry
"Exterior rearview mirrors - As for the side view mirror or mirrors, most people adjust them so they can see the side of the car on the inside edge of the mirror. If you adjust your mirrors using that criteria, are you aware of the huge blind spots that you've created? (Now is the time to take another look at the animated diagram at the top of the page.) Consider the view when the side view mirrors are set up as just described. Essentially, you have created "tunnel vision" to the rear. Your side view mirrors overlap much of what your inside rearview mirrors sees and you've also created blind spots. What in the solution to tunnel vision and blind spots? Simply adjust the side view mirrors just beyond the point where you could see the side of the car on the inside edge of the mirror. With this setup, you almost completely solve the blind spot problem. It takes a little while to get used to, but it is an improvement. Some quick tips: For the driver's side mirror: Place the side of your head against the window, then adjust the mirror until the side of your vehicle comes into view. For the passenger's side mirror: While sitting in the driver's seat, lean to the right so that your head is in the car's centerline. Adjust the mirror until the side of your vehicle comes into view."
http://www.smartmotorist.com/mir/mir.htm
This is just one link that contains this suggestion... I've seen it recommended many times from many different sources. I believe I first became aware of it on Motorweek.
You're right about backing up, and unfortunately there's really no good solution for that problem.
htt,
gregoryc1,
whitecloud1,
Thanks for the info.
Ended up just getting a new battery last night at sears. It seems to have solved the problem.
snarks,
fjm1,
Thanks for the info. I will keep it in mind for future battery problems. I think due to the battery leaking(white crud over the negative terminal) that the battery was basically done.
Talon, ---I will try to set the mirrors using your system, and I will let you know the results. The problem that I am experiencing is that if another vehicle is passing me on the highway on my left, and they are doing so in a "fast pace", I do not loose them in the mirror. By the time they disappear from the mirror, I pick them up in my "side vision". But, when they pass me "slowly", (and tend to "hang" on my left quarter), there is a point when they disappear from the mirror, and I have not picked them up with my "side vision". If I move slightly forward and at the same time looking into the outside mirror I can over come this problem, but in an emergency situation, "time" becomes VERY IMPORTANT!
Hope it helps.
How I do it:
1) While parked, I look at rear view mirror ("RVM") and note what images I see on either end of the mirror. Ex: On the RVM's right half, I see the rear end of my neighbor's MPV, with the tail light cut off by my RVM's right edge.
2) I then move the right outside mirror until it catches the MPV's tail light that was cut off by the RVM.
3) Repeat for left side.
There's a learning curve, but after a few days, you'll learn the relative position of the vehicles on the left and right outside mirrors (they'd be actually quite a distance away).
Now, change lane with confidence.
I bought Honda Accord '03 10 months ago. Now as it ahs passed 10,000 miles the Maint'Reqd Light is on, I asked the dealership and they said that every car will have this every 10,000 miles and I have to take it to dealership and pay them $100 and they''ll change the oil and do all other maintenance..i think they are jsut riping off. any ideas how that light goes off....
Aman
To turn off the light yourself, turn the ignition to the ON position, then hold the trip odometer reset button down until the maintenance light goes out (takes about 10 seconds).
Back light in Digital clock went out couple of weeks ago. I checked the messages in here and replaced the light bulb. It did not fixed the problem. Now, I replaced the whole clock that I bought it from the dealer, and the back light still does not come up.
Clock is working fine except the back light.
I checked any possible fuses also and they are fine. If the fuse is blown, clock itself should not work I think.
I do not know what to do next. Please help.
steve1... I still over my shoulder for both directions anyway. This little mirror trick improves the coverage of blind spots tremendously over the traditional mirror settings, but it can't eliminate blind spots completely.
When the oil is changed, the dealer should reset the light (whether it was illuminated at start-up for a few seconds or on continuously).
For those of you that have the outdoor temperature sensor that reads high or low, you can adjust the temperature read-out up or down by up to 3 degrees by following the same instructions. Hold the odometer reset button down and then turn the ignition switch to the "On" position. After about 10 to 15 seconds, the outside temperature display will start stepping in one degree increments (something like 1, 2, 3, -3, -2, -1). Release the odometer reset button when the correction desired is achieved. If the temp correction of plus or minus 3 degrees is not enough of a correction, I heard you can do this more than once, although I've not tried it.
I read through the forums and did not find any popping sound description similar to mine. Can someone tell me what kind of problem my car might have ?
Intending to save you money by starting with the least aggressive approach, the solvent could loosen a stuck piston ring and/or clean out dirty valve seats which are probably causing the low compression.
Knocking is a sign of carbon deposit build up which the solvent could blast out too.
A top cylinder lubricant (Greg, feel free to elaborate :-) could, finally, be helpful here.
The solvent and top-cylinder lube treatment must be applied long enough (one week ?) to take effect.
If this first-stage treatment fails, open-heart may be unavoidable.
Good luck!
And, there is another additive that actually works..I wouldn't have believed it but it does.
Buy a bottle of Rislone concentrate and add it to your oil. Take the car out and literally drive the hell out of it. Drive it in lower gears at high RPMS. You don't have to speed, just don't be shy at all and keep the RPMS up for 20 minutes or so.
The old timers used to decarbon engines with a bottle of water. Scary to watch but it gets the job done big time. Don't do this, you could blow a piston!
Is Risone a concentrate too? I buy the quart size that is really a 5 weight oil with lots of additives. I occasionally put half a quart in with new oil or put in quart when oil is down just before time to change oil. I let it help for couple hundred miles and then flush.
Lately I've felt that the additives in oil have improved so much that I might just change oil again after 1000 miles...
i am kind of scared to drive it lest i break something expensive....
I have a 2002 Accord V6
"A term you will here when talking about timing chains and belts is "interference engine". When an engine is an "interference engine" the pistons and valves are so close together that if the valves were to stop moving (broken belt or chain) and the crankshaft kept spinning they would crash into the piston. (that's the interference) This crash tends to do bad things to an engine, breaking valve, bending pushrods, and even cracking pistons. This is why most manufacturers recommend changing the timing chain or belt every 60,000 miles. Timing belts dry out, stretch and deteriorate over time so even if you do not have 60,000 miles on the car think about changing the belt after it's 6 years old."
http://www.autoeducation.com/autoshop101/engine.htm
Also is it hard to put back together??
