Visitor Agreement.
Is this really normal? Will this happen again after, say, 10K?
According to the manual, I should use Honda coolant, but I think it should be ok if I buy major-brand coolant and add it myself, right? Or I should go and buy Honda coolant since Honda manual says to repleace engine coolant at 120K or 10 years?
Did you check the level a month ago when the engine was hot? I bet you did.
Prestone brand will do. Make sure you mix it 50/50. I use distilled water for mixing.
I wouldn't wait 120K/10 yrs to replace coolant in my 03EXV6. Flushing coolant is cheap, replacing a corroded radiator is expensive.
Also, I wouldn't wait 105K to change the spark plugs either. Spark plugs are cheap. When the plug and the head become one, it's expensive to replace it.
I did check the level in the morning before I went out. However, I suspect that when I checked the level a month ago, I might check when the engine was hot (I'm not sure).
Anyway, I think I will go to my dealer today to make sure if anything is OK just for a peace of mind.
To diagnose a fuel delivery problem, the quickest way is to loosen up one of the connector bolts in the fuel line leading to the injectors. This is very dangereous and could cause a fire, so it should be done only by two people who both know what's going on. Basically, if there is no fuel squirting out of the fuel line connector after it is loosened up and the engine is being cranked, you might suspect a fuel pump relay or a fuel pump. Both of these are known to act up intermittently before failing completely. It is hard for even experienced techs to diagnose, because it seldom happens in a predictable sequence. Good luck. If you can tell your mechanic that you have spark, but no fuel pressure, he will have a much easier time with the troubleshooting.
Dealer called me 6PM Wednesday...car is ready. Said I could pick up on Thurs. Went to dealer Thursday 2:30PM. They brought my car up and as a habit, I take a quick check under the hood for loose items, tools, damage, etc. (this is from a prior experience). I noticed the radiator reservior was empty. I opened the rad. cap, I could see no water all the way down to the core. I also noticed a plastic piece on top of the engine (near the "H" VTEC symbols) was cracked in half. I summoned the service writer who said he'd send it back to the tech.
After about 20 minutes, the writer came and told me there was an 'air bubble' in the rad. fluid so the tech thought it was full. But supposedly when running the engine, the level went down. AND he stated the cooling fan sensor switch was intermittent and the thermostat was also intermittent. I needed to spend another $175 (on top of my $1100 for timing belt and alternator) to replace the parts. Needless to say, this really pissed me off. I could have driven off the lot and fried my engine on my 35 mile commute due to insufficient radiator fluid. He said I could take the car and risk a failure or have the job fixed. So I reluctantly approved the work. This took another 1 hour. (In the very beginning, I had asked to have the car washed and it wasn't washed yet!) Another 20 minute wait.
While waiting for the wash, I decided to express my frustrations to the Service Manager. After a quick explanation, the service writer was called in and the Manager made the $175 job a 'no charge' to the customer. And she apologized and said she'd speak to the technician (as it was his fault and not the service writer). (BTW, the cracked plastic piece was ordered at their expense and is an easy 'snap on' part)
In conclusion, it pays to speak to the authorities when you are not satisfied with your service. Since you pay more for dealer service than an independent shop, you should get more.
A side note, I'm not sure if anyone else in this group has experienced an alternator failure in the '98 Accord. But the service writer said it was unusual. He said it either fails at 20K or not at all. Oddly enough, while waiting for my car yesterday, another '98 Accord V6 came in with the exact same alternator problem!! Weird!
Hope this helps all fellow '98 Accord V6 owners.
(sorry for the loooong post)
Gary
Make sure you got the fan relay & the thermotstat replaced.
I think I can verify the fan relay change (It's somewhere on the bottom of the engine??) But how do I check the thermostat without removing the radiator hose?
Please advise.
-D
Please advise.
Please advise.
Sorry for posting here. I just want to share my experience here. Seems in the CRV forum I didn't find anybody who treated this as a problem.
I think I will try the Fuel Injector cleaning after the service department looks at on Tuesday. Its still under warranty so better late then never! I know there is a TSB out for the hesitation, along with the thump when starting. So hopefully they can finally find something!
This springy sensitive clutch, coupled with a rather so-so engine that behaves like it has a stuffy nose (I can feel some hesitation when trying to press harder on the gas to accelerate, particularly noticeable on lower gears (2nd and 3rd). In addition, the acceleration is not consistent. Sometimes I can feel the power as I accelerate from a stop; most of the time, the engine is already roaring and yet I don't feel a significant forward acceleration thrust or power, even on a fairly flat road. You press the gas further and you can feel that stuffy-nose-like hesitation/vibration (as this Accord struggles).
Unfortunately, I'm stuck with this Accord 03 LX MT. I'm hesitant to sell it because I don't want my buyer to be cursing me later. Trading it in, in my opinion, gives unearned dollars into the pockets of "smart" auto salesmen, who don't offer you a fair price for your car.
ramida
--a very disappointed first-time Honda owner
I had added a bottle of lubeguard conditioner(suggested by auto.consumerguide.com) and changed(flushed) with new Honda transmission fluid several times, but this problem is still on when I start the engine in the morning and it goes off when the engine(transmission fluid) runs hot. It is on and off situation now.
Please advise.
So far, there has been no recall of ATs on 4 cylinder Accords which for whatever reasons don't have that problem. If there were such a problem it's a sure thing that Honda would face it rather than have hundreds of thousands of failed automatics ruining Honda's reputation and superior resale value.
Few Accord owners actually experience AT problems considering the volume of Accords sold......Richard
miles on it. I just started having problems with the blinkers. It makes the blinker noise without the blinker being on. I did notice some smoke coming out of the handle where you turn the blinkers on so i took out the fuse, i looked at the fuse it looked ok and then i tried a replacement 7.5 fuse that was a extra one on the fuse compartment and it still made the noise.
any Ideas would be welcome. I would like to try and fix it myself if possible. thank you
My question is: Did the spare keys ever work?
Maybe the computer chip in the spare key was never set correctly.
One time we asked for two spare keys when we bought a Honda Accord, and they agreed. The salesman later mentioned that the keys would only work to open the doors, meaning that the computer chip would not be set so the keys could be used to start the car. Maybe the same thing happened to your dad.
Thanks,Ger
MODERATOR /ADMINISTRATOR
Review your vehicle
It's covered under Service Bulletin 00-065
SYMPTOM: With reverse gear already selected, the transmission bangs when the vehicle starts to move backward or when the vehicle is accelerated (torque is applied to the transmission).
PROBABLE CAUSE: The reverse selector is not fully engaged into the countershaft reverse gear.
If this is the issue, the transmission is replaced. The 2000 and 2001 Accord V6 models have an extended warranty of 7 years/100,000 miles on the transmission. The only thing I don't know is if the warranty is transferable... I assume that it is. If so, and the car is under 100,000 miles, you should be covered.
Ultimately I ended up just selling the car, with the buyer getting coverage from a dealer for something like $1,000.
Key things to have in mind: most if not all providers will accept coverage at a fair price if the car is still within the factory warranty / check the provider out completely / be clear about deductible, specific parts covered or not covered and other fine print requirements.
Best bet would be "Honda Care," Honda USA's own warranty coverage.
Extended Warranties
one problem.
The car for lack of a better descrip. 'boggs out' when I am (auto trans)@ 2000 rpm in 3rd gear, 40 mph. It will do this as long as I maintain this reading (+/-) slightly. When I increase on the gas the bogging noise will stop. Another way to describe it is when you are driving a manual trans. and you skip 2nd gear and shift into 3rd. The car will bogg until the rpm's catch up. It's very similar to that feeling and sound. I will also hear the tail pipe whine. I had a prepurchase performed and the mechanic said the exhaust was in good shape.
I've read some previous posts about this same noise. Has anyone come to a diagnosis?
DB
I'm gonna take it to a transmission place just to be sure.
Problem: On her first night drive, she is complaining that headlights of cars in her rear view mirror are smearing or streaking badly. Her rear view mirror is clean. And to the naked eye, her rear windshield is also clean. This is causing her great irritation. Anyone else having this problem?
Any suggestions?
