After a couple of weeks, I heard the horn alarm honking at 10 pm. Going outside(on the middle of a rain storm) I found the lights were blinking,horn honking, all windows down, and the sunroof open. Theory was a one time lightning related event.
A week or so later, I came out in the morning and found all the windows down and the sunroof open. Local lexus dealer checked it out and found no codes or problems.
A week later, In the morning, I found the same thing, is windows down,sunroof open. Took it to the dealer, he ordered aa replacement control module. As an interim he gave me a loaner car, a lexus rx300. Part needed to be shipped from japan, it's been a week.
Today, I go out, and find the windows down, and the sunroof open on the rx300!!
What can be going on? There is no way I could hold down the open button on the key for the ten seconds or so to open all the windows without knowing it. I suspect some kind of local radio transmission. What is the mechanism that the key uses to open all the doors and sunroof? Is there not some security unique to the key? Any other theories? HELP!!
In my previous car (not an Lexus), the alarm used to go off as well. Apparently, the cell phone and the alarm system share the same frequency.
If you do have a cell phone in the car, turn it off or take it out. Calling the cell phone will not help, as apparently, when the cells make the contact with the phone, this phenom occurred. Good Luck !!
Generally it is not a good idea [to prolong engine/tranny life] to crank and drive away on a cold car the fluids need time to reach [or at least get close to] their correct operating temperature.
The designers assummed owners would be familiar with this requirement and let the car idle 3-5-10 minutes [depending on temperature] before driving away when ambient was below 60F.
Not doing so decreases the life of components.
Is there a way to remove and inspect the buttons without having to take apart the door? I can't seem to figure out how to start taking the door apart. What tools would be helpful?
I have a 1991 LS 400 that im very happy with However, over the past few weeks my "low oil pressure" light has been coming on.
This indicator only seems to come on when I get on the freeway or travel at high speeds and will only stay on for about 6 to 15 seconds. The car runs perfect from what I can tell; and this "oil pressure light" concerns me. I've checked the oil levels and there fine, I've also replaced the "oil pressure sending unit". Nothing fixed the problem. Does anyone have any ideas as to what might cause this light to ignite? could this be a serious problem or something minimal? I spoke with a friend and he informed me "it's probably an electrical problem since replacing the "oil pressure sending unit", didn't correct the problem it in the first place."
Any ideas or suggestions would be appreciated. darrenlake@yahoo.com.
thanks in advance,
-Darren
When I back up the car, stop, go forward and then stop, there is often a clunk sound at the right front wheel. It isn't loud but is noticeable. Is this the brake pads reseating or something?
Also when I start driving there is some brake squealing the first couple of times I apply the brakes. It doesn't continue.
I just had the 30k service done at a Lexus dealer and they didn't say anything about either item and they test drove it. The 30k service includes a brake inspection. I forgot to say anything to them. Now I'm wondering if everything is OK.
Whatcha think?
I found a shop that really knew their stuff on the modern fuel injected cars. The problem turned out to be the Throttle Position Sensor located on the throttle body. The computer only checks the presence of the sensor not what it is doing. The sensor was putting out a weak signal to the computer. There are slotted screw adjustments on the sensor, but do not mess with it! Let the Pros adjust it! If you move it you can mess up the computer zero settings and wind up with a galloping idle. (Yup, I did it.) I would get on the web and find a local fuel injector specialist. Forget the dealer. Most dealers won't spend the money to hire good mechanics. In my experience.
Also, Summer fuel (smog additive) can cause idle problems. Good Luck..
Having a TPS off by even 0.1 volt will raise havoc especially at idle since the ecu is geting 2 conflicting signals.
Have you flushed yor PS system lately they clog [small internal screen] and fail causing leaks which take out alternator and PS pump.
thanks in advance...
Thanks to all those who have responded ... if nothing else, it is helping me understand things a little better.
Now you have the problem of resetting it exactly with a VOM.
The car sets the idle correctly for the coolant temperature assumming the intake track is clean [no build up of crud from PCV and EGR] which is usually the problem with high idle along with dirty injectors.
When I back up the car, stop, go forward and then stop, there is often a clunk sound at the front wheel. It isn't loud but is noticeable. Is this the brake pads reseating or something?
Whatcha think?
New Speedometer will be programmed to old mileage by factory on modern all electronic units -- requires dealer certification to avoid Federal tampering charges.
A real exert can take the new needles off a New Speedometer and replace without changing the unit but you must buy a new speedometer to get needles....saves an hour or two but I would want a whole new unit installed as there are otherthings to go wrong.
All older 90,91,92,93,94,95 [12-7 years old] will require maintenance and repairs. Japanese parts are expensive. If you buy a used car which was poorly maintained you will have to replace lots of things. AC systems, alternator, water pumps, belts, timing belts, services are just normal wear items around 100k or earlier.
Lexus has front tension rods and upper A arm bushings which wear and allow movements [noise under braking] these should be checked and replaced when worn.
Thanks.....
The owners manual say TYPE-T-II. The service dept guy I spoke with said he doesnt know about that.????
the guy at autozone said its ok to use DEXRON III.(they did not have TYPE-T-II like my manual indicates)
I read a post #385 and he says the dealer tells him to use IV-its ok.
Can someone please clarify this for me-I am conFUSED!!!
What is okay to use and what is not?
My car has 98k and it is 30k over tranny oil change.
any details I should follow when doing this?
Setting the warm idle voltage correctly is the key to normal operation.
If you still have idle speed problems then you look elsewhere for the solution.
Qualifications: BSEE, MSEE.
Ever wonder why you see so many AC, transmission, and radiator shops, all these people make a good living out of ignorance.
Preventative maintenance is always less expensive than replacing a component and worse, replacement components may not be of the same quality or capacity as those used in the building of the vehicle since the average replacement warranty is only 12mo/12k.
When you drive a car as well designed as a LS [or a Q45, MB etc.] you just can't do nothing and let the components fail from YOUR neglect.
We have many customers [salesmen] who have over 250,000 miles on older LS but they understand the needs of such a car.
Worse are aftermarket partial rebuilds or remmaned which may be horrible.....especially AC compressors, evaporators, condensers, alternators, PS pumps, and transmissions.
If a dealer part lists for $600 and and after market part costs half to a third you are getting what you pay for, since the dealer markup is at worst 40%.....if you chose wisely you can get almost the new component life vs a year.
Most independents must buy from dealer not at cost but a 15-20% markup so they can only make 20% on parts thus they push aftermarket where they can SAY they are saving you money [in the short run] but in reality they are just trying to make the same 40-50% margin on parts sales.
Think long term!
With regard to my 1994 LS (I bought used back in April, 77K miles), I turned the TPS back to its original position. Everything is as it was before I turned it CCW to the screw stops. FYI, I am an electronics engineer, and manager of an industrial electronics repair department. So, I am not afraid to do something as long as I know I can get back to where I started. In this case, so far so good. I have volt meter. Where can I connect it to test the TPS voltage levels q45man suggested? Also, is there a nominal resistance range I can check for on the temperature sensor when the engine is cold? If so, what is it, and where can I take these measurements? I don't have the service manuals, so any information you can provide (sensor locations, measurements and test points) would be appreciated. While I'm on the subject, any thoughts on where we can get service manuals other than from a Lexus dealer. I asked, and they quoted me a price of $245. I said thanks, but no thanks (at least for now).
2.Insert a thickness gauge (0.040mm/.0157)between the throttle stop screw and lever, and connect an ohmmeter between terminals IDL and E2 (E2 is the top pin IDL is the one under it).
3. Gradually turn the TPS clockwise until an ohmmeter resistance is gone, then secure the sensor with two screws. page FI-53
Pretty complicated stuff.
The temp sensor should have a ohm reading of 10 to 15k omhs at 32F and 3 to 4K at 68F. Code for temp sensor is 22.
To check for codes (which I would do first)the basic check follows.
1. Turn ignition on.
2. Connect a jumper to terminals TE1 and E1 of the TDCL connector (there is one under the dash and one under the hood,the one under the dash is round and on the left side below the gas and trunk releases. On the bottom row of terminals the TE1 is the one on the far right and E1 is the third one over from the far right side on the bottom row.
3.Read the diag code from the check engine light.
Write down the flashes there might be more than one code, codes on first gens they are two digit, so flash flash, flash flash = 22 Good Luck
