Visitor Agreement.
Is there a trick or a special tool available for pulling the filter without getting oil all over the place?
Anybody have any thoughts on running synthetic oil in the Avalon? Which weight?
Thanks for any tips or thoughts.
so a tool will fit it, like an oversize socket.
Buy your new Toyota filter, take it by the local
auto parts dealer and match it up with the "socket"
that fits the oil filter. You can then loosen the
filter with either a wrench or ratchet, whichever
you prefer. Having changed oil several times, I've
yet to figure out a way to keep the old oil off of
the exhaust system as it drains from the filter.
Using rags and/or paper towels, you just sop up as
much of the oil as possible and go from there.
You can run synthetic oil but until the warranty
on the car has expired, you may be required to
change as often as if you were running "normal" oil
(to keep from voiding the warranty).
It is perhaps my first "annoyance flaw" that I have found for the ava. My corolla had enough clearance to let the filter and drips drop straight into the disposal box.
I am currently using 5w-30w Castrol syn blend, but plan to change to Mobilone 5w-30w pure syn after the next oil change. I have 6000+ miles and the next change will be my third one.
I've read through the manual and I can't find the specification for the size of the hex wrench required to remove the oil drain plug on a 2000 XLS. Anybody know the size or if it is a special tool sold by Toyota?
Thanks again.
I've also had a rattle in the front and there is a small struct, almost like an idler arm (as I am told) that was worn. Replaced it and the noise went away, but my mechanic said that the bushing on the top of the strut was also worn and needed replacing. He used to be the dealerships service manager and said when he called for the parts they were backordered. A waiting of 25 was ahead of me, seems they fail often.
Some parts will fail due to wear and we need to expect this. However, there are some parts that seem to fail on a regular basis. I don't really believe that the company will ever provide relief for these parts, but I will need to purchase a car in the future and these issues are a factor to consider in making a decision. The problem being who is still producing a good car, with good dealer support.
Does anyone know if toyota makes an alternate transmission for this vehicle or a microchip which would cause it to shift more fluidly. The mpg sticker on the car was impressive when I bought it, but I'm afraid Toyota exacted their mileage performance at the expense of on-demand smooth power by installing a transmission that gets you into the higher gears much sooner than necessary with a 210 hp engine, as good as it is, that is simply inadequate to handle the gear ratio. Don't get me wrong, I can get the performance out of the car if I put a brick on the accellerator. Who wants to go through life like that?
I had strongly considered trading it for a 300ES, which I believe still has a choice of power settings, but hate to give up the big cabin of the xls. Any suggestions? db
On my 2000 XL, the motor oil drain plug comes off with an ordinary metric socket wrench, either 14 or 15 mm size.
However you are right in that the owner manual does not state which size, nor the location of the plug-was Toyota thinking the "average-age 55 or so etc" Ava owner would not be changing his/her own oil?
Anyway it looks like the transmission oil drain plug needs a hex wrench- a rather large one- I'd guess at least 3/8 to 1/2.
Sorry to tell you that the 98 did not have depowered airbags.
My 98 had the creaking noise in the struts. Was fixed under warranty but still creaked for another week , then quit. Good news
The Avalon is no BMW. On paper, 200-210 hp sounds good and it is, for effortless cruising at higher speeds. (Whispering--I ran my 98 up to
122 mph in the desert in third gear). Unfortunately the engine torque curve means you really have to spool this engine up to get better acceleration, and as stated by an earlier contributor, each shift throws the Avalon way behind its torque curve. Any good running Dodge pick-up can shut you down at a stop light or a toll booth. The tranny always performed well in everyday driving and after all , this is Toyota's answer to a Buick.
When my lease was up I decided not to get another because I wanted more zip (5 speed auto), side curtain air bags, and a black leather interior. None of which the Avalon can provide.
Folks, this was a good people hauler that was topss in quality and reliability. Just understand it's intended market target.
I spoke to several people who were interested in the car and told them my experiences with mine. Most seemed very happy with the car and would most likely buy one.
Love mine....hope they get a good one too.
Brian M.
Also, try "beverly hills motoring accessories."
Keep in mind-I was told they are vehicle specific. They are NOT! It is a generic pattern that will closely fit your Avalon. They work great. . .I was just expecting a "Tailor" fit.
I am in the Gulf States area so mine came with all the "fluff" including the Toyoguard. I see no real benefit to it except for the product that came with the car from Toyota....by far one of the better waxes that I have used.
Enjoy.....its a great car.
Even put it on my Hondas. My '99 Av just turned 52,000 miles...no repairs so far. Get 29 mpg on the road. Has the right front strut thump-a-thump sound on a washboard road - but who cares. What a car! Will be looking at the '02 models when the time comes. Av's are pricey, but, quality is never cheap. Enjoy.
You can also get the touch-up paint as well. Years ago, every new toyota came with a can of touch-up paint, however with the advent of clear-coat, etc...that is pretyy impossible now.
Well, I am not looking forward to periodically having the rotors turned to eliminate glazing, and I am very skeptical about the explanation provided by the service manager. To my knowledge, this issue has not come up previously at this web site (though I must admit, I haven't done an exhaustive search). Could the ABS brake system be a factor? I would appreciate any feedback on this issue.
#1 of 2 Avalon #67 (Kymemmie/Marg) by ovlee Feb 09, 2001 (07:16 pm)
Hi Marg: Your question about vinyl mats: I have for years made my own, from clear vinyl carpet protector material, available at Wal-Mart and such. I take the mats out and mark the size with Marks-alot and then cut 'em out with (tough) scissors. It's a little trouble, but I enjoy doing it, and it certainly saves the original mats. I "bolt" them together with nuts/bolts/washers (about 1/2 inch is right). The driver's side mat has the handy "hook" attached to the frame(?) which obviates the left fastening on that mat. Being clear, they, to me, are nicer than anything you can buy....Oliver Lee
tiles in your bathroom.
This is one of those ..."Hey Joe, here comes
another one... lets get him...."
Since rotors grind against break shoes, often, in
high temps, it is normal that they are smooth and
shiny. Acutally and opposite, it is a real problem when they have circular ridges going thru them. Then you need them turned and shoes replaced.
If you still feel uneasy, take the car home, pull
the wheels off and used some fine sand paper and
rub the rotos with it. Shine (glaze) will dissapear. Needless to say, that after two-three
drives, the glaze will re-appear.
Did he give you the special $149 price ?
By the way, the Toyota dealer didn't charge for turning the rotors (based on the warranty). So, I'm not sure why all this happened. My wife thinks that because she brought the car in for the servicing, she as a woman wouldn't be expected to ask questions. Could it have been a ploy to show her they were on top of potential problems with the car and thus reinforce her willingness to keep bringing the car in for servicing? That doen't make a lot of sense to me. Could it be a setup to charge for turning the rotors in the future? That seems crazy too. Oh well, it's not worth wasting any more time on this. I will find another place to service the car. Thanks again.
Brace yourself, 'cause I think the Tundra and Avalon share the same rack.
Additionally, the rebuild dealer gives lifetime warranty on all racks except this one (one year -a clue?).
Another item to look for are the bearings at the top of your front struts. They have a tendancy to fail, noisy when they do and this may solve some of the noise problems in the front end.
Just remember it's a machine and they wear out, a friend of mine restores and shows older cars and as he says "the worst cars built today are better than the best cars built back then"
About a month ago, I started experiencing a scraping sound from the front tire wheel well after I had gone through a dip at speed or rolled through a dip entering a highway. This sound didn't happen when I went over rough roads or hit a pot hole. I did have a significant rattle in the dash though.
I took the car into the Plano Toyota service department (Plano is a suburb of Dallas, TX) and talked with James Wood. I mention this because I had read some horror stories in these forums relating to Toyota dealers and warranty work. They had the car back that afternoon after replacing the front struts and pulling the dash off. No arguments, no "I don't hear anything" or, "That's the nature of that model." They just fixed it. The lack of argument on the struts leads me to believe that Toyota is aware that the front struts are not up to snuff, because James said something to the effect that they had added heavier duty struts than the originals.
They fixed the rattle in the dash, but not the scraping sound. It wasn't quite as bad, but still there, sounding the worst on the drivers side. Looks like the struts weren't the culprits in this case.
I didn't have time to take the car back for a few weeks. The dash rattle came back and I finally had some time to run it by and give them another crack at it. James went for a ride with me. We picked up on the dash rattle right away, but the scraping sound was much harder to reproduce. We finally found a spot right turning into a parking lot (small dip) that finally showed the problem.
James gave me a brand new loaner (9 miles on the odo) and took the car in. It took three days, but they finally took care of the problems. They even had me come back and take a drive with the quality manager to make sure I was satisfied.
They had taken apart the dash completely and tightened every bolt in there. They also made sure all of the wire harnesses were secure (a couple had not been when they opened it up.) As for the scrape, there seemed to be a plastic liner piece that had loosened up in the wheel well that would scrape the tire under certain conditions. They tightened it up and it seems like the sound is gone. I tested it at a known problem site by my house and it worked just fine, no noise. To top it off, they washed and waxed it:-)
I found James and the whole service department to be pleasant, courteous, informative and honest. They seemed to really care that I was happy with the service. James called me on a fairly regular basis to keep me up to date on progress. He even called me to let me know they hadn't found the problem yet, but were working on it. That's great service and I have to say that they did an outstanding job. Everything you buy has the potential for problems. It's how a company treats you when that problem pops up, that counts.
Thus ends my report. I love the Avalon after a year of ownership. The car has performed as I have expected and the service has been outstanding when needed. The above mentioned problems are the only ones I have had in the first 21,000 miles. I hope they will be the last, but I'm old enought to know better. It's a good feeling to know there is a good dealership backing me up.
However I've had a few issues and wonder if anyone has had same:
1) While driving very slowly (5-10 mph) in heavy highway traffic, engine coughed and stammered. This continued for about 10 seconds. I had to shift to neutral and race the pedal to prevent stalling.
2) Driver's seat belt folds and jams. Have to manually unfold the belt (a struggle) before use.
3) Radio went on when I turned on the heat (at first I figured I bumped the radio button). However, radio then powered on and off intermittently (wouldn't stay on or off). I suddenly heard very loud Pop sound and radio died entirely. I checked the fuse (#9 located under the hood) and it's fine. Also, other items on the circuit (dome light) are working fine.
Where is the oil filter ?
to the dealership (where I purchased the car)
to have it changed ($25). Since they did not meet
29' minute gurantee,next one is free. Given it some more thoughts, I think I will stick with dealeship as long as the car is under warranty.
Has anyone ever heard of this? Could the lock be loose or something, or could it have been a random radio frequency that triggered the trunk release?
Comments appreciated.
Otherwise, I am loving this elegant car!
I'm thinking my next car will not be Toyota any more after four Toyota.
Is this a good deal?
Has this paid off for anyone?
I have 30 days to get my money back if I decide I don't want it.
I'm worried that the fine print has a lot of subjective language that could allow Toyota to back out of covering.
The insurance was not thru GM but some independent place (bought it at the time of purchasing the car at the dealership). When the car broke few times (after 3 year warranty) I took it to my mechanic,paid him and then got money back from insurance within a month or so,no hassle. I liked it since I've known my mechanic for over 7 years and I wished I could have taken my car under 3 year warranty to him. Those bozos at dealership are most of the times clueless.
Last Dec. I bough 2001 XL avalon. I did not buy extended as I don't expect this car to break often. If I feel that the car is not as reliable as it supposed to be, I will buy insurance from the same place next year or so.
In summary there are few things to consider. If I was you and had no clue who drove the car before and how it was taken care off, I would buy the insrance but would not necessarily go to a dealer to have it serviced if this was am option.
You can by a new Lexus ES300 for just over 30K., and a 3 year old LS400 for about the same. Both vehicles have the highest quality, lowest defect rates and best reliability records in their classes and are top notch. You can get the service records for ANY Lexus at ANY dealership, since they have a nationwide computer system.
There's a good reason that GM is losing market share in every class they sell in. You may have been lucky with your Bonnevilles, but statistics aren't on your side.
Reliability and performance for all of these models is proven--and build quality is second to none. (The Toyota plant in Kentucky where they build Avalons is an Industry benchmark, incidentally).
No doubt you will see negative comments about Toyota products--there are bound to be some who are harder to please than most. The bottom line is that Toyota's record speaks for itself for the most part--polls and consumer feedback confirm this.
For what it's worth, we have an ES300 and an Avalon XLS. Both are great--not one problem after 50000 combined miles, and none expected.
What you buy is your decision, but you can be assured that odds are you'll have less problem with a Toyota product than most others, IMHO.
Good luck, regardless.
