Visitor Agreement.
brake released and RPMs go up and car starts to
move, vibration goes away. When A/C and Rear Defroster on and steering wheel angled and car in
Drive with foot on brake (such as traffic stops) vibration is extreme. >>>
My 89LXi does the same thing on a few occassions. I believe it happens when the weather is cold and the engine has not warmed up yet.
Sometime the vibration was so bad I had to put the car in neutral.
<<<When A/C and Rear Defroster on and steering wheel angled and car in
Also when you put the car in Reverse (backup lights are on) and foot on brake.
I am not a Honda expert. I think this is a problem with a 4-cyclinder engine. It cannot handle the loads (alternator, A/C compressor, P/S pump) put on.
When the steering wheel is in an angle, the P/S pump works harder.
You won't see this vibration problem with the V6 engine.
Just put the car into neutral if the (extreme) vibration bothers you so much.
I don't think you will have any problem driving your car to 350K miles with all the maintenance you did. My friend has a 90'LX A/T.
The car still runs great at 340K+ miles. He decided not to change the t-belt at 300K miles. If the belt breaks, it's the end of it.
I am finalizing my decision and recently, given the data available on a Toyota V6 issue with regards to acceleration hesitation (safety!), found myself flip flopping. While I was not all together pleased with the Camry SE/XLE interior, I've got a large family and appreciated the space the vehicle offered. My concern with the Accord was with regards to back seat space. Can three pre-teens fit back there comfortably? I've sat in the car but have not dragged my children in to do the same.
Also, are the rattling issues complained about with the Accord that annoying?
Has anyone had these rattles, specifically steering wheel column, and window seals (two front doors), and has anybody had a fix? The dealer replaced the horn assembly for the steering wheel rattle, which worked but only for one month. For the window seal rattles, they replaced the run channels but this worked only for one week. Lubing the window seals today didn't do a darn thing. I feel like I've got a ten year old car that I was tricked into buying new! I feel like a sucker!!!
Anyone--please help / advise! Thanks.
As far as the room goes. My 6'6 husband has sat in the back seat before next to my son (who is still in a car seat). It really depends on the height of your kids. Take them out and let them sit in both. With 3 kids you might want to consider a mini-van or a larger sedan such as the Altima/Maxima, Avalon, etc.
A "conscientious rattle-seeker" in one of the forums a while back found the solution. He discovered that the front window glass rattle was being caused by 2 metal parts of the window riser mechanism hitting. After he wrapped the parts with some adhesive material, the noise went away for good.
Anyone who tells you brake load is 50/50 needs to have their brain serviced. Does that make any sense to you at all? Unless they are talking about the average load over time for a car that happens to be driven as much in reverse as it is in forward, they are smoking something. Obviously there is increased load on the front brakes. Honda decreased the size of the rear brake pads on their vehicles after a certain model year to make up for the difference. I imagine because they either wanted people to have to replace the rear ones more often than...uhh...almost never or because they decided to cut costs with smaller pads on the rears. I seem to remember someone complaining that their newer Accord's rears wore out much faster than their old Accord's did and the response was that Honda had reduced the size of the rear pads. It may have even been back in this forum's earlier days.
As for putting your car into neutral when people cross in front of you, how about just keeping your foot firmly on the brakes like everyone else does? If your can be stopped in a few hundred feet while going 60 then there's no way that your car can overcome your brakes at a dead stop. Don't believe me, try it sometime...you won't go anywhere.
PS - I'm pretty certain the comment about shutting your car off was sarcasm man.
Exactly what is, or where is the "window riser mechanism", and where are these metal parts? Have you been able to have yours fixed as well? Has anyone else out there heard of this too? Thanks.
It's a tricky problem because the rattle is transmitted to, and not created at, the area of the noise. What transmits it is the window channel (hence, it being the first suspect) that runs around the whole window frame up to the area behind the front door speakers.
I'm probably mistaken in saying that it's the riser mechanism (motor and gear unit that regulates window opening); according to post 6704, it's the metal part of the window channel near the riser mechanism area that rubs against another metallic part.
The rubbing noise is carried by the window channel to the window glass. The fix is to put material between those 2 metal parts to eliminate the noise.
There was a post probably in another forum which included photos of the owner showing the repair, but I can't locate it.
The windshield noise is now gone and the following are the Tech Notes on the fix:
"Customer states, check for crackling/rattling noise from left front corner of the windshield...
Metal Hitting at Shock Tower.
Removed upper dash cover, instrument cluster assembly, Test Drove. Noise Still persisted. Pulled (A) pillar assembly, Left corner headliner, Test Drove. Noise still present. Reinstalled dash, cluster assembly and (A) pillar trim. Installed Chasis ear on inside of dash. No Noise present from inside of car. Installed Chasis Ear(s) on outside of vehicle, Heard noise at Shock Tower. Adjusted Body at shock tower, metal touching together, Test Drove with Service Manager.
No Other Noise present."
The problem has not resurfaced.
Hope that Helps.
FM radio always noisy in BAY AREA, California in any weather condition, especially 88.5.
I bout my car to dealership and they did drive test with me. They were agreeing about noises from radio and transmission but they told me it's by design. We drove another car and street noise was more then turbo noise.
Technician was willing to change transmission and radio to eliminate to make me happy but they did once for somebody and it was much worse.
I have to live with it.
Your car should NOT be making any transmission noises at 65-70 MPH. In fact, there should be almost no mechanical noise from the car at all when driving at a steady 70-80 MPH.
Radio reception in the San Francisco area is not very good in my opinion except for the XM radio which I'm glad is standard in my '04 EX-L sedan. XM radio is very clear--no static or other noises (and no commercials, either!)....Richard
what bugs me is the annoying wind noise driving down the highway from both front doors. i don't get it. i might need to slightly move the door stricker further in to pull the door in a bit more. that might help.
hope your problem goes away with that fix.
When I bought the car a month ago, there was no rattle. Within 1 week a rattle started in the left hand corner of the dash near the windshield when driving over rough roads. I took it in, dealer took the molding over the A-pillar off, put it back on and the noise went away. One week later the noise came back stronger. I took it back in, dealer heard noise. Took molding off, put it back on, and ordered a new molding (coming later this week). Noise still there though - so not sure what the problem is (didn't temporarily go away again).
I've tried stuffing cardboard, rubber, sponges anything between the dash and the windshield, the dash and the a-pillar, the a-pillar and the windshield...nothing has worked.
I've had the car a month and the frustration is setting in.
Anyone else run across this problem?
It's a new feature, that some electrical components are operable, a minute or so after the key is removed.
Hardly new - my 97 Accord has this feature. Sunroof works, too.
Shock tower adjustment did not work for my car. Your noise my mostly "go away" after a year or so (but you'll still be able to hear it).
Will continue to lurk here for a while until I know what the solution to this problem is.
Good luck.......
I bought a '05 Accord EX-V6 and noticed the noise. Extremely annoying. This problem is not acceptable. They over emphasize the quality build in the brochure but this is stupid. I would expect this from a little Suzuki not a Honda.
I'm with you...Honda needs to resolve these noise issues.
Wind noise is non-existent in my Accord--I've driven in some very windy areas and haven't noticed any wind noise nor handling problems....Richard
It looks like this TSB applies to your car.
My 03EXV6 is very quiet.
Is the fix real or is it BS? What do you think?
Thx
The TSB 03-085 applies to 03 models. You may need to tell your dealership your 05 has the exact same problem. Take the TSB with you when you go.
Who is your dealship? Mine is Honda Bernadi in Natick.
I've owned both Honda and Toyota products. For the past seveal years, I've noticed a decrease in the "quality" of these vehicles. Do you suppose it has something to do with the fact that these cars are now being assembled in the USA?
I never had any problems with my older Honda and Toyotas... 100% manufactured and assembled in Japan. I am very disappointed in the USA-made Honda/Toyota vehicles.
I'm experiencing several annoying problems with my new '05 Toyota Camry. Very similar to the wind/cabin/tire noise that you described. Fortunately, no rattles have developed as of 2,500 miles. However, there is a major flaw with the electronic throttle/transmission. (Much discussion about this in the Toyota forum.)
Good luck with your new Honda Accord. For those of you who almost bought a Camry, be advised.... it's not much better.
Thoughts and questions so far:
Could they have picked a more odd size? It's tough to find 205/60-16 of anything!
The Michelins are good enough, but don't seem to be an outstanding tire worthy of their price tag.
The most (seemingly) viable V-rated possibilities, the Pirelli P6 and Bridgestone Potenza RE92, were pretty universally panned. And I've seen a lot of people who had good things to say about the Yokohama Avid H4s and Bridgestone Turanza LS-H (or V?). Which makes me wonder...am I really giving up much if I go with an H-rated tire? The Accord tops out around 130mph, not that I ever expect to see those speeds.
Any other better tire ideas, or can someone dispute/backup what I've heard so far?
Thanx!!
While there has been much litigated and written about the (specific model and size) Firestone tire vs. Ford Explorer issue. I believe that you have overblown the question of whether Bridgestone/Firestone tires "have a bad record for safety". That old issue should have no bearing on ronsteve's decision about which brand of tire to consider for his Accord.
Here's one example of some worthwhile reading:
http://www.junkscience.com/oct00/blame.htm
On changing or not the original tire brand and specs, a quick research will show that 1) each carmaker has a dominant criterion for choosing a certain brand and type, and 2) a consumer may differ from the carmaker and still make a sound choice (some corroborative reference: http://www.aaa-calif.com/westways/0503/overdrive.asp).
My take on Honda for favoring the Michelin Energy MXV is that fuel economy is a primary objective - a factor that plays heavily into Honda's competitive pressures and consequent market positioning. Throw in corporate volume discounts and co-marketing benefits and voila - the "untouchable" Honda and Michelin association is born.
Basically a hard compound tire, the MXV series delivers good fuel economy and tire life but falls short on road noise suppression and lateral and longitudinal (brake) grip.
For value ($70-$80) and overall performance, the Bridgestone and Yokohama products rate high in Tirerack's consumer survey results. The Michelin MXV4 series, starting at $118, was rated lower than the aforementioned 2 brands - which makes many think that the Michelin is not enough bang for the buck.
I'd go for the Yokohama, Bridgestone or even Kumho as equal or better replacements.
PS Speed ratings are autobahn-based so moving down as far as the "R" rating, at 106 mph, will be acceptable for most of us (ref: http://www.tirerack.com/tires/tiretech/general/speed.jsp)
I crammed a bunch of felt between the window and the dash and the rattle has gone away.
thanks for your input.
now i am thinking abt camshaft seal + valve cover.
but its way expensive abt 150 + 150.
So let me re-frame the question here... Who here has gone with an H-rated replacement tire on their Accord (particularly V6 models), and what results have you had with what tires? Did you notice a difference (positive or negative, maybe more related to the tire than the rating)? And it might help to give some insight on your driving habits or styles, because that could make you either more or less likely to notice the change.
My preliminary thought is to go with the Yokohama, but if the V vs. H is likely to be a major issue, I might lean toward the Bridgestone Turanza LS-V.
Oh, and I know allll about Tire Rack, and will probably order through them.
For us wet roadholding is the #1 criterion, followed by treadwear, than dry handling. I have dedicated snows (Nokian RSi) so snow traction is not a concern in our case.
Reviews can be tricky because the behavior of a tire in one size and on one vehicle may be dramatically different in a different size and vehicle.
Btw vtec.net has a section on tires for Hondas, sponsored by Tirerack. I ask tire questions in the main Accord forum, though.
