Visitor Agreement.
The nearest Honda dealer is almost 200 miles away, so it is a real inconvenience to have them do the work.
A fellow stereo nut! A couple of questions for you...
-Is this problem new? ie. you have had the same set up for 6 months.
-What gauge wire are you running to your cap/amp?
-How many watts/amps total power is your amplifier drawing or rated @?
-Are you using an oversized, deep cycle, or stock battery?
The reason I ask is that your voltage to your cap/amp will vary greatly due to these factors. You may have the warning signs of a soon to be dead battery or alternator. I had a similar problem that left me stranded
Next issue: [please keep in mind this is under 2000 miles]. At about a 70/30 [city/highway]split, we're getting 19 mpg (this is a stick 4 cyl EX-L). It does run and shift smoothly. Thoughts?
Originally, the brake pedal on my 2004 Accord began sinking to the floor and I was losing stopping power. At that time I wasn't sure if it was all in my head. During the test drive, the Honda tech thought I was insane to be driving on it and scolded me for not bringing it in sooner.
The fix was to bleed the brake lines (twice). I had never opened the brake lines and no leaks were found in the system. When I asked how air got into a closed system, the service guy looked at me like, "why are you asking questions?" *grin*
About a week later, I swear the pedal was sinking again. After about ten days I was sure. I took it in again. The same tech worked on it. He replaced the "ABS/TCS/VSA modulator or modulator/control unit" and bled the brake system again. I haven't bought any service manuals for this car yet, so I don't even understand the premise of how the ABS system works... so I don't know what that thing is that they replaced or how it was leaking air into the brake lines.
I do know that the replacement part costs about $724, labor was $155, and that the total job rang up to about $950... so I'm sure glad it was under warranty.
I've been driving the car for a week now (about 1000 miles... which is typical). No sinking... yet.
And, there are people, believe it or not, who don't know how to drive a stick even though they have for years. I ride with these people sometimes. They will slllllippp the blazes out of the clutch when starting out or between gears or they will shift way to soon and then comment the car has no power.
In your case, it sounds like there is a problem. This doesn't make your car a lemon either.
The clutch is smooth when you press it. The RELEASE (after shifting to 2nd gear) is the problem (at least in my case) -- too difficult/unintuitive to make a smooth acceleration all the time. I have seen posts for other cars that describe a similar problem. Despite the adjustments or workaround to avoid the stutter or hesitation or, the clutch is still a little too sensitive when released after shifting to the 2nd gear. I don't know how smooth others drive, but I know what I want -- a smooth clutch operation and acceleration -- no unnecessary clutch sensation or forward thrust/momentum when the clutch is released.
Your point of view is clear -- that because a problem is not "typical" of Honda that you point to the driver as the cause of the problem.
"And, there are people, believe it or not, who don't know how to drive a stick even though they have for years."
The implication is obvious. FYI, I'm not one of those who "slllllippp the blazes out of the clutch when starting out or between gears or they will shift way to soon."
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Please help!!!
You didnt mention if the 89 is a DX or LX- if so, maybe the carburetor is acting up. My 87 DX has a carburetor and its been a pain to fix- I decided to finally part with my beloved '87, and buy a new '05 Accord. Its tough to get carburetor problems fixed nowadays.
Frank
I've searched the boards here and some posts have helped and I'm assuming it could be a transmission problem. I've already had to replace the tranny once early on when I bought the car due to hard shifting on hills and from Park to 1st and I really don't want to be forced to replace the tranny again. If anyone has any advice or knows whether or not this is normal please help! I'll be trying to drive another car like mine to see if it does the samething hopefully sometime soon, I'm about 4000 miles away from warranty expiration.
noises. Am going to dealer. Any thoughts on cause?
engine ???. Any suggestions would be appreciated.
" In your case, it sounds like there is a problem"
I guess I should have said..." With the car, that is, and not your driving style".
There was no implication as you stated.
I guess I missed the part where you said it was when you RELEASED the clutch.
Shouldn't be hard for your dealer to fix.
The replacement transmission has the same tendency, though not quite as piercing. So, I have a replacement transmission along with the original problem. Very disappointing. I feel like I went backwards instead of forward. The car is good enough overall that I seem to have talked myself into "settling" for the situation, though that's not what I had hoped for from a new Honda (my first).
BTW -- There's a Honda article about this problem on their internal Web system -- titled "AT Whine." AT being automatic transmission.
We own a 2002 Accord SE with the 4cyl. We have approx 50,000km so a fair bit of warranty left. I was wondering if anyone has experienced the following on their '02 Accords:
1)Hesitation upon acceleration from a stop
2)A thump upon starting the vehicle, starter thump?
3)Moderatly hard starts (i.e. cranks for approx 3-5 seconds, occasionaly even longer) in the morning?
Any help would be great. I am taking it in next tuesday for a checkup!
Jas
My car is in the shop right now for a strange noise + smell coming from the engine. I think it's a drive belt (not timing belt) but not sure.
My question is with the timing belt. I've heard recommendations from dealers to have it changed anywhere from 75K to 105K miles....depending on your driving conditions/environment. I'm in Southern CA and do alot of freeway driving which means stop and go traffic. I would think my conditions are considered 'severe'.
I have never had the timing belt changed (or any belts for that matter). Pretty much only had regular oil changes at 6000 mile intervals. No other 20k service, 50 or 90k service. Car runs like new!
Currently have 91000 miles.
I'm waiting for the dreaded diagnosis phone call from the dealer and wanted to post this quick message regarding timing belt change. Do you think it's necessary at 91000 miles? And is the water pump really necessary to change as the dealer recommends? (The whole job will cost me nearly $800!!)
Please advise. Thanks in advance!!
Gary
$800 is a bit stiff. Are there any other dealers?
If yes, I would get another estimate. It could be $100+ difference. Make sure they replace all the seals too.
And, yes change the water pump too. Save some labor cost.
Turns out, the noise/smell was caused from the bearings on the alternator going bad. So it's time for a new one. Tech said this is unusual. He typically sees this within 20K miles or not at all. Regardless, it's a $450 bill!!
I went ahead and authorized that repair AND the timing belt/water pump replacement. ($650 for this one.)
Well, since $1100 is not enough to spend in 1 day, I went ahead and threw in an oil change for another $25!! What the heck!! The tech said he'd talk to the manager and try to "work on a discount" for me. We'll see....
I guess it's cheaper than a new engine or new car for that matter.
this may be the wrong place to ask this -but I recently was in an accident (my brand new accord of 2 months ago )is now sitting in some auto body shop; being that this is my first accident, I cant seem to understand what the process is - who repairs it ? Does it have to be honda or can it be anyone, do I have a choice in this matter or do I have to accept my insurance company's decision?
Any tips would be hugely appreciated- as always, didnt know where to go to but Edmunds
Thanks .
Swapping out the $85 AutoZone alternator in my old truck took me about 15 minutes. I imagine it's not as easy in the cramped engine compartment of an Accord, but $450??!!
Have you noticed the rear window defogger works incredibly slow on this car? I swear it takes about 10 minutes to be able to see through the rear window. Has anyone else here had the same problem? My old Acura's defrost worked immediately...it's the only thing I miss about my old car.
Otherwise it could be a weak starter, low fuel pump pressure, questionable battery, etc...
A good dealer will find the problem; just be prepared to pay.
Now $95/hr. So I guess it's normal.
To replace the alternator in my 89 Accord, the service manual says the left driveshaft needs to be removed from the steering knuckle first.
