A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Sheldon
The BST way to get a manual for a GREAT Deal is on Ebay.com just type in "Lexus Manuals" or somethign like that if they do not have it at that certain time just waite for a few days and one is bound to pop up i have seen LS Manuals from 1990 to 2000 !! and the price is NO where near $160 !!! ok well wish you best of luck!! Ohh and what is transmission shuttering ?? i wonder if i have Type IV fluid wonder how i can tell all i know is i think it is red humm ?
Happy LS400 owner,
Paul
All and all I love my Lexus.
One other dreadful thing happen, parked the car by itself as always, came outside looked at the Lexus,lo and behold someone hit the the lower quarter panel with their bumper and just drove off (boy what a day I was having). Smashed in the quarter panel about the size of a golf ball.
Do you guys recommend someone other than a collision shop to fix golf ball size dents.
Sorry for the long post just had to vent.
Good Luck and let us know.
The dealer has indicated that you can't change the bulb -- that you have to replace the entire $600 unit.
First, that sounds like mighty questionable manufacturing, to have to replace an entire radio to fix a $1.50 bulb. (unless, of course, you're the guy that can charge the $600!).
Any suggestions for how to get this fixed without that much outlay?
1995 LS400 Mark 3
Please add your car's data to the list. Does anyone's car NOT idle fast when cold?
I just need to know if i am operating on the BEST Transmission Fluid the Type IV for my 1994 LS400 if i had fluid put in/checked @ Lexus for the 90,000 service (This winter) would they have put in Type IV in it? I know that the fluid is red , OHH and what is Transmission Shuttering ??? what are the signs and what is the casue ?? Thanks
Happy Lexus Owner,
Paul
Thank you for the post about manuals at E-Bay, I guess that is a good start to purchase many different items.
Sheldon
Is it necessary to use a V-rated tire on these cars?
To replace the light just carefully lift up the plastic cover and remove and replace the bulb ...it just pushes in.
I doubt if you will be able to buy a 1994 LS400 for close to $6k on eBay unless salvage title or worse. Typically people wait to bid until the end and the price will be much higher...even for a car with 150kmi. Make sure you run VIN through CARFAX to check history. For a price estimate look at Edmunds or Kelly blue book on web. On eBay you should be able to get close to wholesale.
As for any costly vehicle you buy you should have a mechanic check out if possible and look for good maintenance records.
On a used LS400 with over 100kmi you will typically need to look at a minimum of the power steering pump, AC and the suspension. The LCD for the time/temp will probably be bled out and need to be replaced.
The keyless entry is built into the key...make sure this works since it is an expensive fix.
If maintained properly you should not worry about the engine or transmission on a used LS400.
These vehicles are very reliable even with 150kmi on them. But as with any used vehicle maintenance will be an issue.
Good Luck on your search for a nice LS400...this will be a car you keep and enjoy for a long time!
Even so, I'd be very careful of any complex old luxury car with this many miles on it. 150K means that most of it's useful life is over, and the part that's left is the expensive part (hey, kind of like people!)
VIN NO J T 8 U F 1 1 E 3 N 0 1 0 2 9 3 3
Sheldon
kwmg@bellsouth.net
I Have heard that Lexol works well On LS400 seats that have turned stiff Personally I have not used the product but I have heard it works well (i would have before i used a VERY harsh chemicial witch caused my leather to become discolerd and now I am in the process of getting it re-dyed)ohh yea can anyone help me , what am I looking to pay for the passenger and center console to be redyed, hope someone has got it done and tell me their results
Happy LS400 Owner,
Paul
1993 model and have some problems with the lights
on the dashboard, sometimes the lights comes back on,sometimes they are off. Does any body know how to solve this problem,is it just the wiring or is there somewhere a junction box that I don not know off. Also when I drive faster than 80 miles an hour I hear a bell,doe also anybody knows how to take this out. Many thanks. Anyhow despite the problems and the stupid fuel bills i really love my lexus and i just want to have everything working.
www.dccarcare.com
I bought some wheelskins from them.
They are very helpful.
I had a '91 LS400 - 110K - started and idled at 700-800. I had another '91 LS400 - 40K - same. I've got a '92 LS400 - 80K - same. Just bought a '97 LS400 - 70K - starts HARD and idles at 1300-1500 ... get whiplash backing out of the garage. But after reaches operating hemp ... idles at 700-800. Going back to dealer ... will post results.
As to transmission, I've gone to the local Toyota dealer, IV fluid is about $30 a gallon, and I just drain and refill every time I change the oil. I view it as cheap insurance. Sound like I need to do the same to the power steering. Anyone have any thoughts on coolant ?
I live in Atlanta and have 95 LS400. Where is your T3 shop located?
S. Cobb = 404-794-7700
Lawrenceville Hwy/Decatur = 404-633-7722
The computer controls the idle speed based on water [engine] temperature....the colder the faster the after start idle when the O2 sensors warm up enough [1-2 minutes] to give a reliable signal they enter the mix of control signals to derive the idle speed.....when coolant reaches 160-170F the idle returns to normal.
AC, power steering, and heavy electrical load [heater fan, window defroster, lights, seat heaters, etc] will cause an momentary or sustained increase in idle speed to make sure that the voltage is always above 13.6 to the fuel injectors. [so that a precise amount of fuel in released per squirt].
The required rpm is measured from the crank angle sensor and the IAC [idle air control] will adjust the amount of it's opening to give the required CORRECT idle speed.
Things can go wrong when the intake track gets dirty and the IAC opening is abnormal or runs out of range....cleaning to remove the EGR build up will return things to normal....eventually the O2 sensors get sluggish [take to long to switch] after 60-100k and the systems appears to hunt back and forth to find a happy idle.
Computers are only as smart as their inputs!
T3 Automotive LLC, SE largest independent servicer of Lexus and Infiniti.
This car is a '94 and to me the blower on max cool has never seemed to cool the car down fast during hot summer months. Just doesn't seem to put out a blast of air. We have a Solara and Tundra in the family and there is NO comparison to air output. Theirs makes mine look sick!
Was this common with the earlier models?
Thanks for any help; sorry to be so verbose here!
I made it fine to 100M then it's been p/s pump, water pump and now the a/c!
But I do love the car. Would buy another in a minute although I'm disappointed in the new 430 looks. Like the old style better.
For A/C you must do your homework in your area. Do not rush, take the time to visit some local A/C shops. Only deal with long time businesses. Pay close attention to the personality of the owner or manager who you will have to deal with if there is a problem after the job is done, if they are nasty or impatient while giving you an estimate move on!. Ask and, verify if possible, that the shop has done Lexus prior to yours. There are shops that specialize in Japanese or Lexus , Infiniti etc. There should be such a shop near you as well. This is a good choice as they are familiar wiht your particular auto.
No matter what route you choose, (Dealer or independent) it will cost you. The A/C on my Lexus was redone before I took possesion of the car. The other repair items you replaced are normal for your car, age miles etc. If the major components of your car are good (Engine Tranny) than the investement is worthwhile. I cannot imagine selling the car for a price with no A/C.
I have found in the past some profesionals who really new Auto A/C well and some times they were able to repair systems for me with out the major complete overhaul! saving $$.
Address your questions also to q45man, he is the real preeminent Lexus Infiniti expert here! and he is part of a independent shop.
Good luck Sheldon
We pay about $400 for each component but the labor especially evaporator is time consumming.
Multiply our cost by 30-40% for retail
Most bills don't exceed $1500.
The transmissions are unusually long lived...250k..if you get the normal very 30k partial fluid replacement.....we recommend a full fluid and chemical flush with runs about $150 to get all the friction material residue out.
Everything else checked out o.k. for now but I'm sure at some point will be looking at a major repair. Thanks for your help and Q-45 man too.
I also have vibration from the front wheels when I apply the brakes. I took of the front wheels to find nice new pads and very healthy rotors. I thought the rotors could be warped or pads worn, however everything looks fine. I think now I should high speed balance the front wheels, what do you think?
I have the clunking noise ! I also thought this noise was from the brakes, from loose pads so I checked the fitting kit and shims it all looks fine. The noise mainly occurs whenI first use the car and it sounds very loud and violent like something is cracking or breaking each time, I get the feeling you know what causes this noise could you please share a fix with me?
Thank you Sheldon
How can yo tell by looking if the rotors are within 0.003" of perfect true [lateral runout]?
When you apply the brakes is the key word here!!
BG makes a "QuickClean" which helps remove [puts in solution] the varnish and loose friction material. This is installed and the car run up to 2500 rom in each of 5 gears for about 4 minutes each [wheels turning on a lift], then the flush machine allows the internal pump to force out the old and suck in the new transmission fluid.....most machines use 14 quarts to make sure 120% of old is replaced.
The dealers standard is just to drain the 3 quarts from the pan and replace so you drive away with 70% old worn out fluid. This is better than nothing and assures that there will be only minor or no problems through 70-100k since the initial fill is a premium expensive ATF. We recommend an every 30k full flush from day one [$200] for those that want maximum life. But a chemical flush can do wonders [for a while] at any age.
The LS suspension upper A arm, ball joints, and tension rods should be checked for wear it will be one of these varies by year
The car runs perfectly all the time when I drive.
I had lexus check it out and they said it was fine. I have never had another car that did this.
Has anyone ever experienced this problem. I really love the car.
I cannot tell microns with the EYE. I was looking for a visible problem, like severly worn components and did not find any. I get your note of "When I apply" I guess I should turn the rotors.
Sheldon
