Visitor Agreement.
And the streaky window may need a thorough cleaning. Nightime driving brings out the worst in poorly cleaned glass.
the car has a bad/worn out turn signal switch at the handle.
DB
I tried pulling one at a time of all three with pliers but could not get them to come out, I kinda started cracking the plastic. Should they be that hard to get out? What is your thought ?
Thank You for the help !!
Your car's turn signal & hazard uses the same relay. Since the hazard works, I don't think it's the relay.
Go to hondaautomotiveparts.com to see the location of the relay. Look under fusebox-relay category.
A lot of people tempt fate by letting their
Hondas go well past the reccommended replacement intervals. Me, I wouldn't want to take the chance.
I can understand the water pump. I'm unfamiliar with the tensioner - I have a VW and they just replace the whole tensioner. Are the bearings on the Honda tensioner replaceable, or should I just R&R the whole tensioner. And finally, the front main seal. Is this known for failing? Is this worthwhile doing? Cost?
Looking back at the 1st invoice, only the part. The labor was included in the timing belt job.
Thank You for your time and advice. This is a great help!
Toyota's engines are definitely noninterference. My Camry broke the timing belt at 120K and the engine just quit firing. After $150 replacement job it worked fine.
The rubber timing belt could break any time. if it were interference, a lot of people would have complained!
Please elaborate.
http://www.gates.com/downloads/download_common.cfm?file=GatesTBR.- pdf&folder=brochure
And it looks like none of the Toyota engines are.
janl
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?i- - nputstate=5&catcgry1=Accord&catcgry2=1992&catcgry3=WG- - N+LX&catcgry4=KA4AT&catcgry5=CONTROL+UNIT
From the drawing, it looks like just a few bolts to remove it.
Well, the car was 10 years old at the time and I wasn't going to dump that kind of money into it. On a hunch, I took it to an independent transmission shop - $80 for parts and labor later, I was on the road again! All it needed was a small electornic module that was $40.
Maybe it would be worthwhile to get a second opinion. YMMV, of course.
I have an 04 Accord EX 4 cyl auto. I just received a letter from dealer indicating it was time to lube the front suspension, steering linkage and shift linkage. I don't find those items in maintenance schedule in owners manual. Aren't these areas sealed lubrication points as in many other vehicles ? If not how often do they need lubrication ? I don't feel I can rely on dealers opinion only.
I would have to stick to Toyota's non interference engine then.
Thanks for an excellent reference.
That is why I only take my car to the dealer for covered warranty work. I just keep receipts for oil changes. By the way, that is the only item that you need to prove you actually did in order to keep yourself covered for an engine related warranty claim. Take it from a mechanic who keeps cars for 12-15 years. I just follow the extreme maintenance schedual listed in the manual. Honda's is more than adequate to keep your car running fine for many years and at least 200,000 miles.
I sold mine on Ebay. It was located on the floor board under the glove box. Easy to remove. You have to match your numbers exactly for it to work. I'm not a mechanic, so get a 2nd and 3rd opinion on what I write here.... All I know is I sold it pretty quick. The numbers had to match for it to work in their car. There's a few sellers on Ebay motors that just sell older model parts for Honda's.I can't imagine how that repair shop can charge $950?? Unless there's something more to it.Next to Stockbrokers, Mechanics are the biggest scam going. I love it when they do stings on em. Big, Fat, Greasy, Greedy S.O.B.'s.
I do know that these are interferance engines. I have a colleauge who had the belt break, and now he doesn't drive htat car anymore....
Honda reccommends replacing timing belts at 90K or 105K depending on the year. It is VERY RARE for one to break before that time in fact a lot of people go a lot farther. One poster here has over 300,000 miles on a 99 Odyssey with the original belt!
If one happens to break, damage **can** occur.
Unacceptable problem with a Honda. Please bring it back to a Honda dealership to fix it ASAP. No charge because your car is still under warranty within 36K miles/ 3 years.
Enjoy your Honda. My friend gets an Accord EX V6 with NAV. and he likes it so much. I have owned so many Accords and going to buy an Accord Hybrid with NAV. soon.
I do enjoy my Accord very much except for this issue. I find it very irritating, as I live in the mountains south west of Denver and commute 35 miles each way to work. This is a pretty big issue for me because I work 6 am to 7 pm, so therefore am usually driving in the dark - I can't have people think I am flashing my brights at them all the time. I have found another forum where people have discussed this very issue, and it is beginning to sound to me as though this is NOT normal, but Honda does not want to admit it because it is very expensive to fix.
Honda is very good on saving fuel yet producing great horsepower and torque. I may find myself irritating too if my next Accord Hybrid gets same problem with its headlights. My son's Accord V6 EX 2003 does not have that issue.
Sorry, I keep spelling your name wrong. Your will enjoy your first 100K miles trouble free. My 95 Accord EX I4 that my wife is driving gets almost 200K miles with no problem except regular oil change and maintenance. Do the regular maintenance as suggested by Honda, change engine oil every 4-5K miles, change transmission oil, coolant, new spark plugs, etc. every year your Honda should be great as day one. I enjoy "pampering" my Honda line-up.
In a non-interference engine, the cylinder head valves don't clash (interfere) with the pistons when the timing belt breaks. Getting stranded is the worst consequence.
The opposite, OTOH, is true of interference engines like the Honda's. Not to belabor the point, but bent valves, cracked pistons, broken rocker arms and scoured camshafts are the catastrophic result of a timing belt breakage. $2,500 went for repairs when it happened to me.
This link explains the topic further: http://www.familycar.com/CarCare/TimingBelt.htm
I'm with the group of folks who'll push the carmaker's recommendations near the limit, knowing that a safety buffer exists beyond it.
The factory-recommended limit on an interference engine's timing belt replacement is one I won't exceed, however. The risk:expense equation just overwhelmingly favors prevention.
